[GRASS-SVN] r54107 - in grass/trunk/lib/vector: diglib rtree
svn_grass at osgeo.org
Fri Nov 30 02:34:13 PST 2012
Author: mmetz
Date: 2012-11-30 02:34:12 -0800 (Fri, 30 Nov 2012)
New Revision: 54107
grass/trunk/lib/vector/diglib/spindex_rw.c
grass/trunk/lib/vector/rtree/index.c
grass/trunk/lib/vector/rtree/index.h
grass/trunk/lib/vector/rtree/indexf.c
grass/trunk/lib/vector/rtree/indexm.c
grass/trunk/lib/vector/rtree/io.c
grass/trunk/lib/vector/rtree/node.c
grass/trunk/lib/vector/rtree/rtree.h
huhabla: rtree dynamic memory allocation
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c 2012-11-30 10:07:39 UTC (rev 54106)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c 2012-11-30 10:34:12 UTC (rev 54107)
@@ -615,12 +615,10 @@
int rtree_dump_node_file(FILE * fp, off_t pos, int with_z, struct RTree *t)
int i;
- static struct RTree_Node n;
- static int node_init = 0;
+ static struct RTree_Node *n = NULL;
- if (!node_init) {
- for (i = 0; i < MAXCARD; i++)
- n.branch[i].rect.boundary = RTreeAllocBoundary(t);
+ if (!n) {
+ n = RTreeAllocNode(t, 1);
/* recursive nearly-but-a-bit-messy depth-first pre-order traversal
@@ -628,21 +626,21 @@
/* TODO: change to non-recursive depth-first post-order traversal */
/* left for comparison with GRASS6.x */
- RTreeReadNode(&n, pos, t);
- fprintf(fp, "Node level=%d count=%d\n", n.level, n.count);
+ RTreeReadNode(n, pos, t);
+ fprintf(fp, "Node level=%d count=%d\n", n->level, n->count);
- if (n.level > 0)
+ if (n->level > 0)
for (i = 0; i < NODECARD; i++) {
- if (n.branch[i].child.pos >= 0) {
+ if (n->branch[i].child.pos >= 0) {
fprintf(fp, " Branch %d", i);
- rtree_dump_branch_file(fp, &n.branch[i], with_z, n.level, t);
+ rtree_dump_branch_file(fp, &(n->branch[i]), with_z, n->level, t);
else
for (i = 0; i < LEAFCARD; i++) {
- if (n.branch[i].child.id) {
+ if (n->branch[i].child.id) {
@@ -691,7 +689,7 @@
int sidx_nodesize, sidx_leafsize;
struct RTree_Node *n;
int i, j, writeout, maxcard;
- struct spidxpstack s[MAXLEVEL];
+ struct spidxpstack *s = G_malloc(MAXLEVEL * sizeof(struct spidxstack));
int top = 0;
/* should be foolproof */
@@ -768,6 +766,8 @@
+ G_free(s);
return nextfreepos;
@@ -793,21 +793,19 @@
- static struct spidxstack s[MAXLEVEL];
- static int stack_init = 0;
+ static struct spidxstack *s = NULL;
int top = 0;
- if (!stack_init) {
+ if (!s) {
+ s = G_malloc(MAXLEVEL * sizeof(struct spidxstack));
for (i = 0; i < MAXLEVEL; i++) {
+ s[i].sn.branch = G_malloc(MAXCARD * sizeof(struct RTree_Branch));
for (j = 0; j < MAXCARD; j++) {
s[i].sn.branch[j].rect.boundary = G_malloc(6 * sizeof(RectReal));
- stack_init = 1;
/* write pending changes to file */
RTreeFlushBuffer(t);
@@ -915,17 +913,17 @@
struct RTree_Node *newnode = NULL;
int i, j, loadnode, maxcard;
struct spidxstack *last;
int top = 0;
+ if (!s) {
- stack_init = 1;
/* stack size of t->rootlevel + 1 would be enough because of
@@ -1041,17 +1039,17 @@
off_t newnode_pos = -1;
int top = 0;
+ if (!s) {
- stack_init = 1;
@@ -1343,10 +1341,12 @@
int which, i = 0;
