[GRASS-SVN] r53348 - grass-addons/grass7/raster/r.in.wms2
svn_grass at osgeo.org
Tue Oct 9 15:02:55 PDT 2012
Author: turek
Date: 2012-10-09 15:02:55 -0700 (Tue, 09 Oct 2012)
New Revision: 53348
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py
grass-addons/grass7/raster/r.in.wms2/wms_base.py
grass-addons/grass7/raster/r.in.wms2/wms_drv.py
grass-addons/grass7/raster/r.in.wms2/wms_gdal_drv.py
r.in.wms2: WMTS support added
Modified: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html 2012-10-09 21:50:21 UTC (rev 53347)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.html 2012-10-09 22:02:55 UTC (rev 53348)
@@ -1,8 +1,9 @@
<h2>DESCRIPTION</h2>
-<em>r.in.wms</em> handles all of downloading and importing raster
+<em>r.in.wms2</em> handles all of downloading and importing raster
data from an <a href="http://www.opengeospatial.org/standards/wms">OGC
-WMS</a> web mapping server. It need only be told the desired data to
+WMS</a> and <a href="http://www.opengeospatial.org/standards/wmts">OGC
+WMTS</a> web mapping servers. It need only be told the desired data to
collect (bounds and resolution) via a region, the server to get the
data from, and the layer or layers to get. It downloads the data in
tiles, reprojects it, imports it, and patches it back together.
@@ -25,39 +26,43 @@
<h3>General Get Capabilities Request</h3>
<div class="code"><pre>
-r.in.wms -c mapserver=http://wms.cuzk.cz/wms.asp
+r.in.wms2 -c url=http://wms.cuzk.cz/wms.asp
</pre></div>
-<h3>CUZK download</h3>
+<h3>>Download raster data from WMS server (GetMap request)</h3>
World extend data:
-r.in.wms mapserver=http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms layers=bluemarble,landsat_1_01 styles=default,default output=landsat srs=4326 format=png
+r.in.wms2 url=http://iceds.ge.ucl.ac.uk/cgi-bin/icedswms layers=bluemarble,landsat_1_01 styles=default,default output=landsat srs=4326 format=png
</pre></div>
* Server supports only WMS 1.1.1 <br>
-r.in.wms mapserver=http://132.156.97.59/cgi-bin/worldmin_en-ca_ows layers=GSC:WORLD_PrecambrianDomains output=pokus srs=4326 format=jpeg
+r.in.wms2 url=http://132.156.97.59/cgi-bin/worldmin_en-ca_ows layers=GSC:WORLD_PrecambrianDomains output=pokus srs=4326 format=jpeg
</pre></div>
<br>
<br>
+<div class="code"><pre>
+r.in.wms2 url=http://gpp3-wxs.ign.fr/yourAPIkey/geoportail/wmts layers=ORTHOIMAGERY.ORTHOPHOTOS output=orthophoto srs=3857 format=jpeg driver=WMTS_GRASS style=normal password=* username=*
+</pre></div>
+* Username, password and API key can be get at <a href="http://api.ign.fr/">IGN API</a> website
+<br>
+<br>
Data in extend of Czech Republic:
-r.in.wms output=kn mapserver=http://wms.cuzk.cz/wms.asp layers=prehledka_kraju-linie srs=4326 format=png
+r.in.wms2 output=kn url=http://wms.cuzk.cz/wms.asp layers=prehledka_kraju-linie srs=4326 format=png
</pre></div>
+r.in.wms2 url=http://geoportal.cuzk.cz/WMTS_ORTOFOTO/WMTService.aspx layers=orto output=ortofoto srs=3857 format=jpeg driver=WMTS_GRASS style=default
+</pre></div>
-<h2>TODO</h2>
-<ul>
- <li>Implement Tiled WMS</li>
-</ul>
<h2>SEE ALSO</h2>
<em>
Modified: grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py
--- grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py 2012-10-09 21:50:21 UTC (rev 53347)
+++ grass-addons/grass7/raster/r.in.wms2/r.in.wms2.py 2012-10-09 22:02:55 UTC (rev 53348)
@@ -1,6 +1,6 @@
#!/usr/bin/env python
-MODULE: r.in.wms
+MODULE: r.in.wms2
AUTHOR(S): Stepan Turek <stepan.turek AT seznam.cz>
@@ -20,7 +20,7 @@
#%end
#%option
-#% key: mapserver
+#% key: url
#% type: string
#% description:URL of WMS server
#% required: yes
@@ -42,6 +42,7 @@
#% key: srs
#% type: integer
#% description: EPSG number of source projection for request
+#% answer:4326
