[GRASS-SVN] r54084 - in grass/trunk/lib/vector: . dglib neta vedit
svn_grass at osgeo.org
Wed Nov 28 00:28:26 PST 2012
Author: martinl
Date: 2012-11-28 00:28:26 -0800 (Wed, 28 Nov 2012)
New Revision: 54084
Added:
grass/trunk/lib/vector/vectorlib_pg.dox
grass/trunk/lib/vector/dglib/dglib.dox
grass/trunk/lib/vector/neta/netalib.dox
grass/trunk/lib/vector/vectorlib.dox
grass/trunk/lib/vector/vectorlib_ascii.dox
grass/trunk/lib/vector/vectorlib_files.dox
grass/trunk/lib/vector/vectorlib_indices.dox
grass/trunk/lib/vector/vectorlib_libraries.dox
grass/trunk/lib/vector/vectorlib_ogr.dox
grass/trunk/lib/vector/vectorlib_tin.dox
grass/trunk/lib/vector/vectorlib_topology.dox
grass/trunk/lib/vector/vedit/veditlib.dox
vlib/dox: add subpage for GRASS-PostGIS data provider
clean up
Modified: grass/trunk/lib/vector/dglib/dglib.dox
--- grass/trunk/lib/vector/dglib/dglib.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/dglib/dglib.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -1,8 +1,8 @@
/*! \page dglib Directed Graph Library
-by GRASS Development Team
+by GRASS Development Team (http://grass.osgeo.org)
-http://grass.osgeo.org/dglib/
+\tableofcontents
\section vlibDglibShortIntro Short introduction
Modified: grass/trunk/lib/vector/neta/netalib.dox
--- grass/trunk/lib/vector/neta/netalib.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/neta/netalib.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -2,6 +2,8 @@
+\tableofcontents
This library is used for network-based analysis, see <tt>v.net.*</tt>
modules for implementation issues.
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/vectorlib.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -4,29 +4,19 @@
\tableofcontents
-\par Table of contents
-- \ref vlibBackground
-- \ref vlibIntro
-- \ref vlibVectorMap
-- \ref vlibVectorLevels
-- \ref vlibCategoriesLayers
-- \ref vlibAttributes
-- \ref vlibGeometry
- - \ref vlibFeatureTypes
-- \ref vlibStructures
-- \ref vlibFunc
-- \ref vlibAuthors
-- \ref vlibReferences
-- \ref vlibSeealso
-\par Subpages
+\par Related
- \subpage vlibDescription
- \subpage vlibFormat
- \subpage vlibTopology
- \subpage vlibIndices
- \subpage vlibAscii
-- \subpage vlibOgr
- \subpage vlibTin
+\par Data providers for external formats
+- \subpage vlibOgr
+- \subpage vlibPg
+\par Related libraries
- \subpage veditlib
- \subpage dglib
- \subpage netalib
Modified: grass/trunk/lib/vector/vectorlib_ascii.dox
--- grass/trunk/lib/vector/vectorlib_ascii.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/vectorlib_ascii.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -2,6 +2,8 @@
+\tableofcontents
\section vlibAsciiMain Vector ASCII Format Specifications
The GRASS ASCII vector map format may contain a mix of primitives
Property changes on: grass/trunk/lib/vector/vectorlib_ascii.dox
___________________________________________________________________
Added: svn:mime-type
+ text/plain
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
Modified: grass/trunk/lib/vector/vectorlib_files.dox
--- grass/trunk/lib/vector/vectorlib_files.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/vectorlib_files.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -4,14 +4,6 @@
\tableofcontents
-- \ref vlibDirectoryStructure
-- \ref vlibDblnFileFormat
-- \ref vlibCoorFileFormat
- - \ref vlibCoorFileHead
- - \ref vlibCoorFileBody
\section vlibDirectoryStructure Directory structure
Vector map is stored in a number of data files. Vector map directory
Property changes on: grass/trunk/lib/vector/vectorlib_files.dox
+ text/plain
