[GRASS-SVN] r53316 - grass/trunk/lib/python
svn_grass at osgeo.org
Thu Oct 4 23:08:01 PDT 2012
Author: cmbarton
Date: 2012-10-04 23:08:00 -0700 (Thu, 04 Oct 2012)
New Revision: 53316
grass/trunk/lib/python/core.py
core.create_location update to match new g.proj arguments
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2012-10-04 14:13:15 UTC (rev 53315)
+++ grass/trunk/lib/python/core.py 2012-10-05 06:08:00 UTC (rev 53316)
@@ -1191,7 +1191,7 @@
def create_location(dbase, location,
epsg = None, proj4 = None, filename = None, wkt = None,
- datum = None, desc = None):
+ datum = None, datum_trans = None, desc = None):
"""!Create new location
Raise ScriptError on error.
@@ -1202,7 +1202,8 @@
@param proj4 if given create new location based on Proj4 definition
@param filename if given create new location based on georeferenced file
@param wkt if given create new location based on WKT definition (path to PRJ file)
- @param datum datum transformation parameters (used for epsg and proj4)
+ @param datum GRASS format datum code
+ @param datum_trans datum transformation parameters (used for epsg and proj4)
@param desc description of the location (creates MYNAME file)
gisdbase = None
@@ -1216,6 +1217,8 @@
kwargs = dict()
if datum:
kwargs['datum'] = datum
+ if datum_trans:
+ kwargs['datum_trans'] = datum_trans
if epsg:
ps = pipe_command('g.proj',
