[GRASS-SVN] r53309 - sandbox/lucadelu
Wed Oct 3 08:44:09 PDT 2012
Author: lucadelu
Date: 2012-10-03 08:44:08 -0700 (Wed, 03 Oct 2012)
New Revision: 53309
   sandbox/lucadelu/r.li.setup.py
big improvement in r.li.setup, thanks to anna kratochvilova
Modified: sandbox/lucadelu/r.li.setup.py
--- sandbox/lucadelu/r.li.setup.py	2012-10-03 14:22:32 UTC (rev 53308)
+++ sandbox/lucadelu/r.li.setup.py	2012-10-03 15:44:08 UTC (rev 53309)
@@ -4,10 +4,11 @@
 @brief   GUI per r.li.setup module
 Classes:
- - RLiSetupFrame (first frame to show existing conf file and choose some operation)
+ - RLiSetupFrame (first frame to show existing conf file and choose some
+                 operation)
  - RLIWizard (the main wizard)
  - FirstPage (first page of wizard, choose name of conf file, raster, vector,
-	      sampling region)
+              sampling region)
  - Keybord (page to insert region areas from keybord)
  - SamplingAreas (define sampling area)
  - SummaryPage (show choosen options)
@@ -25,15 +26,12 @@
 sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
 import wx
-import wx.lib.mixins.listctrl as listmix
 import wx.wizard as wiz
 import wx.lib.scrolledpanel as scrolled
-import time
 from core import globalvar
 from gui_core import gselect
 from core import gcmd
-from core import utils
 from location_wizard.wizard import TitledPage as TitledPage
 from grass.script import core as grass
 from grass.script import raster as grast
@@ -42,55 +40,65 @@
 ## r.li.windows.tcl:
 #exec echo "SAMPLINGFRAME $per_x|$per_y|$per_rl|$per_cl" >> $env(TMP).set
 def checkValue(value):
     if value == '':
         wx.FindWindowById(wx.ID_FORWARD).Enable(False)
     else:
         wx.FindWindowById(wx.ID_FORWARD).Enable(True)
 def retRLiPath():
     major_version = int(grass.version()['version'].split('.', 1)[0])
-    rlipath = os.path.join(os.environ['HOME'], '.grass%d' % major_version, 'r.li')
+    rlipath = os.path.join(os.environ['HOME'], '.grass%d' % major_version,
+                           'r.li')
     if os.path.exists(rlipath):
         return rlipath
     else:
         os.mkdir(rlipath)
         return rlipath
 class RLiSetupFrame(wx.Frame):
-    def __init__(self, parent, id = wx.ID_ANY,
-        style = wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER,
-                title = _("r.li.setup"), **kwargs):
-	###VARIABLES
+    def __init__(self, parent, id=wx.ID_ANY, title=_("r.li.setup"),
+                 style=wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER, **kwargs):
+        ###VARIABLES
         self.parent = parent
         self.cmd = "r.li.setup"
         self.rlipath = retRLiPath()
         self.listfiles = self.ListFiles()
         ###END VARIABLES
         #init of frame
-        wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
-        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
-        self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        wx.Frame.__init__(self, parent=parent, id=id, title=title,
+                          **kwargs)
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'),
+                             wx.BITMAP_TYPE_ICO))
+        self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
         #box for select configuration file
-        self.confilesBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
-                                        label= _('Available sampling area configuration files'))
-        self.listfileBox = wx.ListBox(parent = self.panel,  id = wx.ID_ANY,
-                    choices = self.listfiles)
+        self.confilesBox = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
+                                        label=_('Available sampling area " \
+                                                "configuration files'))
+        self.listfileBox = wx.ListBox(parent=self.panel,  id=wx.ID_ANY,
+                    choices=self.listfiles)
         ###BUTTONS
         #definition
-        self.btn_close = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
-        self.btn_help = wx.Button(parent = self.panel, id = wx.ID_HELP)
-        self.btn_remove = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Remove"))
+        self.btn_close = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
+        self.btn_help = wx.Button(parent=self.panel, id=wx.ID_HELP)
+        self.btn_remove = wx.Button(parent=self.panel, id=wx.ID_ANY,
+                                    label=_("Remove"))
         self.btn_remove.SetToolTipString(_('Remove a configuration file'))
-        self.btn_new = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Create"))
+        self.btn_new = wx.Button(parent=self.panel, id=wx.ID_ANY,
+                                 label=_("Create"))
         self.btn_new.SetToolTipString(_('Create a new configuration file'))
-        self.btn_rename = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("Rename"))
-        self.btn_rename.SetToolTipString(_('Renane a configuration file'))
+        self.btn_rename = wx.Button(parent=self.panel, id=wx.ID_ANY,
+                                    label=_("Rename"))
+        self.btn_rename.SetToolTipString(_('Rename a configuration file'))
         #set action for button
         self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
         self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
         self.btn_remove.Bind(wx.EVT_BUTTON, self.OnRemove)
-        self.btn_new.Bind(wx.EVT_BUTTON, self.OnNew)
+        self.btn_new.Bind(wx.EVT_BUTTON, self.OnNew)
         self.btn_rename.Bind(wx.EVT_BUTTON, self.OnRename)
         self._layout()
         ###END BUTTONS
@@ -104,24 +112,24 @@
     def _layout(self):
         """Set the layout"""
         sizer = wx.BoxSizer(wx.VERTICAL)
-        ###CONFILES
+        ###CONFILES
         confilesSizer = wx.StaticBoxSizer(self.confilesBox, wx.HORIZONTAL)
-        confilesSizer.Add(item = self.listfileBox, proportion = 1,
-                         flag = wx.EXPAND)
+        confilesSizer.Add(item=self.listfileBox, proportion=1,
+                         flag=wx.EXPAND)
         ###END CONFILES
-        ###BUTTONS
+        ###BUTTONS
         buttonSizer = wx.BoxSizer(wx.HORIZONTAL)
-        buttonSizer.Add(item = self.btn_new, flag = wx.ALL, border = 5)
-        buttonSizer.Add(item = self.btn_rename, flag = wx.ALL, border = 5)
-        buttonSizer.Add(item = self.btn_remove, flag = wx.ALL, border = 5)
-        buttonSizer.Add(item = self.btn_help, flag = wx.ALL, border = 5)
-        buttonSizer.Add(item = self.btn_close, flag = wx.ALL, border = 5)
-        ###END BUTTONS
+        buttonSizer.Add(item=self.btn_new, flag=wx.ALL, border=5)
+        buttonSizer.Add(item=self.btn_rename, flag=wx.ALL, border=5)