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass/trunk/lib/vector/vectorlib_indices.dox
--- grass/trunk/lib/vector/vectorlib_indices.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/vectorlib_indices.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -4,15 +4,6 @@
\tableofcontents
-- \ref vlibSpidx
- - \ref vlibSidxFileFormat
-- \ref vlibCidx
- - \ref vlibCidxFileFormat
- - \ref vlibCidxFileHead
\section vlibSpidx Vector library spatial index management
Spatial index (based on R*-tree) is created with topology, see \ref
Property changes on: grass/trunk/lib/vector/vectorlib_indices.dox
+ text/plain
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass/trunk/lib/vector/vectorlib_libraries.dox
--- grass/trunk/lib/vector/vectorlib_libraries.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/vectorlib_libraries.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -4,11 +4,6 @@
\tableofcontents
-- \ref vlibsAboutIntro
-- \ref vlibsHistory
\section vlibsAboutIntro Introduction
Besides internal library functions there are two main libraries:
Property changes on: grass/trunk/lib/vector/vectorlib_libraries.dox
+ text/plain
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass/trunk/lib/vector/vectorlib_ogr.dox
--- grass/trunk/lib/vector/vectorlib_ogr.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/vectorlib_ogr.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -1,18 +1,11 @@
-/*! \page vlibOgr OGR interface
+/*! \page vlibOgr GRASS-OGR data provider
+\tableofcontents
-- \ref vlibOgrIface
- - \ref vlibFrmtFileFormat
- - \ref vlibFidxFileFormat
+\section vLibPseudoTopo Pseudo-topology
-\section vlibOgrIface OGR interface
-\subsection vLibPseudoTopo Pseudo-topology
Reduced topology: each boundary is attached to one area only,
i.e. smoothing, simplification, removing small areas etc. will not
work properly for adjacent areas or areas within areas.
@@ -21,7 +14,7 @@
be built after all polygons are converted to areas and cleaned as done
by <tt>v.in.ogr</tt>.
-\subsection vlibFrmtFileFormat Frmt file format specification
+\section vlibFrmtFileFormat Frmt file format specification
Frmt is a plain text file which contains basic information about
external format of linked vector map. Each line contains key, value
@@ -46,7 +39,7 @@
file ('sidx') and category index file ('cidx'). Additionally also
feature index file (see \ref vlibFidxFileFormat) is created.
-\subsection vlibFidxFileFormat Fidx file format specification
+\section vlibFidxFileFormat Fidx file format specification
Note: <tt>finfo</tt> is an instance of \ref Format_info structure.
Property changes on: grass/trunk/lib/vector/vectorlib_ogr.dox
+ text/plain
Added: svn:keywords
+ Author Date Id
+ native
Added: grass/trunk/lib/vector/vectorlib_pg.dox
--- grass/trunk/lib/vector/vectorlib_pg.dox (rev 0)
+++ grass/trunk/lib/vector/vectorlib_pg.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -0,0 +1,101 @@
+/*! \page vlibPg GRASS-PostGIS data provider
+\tableofcontents
+\section vlibPgInro Introduction
+<b>GRASS-PostGIS data provider</b> allows GRASS vector library to read and
+write PostGIS data directly without any external library (like in the
+case of \ref vlibOgr). GRASS-PostGIS data provider is implemented
+using <a
+href="http://www.postgresql.org/docs/9.2/static/libpq.html">libpq
+library</a>.
+Note that GRASS-PostGIS data provider is compiled only when GRASS is
+configured with <tt>--with-postgres</tt> switch.
+See the <a
+href="http://trac.osgeo.org/grass/wiki/Grass7/VectorLib/PostGISInterface">trac
+page</a> for more info.