/* check mru first */
+ /* t->used[level][i] */
while (t->nb[level][t->used[level][i]].pos != nodepos &&
- t->nb[level][t->used[level][i]].pos >= 0 &&
- i < NODE_BUFFER_SIZE - 1)
+ t->nb[level][t->used[level][i]].pos >= 0 &&
+ i < NODE_BUFFER_SIZE - 1) {
i++;
which = t->used[level][i];
@@ -1355,6 +1355,8 @@
t->nb[level][which].pos = nodepos;
assert(t->nb[level][which].n.level == level);
/* make it mru */
if (i) { /* t->used[level][0] != which */
#if 0
Modified: grass/trunk/lib/vector/rtree/index.c
--- grass/trunk/lib/vector/rtree/index.c 2012-11-30 10:07:39 UTC (rev 54106)
+++ grass/trunk/lib/vector/rtree/index.c 2012-11-30 10:34:12 UTC (rev 54107)
@@ -110,19 +110,19 @@
new_rtree->nb[i] = new_rtree->nb[i - 1] + NODE_BUFFER_SIZE;
+ new_rtree->used = malloc(MAXLEVEL * sizeof(int *));
+ new_rtree->used[0] = malloc(MAXLEVEL * NODE_BUFFER_SIZE * sizeof(int));
- for (j = 0; j < MAXCARD; j++) {
- new_rtree->fs[i].sn.branch[j].rect.boundary = RTreeAllocBoundary(new_rtree);
+ if (i)
+ new_rtree->used[i] = new_rtree->used[i - 1] + NODE_BUFFER_SIZE;
for (j = 0; j < NODE_BUFFER_SIZE; j++) {
new_rtree->nb[i][j].dirty = 0;
new_rtree->nb[i][j].pos = -1;
/* usage order */
new_rtree->used[i][j] = j;
+ new_rtree->nb[i][j].n.branch = malloc(MAXCARD * sizeof(struct RTree_Branch));
/* alloc memory for rectangles */
for (k = 0; k < MAXCARD; k++) {
new_rtree->nb[i][j].n.branch[k].rect.boundary = RTreeAllocBoundary(new_rtree);
@@ -166,12 +166,16 @@
new_rtree->n_leafs = 0;
/* initialize temp variables */
+ new_rtree->ns = malloc(MAXLEVEL * sizeof(struct nstack));
new_rtree->p.cover[0].boundary = RTreeAllocBoundary(new_rtree);
new_rtree->p.cover[1].boundary = RTreeAllocBoundary(new_rtree);
new_rtree->tmpb1.rect.boundary = RTreeAllocBoundary(new_rtree);
new_rtree->tmpb2.rect.boundary = RTreeAllocBoundary(new_rtree);
new_rtree->c.rect.boundary = RTreeAllocBoundary(new_rtree);
+ new_rtree->BranchBuf = malloc((MAXCARD + 1) * sizeof(struct RTree_Branch));
for (i = 0; i <= MAXCARD; i++) {
new_rtree->BranchBuf[i].rect.boundary = RTreeAllocBoundary(new_rtree);
@@ -226,11 +230,15 @@
free(t->free_nodes.pos);
free(t->nb[0]);
free(t->nb);
+ free(t->used[0]);
+ free(t->used);
else if (t->root)
RTreeDestroyNode(t->root, t->root->level ? t->nodecard : t->leafcard);
/* free temp variables */
+ free(t->ns);
RTreeFreeBoundary(&(t->p.cover[0]));
RTreeFreeBoundary(&(t->p.cover[1]));
@@ -240,6 +248,7 @@
RTreeFreeBoundary(&(t->BranchBuf[i].rect));
+ free(t->BranchBuf);
RTreeFreeBoundary(&(t->rect_0));
RTreeFreeBoundary(&(t->rect_1));
RTreeFreeBoundary(&(t->upperrect));
Modified: grass/trunk/lib/vector/rtree/index.h
--- grass/trunk/lib/vector/rtree/index.h 2012-11-30 10:07:39 UTC (rev 54106)
+++ grass/trunk/lib/vector/rtree/index.h 2012-11-30 10:34:12 UTC (rev 54107)
@@ -111,9 +111,7 @@
/* io.c */
struct RTree_Node *RTreeGetNode(off_t, int, struct RTree *);
void RTreeNodeChanged(struct RTree_Node *, off_t , struct RTree *);
-void RTreePutNode(struct RTree_Node *, off_t, struct RTree *);