#% guisection: Request properties
#%end
@@ -98,11 +99,25 @@
#%option
#% key: urlparams
#% type:string
-#% description: Addition query parameters for server (only with 'd' flag)
+#% description: Additional query parameters for server
#%end
#%option
+#% key: username
+#% type:string
+#% description: Username for server connection
+#% guisection: Request properties
+#%end
+#%option
+#% key: password
+#% type:string
+#% description: Password for server connection
+#%end
+#%option
#% key: styles
#% type: string
#% description: Styles to request from map server
@@ -113,7 +128,7 @@
#%option
#% key: bgcolor
#% type: string
-#% description: Color of map background (only with 'd' flag)
+#% description: Color of map background
#% guisection: Map style
#%end
@@ -130,23 +145,27 @@
#% suppress_required: yes
#%end
-#%flag
-#% key: d
-#% description: Do not use GDAL WMS driver
+#%option
+#% key: driver
+#% type:string
+#% description: Driver for communication with server
+#% options:WMS_GDAL, WMS_GRASS, WMTS_GRASS
+#% answer:WMS_GDAL
#%end
import os
import sys
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'r.in.wms'))
+sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'r.in.wms2'))
import grass.script as grass
def main():
- if flags['d']:
- grass.debug("Using own driver")
+ if 'GRASS' in options['driver']:
+ grass.debug("Using GRASS driver")
from wms_drv import WMSDrv
wms = WMSDrv()
- else:
+ elif 'GDAL' in options['driver']:
grass.debug("Using GDAL WMS driver")
from wms_gdal_drv import WMSGdalDrv
wms = WMSGdalDrv()
Modified: grass-addons/grass7/raster/r.in.wms2/wms_base.py
--- grass-addons/grass7/raster/r.in.wms2/wms_base.py 2012-10-09 21:50:21 UTC (rev 53347)
+++ grass-addons/grass7/raster/r.in.wms2/wms_base.py 2012-10-09 22:02:55 UTC (rev 53348)
@@ -1,8 +1,8 @@
import os
from math import ceil
-import xml.etree.ElementTree as etree
from urllib2 import urlopen, HTTPError, URLError
+from httplib import HTTPException
@@ -13,7 +13,9 @@
self.cleanup_mask = False
self.cleanup_layers = False
- self.bbox = None
+ self.params = {}
+ self.tile_size = {'bbox' : None}
self.temp_map = None
def __del__(self):
@@ -26,14 +28,14 @@
grass.fatal(_('%s failed') % 'r.mask')
# restore original mask, if exists
- if grass.find_file(self.o_output + self.original_mask_suffix, element = 'cell', mapset = '.' )['name']:
+ if grass.find_file(self.params['output'] + self.original_mask_suffix, element = 'cell', mapset = '.' )['name']:
if grass.run_command('g.copy',
quiet = True,
- rast = self.o_output + self.original_mask_suffix + ',MASK') != 0:
+ rast = self.params['output'] + self.original_mask_suffix + ',MASK') != 0:
grass.fatal(_('%s failed') % 'g.copy')
# tries to remove temporary files, all files should be
- # removoved before, implemented just in case of unexpected
+ # removed before, implemented just in case of unexpected
# stop of module
for temp_file in self.temp_files_to_cleanup:
grass.try_remove(temp_file)
@@ -42,7 +44,7 @@
if self.cleanup_layers:
maps = []
for suffix in ('.red', '.green', '.blue', '.alpha', self.original_mask_suffix):
- rast = self.o_output + suffix
+ rast = self.params['output'] + suffix
if grass.find_file(rast, element = 'cell', mapset = '.')['file']:
maps.append(rast)
@@ -52,7 +54,7 @@
flags = 'f',
rast = ','.join(maps))
- # deletes enviromental variable which overrides region
+ # deletes environmental variable which overrides region
if 'GRASS_REGION' in os.environ.keys():
os.environ.pop('GRASS_REGION')
@@ -63,100 +65,109 @@
def _initializeParameters(self, options, flags):
self._debug("_initialize_parameters", "started")
- # inicialization of module parameters (options, flags)
- self.flags = flags
- if self.flags['o']:
- self.transparent = 'FALSE'
+ # initialization of module parameters (options, flags)
