[GRASS-SVN] r53329 - in grass/trunk/scripts: m.proj r.out.xyz r.tileset r3.in.xyz v.in.lines
svn_grass at osgeo.org
Sun Oct 7 03:06:34 PDT 2012
Author: martinl
Date: 2012-10-07 03:06:34 -0700 (Sun, 07 Oct 2012)
New Revision: 53329
grass/trunk/scripts/m.proj/m.proj.py
grass/trunk/scripts/r.out.xyz/r.out.xyz.py
grass/trunk/scripts/r.tileset/r.tileset.py
grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
grass/trunk/scripts/v.in.lines/v.in.lines.py
Keys in `options` dictionary cannot be shortened. Patch provided by Stepan Turek.
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2012-10-06 22:14:49 UTC (rev 53328)
+++ grass/trunk/scripts/m.proj/m.proj.py 2012-10-07 10:06:34 UTC (rev 53329)
@@ -112,7 +112,7 @@
def main():
input = options['input']
output = options['output']
- fs = options['sep']
+ fs = options['separator']
proj_in = options['proj_input']
proj_out = options['proj_output']
ll_in = flags['i']
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2012-10-06 22:14:49 UTC (rev 53328)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2012-10-07 10:06:34 UTC (rev 53329)
@@ -37,7 +37,7 @@
# if no output filename, output to stdout
- ret = grass.run_command("r.stats", flags = "1gn", input = options['input'], sep = options['sep'], output = output)
+ ret = grass.run_command("r.stats", flags = "1gn", input = options['input'], sep = options['separator'], output = output)
sys.exit(ret)
if __name__ == "__main__":
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py 2012-10-06 22:14:49 UTC (rev 53328)
+++ grass/trunk/scripts/r.tileset/r.tileset.py 2012-10-07 10:06:34 UTC (rev 53329)
@@ -372,7 +372,7 @@
(tile_bbox['w'], tile_bbox['s'], tile_bbox['e'], tile_bbox['n'],
tile_size_overlap[0], tile_size_overlap[1])
else:
print "%s%s%s%s%s%s%s%s%s%s%s" % \
(tile_bbox['w'], fs, tile_bbox['s'], fs, tile_bbox['e'], fs, tile_bbox['n'], fs,
tile_size_overlap[0], fs, tile_size_overlap[1])
Modified: grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
--- grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py 2012-10-06 22:14:49 UTC (rev 53328)
+++ grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py 2012-10-07 10:06:34 UTC (rev 53329)
@@ -190,7 +190,7 @@
method = options['method']
dtype = options['type']
x = options['x']
y = options['y']
z = options['z']
Modified: grass/trunk/scripts/v.in.lines/v.in.lines.py
--- grass/trunk/scripts/v.in.lines/v.in.lines.py 2012-10-06 22:14:49 UTC (rev 53328)
+++ grass/trunk/scripts/v.in.lines/v.in.lines.py 2012-10-07 10:06:34 UTC (rev 53329)
@@ -44,7 +44,7 @@
def main():
global tmp
threeD = flags['z']
prog = 'v.in.lines'