size_t RTreeRewriteNode(struct RTree_Node *, off_t, struct RTree *);
-void RTreeUpdateRect(struct RTree_Rect *, struct RTree_Node *, off_t, int, struct RTree *);
void RTreeAddNodePos(off_t, int, struct RTree *);
#endif /* _INDEX_ */
Modified: grass/trunk/lib/vector/rtree/indexf.c
--- grass/trunk/lib/vector/rtree/indexf.c 2012-11-30 10:07:39 UTC (rev 54106)
+++ grass/trunk/lib/vector/rtree/indexf.c 2012-11-30 10:34:12 UTC (rev 54107)
@@ -42,7 +42,7 @@
int hitCount = 0, notfound, currlevel;
int i;
int top = 0;
- struct fstack *s = t->fs;
+ struct nstack *s = t->ns;
/* stack size of t->rootlevel + 1 is enough because of depth first search */
/* only one node per level on stack at any given time */
@@ -51,7 +51,6 @@
currlevel = t->rootlevel;
s[top].pos = t->rootpos;
s[top].sn = RTreeGetNode(s[top].pos, currlevel, t);
- /* RTreeGetNode(&(s[top].sn), s[top].pos, currlevel, t); */
s[top].branch_id = i = 0;
while (top >= 0) {
@@ -66,7 +65,6 @@
/* add next node to stack */
s[top].pos = n->branch[i].child.pos;
s[top].branch_id = 0;
notfound = 0;
break;
@@ -119,28 +117,16 @@
int top = 0, down = 0;
int result;
struct RTree_Branch *b = &(t->tmpb2);
- static struct RTree_Node nn;
- static struct RTree_Rect nr;
- static int rect_init = 0;
- if (!rect_init) {
- for (i = 0; i < MAXCARD; i++) {
- nn.branch[i].rect.boundary = RTreeAllocBoundary(t);
- nr.boundary = RTreeAllocBoundary(t);
- rect_init = t->ndims_alloc;
+ struct RTree_Rect *nr = &(t->orect);
- n2 = &nn;
- /* n2 = newnode; */
+ n2 = newnode;
/* add root node position to stack */
/* go down to level of insertion */
while (s[top].sn->level > level) {
@@ -151,10 +137,7 @@
- assert(s[top].sn->level == currlevel);
- assert(s[top].sn->level == level);
/* Have reached level for insertion. Add rect, split if necessary */
RTreeCopyRect(&(b->rect), r, t);
@@ -166,7 +149,6 @@
cover = &(s[top - 1].sn->branch[s[top - 1].branch_id].rect);
result = RTreeAddBranch(b, s[top].sn, &n2, ee, cover, overflow, t);
/* update node */
- /* RTreePutNode(&(s[top].sn), s[top].pos, t); */
RTreeNodeChanged(s[top].sn, s[top].pos, t);
/* write out new node if node was split */
if (result == 1) {
@@ -180,24 +162,16 @@
down = top--;
i = s[top].branch_id;
if (result == 0) { /* branch was added */
- RTreeCombineRect(&(s[top].sn->branch[i].rect), r, &nr, t);
- /* rewrite rect */
- if (!RTreeCompareRect(&nr, &(s[top].sn.branch[i].rect), t)) {
- RTreeUpdateRect(&nr, &(s[top].sn), s[top].pos, i, t);
if (RTreeExpandRect(&(s[top].sn->branch[i].rect), r, t)) {
else if (result == 2) { /* branches were removed */
/* get node cover of previous node */
- RTreeNodeCover(s[down].sn, &nr, t);
+ RTreeNodeCover(s[down].sn, nr, t);
/* rewrite rect */
- if (!RTreeCompareRect(&nr, &(s[top].sn->branch[i].rect), t)) {
- /* RTreeUpdateRect(&nr, &(s[top].sn), s[top].pos, i, t); */
- RTreeCopyRect(&(s[top].sn->branch[i].rect), &nr, t);
+ if (!RTreeCompareRect(nr, &(s[top].sn->branch[i].rect), t)) {
+ RTreeCopyRect(&(s[top].sn->branch[i].rect), nr, t);
@@ -216,7 +190,6 @@