+ self.params['driver'] = options['driver']
+ self.flags = flags
+ if self.flags['o'] and 'WMS' not in self.params['driver']:
+ grass.warning(_("Flag '%s' is relevant only for WMS.") % 'o')
+ elif self.flags['o']:
+ self.params['transparent'] = 'FALSE'
else:
- self.transparent = 'TRUE'
+ self.params['transparent'] = 'TRUE'
+ for key in ['url', 'layers', 'styles', 'output', 'method']:
+ self.params[key] = options[key].strip()
+ for key in ['password', 'username', 'urlparams']:
+ if self.params[key] != "" and 'GRASS' not in self.params['driver']:
+ grass.warning(_("Parameter '%s' is relevant only for %s drivers.") % (key, '*_GRASS'))
- self.o_mapserver_url = options['mapserver'].strip() + "?"
- self.o_layers = options['layers'].strip()
- self.o_styles = options['styles'].strip()
- self.o_output = options['output']
- self.o_method = options['method']
- self.o_bgcolor = options['bgcolor'].strip()
- if self.o_bgcolor != "" and not flags["d"]:
- grass.warning(_("Parameter bgcolor ignored, use -d flag"))
- self.o_urlparams = options['urlparams'].strip()
- if self.o_urlparams != "" and not flags["d"]:
- grass.warning(_("Parameter urlparams ignored, use -d flag"))
- self.o_wms_version = options['wms_version']
- if self.o_wms_version == "1.3.0":
- self.projection_name = "CRS"
+ self.params['bgcolor'] = options['bgcolor'].strip()
+ if self.params['bgcolor'] != "" and 'WMS_GRASS' not in self.params['driver']:
+ grass.warning(_("Parameter '%s' is relevant only for %s driver.") % ('bgcolor', 'WMS_GRASS'))
+ self.params['wms_version'] = options['wms_version']
+ if self.params['wms_version'] == "1.3.0":
+ self.params['proj_name'] = "CRS"
else:
- self.projection_name = "SRS"
+ self.params['proj_name'] = "SRS"
- self.o_format = options['format']
- if self.o_format == "geotiff":
- self.mime_format = "image/geotiff"
- elif self.o_format == "tiff":
- self.mime_format = "image/tiff"
- elif self.o_format == "png":
- self.mime_format = "image/png"
- elif self.o_format == "jpeg":
- self.mime_format = "image/jpeg"
+ if options['format'] == "geotiff":
+ self.params['format'] = "image/geotiff"
+ elif options['format'] == "tiff":
+ self.params['format'] = "image/tiff"
+ elif options['format'] == "png":
+ self.params['format'] = "image/png"
+ elif options['format'] == "jpeg":
+ self.params['format'] = "image/jpeg"
if flags['o']:
grass.warning(_("JPEG format does not support transparency"))
- elif self.o_format == "gif":
- self.mime_format = "image/gif"
+ elif self.params['format'] == "gif":
+ self.params['format'] = "image/gif"
else:
- self.mime_format = self.o_format
+ self.params['format'] = self.params['format']
- self.o_srs = int(options['srs'])
- if self.o_srs <= 0:
- grass.fatal(_("Invalid EPSG code %d") % self.o_srs)
+ self.params['srs'] = int(options['srs'])
+ if self.params['srs'] <= 0:
+ grass.fatal(_("Invalid EPSG code %d") % self.params['srs'])
# read projection info
self.proj_location = grass.read_command('g.proj',
flags ='jf').rstrip('\n')
- self.proj_srs = grass.read_command('g.proj',
- flags = 'jf',
- epsg = str(self.o_srs) ).rstrip('\n')
+ if self.params['srs'] in [3857, 900913]:
+ # HACK: epsg 3857 def: http://spatialreference.org/ref/sr-org/7483/
+ # g.proj can return: ...+a=6378137 +rf=298.257223563... (WGS84 elipsoid def instead of sphere), it can make 20km shift in Y, when raster is transformed
+ # needed to be tested on more servers
+ self.proj_srs = '+proj=merc +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +no_defs +a=6378137 +b=6378137 +nadgrids=@null +to_meter=1 +wktext'
+ else:
+ self.proj_srs = grass.read_command('g.proj',
+ flags = 'jf',
+ epsg = str(self.params['srs']) ).rstrip('\n')
if not self.proj_srs or not self.proj_location:
grass.fatal(_("Unable to get projection info"))
# set region
- self.o_region = options['region']
- if self.o_region:
- if not grass.find_file(name = self.o_region, element = 'windows', mapset = '.' )['name']:
- grass.fatal(_("Region <%s> not found") % self.o_region)
+ self.params['region'] = options['region']
+ if self.params['region']:
+ if not grass.find_file(name = self.params['region'], element = 'windows', mapset = '.' )['name']:
+ grass.fatal(_("Region <%s> not found") % self.params['region'])
- if self.o_region:
s = grass.read_command('g.region',
quiet = True,
flags = 'ug',
- region = self.o_region)
+ region = self.params['region'])
self.region = grass.parse_key_val(s, val_type = float)
else:
self.region = grass.region()
min_tile_size = 100
- self.o_maxcols = int(options['maxcols'])
- if self.o_maxcols <= min_tile_size:
+ maxcols = int(options['maxcols'])
+ if maxcols <= min_tile_size:
grass.fatal(_("Maxcols must be greater than 100"))
- self.o_maxrows = int(options['maxrows'])
- if self.o_maxrows <= min_tile_size:
+ maxrows = int(options['maxrows'])
+ if maxrows <= min_tile_size:
grass.fatal(_("Maxrows must be greater than 100"))
# setting optimal tile size according to maxcols and maxrows constraint and region cols and rows
- self.tile_cols = int(self.region['cols'] / ceil(self.region['cols'] / float(self.o_maxcols)))
- self.tile_rows = int(self.region['rows'] / ceil(self.region['rows'] / float(self.o_maxrows)))
+ self.tile_size['cols'] = int(self.region['cols'] / ceil(self.region['cols'] / float(maxcols)))
+ self.tile_size['rows'] = int(self.region['rows'] / ceil(self.region['rows'] / float(maxrows)))
# suffix for existing mask (during overriding will be saved
- # into raster named:self.o_output + this suffix)
+ # into raster named:self.params['output'] + this suffix)
self.original_mask_suffix = "_temp_MASK"
# check names of temporary rasters, which module may create
maps = []
for suffix in ('.red', '.green', '.blue', '.alpha', self.original_mask_suffix ):
maps.append(rast)
@@ -177,20 +188,35 @@
self.bbox = self._computeBbox()
- self.temp_map = self._download()
+ self.temp_map = self._download()
+ if not self.temp_map:
+ return
self._createOutputMap()
- def GetCapabilities(self, options):
- """!Get capabilities from WMS server
+ def _fetchCapabilities(self, options):
+ """!Download capabilities from WMS server
# download capabilities file
- cap_url = options['mapserver'] + "?service=WMS&request=GetCapabilities&version=" + options['wms_version']
+ cap_url = options['url']
+ if 'WMTS' in options['driver']:
+ cap_url += "?SERVICE=WMTS&REQUEST=GetCapabilities&VERSION=1.0.0"
+ else:
+ cap_url += "?SERVICE=WMS&REQUEST=GetCapabilities&VERSION=" + options['wms_version']
try:
cap = urlopen(cap_url)
- except IOError:
- grass.fatal(_("Unable to get capabilities from '%s'") % options['mapserver'])
+ except (IOError, HTTPError):
+ grass.fatal(_("Unable to get capabilities from '%s'") % options['url'])
+ return cap
+ def GetCapabilities(self, options):
+ """!Get capabilities from WMS server
+ cap = self._fetchCapabilities(options)
cap_lines = cap.readlines()
for line in cap_lines:
print line
@@ -228,7 +254,7 @@
grass.fatal(_("Unable to write data into tempfile"))
finally:
temp_region_opened.close()
points = grass.read_command('m.proj', flags = 'd',
proj_output = self.proj_srs,
proj_input = self.proj_location,
@@ -239,10 +265,13 @@
points = points.splitlines()
if len(points) != 4:
- grass.fatal(_("Region defintion: 4 points required"))
+ grass.fatal(_("Region definition: 4 points required"))
for point in points:
- point = map(float, point.split("|"))
+ try:
+ point = map(float, point.split("|"))
+ except ValueError:
+ grass.fatal(_('Reprojection of region using m.proj failed.'))
