[GRASS-SVN] r54108 - grass/trunk/vector/v.kernel
svn_grass at osgeo.org
Fri Nov 30 03:43:58 PST 2012
Author: mmetz
Date: 2012-11-30 03:43:58 -0800 (Fri, 30 Nov 2012)
New Revision: 54108
grass/trunk/vector/v.kernel/global.h
grass/trunk/vector/v.kernel/main.c
v.kernel speed up
Modified: grass/trunk/vector/v.kernel/global.h
--- grass/trunk/vector/v.kernel/global.h 2012-11-30 10:34:12 UTC (rev 54107)
+++ grass/trunk/vector/v.kernel/global.h 2012-11-30 11:43:58 UTC (rev 54108)
@@ -36,8 +36,9 @@
double dmax);
double compute_all_net_distances(struct Map_info *In, struct Map_info *Net,
double netmax, double **dists, double dmax);
-void compute_distance(double N, double E, struct Map_info *In, double sigma,
- double term, double *gaussian, double dmax);
+void compute_distance(double N, double E, double sigma, double term,
+ double *gaussian, double dmax, struct bound_box *box,
+ struct boxlist *NList);
void compute_net_distance(double x, double y, struct Map_info *In,
struct Map_info *Net, double netmax, double sigma,
double term, double *gaussian, double dmax, int node_method);
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2012-11-30 10:34:12 UTC (rev 54107)
+++ grass/trunk/vector/v.kernel/main.c 2012-11-30 11:43:58 UTC (rev 54108)
@@ -497,6 +497,10 @@
Vect_close(&Out);
else {
+ /* spatial index handling, borrowed from lib/vector/Vlib/find.c */
+ struct bound_box box;
+ struct boxlist *NList = Vect_new_boxlist(1);
G_message(_("\nWriting output raster map using smooth parameter=%f."),
sigma);
G_message(_("\nNormalising factor=%f."),
@@ -517,8 +521,26 @@
N = Rast_row_to_northing(row + 0.5, &window);
E = Rast_col_to_easting(col + 0.5, &window);
+ if ((col & 31) == 0) {
+ /* create bounding box 32x2*dmax size from the current cell center */
+ box.N = N + dmax;
+ box.S = N - dmax;
+ box.E = E + dmax + 32 * window.ew_res;
+ box.W = E - dmax;
+ box.T = HUGE_VAL;
+ box.B = -HUGE_VAL;
+ Vect_select_lines_by_box(&In, &box, GV_POINT, NList);
+ box.N = N + dmax;
+ box.S = N - dmax;
+ box.E = E + dmax;
+ box.W = E - dmax;
+ box.T = HUGE_VAL;
/* compute_distance(N, E, &In, sigma, term, &gaussian, dmax); */
- compute_distance(N, E, &In, sigma, term, &gaussian, dmax);
+ compute_distance(N, E, sigma, term, &gaussian, dmax, &box, NList);
output_cell[col] = multip * gaussian;
if (gaussian > gausmax)
@@ -791,35 +813,19 @@
- double sigma, double term, double *gaussian,
- double dmax)
int line, nlines;
double a[2], b[2];
double dist;
- /* spatial index handling, borrowed from lib/vector/Vlib/find.c */
- struct bound_box box;
- static struct boxlist *NList = NULL;
a[0] = E;
a[1] = N;
- if (!NList) {
- NList = Vect_new_boxlist(1);
- /* create bounding box 2x2*dmax size from the current cell center */
- box.N = N + dmax;
- box.S = N - dmax;
- box.E = E + dmax;
- box.W = E - dmax;
- box.T = HUGE_VAL;
- box.B = -HUGE_VAL;
/* number of lines within dmax box */
- nlines = Vect_select_lines_by_box(In, &box, GV_POINT, NList);
+ nlines = NList->n_values;
*gaussian = .0;
@@ -828,10 +834,13 @@
b[0] = NList->box[line].E;
b[1] = NList->box[line].N;
- dist = euclidean_distance(a, b, 2);
+ if (b[0] <= box->E && b[0] >= box->W &&
+ b[1] <= box->N && b[1] >= box->S) {
+ dist = euclidean_distance(a, b, 2);
- if (dist <= dmax)
- /* *gaussian += gaussianKernel(dist / sigma, term); */
- *gaussian += kernelFunction(term, sigma, dist);
+ if (dist <= dmax)
+ /* *gaussian += gaussianKernel(dist / sigma, term); */
+ *gaussian += kernelFunction(term, sigma, dist);