/* update node */
@@ -228,9 +201,6 @@
- /* copy node */
- RTreeCopyNode(newnode, n2, t);
return result;
@@ -247,48 +217,42 @@
struct RTree_ListBranch *reInsertList = NULL;
struct RTree_ListBranch *e;
- int i, result;
+ int result;
char overflow[MAXLEVEL];
struct RTree_Branch *b = &(t->tmpb1);
struct RTree_Node *oldroot;
- static struct RTree_Node newroot, newnode;
+ static struct RTree_Node *newroot = NULL, *newnode = NULL;
- if (!rect_init) {
- /* oldroot.branch[i].rect.boundary = RTreeAllocBoundary(t); */
- newroot.branch[i].rect.boundary = RTreeAllocBoundary(t);
- newnode.branch[i].rect.boundary = RTreeAllocBoundary(t);
+ if (!newroot) {
+ newroot = RTreeAllocNode(t, 1);
+ newnode = RTreeAllocNode(t, 1);
/* R*-tree forced reinsertion: for each level only once */
memset(overflow, t->overflow, MAXLEVEL);
- result = RTreeInsertRect2F(r, child, level, &newnode, &newnode_pos,
+ result = RTreeInsertRect2F(r, child, level, newnode, &newnode_pos,
t, &reInsertList, overflow);
if (result == 1) { /* root split */
oldroot = RTreeGetNode(t->rootpos, t->rootlevel, t);
- /* RTreeGetNode(&oldroot, t->rootpos, t->rootlevel, t); */
/* grow a new root, & tree taller */
t->rootlevel++;
- RTreeInitNode(t, &newroot, NODETYPE(t->rootlevel, t->fd));
- newroot.level = t->rootlevel;
+ RTreeInitNode(t, newroot, NODETYPE(t->rootlevel, t->fd));
+ newroot->level = t->rootlevel;
/* branch for old root */
RTreeNodeCover(oldroot, &(b->rect), t);
b->child.pos = t->rootpos;
- RTreeAddBranch(b, &newroot, NULL, NULL, NULL, NULL, t);
+ RTreeAddBranch(b, newroot, NULL, NULL, NULL, NULL, t);
/* branch for new node created by RTreeInsertRect2() */
- RTreeNodeCover(&newnode, &(b->rect), t);
+ RTreeNodeCover(newnode, &(b->rect), t);
b->child.pos = newnode_pos; /* offset to new node as returned by RTreeInsertRect2F() */
/* write new root node */
t->rootpos = RTreeGetNodePos(t);
- RTreeWriteNode(&newroot, t);
+ RTreeWriteNode(newroot, t);
t->n_nodes++;
return result;
@@ -304,27 +268,26 @@
RTreeFreeListBranch(e);
/* reinsert branches */
result =
- RTreeInsertRect2F(&(b->rect), b->child, level, &newnode, &newnode_pos, t,
+ RTreeInsertRect2F(&(b->rect), b->child, level, newnode, &newnode_pos, t,
t->rootlevel++;
t->n_nodes++;
@@ -347,23 +310,14 @@
int minfill;
- assert(ee);
- if (!rect_init) {
- rect_init = 1;
while (notfound && top >= 0) {
@@ -378,7 +332,6 @@
notfound = 0;
@@ -398,7 +351,6 @@
if (s[top].sn->branch[i].child.id &&
s[top].sn->branch[i].child.id == child.id) { /* found item */
RTreeDisconnectBranch(s[top].sn, i, t);
t->n_leafs--;
notfound = 0;
@@ -419,22 +371,19 @@
down = top;
top--;
i = s[top].branch_id - 1;
- assert(s[down].sn->level == s[top].sn->level - 1);
minfill = (s[down].sn->level ? t->min_node_fill : t->min_leaf_fill);
if (s[down].sn->count >= minfill) {
/* just update node cover */
/* rewrite rect */
else {
/* not enough entries in child, eliminate child node */
- assert(s[top].sn->branch[i].child.pos == s[down].pos);
n = RTreeAllocNode(t, s[down].sn->level);
