[GRASS-SVN] r53317 - grass/trunk/gui/wxpython/location_wizard
svn_grass at osgeo.org
Thu Oct 4 23:17:10 PDT 2012
Author: cmbarton
Date: 2012-10-04 23:17:09 -0700 (Thu, 04 Oct 2012)
New Revision: 53317
grass/trunk/gui/wxpython/location_wizard/wizard.py
wxgui location wizard: update location wizard to match updates to g.proj and core.create_location
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py 2012-10-05 06:08:00 UTC (rev 53316)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py 2012-10-05 06:17:09 UTC (rev 53317)
@@ -891,8 +891,10 @@
# proj4string = self.parent.CreateProj4String() + ' +datum=%s' % self.datum
ret = RunCommand('g.proj',
read = True,
- proj4 = '%s +datum=%s' % (proj, self.datum),
- datumtrans = '-1')
+ proj4 = '%s' % proj,
+ datum = '%s' % self.datum,
+ datum_trans = '-1')
+# wx.Messagebox('here')
if ret != '':
dtrans = ''
# open a dialog to select datum transform number
@@ -909,14 +911,14 @@
event.Veto()
return 'Datum transform is required.'
- self.parent.datumtrans = dtrans
+ self.parent.datum_trans = dtrans
self.GetNext().SetPrev(self)
self.parent.ellipsepage.ellipse = self.ellipse
self.parent.ellipsepage.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
def OnEnterPage(self,event):
- self.parent.datumtrans = None
+ self.parent.datum_trans = None
if event.GetDirection():
if len(self.datum) == 0:
# disable 'next' button by default when entering from previous page
@@ -1358,7 +1360,7 @@
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
def OnEnterPage(self, event):
if not self.epsgcode:
@@ -1381,7 +1383,7 @@
read = True,
epsg = self.epsgcode,
if ret != '':
dtrans = ''
@@ -1399,7 +1401,7 @@
event.Veto()
def OnText(self, event):
@@ -1533,7 +1535,7 @@
ret, out, err = RunCommand('g.proj',
read = True, getErrorMsg = True,
proj4 = self.customstring,
if ret != 0:
wx.MessageBox(parent = self,
message = err,
@@ -1558,7 +1560,7 @@
event.Veto()
return _('Datum transform is required.')
@@ -1662,7 +1664,8 @@
location = self.parent.startpage.location
epsgcode = self.parent.epsgpage.epsgcode
- dtrans = self.parent.datumtrans
+ datum = self.parent.datumpage.datum
+ dtrans = self.parent.datum_trans
global coordsys
if coordsys in ('proj', 'epsg'):
@@ -1670,7 +1673,8 @@
ret, projlabel, err = RunCommand('g.proj',
flags = 'jf',
proj4 = proj4string,
- datumtrans = dtrans,
+ datum = datum,
+ datum_trans = dtrans,
location = location,
getErrorMsg = True,
read = True)
@@ -1678,13 +1682,15 @@
flags = 'jf',
epsg = epsgcode,
getErrorMsg = True,
read = True)
finishButton = wx.FindWindowById(wx.ID_FORWARD)
if ret == 0:
+ if datum != '':
+ projlabel = projlabel + ' ' + 'datum=%s' % datum
self.lproj4string.SetLabel(projlabel.replace(' ', os.linesep))
finishButton.Enable(True)
else:
@@ -1755,7 +1761,7 @@
# datum transform number and list of datum transforms
- self.datumtrans = None
+ self.datum_trans = None
self.proj4string = ''
# file from which new location is created
@@ -2027,7 +2033,8 @@
grass.create_location(dbase = self.startpage.grassdatabase,
location = self.startpage.location,
proj4 = self.CreateProj4String(),
- datum = self.datumtrans,
+ datum = self.datumpage.datum,
+ datum_trans = self.datum_trans,
desc = self.startpage.locTitle)
elif coordsys == 'custom':
@@ -2041,7 +2048,8 @@
epsg = self.epsgpage.epsgcode,
elif coordsys == "file":
if not self.filepage.georeffile or \
@@ -2074,7 +2082,7 @@
projdesc = self.projpage.projdesc
proj4params = self.paramspage.p4projparams
- datum = self.datumpage.datum
+# datum = self.datumpage.datum
if self.datumpage.datumdesc:
datumdesc = self.datumpage.datumdesc +' - ' + self.datumpage.ellipse
else:
@@ -2099,9 +2107,7 @@
item = ' +' + item
proj4string = '%s %s' % (proj4string, item)
- # set datum and transform parameters if relevant
- if datum != '':
- proj4string = '%s +datum=%s' % (proj4string, datum)
+ # set datum transform parameters if relevant
if datumparams:
for item in datumparams:
proj4string = '%s +%s' % (proj4string,item)
