[GRASS-SVN] r53311 - in grass/branches/develbranch_6/gui/wxpython: gui_core lmgr xml
Thu Oct 4 06:24:33 PDT 2012
Author: martinl
Date: 2012-10-04 06:24:33 -0700 (Thu, 04 Oct 2012)
New Revision: 53311
   grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py
   grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: #1743 (WXGUI About GRASS dialog should allow to copy version information)
       (merge r53292 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py	2012-10-03 17:22:45 UTC (rev 53310)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/ghelp.py	2012-10-04 13:24:33 UTC (rev 53311)
@@ -388,7 +388,7 @@
         # icon
         self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
         # get version and web site
         vInfo = grass.version()
@@ -425,7 +425,7 @@
         row += 2
         infoGridSizer.Add(item = wx.StaticText(parent = infoTxt, id = wx.ID_ANY,
-                                               label = _('SVN Revision:')),
+                                               label = '%s:' % _('SVN Revision')),
                           pos = (row, 0),
                           flag = wx.ALIGN_RIGHT)
@@ -436,7 +436,7 @@
         row += 1
-                                               label = _('GIS Library Revision:')),
+                                               label = '%s:' % _('GIS Library Revision')),
                           pos = (row, 0),
@@ -448,7 +448,7 @@
         row += 2
-                                               label = _('Python:')),
+                                               label = 'Python:'),
                           pos = (row, 0),
@@ -459,7 +459,7 @@
         row += 1
-                                               label = _('wxPython:')),
+                                               label =  'wxPython:'),
                           pos = (row, 0),
@@ -474,7 +474,7 @@
         row += 2
-                                               label = _('Language:')),
+                                               label = "%s:" % _('Language')),
                           pos = (row, 0),
         lang = grass.gisenv().get('LANG', None)
Modified: grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py
--- grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py	2012-10-03 17:22:45 UTC (rev 53310)
+++ grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py	2012-10-04 13:24:33 UTC (rev 53311)
@@ -22,6 +22,7 @@
 import os
 import tempfile
 import stat
+import platform
 try:
     import xml.etree.ElementTree as etree
 except ImportError:
@@ -736,6 +737,23 @@
                                             lcmd = ['d.vect', 'map=%s' % name])
         dlg.Destroy()
+    def OnSystemInfo(self, event):
+        """!Print system information"""
+        vInfo = grass.version()
+        self.goutput.WriteLog("%s: %s\n"
+                              "%s: %s\n"
+                              "%s: %s (%s)\n"
+                              "Python: %s\n"
+                              "wxPython: %s\n"
+                              "%s: %s\n"% (_("GRASS version"), vInfo['version'],
+                                           _("GRASS SVN Revision"), vInfo['revision'],
+                                           _("GIS Library Revision"), vInfo['libgis_revision'], vInfo['libgis_date'].split(' ', 1)[0],
+                                           platform.python_version(),
+                                           wx.__version__,
+                                           _("Platform"), platform.platform()),
+                              switchPage = True)
     def OnAboutGRASS(self, event):
         """!Display 'About GRASS' dialog"""
         win = AboutWindow(self)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2012-10-03 17:22:45 UTC (rev 53310)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2012-10-04 13:24:33 UTC (rev 53311)
@@ -3165,6 +3165,11 @@
         </menuitem>
         <separator />
         <menuitem>
+          <label>About system</label>
+          <help>Prints system information</help>
+          <handler>OnSystemInfo</handler>
+        </menuitem>
+        <menuitem>
           <label>About GRASS GIS</label>
           <help>About GRASS GIS</help>
           <handler>OnAboutGRASS</handler>