/* copy node */
RTreeCopyNode(n, s[down].sn, t);
@@ -442,7 +391,6 @@
RTreeReInsertNode(n, ee);
@@ -464,16 +412,6 @@
struct RTree_ListNode *e, *reInsertList = NULL;
- static struct RTree_Node rn;
- if (!rect_init) {
- rn.branch[i].rect.boundary = RTreeAllocBoundary(t);
- rect_init = 1;
if (!RTreeDeleteRect2F(r, child, t, &reInsertList)) {
/* found and deleted a data item */
@@ -505,10 +443,6 @@
/* check for redundant root (not leaf, 1 child) and eliminate */
n = RTreeGetNode(t->rootpos, t->rootlevel, t);
- RTreeGetNode(&rn, t->rootpos, t->rootlevel, t);
- n = &rn;
if (n->count == 1 && n->level > 0) {
for (i = 0; i < t->nodecard; i++) {
Modified: grass/trunk/lib/vector/rtree/indexm.c
--- grass/trunk/lib/vector/rtree/indexm.c 2012-11-30 10:07:39 UTC (rev 54106)
+++ grass/trunk/lib/vector/rtree/indexm.c 2012-11-30 10:34:12 UTC (rev 54107)
@@ -39,7 +39,7 @@
int hitCount = 0, notfound;
int i;
int top = 0;
- struct mstack *s = t->ms;
@@ -111,7 +111,7 @@
int result;
/* add root node to stack */
s[top].sn = t->root;
@@ -270,7 +270,7 @@
int minfill;
assert(ee);
Modified: grass/trunk/lib/vector/rtree/io.c
--- grass/trunk/lib/vector/rtree/io.c 2012-11-30 10:07:39 UTC (rev 54106)
+++ grass/trunk/lib/vector/rtree/io.c 2012-11-30 10:34:12 UTC (rev 54107)
@@ -24,7 +24,7 @@
#include <grass/config.h>
#include "index.h"
-#define USAGE_SWAP
+/* #define USAGE_SWAP */
/* add new free node position for recycling */
void RTreeAddNodePos(off_t pos, int level, struct RTree *t)
@@ -50,7 +50,6 @@
/* is it possible that this node is not in the buffer? */
assert(i < NODE_BUFFER_SIZE);
- assert(t->nb[level][which].n.level == level);
t->nb[level][which].pos = -1;
t->nb[level][which].dirty = 0;
@@ -123,8 +122,6 @@
if (t->nb[level][which].pos != nodepos) {
/* rewrite node in buffer */
if (t->nb[level][which].dirty) {
- assert(t->nb[level][which].pos >= 0);
RTreeRewriteNode(&(t->nb[level][which].n),
t->nb[level][which].pos, t);
@@ -132,7 +129,6 @@
RTreeReadNode(&(t->nb[level][which].n), nodepos, t);
/* make it mru */
#ifdef USAGE_SWAP
@@ -202,7 +198,6 @@
/* as it is used, it should always be mru */
assert(i == 0);
which = t->used[n->level][i];
- assert(t->nb[n->level][which].n.level == n->level);
t->nb[n->level][which].dirty = 1;
@@ -221,84 +216,6 @@
-/* update node in buffer */
-void RTreePutNode(struct RTree_Node *n, off_t nodepos, struct RTree *t)
- int which, i = 0;
- /* check mru first */
- while (t->nb[n->level][t->used[n->level][i]].pos != nodepos &&
- i < NODE_BUFFER_SIZE)
- i++;
- assert(i < NODE_BUFFER_SIZE);
- /* as it is used, it should always be mru */
- assert(i == 0);
- which = t->used[n->level][i];
- /* copy node */
- RTreeCopyNode(&(t->nb[n->level][which].n), n, t);
- t->nb[n->level][which].dirty = 1;
- /* make it mru */
- if (i) { /* t->used[level][0] != which */
-#ifdef USAGE_SWAP
- t->used[n->level][i] = t->used[n->level][0];
- t->used[n->level][0] = which;
-#else
- while (i) {
- t->used[n->level][i] = t->used[n->level][i - 1];
- i--;
-#endif
-/* update rectangle */