+        buttonSizer.Add(item=self.btn_remove, flag=wx.ALL, border=5)
+        buttonSizer.Add(item=self.btn_help, flag=wx.ALL, border=5)
+        buttonSizer.Add(item=self.btn_close, flag=wx.ALL, border=5)
+        ###END BUTTONS
         #add to sizer
-        sizer.Add(item = confilesSizer, proportion = 0,
-                  flag = wx.ALIGN_LEFT | wx.EXPAND | wx.ALL, border = 3)
-        sizer.Add(item = buttonSizer, proportion = 0,
-                  flag = wx.ALIGN_RIGHT | wx.ALL, border = 3)
+        sizer.Add(item=confilesSizer, proportion=0,
+                  flag=wx.ALIGN_LEFT | wx.EXPAND | wx.ALL, border=3)
+        sizer.Add(item=buttonSizer, proportion=0,
+                  flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
         #set dimension
         self.panel.SetAutoLayout(True)
         self.panel.SetSizer(sizer)
@@ -135,23 +143,23 @@
         #return all the configuration files in self.rlipath, check if there are
         #link or directory and doesn't add them
         for l in os.listdir(self.rlipath):
-            if os.path.isfile(os.path.join(self.rlipath,l)):
-                listfiles.append(l)
+            if os.path.isfile(os.path.join(self.rlipath, l)):
+                listfiles.append(l)
         return listfiles
-    def OnClose(self,event):
+    def OnClose(self, event):
         """!Close window"""
         self.Destroy()
     def OnHelp(self, event):
         """!Launches r.mapcalc help"""
-        gcmd.RunCommand('g.manual', parent = self, entry = self.cmd)
+        gcmd.RunCommand('g.manual', parent=self, entry=self.cmd)
     def OnRemove(self, event):
         """!Remove configuration file from path and update the list"""
         confile = self.listfiles[self.listfileBox.GetSelections()[0]]
         self.listfileBox.Delete(self.listfileBox.GetSelections()[0])
-        grass.try_remove(os.path.join(self.rlipath,confile))
+        grass.try_remove(os.path.join(self.rlipath, confile))
         return
     def OnNew(self, event):
@@ -166,35 +174,39 @@
         try:
         except:
-            gcmd.GMessage(parent = self,
-                          message = _("You have to select a configuration file"))
+            gcmd.GMessage(parent=self,
+                          message=_("You have to select a configuration file"))
             return
-        dlg = wx.TextEntryDialog(parent = self.parent,
-                 message = _('Set te new name for %s configuration file') % confile,
-                 caption = _('Rename configuration file'))
+        dlg = wx.TextEntryDialog(parent=self.parent,
+                                 message=_('Set te new name for %s " \
+                                           "configuration file') % confile,
+                                 caption=_('Rename configuration file'))
         if dlg.ShowModal() == wx.ID_OK:
             res = dlg.GetValue()
             newname = "%s%s%s" % (self.rlipath, os.sep, res)
-            os.rename(os.path.join(self.rlipath,confile), newname)
+            os.rename(os.path.join(self.rlipath, confile), newname)
             self.listfileBox.Clear()
-            self.listfileBox.Set(self.listfiles)
+            self.listfileBox.Set(self.listfiles)
 class RLIWizard(object):
     Start wizard here and finish wizard here
     def __init__(self, parent):
-        self.parent = parent # GMFrame
-        self.wizard = wiz.Wizard(parent=parent, id=wx.ID_ANY, title=_("Create new configuration file for r.li modules"))
+        self.parent = parent  ## GMFrame
+        self.wizard = wiz.Wizard(parent=parent, id=wx.ID_ANY,
+                                 title=_("Create new configuration file for " \
+                                 "r.li modules"))
         #pages
         self.startpage = FirstPage(self.wizard, self)
         self.keyboardpage = KeybordPage(self.wizard, self)
         self.samplingareapage = SamplingAreasPage(self.wizard, self)
         self.summarypage = SummaryPage(self.wizard, self)
-        self.samplingunits = SampleUnitsKeyPage(self.wizard, self)
+        self.units = SampleUnitsKeyPage(self.wizard, self)
         self.moving = MovingWindows(self.wizard, self)
         #order of pages
@@ -203,47 +215,47 @@
         self.keyboardpage.SetNext(self.samplingareapage)
         self.samplingareapage.SetPrev(self.startpage)
         self.samplingareapage.SetNext(self.summarypage)
-        self.samplingunits.SetPrev(self.samplingareapage)
-        self.samplingunits.SetNext(self.summarypage)
+        self.units.SetPrev(self.samplingareapage)
+        self.units.SetNext(self.summarypage)
         self.moving.SetPrev(self.samplingareapage)
         self.moving.SetNext(self.summarypage)
         self.summarypage.SetPrev(self.samplingareapage)
-        #layout
+        #layout
         self.startpage.DoLayout()
         self.keyboardpage.DoLayout()
         self.samplingareapage.DoLayout()
         self.summarypage.DoLayout()
-        self.samplingunits.DoLayout()
+        self.units.DoLayout()
         self.moving.DoLayout()
         self.wizard.FitToPage(self.startpage)
         #run_wizard
         if self.wizard.RunWizard(self.startpage):
-            print self.startpage.conf_name, self.startpage.newconftxt.GetValue()
-            dlg = wx.MessageDialog(parent = self.parent,
-                                message = _("Do you want to create r.li configuration file <%s>?") % self.startpage.conf_name,
-                                caption = _("Create new r.li configuration file?"),
-                                style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+            dlg = wx.MessageDialog(parent=self.parent,
+                                message=_("Do you want to create r.li " \
+                                          "configuration file <%s>?") % self.startpage.conf_name,
+                                caption=_("Create new r.li configuration file?"),
+                                style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
             if dlg.ShowModal() == wx.ID_NO:
                 self._cleanup()
-                dlg.Destroy()
+                dlg.Destroy()
             else:
                 self._write_confile()
                 self._cleanup()
                 dlg.Destroy()
         else:
             self.wizard.Destroy()
-            gcmd.GMessage(parent = self.parent,
-                     message = _("r.li.setup wizard canceled. "
-                                 "Configuration file not created."))
+            gcmd.GMessage(parent=self.parent,
+                     message=_("r.li.setup wizard canceled. "
+                                "Configuration file not created."))
