[GRASS-SVN] r53347 - in grass-addons/grass7/raster: . r.in.wms2
svn_grass at osgeo.org
Tue Oct 9 14:50:21 PDT 2012
Author: turek
Date: 2012-10-09 14:50:21 -0700 (Tue, 09 Oct 2012)
New Revision: 53347
Added:
grass-addons/grass7/raster/r.in.wms2/
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py
Removed:
grass-addons/grass7/raster/r.in.wms/
grass-addons/grass7/raster/r.in.wms2/r.in.wms.html
grass-addons/grass7/raster/r.in.wms2/r.in.wms.py
grass-addons/grass7/raster/Makefile
grass-addons/grass7/raster/r.in.wms2/Makefile
r.in.wms -> r.in.wms2, Makefiles modified
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile 2012-10-09 21:20:55 UTC (rev 53346)
+++ grass-addons/grass7/raster/Makefile 2012-10-09 21:50:21 UTC (rev 53347)
@@ -7,6 +7,7 @@
r.fuzzy \
r.hydrodem \
r.in.srtm.region \
+ r.in.wms2 \
r.modis \
r.regression.multi \
r.regression.series \
Modified: grass-addons/grass7/raster/r.in.wms2/Makefile
--- grass-addons/grass7/raster/r.in.wms/Makefile 2012-10-09 21:20:55 UTC (rev 53346)
+++ grass-addons/grass7/raster/r.in.wms2/Makefile 2012-10-09 21:50:21 UTC (rev 53347)
@@ -1,20 +1,18 @@
MODULE_TOPDIR = ../..
-PGM = r.in.wms
+PGM = r.in.wms2
+MODULES = wms_base wms_drv wms_gdal_drv
+PYFILES := $(patsubst %,$(ETC)/%.py,$(MODULES))
+PYCFILES := $(patsubst %,$(ETC)/%.pyc,$(MODULES))
include $(MODULE_TOPDIR)/include/Make/Script.make
include $(MODULE_TOPDIR)/include/Make/Python.make
-ETCDIR = $(ETC)/r.in.wms
-MODULES = wms_base wms_drv wms_gdal_drv
-PYFILES := $(patsubst %,$(ETCDIR)/%.py,$(MODULES))
-PYCFILES := $(patsubst %,$(ETCDIR)/%.pyc,$(MODULES))
default: script $(PYFILES) $(PYCFILES)
$(ETCDIR):
$(MKDIR) $@
-$(ETCDIR)/%: % | $(ETCDIR)
+$(ETC)/%: % | $(ETC)
$(INSTALL_DATA) $< $@
Deleted: grass-addons/grass7/raster/r.in.wms2/r.in.wms.html
--- grass-addons/grass7/raster/r.in.wms/r.in.wms.html 2012-10-09 21:20:55 UTC (rev 53346)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms.html 2012-10-09 21:50:21 UTC (rev 53347)
@@ -1,76 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.in.wms</em> handles all of downloading and importing raster
-data from an <a href="http://www.opengeospatial.org/standards/wms">OGC
-WMS</a> web mapping server. It need only be told the desired data to
-collect (bounds and resolution) via a region, the server to get the
-data from, and the layer or layers to get. It downloads the data in
-tiles, reprojects it, imports it, and patches it back together.
-<h2>NOTES</h2>
-By default data is downloaded to <tt>$GISDBASE/wms_download</tt>. This can be changed
-by setting the <b>folder</b> option when using <em>r.in.wms</em>.
-<p>To understand the data you are getting it is necessary to look at the
-capabilities of the WMS server. This should be available via a capabilities
-request. This is an
-<a href="http://wms.jpl.nasa.gov/wms.cgi?request=GetCapabilities">example
-capabilities request to NASA's OnEarth server</a>.
-<h2>EXAMPLES</h2>
-<h3>General Get Capabilities Request</h3>
-<div class="code"><pre>
-r.in.wms -c mapserver=http://wms.cuzk.cz/wms.asp
-</pre></div>
-<h3>CUZK download</h3>
-World extend data:
-r.in.wms mapserver=http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms layers=bluemarble,landsat_1_01 styles=default,default output=landsat srs=4326 format=png
-</pre></div>
-* Server supports only WMS 1.1.1 <br>
-r.in.wms mapserver=http://132.156.97.59/cgi-bin/worldmin_en-ca_ows layers=GSC:WORLD_PrecambrianDomains output=pokus srs=4326 format=jpeg
-</pre></div>
-<br>
-<br>
-Data in extend of Czech Republic:
-r.in.wms output=kn mapserver=http://wms.cuzk.cz/wms.asp layers=prehledka_kraju-linie srs=4326 format=png
-</pre></div>
-<h2>TODO</h2>
-<ul>
- <li>Implement Tiled WMS</li>
-</ul>
-<h2>SEE ALSO</h2>
-<em>
- <a href="r.in.gdal.html">r.in.gdal</a>,
- <a href="r.patch.html">r.patch</a>,
- <a href="r.colors.html">r.colors</a>,
- <a href="r.composite.html">r.composite</a>,
- <a href="v.in.wfs.html">v.in.wfs</a>
-</em>
-<h2>AUTHORS</h2>
-Stepan Turek, Czech Technical University in Prague, Czech Republic (bachelor's final project 2012, mentor: Martin Landa)
-<p>
-<i>Last changed: $Date$</i>
Deleted: grass-addons/grass7/raster/r.in.wms2/r.in.wms.py
--- grass-addons/grass7/raster/r.in.wms/r.in.wms.py 2012-10-09 21:20:55 UTC (rev 53346)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms.py 2012-10-09 21:50:21 UTC (rev 53347)
@@ -1,163 +0,0 @@
-#!/usr/bin/env python
-MODULE: r.in.wms
-AUTHOR(S): Stepan Turek <stepan.turek AT seznam.cz>
-PURPOSE: Downloads and imports data from WMS server.