-void RTreeUpdateRect(struct RTree_Rect *r, struct RTree_Node *n,
- off_t nodepos, int b, struct RTree *t)
- int i, j, k, which;
- i = 0;
- i++;
- assert(i == 0);
- for (j = 0; j < t->ndims_alloc; j++) {
- t->nb[n->level][which].n.branch[b].rect.boundary[j] =
- n->branch[b].rect.boundary[j] = r->boundary[j];
- k = j + t->ndims_alloc;
- t->nb[n->level][which].n.branch[b].rect.boundary[k] =
- n->branch[b].rect.boundary[k] = r->boundary[k];
- /* make it mru */
-#ifdef USAGE_SWAP
-#else
- while (i) {
- i--;
-#endif
/* flush pending changes to file */
void RTreeFlushBuffer(struct RTree *t)
Modified: grass/trunk/lib/vector/rtree/node.c
--- grass/trunk/lib/vector/rtree/node.c 2012-11-30 10:07:39 UTC (rev 54106)
+++ grass/trunk/lib/vector/rtree/node.c 2012-11-30 10:34:12 UTC (rev 54107)
@@ -81,6 +81,8 @@
n->count = 0;
n->level = level;
+ n->branch = malloc(MAXCARD * sizeof(struct RTree_Branch));
n->branch[i].rect.boundary = RTreeAllocBoundary(t);
@@ -99,6 +101,7 @@
RTreeFreeBoundary(&(n->branch[i].rect));
+ free(n->branch);
free(n);
Modified: grass/trunk/lib/vector/rtree/rtree.h
--- grass/trunk/lib/vector/rtree/rtree.h 2012-11-30 10:07:39 UTC (rev 54106)
+++ grass/trunk/lib/vector/rtree/rtree.h 2012-11-30 10:34:12 UTC (rev 54107)
@@ -52,7 +52,7 @@
#define MAXLEVEL 20 /* 8^MAXLEVEL items are guaranteed to fit into the tree */
/* number of nodes buffered per level */
-#define NODE_BUFFER_SIZE 8
+#define NODE_BUFFER_SIZE 32
struct RTree_Rect
@@ -78,7 +78,7 @@
int count; /* number of branches */
int level; /* 0 is leaf, others positive */
- struct RTree_Branch branch[MAXCARD];
+ struct RTree_Branch *branch;
@@ -99,20 +99,13 @@
typedef int rt_valid_child_fn(union RTree_Child *);
/* temp vars for each tree */
-/* stacks used for non-recursive insertion/deletion */
-/* stack for file-based index */
-struct fstack
+/* node stack used for non-recursive insertion/deletion */
+struct nstack
struct RTree_Node *sn; /* stack node */
int branch_id; /* branch number to follow down */
off_t pos; /* file position of stack node */
-/* stack for memory-based index */
-struct mstack
- struct RTree_Node *sn; /* stack node pointer */
- int branch_id; /* branch number to follow down */
/* node buffer for file-based index */
struct NodeBuffer
@@ -171,7 +164,7 @@
/* usage order of buffered nodes per level
* used[level][0] = most recently used
* used[level][NODE_BUFFER_SIZE - 1] = least recently used */
- int used[MAXLEVEL][NODE_BUFFER_SIZE];
+ int **used;
/* insert, delete, search */
rt_insert_fn *insert_rect;
@@ -183,13 +176,12 @@
/* internal variables, specific for each tree,
* allocated with tree initialization */
- /* stacks for tree traversal */
- struct mstack ms[MAXLEVEL];
- struct fstack fs[MAXLEVEL];
+ /* node stack for tree traversal */
+ struct nstack *ns;
/* variables for splitting / forced reinsertion */
struct RTree_PartitionVars p;
- struct RTree_Branch BranchBuf[MAXCARD + 1];
+ struct RTree_Branch *BranchBuf;
struct RTree_Branch tmpb1, tmpb2, c;
int BranchCount;