             self._cleanup()
     def _write_confile(self):
         """Write the configuration file"""
-        f = open(os.path.join(self.rlipath,self.startpage.conf_name),'w')
+        f = open(os.path.join(self.rlipath, self.startpage.conf_name), 'w')
+        self.rasterinfo = grast.raster_info(self.startpage.rast)
         self._write_region(f)
         self._write_area(f)
         f.close()
@@ -253,42 +265,109 @@
         grass.use_temp_region()
         # Temporarily aligning region resolution to $RASTER resolution
         # keep boundary settings
-        grass.run_command('g.region', rast = self.startpage.rast)
+        grass.run_command('g.region', rast=self.startpage.rast)
         self.gregion = grass.region()
+        self.SF_NSRES = self.gregion['nsres']
+        self.SF_EWRES = self.gregion['ewres']
-    def _write_region(self,fil):
+    def _write_region(self, fil):
         """Write the region"""
-        self.rasterinfo = grast.raster_info(self.startpage.rast)
         if self.startpage.region == 'whole':
             fil.write("SAMPLINGFRAME 0|0|1|1\n")
             self._temp_region()
             self.SF_X = 0.0
             self.SF_Y = 0.0
-            self.SF_RL = abs(int(float(self.gregion['s']-self.gregion['n']) / float(self.gregion['nsres'])))
-            self.SF_CL = abs(int(float(self.gregion['e']-self.gregion['w']) / float(self.gregion['ewres'])))
+            self.SF_RL = abs(int(float(self.gregion['s'] - self.gregion['n'])
+                        / float(self.gregion['nsres'])))
+            self.SF_CL = abs(int(float(self.gregion['e'] - self.gregion['w'])
+                        / float(self.gregion['ewres'])))
+            self.SF_N = self.gregion['n']
+            self.SF_S = self.gregion['s']
+            self.SF_E = self.gregion['e']
+            self.SF_W = self.gregion['w']
         elif self.startpage.region == 'key':
             self._temp_region()
             self.SF_X = self.keyboardpage.col_up
             self.SF_Y = self.keyboardpage.row_up
             self.SF_RL = self.keyboardpage.row_len
-            self.SF_CL =  self.keyboardpage.col_len
+            self.SF_CL = self.keyboardpage.col_len
+            self.SF_N = self.gregion['n'] - (self.SF_NSRES * self.SF_Y)
+            self.SF_S = self.gregion['n'] - (self.SF_NSRES * self.SF_Y + self.SF_RL)
+            self.SF_W = self.gregion['w'] + (self.SF_EWRES * self.SF_X)
+            self.SF_E = self.gregion['w'] + (self.SF_EWRES * self.SF_X + self.SF_CL)
             per_x = float(self.SF_X) / float(self.rasterinfo['cols'])
             per_y = float(self.SF_Y) / float(self.rasterinfo['rows'])
             per_rl = float(self.SF_RL) / float(self.rasterinfo['cols'])
             per_cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
-            fil.write("SAMPLINGFRAME %f|%f|%f|%f\n" % (per_x,per_y,per_rl,per_cl))
+            fil.write("SAMPLINGFRAME %s|%s|%s|%s\n" % (str(per_x), str(per_y),
+                                                       str(per_rl),  str(per_cl)))
-    def _write_area(self,fil):
+    def _circle(self, radius, mask):
+        """create a circle mask"""
+        self.CIR_RL = round((2 * radius) / self.rasterinfo['ewres'])
+        self.CIR_CL = round((2 * radius) / self.rasterinfo['nsres'])
+        if not self.CIR_RL % 2:
+            self.CIR_RL += 1
+        if not self.CIR_CL % 2:
+            self.CIR_CL += 1
+        eastEdge = float(self.SF_W + (self.CIR_RL * self.SF_EWRES))
+        southEdge = float(self.SF_N - (self.CIR_CL * self.SF_NSRES))
+        grass.del_temp_region()
+        grass.use_temp_region()
+        grass.run_command('g.region', n=self.SF_N, s=southEdge, e=eastEdge,
+                          w=self.SF_W)
+        xcenter = grass.region(complete=True)['center_easting']
+        ycenter = grass.region(complete=True)['center_northing']
+        grass.run_command('r.circle', flags='b', out=mask, max=radius,
+                          coordinate=[xcenter, ycenter])
+    def _write_area(self, fil):
         if self.samplingareapage.samplingtype == 'whole':
-            cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
+            cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
             rl = float(self.SF_RL) / float(self.rasterinfo['rows'])
-                fil.write("SAMPLEAREA %.1f|%.1f|%.1f|%.1f\n" % (x,y,rl,cl))
+                fil.write("SAMPLEAREA %s|%s|%s|%s\n" % (str(per_x), str(per_y),
+                                                        str(rl),  str(cl)))
-                fil.write("SAMPLEAREA %f|%f|%f|%f\n" % (x,y,rl,cl))
+        elif self.samplingareapage.samplingtype == 'moving':
+            if self.moving.boxtype == 'circle':
+                self._circle(self.moving.width, self.moving.height)
+                cl = float(self.CIR_CL) / float(self.rasterinfo['cols'])
+                rl = float(self.CIR_RL) / float(self.rasterinfo['rows'])
+            else:
+                cl = float(self.moving.width) / float(self.rasterinfo['cols'])
+                rl = float(self.moving.height) / float(self.rasterinfo['rows'])
+            fil.write("SAMPLEAREA -1|-1|%s|%s" % (str(rl), str(cl)))
+                fil.write("|%s" % self.moving.height)
+            fil.write("\nMOVINGWINDOW\n")
+        elif self.samplingareapage.samplingtype == 'units':
+            if self.units.boxtype == 'circle':
+                self._circle(self.units.width, self.units.height)
+            else:
+                cl = float(self.units.width) / float(self.rasterinfo['cols'])
+                rl = float(self.units.height) / float(self.rasterinfo['rows'])
+            fil.write("SAMPLEAREA -1|-1|%s|%s\n" % (str(rl), str(cl)))
+            if self.units.distrtype == 'non_overlapping':
+                fil.write("RANDOMNONOVERLAPPING %s\n" % str(NUMERO))
+            elif self.units.distrtype == 'systematic_contiguos':
+                fil.write("SYSTEMATICCONTIGUOUS\n")
+            elif self.units.distrtype == 'stratified_random':
+                fil.write("STRATIFIEDRANDOM %s|%s" % (str(NUMERO), str(NUMERO)))
+            elif self.units.distrtype == 'systematic_noncontiguos':
+                fil.write("SYSTEMATICNONCONTIGUOUS %s\n" % str(NUMERO))
+            elif self.units.distrtype == 'centered_oversites':
+                fil.write("")
     def _cleanup(self):
         """Clean all the variables to save into configuration file"""
@@ -301,9 +380,14 @@
         self.keyboardpage.row_len = ''
         self.keyboardpage.row_up = ''
         self.samplingareapage.samplingtype = 'whole'
-        self.samplingunits.sizew = ''
-        self.samplingunits.sizeh = ''
+        self.units.width = ''
+        self.units.height = ''
+        self.units.boxtype = ''
+        self.moving.width = ''
+        self.moving.height = ''
+        self.moving.boxtype = ''
 class FirstPage(TitledPage):
     Set name of configuration file, choose raster and optionally vector/sites
@@ -315,62 +399,72 @@
         self.region = 'whole'
         self.rast = ''
         self.conf_name = ''
-        self.vect = ''
-        wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+        self.vect = ''
-        self.sizer.AddGrowableCol(2)
         #name of output configuration file
-        self.newconflabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Name for new configuration file to create'))
+        self.newconflabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                        label=_('Name for new configuration file to create'))
-        self.newconftxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        self.newconftxt = wx.TextCtrl(parent=self, id=wx.ID_ANY,