+\section vlibFn List of functions
+Note that the functions listed bellow are lower level subroutines, in
+other word these functions are not consider for usage. They are
+internally used by the vector library when accessing PostGIS data. The
+programmer should use higher level functions instead.
+- Vect_open_old() to open exising vector map (ie. PostGIS table when using GRASS-PostGIS data provider)
+- Vect_open_new() to create new vector map
+- Vect_close() to close vector map
+- Vect_rewind() to rewind the map for sequential access
+- Vect_read_next_line() for sequential access
+- Vect_read_line() for random access
+- Vect_write_line() to write a new feature
+- Vect_delete_line() to delete existing feature
+- Vect_rewrite_line() to modify exising feature
+- Vect_build() to build (pseudo-)topology
+Note that functions with <tt>V1_</tt> prefix access vector data
+without topology. Topological (pseudo-topological for simple features)
+access is provided by functions starting with <tt>V2_</tt> prefix.
+\par Open/Create PostGIS table as GRASS vector map
+- V1_open_old_pg()
+- V2_open_old_pg()
+- V1_open_new_pg()
+- V2_open_new_pg()
+- V1_close_pg()
+- V2_close_pg()
+\par Read feature from PostGIS table
+- V1_rewind_pg()
+- V2_rewind_pg()
+- V1_read_next_line_pg()
+- V2_read_next_line_pg()
+- V1_read_line_pg()
+- V2_read_line_sfa()
+- V2_read_line_pg()
+\par Write new feature to PostGIS table
+- V1_write_line_pg()
+- V2_write_line_sfa()
+- V2_write_line_pg()
+\par Delete exising feature from PostGIS table
+- V1_delete_line_pg()
+- V2_delete_line_sfa()
+\par Modify existing feature from PostGIS table
+- V1_rewrite_line_pg()
+- V2_rewrite_line_sfa()
+\par Build topology
+- Vect_open_topo_pg()
+- Vect__build_sfa()
+- Vect_build_pg()
+\section vlibPgSeeAlso See Also
+ - \ref vlibOgr
+\section vlibPgAuthors Authors
+Martin Landa <landa.martin gmail.com>
Property changes on: grass/trunk/lib/vector/vectorlib_pg.dox
+ text/plain
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass/trunk/lib/vector/vectorlib_tin.dox
--- grass/trunk/lib/vector/vectorlib_tin.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/vectorlib_tin.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -2,6 +2,8 @@
+\tableofcontents
<em>This page needs to be enhanced.</em>
\section vlibTinIntro Short introduction
Property changes on: grass/trunk/lib/vector/vectorlib_tin.dox
+ text/plain
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass/trunk/lib/vector/vectorlib_topology.dox
--- grass/trunk/lib/vector/vectorlib_topology.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/vectorlib_topology.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -2,18 +2,8 @@
+\tableofcontents
-- \ref vlibTopoManagement
- - \ref vlibTopoFileFormat
- - \ref vlibTopoFileHead
- - \ref vlibTopoFileBody
- - \ref vlibTopoLevels
- - \ref vlibTopoExamples
- - \ref vlibTopoMemory
\section vlibTopoManagement Vector library topology management
Topology general characteristics:
Property changes on: grass/trunk/lib/vector/vectorlib_topology.dox
+ text/plain
Added: svn:keywords
+ Author Date Id
+ native
Modified: grass/trunk/lib/vector/vedit/veditlib.dox
--- grass/trunk/lib/vector/vedit/veditlib.dox 2012-11-28 08:06:23 UTC (rev 54083)
+++ grass/trunk/lib/vector/vedit/veditlib.dox 2012-11-28 08:28:26 UTC (rev 54084)
@@ -2,6 +2,8 @@
+\tableofcontents
\section veditIntro Introduction to Vedit Library
This library contains higher level functions for editing %vector
@@ -44,9 +46,6 @@
\subsection veditSelect Select features
- Vedit_select_by_query()
\subsection veditSnap Snapping