if not bbox['maxy']:
bbox['maxy'] = point[1]
bbox['miny'] = point[1]
@@ -263,16 +292,9 @@
self._debug("_computeBbox", "finished -> %s" % bbox)
# Ordering of coordinates axis of geographic coordinate
- # systems in WMS 1.3.0 is fliped. If self.flip_coords is
+ # systems in WMS 1.3.0 is flipped. If self.tile_size['flip_coords'] is
# True, coords in bbox need to be flipped in WMS query.
- self.flip_coords = False
- hasLongLat = self.proj_srs.find("+proj=longlat")
- hasLatLong = self.proj_srs.find("+proj=latlong")
- if (hasLongLat != -1 or hasLatLong != -1) and self.o_wms_version == "1.3.0":
- self.flip_coords = True
return bbox
def _createOutputMap(self):
@@ -289,19 +311,20 @@
else:
nuldev = None
+ #"+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"
# RGB rasters - alpha layer is added for cropping edges of projected raster
if self.temp_map_bands_num == 3:
ps = grass.Popen(['gdalwarp',
'-s_srs', '%s' % self.proj_srs,
'-t_srs', '%s' % self.proj_location,
- '-r', self.o_method, '-dstalpha',
+ '-r', self.params['method'], '-dstalpha',
self.temp_map, temp_warpmap], stdout = nuldev)
# RGBA rasters
else:
ps.wait()
@@ -319,7 +342,7 @@
if grass.run_command('r.in.gdal',
quiet = True,
input = temp_warpmap,
- output = self.o_output) != 0:
+ output = self.params['output']) != 0:
grass.fatal(_('%s failed') % 'r.in.gdal')
# information for destructor to cleanup temp_layers, created
@@ -327,17 +350,17 @@
self.cleanup_layers = True
# setting region for full extend of imported raster
- os.environ['GRASS_REGION'] = grass.region_env(rast = self.o_output + '.red')
+ os.environ['GRASS_REGION'] = grass.region_env(rast = self.params['output'] + '.red')
# mask created from alpha layer, which describes real extend
# of warped layer (may not be a rectangle), also mask contains
# transparent parts of raster
- if grass.find_file( self.o_output + '.alpha', element = 'cell', mapset = '.' )['name']:
+ if grass.find_file( self.params['output'] + '.alpha', element = 'cell', mapset = '.' )['name']:
# saving current mask (if exists) into temp raster
if grass.find_file('MASK', element = 'cell', mapset = '.' )['name']:
quiet = True,
- rast = 'MASK,' + self.o_output + self.original_mask_suffix) != 0:
+ rast = 'MASK,' + self.params['output'] + self.original_mask_suffix) != 0:
# info for destructor
@@ -347,39 +370,20 @@
overwrite = True,
maskcats = "0",
flags = 'i',
- input = self.o_output + '.alpha') != 0:
+ input = self.params['output'] + '.alpha') != 0:
if grass.run_command('r.composite',
quiet = True,
- red = self.o_output + '.red',
- green = self.o_output + '.green',
- blue = self.o_output + '.blue',
- output = self.o_output ) != 0:
+ red = self.params['output'] + '.red',
+ green = self.params['output'] + '.green',
+ blue = self.params['output'] + '.blue',
+ output = self.params['output'] ) != 0:
grass.fatal(_('%s failed') % 'r.composite')
grass.try_remove(temp_warpmap)
grass.try_remove(self.temp_map)
- def _flipBbox(self, bbox):
- flips items in dictionary
- value flips between this keys:
- maxy -> maxx
- maxx -> maxy
- miny -> minx
- minx -> miny
- @return copy of bbox with fliped cordinates
- temp_bbox = dict(bbox)
- new_bbox = {}
- new_bbox['maxy'] = temp_bbox['maxx']
- new_bbox['miny'] = temp_bbox['minx']
- new_bbox['maxx'] = temp_bbox['maxy']