+                                      size=(250, -1))
         wx.CallAfter(self.newconftxt.SetFocus)
-        self.sizer.Add(item = self.newconflabel, border=5, pos=(1, 1),
+        self.sizer.Add(item=self.newconflabel, border=5, pos=(0, 0),
                         flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
-        self.sizer.Add(item = self.newconftxt, border=5, pos=(1, 2),
+        self.sizer.Add(item=self.newconftxt, border=5, pos=(0, 1),
         #raster
-        self.mapsellabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Raster map to use to select areas'))
-        self.mapselect = gselect.Select(parent = self, id = wx.ID_ANY, size = (250, -1),
-                                            type = 'cell', multiple = False)
-        self.sizer.Add(item = self.mapsellabel, border=5, pos=(2, 1),
+        self.mapsellabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                        label=_('Raster map to use to select areas'))
+        self.mapselect = gselect.Select(parent=self, id=wx.ID_ANY,
+                                        size=(250, -1), type='cell',
+                                        multiple=False)
+        self.sizer.Add(item=self.mapsellabel, border=5, pos=(1, 0),
-        self.sizer.Add(item = self.mapselect, border=5, pos=(2, 2),
+        self.sizer.Add(item=self.mapselect, border=5, pos=(1, 1),
         #vector
-        self.vectsellabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Vector map to use to select areas'))
-        self.vectselect = gselect.Select(parent = self, id = wx.ID_ANY, size = (250, -1),
-                                            type = 'vector', multiple = False)
-        self.sizer.Add(item = self.vectsellabel, border=5, pos=(3, 1),
+        self.vectsellabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                        label=_('Vector map to use to select areas'))
+        self.vectselect = gselect.Select(parent=self, id=wx.ID_ANY,
+                                         size=(250, -1), type='vector',
+                                         multiple=False)
+        self.vectsellabel.Enable(False)
+        self.vectselect.Enable(False)
+        self.sizer.Add(item=self.vectsellabel, border=5, pos=(2, 0),
-        self.sizer.Add(item = self.vectselect, border=5, pos=(3, 2),
+        self.sizer.Add(item=self.vectselect, border=5, pos=(2, 1),
         #define sampling region
         self.sampling_reg = wx.RadioBox(parent=self, id=wx.ID_ANY,
-                                      label= _("Define sampling region (region for analysis)"),
-                                      choices=[_('Whole map layer'),
-                                      _('Keyboard setting'), _('Draw the sampling frame')],
-                                      majorDimension=wx.RA_SPECIFY_COLS)
+                                      label=" %s " % _("Define sampling " \
+                                      " region(region for analysis)"),
+                                      choices=[_('Whole map layer'),
+                                               _('Keyboard setting'),
+                                               _('Draw the sampling frame')],
+                                      majorDimension=1,
+                                      style=wx.RA_SPECIFY_ROWS)
+        self.sampling_reg.EnableItem(2, False) # disable 'draw' for now
+        self.sampling_reg.SetItemToolTip(2, _("This option is not supported yet"))
         self.sizer.Add(item=self.sampling_reg,
                         flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
-                        pos=(5, 1), span=(5, 2))
+                        pos=(4, 0), span=(1, 2))
         #bindings
         self.sampling_reg.Bind(wx.EVT_RADIOBOX, self.OnSampling)
         self.newconftxt.Bind(wx.EVT_KILL_FOCUS, self.OnName)
         self.vectselect.Bind(wx.EVT_TEXT, self.OnVector)
         self.mapselect.Bind(wx.EVT_TEXT, self.OnRast)
         #self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
         self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
+        wx.CallAfter(wx.FindWindowById(wx.ID_FORWARD).Enable, False)
+        # wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+        # self.OnName(None)
-    def OnSampling(self,event):
+    def OnSampling(self, event):
         """!Change map type"""
         if event.GetInt() == 0:
@@ -378,51 +472,41 @@
         elif event.GetInt() == 1:
             self.region = 'key'
             self.SetNext(self.parent.keyboardpage)
-        elif event.GetInt() == 2:
-	    self.region = 'draw'
-	    #to remove when I know how to connect or create a monitor
-                              message = _("Function not supported yet"))
-        return
-        if self.conf_name != '' and self.rast != '' and self.region != 'draw' \
-                            and not wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
-            wx.FindWindowById(wx.ID_FORWARD).Enable(True)
-        else:
+        elif event.GetInt() == 2: # currently disabled
+            self.region = 'draw'
-    def OnName(self,event):
-	"""!Sets the name of configuration file"""
-	self.conf_name = self.newconftxt.GetValue()
-	print self.conf_name
-	if self.conf_name in self.parent.parent.listfiles:
-                          message = _("The configuration file %s " % self.conf_name \
-                          + "already exists, please change name"))
+    def OnName(self, event):
+        """!Sets the name of configuration file"""
+        self.conf_name = self.newconftxt.GetValue()
+        if self.conf_name in self.parent.parent.listfiles:
+                          message=_("The configuration file %s "
+                                    "already exists, please change name") % self.conf_name)
             self.newconftxt.SetValue('')
-	if self.region != 'draw' and self.rast != '' and self.conf_name != '' and not \
-				wx.FindWindowById(wx.ID_FORWARD).IsEnabled():
-	else:
+            self.conf_name = ''
+        next = wx.FindWindowById(wx.ID_FORWARD)
+        next.Enable(self.CheckInput())
     def OnRast(self, event):
         """!Sets raster map"""
         self.rast = event.GetString()
-	if self.region != 'draw' and self.conf_name != '' and self.rast != '' and not \
-        else:
     def OnVector(self, event):
         """!Sets vector map"""
         self.vect = event.GetString()
-        else:
+    def CheckInput(self):
+        """!Check input fields.
+        @return True if configuration file is given and raster xor vector map,
+        False otherwise
+        return bool(self.conf_name and (bool(self.rast) != bool(self.vect)))
     def OnExitPage(self, event=None):
         """!Function during exiting"""
         if self.region == 'draw' or self.conf_name == '' or self.rast == '':
@@ -437,11 +521,12 @@
                 self.SetNext(self.parent.samplingareapage)
                 self.parent.samplingareapage.SetPrev(self)
             elif self.region == 'draw':
+                              message=_("Function not supported yet"))
                 event.Veto()
                 return
 class KeybordPage(TitledPage):
@@ -456,58 +541,60 @@
         self.row_len = ''
         self.col_up = '0'
         self.row_up = '0'
         #column up/left
-        self.ColUpLeftlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Column of upper left corner'))
+        self.ColUpLeftlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                            label=_("Column of upper left " \