-COPYRIGHT: (C) 2012 Stepan Turek, and by the GRASS Development Team
-This program is free software under the GNU General Public License
-(>=v2). Read the file COPYING that comes with GRASS for details.
-#%module
-#% description: Downloads and imports data from WMS servers.
-#% keywords: raster
-#% keywords: import
-#% keywords: wms
-#%end
-#%option
-#% key: mapserver
-#% type: string
-#% description:URL of WMS server
-#% required: yes
-#%end
-#%option
-#% key: layers
-#% type: string
-#% description: Layers to request from map server
-#% multiple: yes
-#% required: yes
-#%end
-#%option G_OPT_R_OUTPUT
-#% description: Name for output raster map
-#%end
-#%option
-#% key: srs
-#% type: integer
-#% description: EPSG number of source projection for request
-#% guisection: Request properties
-#%end
-#%option
-#% key: region
-#% type: string
-#% description: Named region to request data for. Current region used if omitted
-#%end
-#%option
-#% key: wms_version
-#% type:string
-#% description:WMS standard
-#% options:1.1.1,1.3.0
-#% answer:1.1.1
-#%end
-#%option
-#% key: format
-#% type: string
-#% description: Image format requested from the server
-#% options: geotiff,tiff,jpeg,gif,png
-#% answer: geotiff
-#%end
-#%option
-#% key: method
-#% type: string
-#% description: Reprojection method to use
-#% options:near,bilinear,cubic,cubicspline
-#% answer:near
-#%end
-#%option
-#% key: maxcols
-#% type:integer
-#% description: Maximum columns to request at a time
-#% answer:400
-#%end
-#%option
-#% key: maxrows
-#% type: integer
-#% description: Maximum rows to request at a time
-#% answer: 300
-#%end
-#%option
-#% key: urlparams
-#% type:string
-#% description: Addition query parameters for server (only with 'd' flag)
-#%end
-#%option
-#% key: styles
-#% type: string
-#% description: Styles to request from map server
-#% multiple: yes
-#% guisection: Map style
-#%end
-#%option
-#% key: bgcolor
-#% type: string
-#% description: Color of map background (only with 'd' flag)
-#%end
-#%flag
-#% key: o
-#% description: Don't request transparent data
-#%end
-#%flag
-#% key: c
-#% description: Get capabilities
-#% suppress_required: yes
-#%end
-#%flag
-#% key: d
-#% description: Do not use GDAL WMS driver
-#%end
-import os
-import sys
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'r.in.wms'))
-import grass.script as grass
-def main():
- if flags['d']:
- grass.debug("Using own driver")
- from wms_drv import WMSDrv
- wms = WMSDrv()
- else:
- grass.debug("Using GDAL WMS driver")
- from wms_gdal_drv import WMSGdalDrv
- wms = WMSGdalDrv()
- if flags['c']:
- wms.GetCapabilities(options)
- else:
- wms.GetMap(options, flags)
- return 0
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
Copied: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html (from rev 53346, grass-addons/grass7/raster/r.in.wms/r.in.wms.html)
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html (rev 0)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html 2012-10-09 21:50:21 UTC (rev 53347)
@@ -0,0 +1,76 @@
+<h2>DESCRIPTION</h2>
+<em>r.in.wms</em> handles all of downloading and importing raster
+data from an <a href="http://www.opengeospatial.org/standards/wms">OGC
+WMS</a> web mapping server. It need only be told the desired data to
+collect (bounds and resolution) via a region, the server to get the
+data from, and the layer or layers to get. It downloads the data in
+tiles, reprojects it, imports it, and patches it back together.
+<h2>NOTES</h2>
+By default data is downloaded to <tt>$GISDBASE/wms_download</tt>. This can be changed
+by setting the <b>folder</b> option when using <em>r.in.wms</em>.
+<p>To understand the data you are getting it is necessary to look at the
+capabilities of the WMS server. This should be available via a capabilities
+request. This is an
+<a href="http://wms.jpl.nasa.gov/wms.cgi?request=GetCapabilities">example
+capabilities request to NASA's OnEarth server</a>.