- new_bbox['minx'] = temp_bbox['miny']
- return new_bbox
def _tempfile(self):
"""!Create temp_file and append list self.temp_files_to_cleanup
with path of file
Modified: grass-addons/grass7/raster/r.in.wms2/wms_drv.py
--- grass-addons/grass7/raster/r.in.wms2/wms_drv.py 2012-10-09 21:50:21 UTC (rev 53347)
+++ grass-addons/grass7/raster/r.in.wms2/wms_drv.py 2012-10-09 22:02:55 UTC (rev 53348)
@@ -1,3 +1,8 @@
+import grass.script as grass
+from urllib2 import urlopen, HTTPError
try:
from osgeo import gdal
from osgeo import gdalconst
@@ -4,172 +9,146 @@
except:
grass.fatal(_("Unable to load GDAL python bindings"))
-from urllib2 import urlopen
+import urllib2
+import xml.etree.ElementTree as etree
import numpy as Numeric
Numeric.arrayrange = Numeric.arange
-import grass.script as grass
+from math import pi, floor
from wms_base import WMSBase
class WMSDrv(WMSBase):
def _download(self):
"""!Downloads data from WMS server using own driver
- @return temp_map with stored downloaded data
+ @return temp_map with downloaded data
grass.message(_("Downloading data from WMS server..."))
- proj = self.projection_name + "=EPSG:"+ str(self.o_srs)
- url = self.o_mapserver_url + "REQUEST=GetMap&VERSION=%s&LAYERS=%s&WIDTH=%s&HEIGHT=%s&STYLES=%s&BGCOLOR=%s&TRANSPARENT=%s" %\
- (self.o_wms_version, self.o_layers, self.tile_cols, self.tile_rows, self.o_styles, self.o_bgcolor, self.transparent)
- url += "&" +proj+ "&" + "FORMAT=" + self.mime_format
- if self.o_urlparams != "":
- url +="&" + self.o_urlparams
- cols = int(self.region['cols'])
- rows = int(self.region['rows'])
- # computes parameters of tiles
- num_tiles_x = cols / self.tile_cols
- last_tile_x_size = cols % self.tile_cols
- tile_x_length = float(self.tile_cols) / float(cols ) * (self.bbox['maxx'] - self.bbox['minx'])
- last_tile_x = False
- if last_tile_x_size != 0:
- last_tile_x = True
- num_tiles_x = num_tiles_x + 1
- num_tiles_y = rows / self.tile_rows
- last_tile_y_size = rows % self.tile_rows
- tile_y_length = float(self.tile_rows) / float(rows) * (self.bbox['maxy'] - self.bbox['miny'])
- last_tile_y = False
- if last_tile_y_size != 0:
- last_tile_y = True
- num_tiles_y = num_tiles_y + 1
- # each tile is downloaded and written into temp_map
- tile_bbox = dict(self.bbox)
- tile_bbox['maxx'] = self.bbox['minx'] + tile_x_length
- tile_to_temp_map_size_x = self.tile_cols
- for i_x in range(num_tiles_x):
- # set bbox for tile i_x,i_y (E, W)
- if i_x != 0:
- tile_bbox['maxx'] += tile_x_length
- tile_bbox['minx'] += tile_x_length
- if i_x == num_tiles_x - 1 and last_tile_x:
- tile_to_temp_map_size_x = last_tile_x_size
- tile_bbox['maxy'] = self.bbox['maxy']
- tile_bbox['miny'] = self.bbox['maxy'] - tile_y_length
- tile_to_temp_map_size_y = self.tile_rows
- for i_y in range(num_tiles_y):
- # set bbox for tile i_x,i_y (N, S)
- if i_y != 0:
- tile_bbox['miny'] -= tile_y_length
- tile_bbox['maxy'] -= tile_y_length
- if i_y == num_tiles_y - 1 and last_tile_y:
- tile_to_temp_map_size_y = last_tile_y_size
- if self.flip_coords:
- # flips coordinates if WMS strandard is 1.3.0 and
- # projection is geographic (see:wms_base.py _computeBbox)
- query_bbox = dict(self._flipBbox(tile_bbox))
+ # initialize correct manager according to chosen OGC service
+ if self.params['driver'] == 'WMTS_GRASS':