+                                            "corner"))
-        self.ColUpLefttxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        self.ColUpLefttxt = wx.TextCtrl(parent=self, id=wx.ID_ANY,
+                                        size=(250, -1))
         wx.CallAfter(self.ColUpLeftlabel.SetFocus)
-        self.sizer.Add(item = self.ColUpLeftlabel, border=5, pos=(1, 1),
+        self.sizer.Add(item=self.ColUpLeftlabel, border=5, pos=(1, 1),
-        self.sizer.Add(item = self.ColUpLefttxt, border=5, pos=(1, 2),
+        self.sizer.Add(item=self.ColUpLefttxt, border=5, pos=(1, 2),
         #row up/left
-        self.RowUpLeftlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Row of upper left corner'))
+        self.RowUpLeftlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                            label=_('Row of upper left corner'))
-        self.RowUpLefttxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        self.RowUpLefttxt = wx.TextCtrl(parent=self, id=wx.ID_ANY,
+                                        size=(250, -1))
         wx.CallAfter(self.RowUpLeftlabel.SetFocus)
-        self.sizer.Add(item = self.RowUpLeftlabel, border=5, pos=(2, 1),
-                        flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
-        self.sizer.Add(item = self.RowUpLefttxt, border=5, pos=(2, 2),
+        self.sizer.Add(item=self.RowUpLeftlabel, border=5, pos=(2, 1),
+                       flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
+        self.sizer.Add(item=self.RowUpLefttxt, border=5, pos=(2, 2),
         #row lenght
-        self.RowLenlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Row lenght of sampling frame'))
+        self.RowLenlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                         label=_('Row lenght of sampling frame'))
-        self.RowLentxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        self.RowLentxt = wx.TextCtrl(parent=self, id=wx.ID_ANY, size=(250, -1))
         wx.CallAfter(self.RowLenlabel.SetFocus)
-        self.sizer.Add(item = self.RowLenlabel, border=5, pos=(3, 1),
+        self.sizer.Add(item=self.RowLenlabel, border=5, pos=(3, 1),
-        self.sizer.Add(item = self.RowLentxt, border=5, pos=(3, 2),
+        self.sizer.Add(item=self.RowLentxt, border=5, pos=(3, 2),
         #column lenght
-        self.ColLenlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+        self.ColLenlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
-        self.ColLentxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
+        self.ColLentxt = wx.TextCtrl(parent=self, id=wx.ID_ANY, size=(250, -1))
         wx.CallAfter(self.ColLenlabel.SetFocus)
-        self.sizer.Add(item = self.ColLenlabel, border=5, pos=(4, 1),
+        self.sizer.Add(item=self.ColLenlabel, border=5, pos=(4, 1),
-        self.sizer.Add(item = self.ColLentxt, border=5, pos=(4, 2),
+        self.sizer.Add(item=self.ColLentxt, border=5, pos=(4, 2),
         self.ColUpLefttxt.SetValue(self.col_up)
-        self.RowUpLefttxt.SetValue(self.row_up)
+        self.RowUpLefttxt.SetValue(self.row_up)
         self.ColUpLefttxt.Bind(wx.EVT_KILL_FOCUS, self.OnColLeft)
         self.RowUpLefttxt.Bind(wx.EVT_KILL_FOCUS, self.OnRowLeft)
         self.ColLentxt.Bind(wx.EVT_KILL_FOCUS, self.OnColLen)
@@ -515,26 +602,26 @@
-    def OnColLeft(self,event):
+    def OnColLeft(self, event):
         self.col_up = self.ColUpLefttxt.GetValue()
         checkValue(self.col_up)
-    def OnRowLeft(self,event):
+    def OnRowLeft(self, event):
         self.row_up = self.RowUpLefttxt.GetValue()
         checkValue(self.row_up)
-    def OnColLen(self,event):
+    def OnColLen(self, event):
         self.col_len = self.ColLentxt.GetValue()
         checkValue(self.col_len)
-    def OnRowLen(self,event):
+    def OnRowLen(self, event):
         self.row_len = self.RowLentxt.GetValue()
         checkValue(self.row_len)
     def OnEnterPage(self, event):
         """!Sets the default values, for the entire map
@@ -553,6 +640,7 @@
         else:
 class SamplingAreasPage(TitledPage):
@@ -562,74 +650,77 @@
         TitledPage.__init__(self, wizard, _("Insert sampling areas"))
         self.samplingtype = 'whole'
         # toggles
-        self.radio1 = wx.RadioButton(parent = self, id = wx.ID_ANY,
-                                     label = _("Whole maplayer"),
-                                     style  =  wx.RB_GROUP)
-        self.radio2 = wx.RadioButton(parent = self, id = wx.ID_ANY,
-                                     label = _("Regions"))
-        self.radio3 = wx.RadioButton(parent = self, id = wx.ID_ANY,
-                                     label = _("Sample units"))
-        self.radio4 = wx.RadioButton(parent = self, id = wx.ID_ANY,
-                                     label = _("Moving window"))
+        self.radioBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
+                                      label="",
+                                      choices=[_("Whole map layer"),
+                                               _("Regions"),
+                                               _("Sample units"),
+                                               _("Moving window"),
+                                               _("Select areas from the\n"
+                                                 "overlayed vector map")],
+                                      majorDimension=1,
+                                      style=wx.RA_SPECIFY_COLS | wx.NO_BORDER)
+        self.radioBox.EnableItem(1, False)
+        self.radioBox.SetItemToolTip(1, _("This option is not supported yet"))
         # layout
-        self.sizer.AddGrowableCol(1)
         self.sizer.SetVGap(10)
-        self.sizer.Add(item = self.radio1, flag = wx.ALIGN_LEFT, pos = (1, 1))
-        self.sizer.Add(item = self.radio2, flag = wx.ALIGN_LEFT, pos = (2, 1))
-        self.sizer.Add(item = self.radio3, flag = wx.ALIGN_LEFT, pos = (3, 1))
-        self.sizer.Add(item = self.radio4, flag = wx.ALIGN_LEFT, pos = (4, 1))
+        self.sizer.Add(item=self.radioBox, flag=wx.ALIGN_LEFT, pos=(0, 0))
+        self.regionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
+                        label=_("Choose a method"),
+                        choices=[_('Use keyboard to enter sampling area'),
+                        _('Use mouse to draw sampling area')],
+                        majorDimension=1,
+        self.regionBox.EnableItem(1, False)
+        self.regionBox.SetItemToolTip(1, _("This option is not supported yet"))
+        self.sizer.Add(self.regionBox, flag=wx.ALIGN_CENTER, pos=(1, 0))
         # bindings
-        self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio1.GetId())
-        self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio2.GetId())
-        self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio3.GetId())
-        self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio4.GetId())
+        self.radioBox.Bind(wx.EVT_RADIOBOX, self.SetVal)
+        self.regionBox.Bind(wx.EVT_RADIOBOX, self.OnRegionDraw)
+        self.regionbox = 'keybord'
         """!Insert values into text controls for summary of location
         creation options
-        try:
-            self.sizer.Hide(self.radio5)
-            self.sizer.Remove(self.radio5)
-            self.sizer.Layout()
-        except:
-            pass
-            if self.parent.startpage.vect != '':
-                self.radio5 = wx.RadioButton(parent = self, id = wx.ID_ANY,
-                                            label = _("Select areas from the "