+<h2>EXAMPLES</h2>
+<h3>General Get Capabilities Request</h3>
+<div class="code"><pre>
+r.in.wms -c mapserver=http://wms.cuzk.cz/wms.asp
+</pre></div>
+<h3>CUZK download</h3>
+World extend data:
+r.in.wms mapserver=http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms layers=bluemarble,landsat_1_01 styles=default,default output=landsat srs=4326 format=png
+</pre></div>
+* Server supports only WMS 1.1.1 <br>
+r.in.wms mapserver=http://132.156.97.59/cgi-bin/worldmin_en-ca_ows layers=GSC:WORLD_PrecambrianDomains output=pokus srs=4326 format=jpeg
+</pre></div>
+<br>
+<br>
+Data in extend of Czech Republic:
+r.in.wms output=kn mapserver=http://wms.cuzk.cz/wms.asp layers=prehledka_kraju-linie srs=4326 format=png
+</pre></div>
+<h2>TODO</h2>
+<ul>
+ <li>Implement Tiled WMS</li>
+</ul>
+<h2>SEE ALSO</h2>
+<em>
+ <a href="r.in.gdal.html">r.in.gdal</a>,
+ <a href="r.patch.html">r.patch</a>,
+ <a href="r.colors.html">r.colors</a>,
+ <a href="r.composite.html">r.composite</a>,
+ <a href="v.in.wfs.html">v.in.wfs</a>
+</em>
+<h2>AUTHORS</h2>
+Stepan Turek, Czech Technical University in Prague, Czech Republic (bachelor's final project 2012, mentor: Martin Landa)
+<p>
+<i>Last changed: $Date$</i>
Copied: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py (from rev 53346, grass-addons/grass7/raster/r.in.wms/r.in.wms.py)
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py (rev 0)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py 2012-10-09 21:50:21 UTC (rev 53347)
@@ -0,0 +1,163 @@
+#!/usr/bin/env python
+MODULE: r.in.wms
+AUTHOR(S): Stepan Turek <stepan.turek AT seznam.cz>
+PURPOSE: Downloads and imports data from WMS server.
+COPYRIGHT: (C) 2012 Stepan Turek, and by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+#%module
+#% description: Downloads and imports data from WMS servers.
+#% keywords: raster
+#% keywords: import
+#% keywords: wms
+#%end
+#%option
+#% key: mapserver
+#% type: string
+#% description:URL of WMS server
+#% required: yes
+#%end
+#%option
+#% key: layers
+#% type: string
+#% description: Layers to request from map server
+#% multiple: yes
+#% required: yes
+#%end
+#%option G_OPT_R_OUTPUT
+#% description: Name for output raster map
+#%end
+#%option
+#% key: srs
+#% type: integer
+#% description: EPSG number of source projection for request
+#% guisection: Request properties
+#%end
+#%option
+#% key: region
+#% type: string
+#% description: Named region to request data for. Current region used if omitted
+#%end
+#%option
+#% key: wms_version
+#% type:string
+#% description:WMS standard
+#% options:1.1.1,1.3.0
+#% answer:1.1.1
+#%end
+#%option
+#% key: format
+#% type: string
+#% description: Image format requested from the server
+#% options: geotiff,tiff,jpeg,gif,png
+#% answer: geotiff
+#%end
+#%option
+#% key: method
+#% type: string
+#% description: Reprojection method to use
+#% options:near,bilinear,cubic,cubicspline
+#% answer:near
+#%end
+#%option
+#% key: maxcols
+#% type:integer
+#% description: Maximum columns to request at a time
+#% answer:400
+#%end
+#%option
+#% key: maxrows
+#% type: integer
+#% description: Maximum rows to request at a time
+#% answer: 300
+#%end
+#%option
+#% key: urlparams
+#% type:string
+#% description: Addition query parameters for server (only with 'd' flag)
+#%end
+#%option
+#% key: styles
+#% type: string
+#% description: Styles to request from map server
+#% multiple: yes
+#% guisection: Map style
+#%end
+#%option
+#% key: bgcolor
+#% type: string
+#% description: Color of map background (only with 'd' flag)
+#%end
+#%flag
+#% key: o
+#% description: Don't request transparent data
+#%end
+#%flag
+#% key: c
+#% description: Get capabilities
+#% suppress_required: yes
+#%end
+#%flag
+#% key: d
+#% description: Do not use GDAL WMS driver
+#%end
+import os
+import sys
+sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'r.in.wms'))
+import grass.script as grass
+def main():
+ if flags['d']:
+ grass.debug("Using own driver")
+ from wms_drv import WMSDrv
+ wms = WMSDrv()
+ else:
+ grass.debug("Using GDAL WMS driver")
+ from wms_gdal_drv import WMSGdalDrv
+ wms = WMSGdalDrv()
+ if flags['c']:
+ wms.GetCapabilities(options)
+ else:
+ wms.GetMap(options, flags)
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