+ req_mgr = WMTSRequestMgr(self.params, self.bbox, self.region, self.proj_srs, self._fetchCapabilities(self.params))
+ elif self.params['driver'] == 'WMS_GRASS':
+ req_mgr = WMSRequestMgr(self.params, self.bbox, self.region, self.tile_size, self.proj_srs)
+ # set password and username to urlib2
+ if self.params['username']:
+ passman = urllib2.HTTPPasswordMgrWithDefaultRealm()
+ passman.add_password(None, self.params['url'], self.params['username'], self.params['password'])
+ auth_handler = urllib2.HTTPBasicAuthHandler(passman)
+ opener = urllib2.build_opener(auth_handler)
+ urllib2.install_opener(opener)
+ # get information about size in pixels and bounding box of raster, where all tiles will be joined
+ map_region = req_mgr.GetMapRegion()
+ init = True
+ temp_map = None
+ # iterate through all tiles and download them
+ while True:
+ # get url for request the tile and information for placing the tile into raster with other tiles
+ tile = req_mgr.GetNextTile()
+ # if last tile has been already downloaded
+ if not tile:
+ break
+ # url for request the tile
+ query_url = tile[0]
+ # the tile size and offset in pixels for placing it into raster where tiles are joined
+ tileRef = tile[1]
+ grass.debug(query_url)
+ try:
+ wms_data = urllib2.urlopen(query_url)
+ except (IOError, HTTPException), e:
+ if HTTPError == type(e) and e.code == 401:
+ grass.fatal(_("Authorization failed"))
else:
- query_bbox = tile_bbox
+ grass.fatal(_("Unable to fetch data from server"))
- query_url = url + "&" + "BBOX=%s,%s,%s,%s" % ( query_bbox['minx'], query_bbox['miny'], query_bbox['maxx'], query_bbox['maxy'])
- grass.debug(query_url)
- try:
- wms_data = urlopen(query_url)
- except IOError:
- grass.fatal(_("Unable to fetch data from mapserver"))
+ temp_tile = self._tempfile()
- temp_tile = self._tempfile()
+ # download data into temporary file
+ try:
+ temp_tile_opened = open(temp_tile, 'w')
+ temp_tile_opened.write(wms_data.read())
+ except IOError:
+ grass.fatal(_("Unable to write data into tempfile"))
+ finally:
+ temp_tile_opened.close()
- # download data into temporary file
+ tile_dataset_info = gdal.Open(temp_tile, gdal.GA_ReadOnly)
+ if tile_dataset_info is None:
+ # print error xml returned from server
try:
- temp_tile_opened = open(temp_tile, 'w')
- temp_tile_opened.write(wms_data.read())
+ error_xml_opened = open(temp_tile, 'r')
+ err_str = error_xml_opened.read()
except IOError:
- grass.fatal(_("Unable to write data into tempfile"))
+ grass.fatal(_("Unable to read data from tempfile"))
finally:
- temp_tile_opened.close()
- tile_dataset_info = gdal.Open(temp_tile, gdal.GA_ReadOnly)
- if tile_dataset_info is None:
- # print error xml returned from server
- try:
- error_xml_opened = open(temp_tile, 'r')
- err_str = error_xml_opened.read()
- except IOError:
- grass.fatal(_("Unable to read data from tempfile"))
- finally:
- error_xml_opened.close()
+ error_xml_opened.close()
- if err_str is not None:
- grass.fatal(_("WMS server error: %s") % err_str)
- else:
- grass.fatal(_("WMS server unknown error") )
+ if err_str is not None:
+ grass.fatal(_("WMS server error: %s") % err_str)
+ else:
+ grass.fatal(_("WMS server unknown error") )
- band = tile_dataset_info.GetRasterBand(1)
- cell_type_func = band.__swig_getmethods__["DataType"]#??