-                                            "overlayed vector map"))
-                self.sizer.Add(item = self.radio5, flag = wx.ALIGN_LEFT, pos = (5, 1))
-                self.Bind(wx.EVT_RADIOBUTTON, self.SetVal, id = self.radio5.GetId())
+        self.SetVal(None)
+        if self.parent.startpage.vect:
+            self.radioBox.ShowItem(4, True)
+        else:
+            self.radioBox.ShowItem(4, False)
+        self.sizer.Layout()
+        wx.FindWindowById(wx.ID_FORWARD).Enable(True)
     def SetVal(self, event):
         """!Choose method"""
-        if event.GetId() == self.radio1.GetId():
-	    self.samplingtype = 'whole'
-	    self.DrawNothing()
-        elif event.GetId() == self.radio2.GetId():
-	    self.samplingtype = 'regions'
-	    self.Region()
-        elif event.GetId() == self.radio3.GetId():
-	    self.samplingtype = 'units'
-	    self.SetNext(self.parent.samplingunits)
-	    self.KeyDraw()
-        elif event.GetId() == self.radio4.GetId():
-	    self.samplingtype = 'moving'
-	    self.SetNext(self.parent.moving)
-	    self.KeyDraw()
-        elif event.GetId() == self.radio5.GetId():
-	    self.samplingtype = 'vector'
+        radio = self.radioBox.GetSelection()
+        if radio == 0:
+            self.samplingtype = 'whole'
+            self.DrawNothing()
+        # elif event.GetInt() == 1: # disabled
+        # self.samplingtype = 'regions'
+        # self.Region()
+        elif radio == 2:
+            self.samplingtype = 'units'
+            self.SetNext(self.parent.units)
+            self.KeyDraw()
+        elif radio == 3:
+            self.samplingtype = 'moving'
+            self.SetNext(self.parent.moving)
+            self.KeyDraw()
+        elif radio == 4:
+            self.samplingtype = 'vector'
     def Region(self):
-	"""show this only if radio2 it is selected"""
+        """show this only if radio2 it is selected"""
         try:
             self.sizer.Hide(self.regionBox)
             self.sizer.Remove(self.regionBox)
@@ -645,54 +736,33 @@
         #self.sizer.Add(self.regionBox, flag = wx.ALIGN_CENTER, pos = (6, 1))
         #self.sizer.Layout()
         #self.SetNext(self.parent.draw)
-        gcmd.GMessage(parent = self, message = _("Function not supported yet"))
+        gcmd.GMessage(parent=self, message=_("Function not supported yet"))
         return
     def KeyDraw(self):
         """Show this only if radio3 and radio4 it is selected"""
-        try:
-            self.sizer.Hide(self.regionBox)
-            self.sizer.Remove(self.regionBox)
-        except:
-            pass
-        self.regionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
-                        label= _("Choose a method"),
-                        choices=[_('Use keyboard to enter sampling area'),
-                        _('Use mouse to draw sampling area')],
-        self.sizer.Add(self.regionBox, flag = wx.ALIGN_CENTER, pos = (6, 1))
+        self.sizer.Show(self.regionBox)
         self.sizer.Layout()
-        self.regionbox = 'keybord'
-        self.regionBox.Bind(wx.EVT_RADIOBOX, self.OnRegionDraw)
-    def OnRegionDraw(self,event):
+    def OnRegionDraw(self, event):
         """Function called by KeyDraw to find what method is choosed"""
             self.regionbox = 'drawmouse'
             return
-            #self.SetNext(self.parent.draw)
+            #self.SetNext(self.parent.draw)
     def DrawNothing(self):
-        try:
-        except:
-            pass
+        self.sizer.Hide(self.regionBox)
         self.SetNext(self.parent.summarypage)
 class SampleUnitsKeyPage(TitledPage):
     """!Set values from keyboard for sample units"""
@@ -700,112 +770,142 @@
         TitledPage.__init__(self, wizard, _("Units"))
-        self.scrollPanel = scrolled.ScrolledPanel(parent = self, id = wx.ID_ANY)
-        self.scrollPanel.SetupScrolling(scroll_x = False)
-        self.sizer = wx.BoxSizer()
-        self.sizer.Add(self.scrollPanel,  proportion = 1, flag = wx.EXPAND)
-        self.panelSizer = wx.GridBagSizer(5,5)
-        self.sizew = ''
-        self.sizeh = ''
+        self.scrollPanel = scrolled.ScrolledPanel(parent=self, id=wx.ID_ANY)
+        self.scrollPanel.SetupScrolling(scroll_x=False)
+        self.panelSizer = wx.GridBagSizer(5, 5)
+        self.width = ''
+        self.height = ''
+        self.boxtype = ''
         # type of shape
         self.typeBox = wx.RadioBox(parent=self.scrollPanel, id=wx.ID_ANY,
-                        majorDimension=1, style=wx.RA_SPECIFY_COLS,
-				      label= _("Select type of shape"),
-				      choices=[_('Rectangle'), _('Circle')])
+                                   majorDimension=1, style=wx.RA_SPECIFY_COLS,
+                                   label=" %s " % _("Select type of shape"),
+                                   choices=[_('Rectangle'), _('Circle')])
-        self.panelSizer.Add(self.typeBox, flag = wx.ALIGN_LEFT, pos = (1, 1), span = (1, 2))
+        self.panelSizer.Add(self.typeBox, flag=wx.ALIGN_LEFT, pos=(0, 0),
+                            span=(1, 2))
+        self.widthLabel = wx.StaticText(parent=self.scrollPanel, id=wx.ID_ANY)
+        self.widthTxt = wx.TextCtrl(parent=self.scrollPanel, id=wx.ID_ANY,
+                                    size=(250, -1))
+        self.panelSizer.Add(item=self.widthLabel, pos=(1, 0),
+        self.panelSizer.Add(item=self.widthTxt, pos=(1, 1),
+        self.heightLabel = wx.StaticText(parent=self.scrollPanel, id=wx.ID_ANY)
+        self.heightTxt = wx.TextCtrl(parent=self.scrollPanel, id=wx.ID_ANY,
+                                     size=(250, -1))
+        self.panelSizer.Add(item=self.heightLabel, pos=(2, 0),
+        self.panelSizer.Add(item=self.heightTxt, pos=(2, 1),
+        self.widthLabels = [_('Width size (in cells)? '),
+                            _('What radius size (in meters)? ')]
+        self.heightLabels = [_('Height size (in cells)? '),
+                             _('Name of the circle mask')]
         self.distributionBox = wx.RadioBox(parent=self.scrollPanel, id=wx.ID_ANY,
-                    label= _("Select method of sampling unit distribution"),
-                    choices=[_('Random non overlapping'),
-                    _('Systematic contiguos'), _('Stratified random'),
-                    _('Systematic non contiguos'), _('Centered over sites')]
-        self.panelSizer.Add(item = self.distributionBox, pos=(2, 1), span = (1, 2),
+                                           label= " %s " % _("Select method of sampling unit distribution"),
+                                           choices=[_('Random non overlapping'),
+                                                    _('Systematic contiguos'),
+                                                    _('Stratified random'),
+                                                    _('Systematic non contiguos'),
+                                                    _('Centered over sites')]
+        self.panelSizer.Add(item=self.distributionBox, pos=(3, 0), span=(1, 2),
-        self.widthLabel = wx.StaticText(parent = self.scrollPanel, id = wx.ID_ANY,
-                                label = _('Width size (in cells)? '))
-        self.widthTxt = wx.TextCtrl(parent = self.scrollPanel, id = wx.ID_ANY, size=(250, -1))
-        self.panelSizer.Add(item = self.widthLabel, pos=(3, 1),
-        self.panelSizer.Add(item = self.widthTxt, pos=(3, 2),
+        self.distr1Label = wx.StaticText(parent=self.scrollPanel, id=wx.ID_ANY,
+                                         label=_("What number of Sampling " \
+                                         "Units to use?"))
