[GRASS-SVN] r53310 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Wed Oct 3 10:22:46 PDT 2012
Author: pkelly
Date: 2012-10-03 10:22:45 -0700 (Wed, 03 Oct 2012)
New Revision: 53310
grass/trunk/general/g.proj/main.c
Rename datumtrans= option to datum_trans= as suggested by Glynn. Add
key_desc values for epsg(=code) and datum_trans(=index) options.
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2012-10-03 15:44:08 UTC (rev 53309)
+++ grass/trunk/general/g.proj/main.c 2012-10-03 17:22:45 UTC (rev 53310)
@@ -151,6 +151,7 @@
inepsg = G_define_option();
inepsg->key = "epsg";
inepsg->type = TYPE_INTEGER;
+ inepsg->key_desc = "code";
inepsg->required = NO;
inepsg->options = "1-1000000";
inepsg->guisection = _("Specification");
@@ -169,8 +170,9 @@
_("Accepts standard GRASS datum codes, or \"list\" to list and exit");
dtrans = G_define_option();
- dtrans->key = "datumtrans";
+ dtrans->key = "datum_trans";
dtrans->type = TYPE_INTEGER;
+ dtrans->key_desc = "index";
dtrans->required = NO;
dtrans->options = "-1-100";
dtrans->answer = "0";