+        self.distr1Txt = wx.TextCtrl(parent=self.scrollPanel, id=wx.ID_ANY,
+                                     size=(250, -1))
+        self.panelSizer.Add(item=self.distr1Label, pos=(4, 0),
-        self.heightLabel = wx.StaticText(parent = self.scrollPanel, id = wx.ID_ANY,
-                                label = _('Height size (in cells)? '))
-        self.heightTxt = wx.TextCtrl(parent = self.scrollPanel, id = wx.ID_ANY, size=(250, -1))
-        self.panelSizer.Add(item = self.heightLabel, pos=(4, 1),
-        self.panelSizer.Add(item = self.heightTxt, pos=(4, 2),
+        self.panelSizer.Add(item=self.distr1Txt, pos=(4, 1),
+        self.distr2Label = wx.StaticText(parent=self.scrollPanel, id=wx.ID_ANY)
+        self.distr2Txt = wx.TextCtrl(parent=self.scrollPanel, id=wx.ID_ANY,
+                                     size=(250, -1))
+        self.panelSizer.Add(item=self.distr2Label, pos=(5, 0),
+        self.panelSizer.Add(item=self.distr2Txt, pos=(5, 1),
+        self.panelSizer.Hide(self.distr2Txt)
         self.typeBox.Bind(wx.EVT_RADIOBOX, self.OnType)
+        self.distributionBox.Bind(wx.EVT_RADIOBOX, self.OnDistr)
+        self.widthTxt.Bind(wx.EVT_TEXT, self.OnWidth)
+        self.heightTxt.Bind(wx.EVT_TEXT, self.OnHeight)
+        self.sizer.Add(item=self.scrollPanel, pos=(0, 0), flag=wx.EXPAND)
+        self.sizer.AddGrowableCol(0)
+        self.sizer.AddGrowableRow(0)
         self.scrollPanel.SetSizer(self.panelSizer)
-    def OnType(self,event):
-        try:
-            self.sizer.Hide(self.widthLabel)
-            self.sizer.Hide(self.widthTxt)
-            self.sizer.Hide(self.heightLabel)
-            self.sizer.Hide(self.heightTxt)
-            self.sizer.Remove(self.widthLabel)
-            self.sizer.Remove(self.widthTxt)
-            self.sizer.Remove(self.heightLabel)
-            self.sizer.Remove(self.heightTxt)
-        except:
-            pass
-	if event.GetInt() == 0:
-	    self.widthLabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-            self.widthTxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
-            self.sizer.Add(item = self.widthLabel, border=5, pos=(3, 1),
-            self.sizer.Add(item = self.widthTxt, border=5, pos=(3, 2),
-            self.heightLabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-            self.heightTxt = wx.TextCtrl(parent = self, id = wx.ID_ANY, size=(250, -1))
-            self.sizer.Add(item = self.heightLabel, border=5, pos=(4, 1),
-            self.sizer.Add(item = self.heightTxt, border=5, pos=(4, 2),
-	elif event.GetInt() == 1:
-                                   label = _('What radius size (in meters)? '))
-                                   label = _('Name of the circle mask'))
+        self.OnType(None)
-    def OnMethod(self,event):
-                # exit a window asking "What number of sampling units to use"
-            print "Random non overlapping"
-                # no window more
-            print "Systematic contiguos"
-                # exit a window asking "Insert distance between units"
-            print "Stratified random"
-        elif event.GetInt() == 3:
-                # exit a window asking "Insert number of row strates" and "Insert number of column strates"
-            print "Systematic non contiguos"
-        elif event.GetInt() == 4:
-            print "Centered over sites"
+    def OnType(self, event):
+        chosen = self.typeBox.GetSelection()
+        self.widthLabel.SetLabel(self.widthLabels[chosen])
+        self.heightLabel.SetLabel(self.heightLabels[chosen])
+        self.panelSizer.Layout()
+        if chosen == 0:
+            self.boxtype = 'rectangle'
+        else:
+            self.boxtype = 'circle'
+    def OnDistr(self, event):
+        chosen = self.distributionBox.GetSelection()
+        if chosen == 0:
+            self.distrtype = 'non_overlapping'
+            self.distr1Label.SetLabel(_("What number of Sampling Units to use?"))
+            self.panelSizer.Show(self.distr1Txt)
+            self.distr2Label.SetLabel("")
+        elif chosen == 1:
+            self.distrtype = 'systematic_contiguos'
+            self.distr1Label.SetLabel("")
+            self.panelSizer.Hide(self.distr1Txt)
+        elif chosen == 2:
+            self.distrtype = 'stratified_random'
+            self.distr1Label.SetLabel(_("Insert number of row strates"))
+            self.distr2Label.SetLabel(_("Insert number of column strates"))
+            self.panelSizer.Show(self.distr2Txt)
+        elif chosen == 3:
+            self.distrtype = 'systematic_noncontiguos'
+            self.distr1Label.SetLabel(_("Insert distance between units"))
+        elif chosen == 4:
+            self.distrtype = 'centered_oversites'
+    def OnWidth(self, event):
+        self.width = event.GetString()
+    def OnHeight(self, event):
+        self.height = event.GetString()
 class MovingWindows(TitledPage):
@@ -814,151 +914,159 @@
-        self.sizew = ''
-        self.sizeh = ''
+        self.width = ''
+        self.height = ''
+        self.boxtype = ''
         # type of shape
         self.typeBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
                                       choices=[_('Rectangle'), _('Circle')],
+                                      majorDimension=1,
+                                      style=wx.RA_SPECIFY_COLS)
-        self.sizer.Add(self.typeBox, flag = wx.ALIGN_LEFT, pos = (1, 1))
+        self.sizer.Add(self.typeBox, flag=wx.ALIGN_LEFT, pos=(1, 1))
-                                   label = _('Width size (in cells) ?'))
-        wx.CallAfter(self.widthLabel.SetFocus)
-        self.sizer.Add(item = self.widthLabel, border=5, pos=(2, 1),
+        self.widthLabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                        label=_('Width size (in cells) ?'))
+        self.widthTxt = wx.TextCtrl(parent=self, id=wx.ID_ANY, size=(250, -1))
+        self.sizer.Add(item=self.widthLabel, border=5, pos=(2, 1),
-        self.sizer.Add(item = self.widthTxt, border=5, pos=(2, 2),
+        self.sizer.Add(item=self.widthTxt, border=5, pos=(2, 2),
-                                label = _('Height size (in cells) ?'))
-        wx.CallAfter(self.heightTxt.SetFocus)
-        self.sizer.Add(item = self.heightLabel, border=5, pos=(3, 1),
-        self.sizer.Add(item = self.heightTxt, border=5, pos=(3, 2),
-    def OnEnterPage(self,event):
-        try:
-        except:
-            pass
-        try:
-            self.sizer.Hide(self.distributionBox)
-            self.sizer.Remove(self.distributionBox)
-        except:
-            pass
-                                   label = _('Width size (in cells)?)'))
+        self.heightLabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                         label=_('Height size (in cells) ?'))
+        self.heightTxt = wx.TextCtrl(parent=self, id=wx.ID_ANY, size=(250, -1))
+        self.sizer.Add(item=self.heightLabel, border=5, pos=(3, 1),
-                                   label = _('Height size (in cells)?)'))
+        self.sizer.Add(item=self.heightTxt, border=5, pos=(3, 2),
-                                   label = _('What radius size (in meters)?)'))
+    def OnEnterPage(self, event):
+        self.OnType(None)
+        if chosen == 0:
+        else:
 class SummaryPage(TitledPage):
     """!Shows summary result of choosing data"""
     def __init__(self, wizard, parent):
         TitledPage.__init__(self, wizard, _("Summary"))
         global rlisettings
+        self.sizer.AddGrowableCol(2)
         #configuration file name
-        self.conflabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Configuration file name:'))
-        self.conftxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = "")
-        self.sizer.Add(item = self.conflabel, border=5, pos=(1, 1),
+        self.conflabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                       label=_('Configuration file name:'))
+        self.conftxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                     label="")
+        self.sizer.Add(item=self.conflabel, border=5, pos=(0, 0),
-        self.sizer.Add(item = self.conftxt, border=5, pos=(1, 2),
+        self.sizer.Add(item=self.conftxt, border=5, pos=(0, 1),
         #raster name
-        self.rastlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Raster name:'))
-        self.rasttxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = "")
-        self.sizer.Add(item = self.rastlabel, border=5, pos=(2, 1),
+        self.rastlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                       label=_('Raster name:'))
+        self.rasttxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                     label="")
+        self.sizer.Add(item=self.rastlabel, border=5, pos=(1, 0),
+        self.sizer.Add(item=self.rasttxt, border=5, pos=(1, 1),
+        #vector name
+        self.vectlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                        label=_('Vector name:'))
+        self.vecttxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                        label="")
+        self.sizer.Add(item=self.vectlabel, border=5, pos=(2, 0),
-        self.sizer.Add(item = self.rasttxt, border=5, pos=(2, 2),
+        self.sizer.Add(item=self.vecttxt, border=5, pos=(2, 1),
         #region type name
-        self.regionlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = _('Region type:'))
-        self.regiontxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-                        label = "")
-        self.sizer.Add(item = self.regionlabel, border=5, pos=(4, 1),
+        self.regionlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                        label=_('Region type:'))
+        self.regiontxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                        label="")
+        self.sizer.Add(item=self.regionlabel, border=5, pos=(3, 0),
-        self.sizer.Add(item = self.regiontxt, border=5, pos=(4, 2),
+        self.sizer.Add(item=self.regiontxt, border=5, pos=(3, 1),
-	self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
-	#sampling area
-	self.samplinglabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = _('Sampling area type:'))
-	self.samplingtxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-					  label = "")
-	self.sizer.Add(item = self.samplinglabel, border=5, pos=(6, 1),
+        #region keyboard
+        self.regionkeylabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                            label="")
+        self.regionkeytxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                          label="")
+        self.sizer.Add(item=self.regionkeylabel, border=5, pos=(4, 0),
-	self.sizer.Add(item = self.samplingtxt, border=5, pos=(6, 2),
+        self.sizer.Add(item=self.regionkeytxt, border=5, pos=(4, 1),
+        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
+        #sampling area
+        self.samplinglabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                           label=_('Sampling area type:'))
+        self.samplingtxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                         label="")
+        self.sizer.Add(item=self.samplinglabel, border=5, pos=(5, 0),
+        self.sizer.Add(item=self.samplingtxt, border=5, pos=(5, 1),
+        #shapetype
+        self.shapelabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                        label="")
+        self.shapetxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                      label="")
+        self.sizer.Add(item=self.shapelabel, border=5, pos=(6, 0),
+        self.sizer.Add(item=self.shapetxt, border=5, pos=(6, 1),
+        #shapedim
+        self.shapewidthlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                        label="")
+        self.shapewidthtxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                      label="")
+        self.sizer.Add(item=self.shapewidthlabel, border=5, pos=(7, 0),
+        self.sizer.Add(item=self.shapewidthtxt, border=5, pos=(7, 1),
+        self.shapeheightlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                        label="")
+        self.shapeheighttxt = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                      label="")
+        self.sizer.Add(item=self.shapeheightlabel, border=5, pos=(8, 0),
+        self.sizer.Add(item=self.shapeheighttxt, border=5, pos=(8, 1),
@@ -966,58 +1074,59 @@
         self.conftxt.SetLabel(self.parent.startpage.conf_name)
         self.rasttxt.SetLabel(self.parent.startpage.rast)
-        self.samplingtxt.SetLabel(self.parent.samplingareapage.samplingtype)
+        self.samplingtxt.SetLabel(self.parent.samplingareapage.samplingtype)
         self.regiontxt.SetLabel(self.parent.startpage.region)
-        try:
-            #try to remove label and text of vector and region key
-            self.sizer.Hide(self.vectlabel)
-            self.sizer.Hide(self.vecttxt)
-            self.sizer.Remove(self.vectlabel)
-            self.sizer.Remove(self.vecttxt)
-            self.sizer.Hide(self.regionkeylabel)
-            self.sizer.Hide(self.regionkeytxt)
-            self.sizer.Remove(self.regionkeylabel)
-            self.sizer.Remove(self.regionkeytxt)
-        except:
-            pass
-            #vector name
-            self.vectlabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                                label = _('Vector name:'))
-            self.vecttxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-                                label = "")
-            self.sizer.Add(item = self.vectlabel, border=5, pos=(3, 1),
-            self.sizer.Add(item = self.vecttxt, border=5, pos=(3, 2),
-            self.vecttxt.SetLabel(self.parent.startpage.vect)
-        if self.parent.startpage.region == 'key':
+        self.vecttxt.SetLabel(self.parent.startpage.vect)
+        if self.parent.startpage.region == 'key':
             #region keybord values
-            self.regionkeylabel = wx.StaticText(parent = self, id = wx.ID_ANY,
-                                label = _('Region keybord values:'))
-            self.regionkeytxt = wx.StaticText(parent = self, id = wx.ID_ANY,
-                                label = "")
-            self.sizer.Add(item = self.regionkeylabel, border=5, pos=(5, 1),
-            self.sizer.Add(item = self.regionkeytxt, border=5, pos=(5, 2),
-            regKeyVals = "Column left up: %s - Row left up: %s\nColumn length: %s - Row length: %s\n" \
-                    % (self.parent.keyboardpage.col_up, self.parent.keyboardpage.row_up,
-                    self.parent.keyboardpage.col_len, self.parent.keyboardpage.row_len)
+            self.regionkeylabel.SetLabel(_('Region keybord values:'))
+            regKeyVals = "Column left up: %s - Row left up: %s\n" \
+                         "Column length: %s - Row length: %s\n" % (
+                         self.parent.keyboardpage.col_up,
+                         self.parent.keyboardpage.row_up,
+                         self.parent.keyboardpage.col_len,
+                         self.parent.keyboardpage.row_len)
             self.regionkeytxt.SetLabel(regKeyVals)
+        else:
+            self.regionkeylabel.SetLabel("")
+            self.regionkeytxt.SetLabel("")
+        if self.parent.samplingareapage.samplingtype == 'units':
+            self.shapelabel.SetLabel(_('Type of shape:'))
+            self.shapetxt.SetLabel(self.parent.units.boxtype)
+            if self.parent.units.boxtype == 'circle':
+                self.shapewidthlabel.SetLabel(_("Radius size:"))
+                self.shapeheightlabel.SetLabel(_("Name circle mask:"))
+            else:
+                self.shapewidthlabel.SetLabel(_("Width size:"))
+                self.shapeheightlabel.SetLabel(_("Heigth size:"))
+            self.shapewidthtxt.SetLabel(self.parent.units.width)
+            self.shapeheighttxt.SetLabel(self.parent.units.height)
+        elif self.parent.samplingareapage.samplingtype == 'moving':
+            self.shapetxt.SetLabel(self.parent.moving.boxtype)
+            if self.parent.moving.boxtype == 'circle':
+            else:
+            self.shapewidthtxt.SetLabel(self.parent.moving.width)
+            self.shapeheighttxt.SetLabel(self.parent.moving.height)
+        else:
+            self.shapelabel.SetLabel("")
+            self.shapetxt.SetLabel("")
+            self.shapewidthlabel.SetLabel("")
+            self.shapewidthtxt.SetLabel("")
+            self.shapeheightlabel.SetLabel("")
+            self.shapeheighttxt.SetLabel("")
 if __name__ == "__main__":
     import gettext
-    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'),
+                    unicode=True)
     app = wx.App(0)
-    frame = RLiSetupFrame(parent = None)
+    frame = RLiSetupFrame(parent=None)
     frame.Show()
-    app.MainLoop()
+    app.MainLoop()
\ No newline at end of file