- bands_number_func = tile_dataset_info.__swig_getmethods__["RasterCount"]
+ band = tile_dataset_info.GetRasterBand(1)
+ cell_type_func = band.__swig_getmethods__["DataType"]#??
+ bands_number_func = tile_dataset_info.__swig_getmethods__["RasterCount"]
- ##### see original r.in.wms - file gdalwarp.py line 117 ####
- temp_tile_pct2rgb = None
- if bands_number_func(tile_dataset_info) == 1 and band.GetRasterColorTable() is not None:
- # expansion of color table into bands
- temp_tile_pct2rgb = self._tempfile()
- tile_dataset = self._pct2rgb(temp_tile, temp_tile_pct2rgb)
- else:
- tile_dataset = tile_dataset_info
+ temp_tile_pct2rgb = None
+ if bands_number_func(tile_dataset_info) == 1 and band.GetRasterColorTable() is not None:
+ # expansion of color table into bands
+ temp_tile_pct2rgb = self._tempfile()
+ tile_dataset = self._pct2rgb(temp_tile, temp_tile_pct2rgb)
+ else:
+ tile_dataset = tile_dataset_info
- # initialization of temp_map_dataset, where all tiles are merged
- if i_x == 0 and i_y == 0:
- temp_map = self._tempfile()
+ # initialization of temp_map_dataset, where all tiles are merged
+ if init:
+ temp_map = self._tempfile()
- driver = gdal.GetDriverByName(self.gdal_drv_format)
- metadata = driver.GetMetadata()
- if not metadata.has_key(gdal.DCAP_CREATE) or \
- metadata[gdal.DCAP_CREATE] == 'NO':
- grass.fatal(_('Driver %s does not supports Create() method') % drv_format)
+ driver = gdal.GetDriverByName(self.gdal_drv_format)
+ metadata = driver.GetMetadata()
+ if not metadata.has_key(gdal.DCAP_CREATE) or \
+ metadata[gdal.DCAP_CREATE] == 'NO':
+ grass.fatal(_('Driver %s does not supports Create() method') % drv_format)
- self.temp_map_bands_num = bands_number_func(tile_dataset)
- temp_map_dataset = driver.Create(temp_map, int(cols), int(rows),
- self.temp_map_bands_num, cell_type_func(band));
+ self.temp_map_bands_num = bands_number_func(tile_dataset)
+ temp_map_dataset = driver.Create(temp_map, map_region['cols'], map_region['rows'],
+ self.temp_map_bands_num, cell_type_func(band))
+ init = False
- # tile written into temp_map
- tile_to_temp_map = tile_dataset.ReadRaster(0, 0, tile_to_temp_map_size_x, tile_to_temp_map_size_y,
- tile_to_temp_map_size_x, tile_to_temp_map_size_y)
+ # tile is written into temp_map
+ tile_to_temp_map = tile_dataset.ReadRaster(0, 0, tileRef['sizeX'], tileRef['sizeY'],
+ tileRef['sizeX'], tileRef['sizeY'])
- temp_map_dataset.WriteRaster(self.tile_cols * i_x, self.tile_rows * i_y,
- tile_to_temp_map_size_x, tile_to_temp_map_size_y, tile_to_temp_map)
+ temp_map_dataset.WriteRaster(tileRef['t_cols_offset'], tileRef['t_rows_offset'],
+ tileRef['sizeX'], tileRef['sizeY'], tile_to_temp_map)
- tile_dataset = None
- tile_dataset_info = None
- grass.try_remove(temp_tile)
- grass.try_remove(temp_tile_pct2rgb)
+ tile_dataset = None
+ tile_dataset_info = None
+ grass.try_remove(temp_tile)
+ grass.try_remove(temp_tile_pct2rgb)
+ if not temp_map:
+ return temp_map
# georeferencing and setting projection of temp_map
projection = grass.read_command('g.proj',
flags = 'wf',
- epsg =self.o_srs).rstrip('\n')
+ epsg =self.params['srs']).rstrip('\n')
temp_map_dataset.SetProjection(projection)
+ pixel_x_length = (map_region['maxx'] - map_region['minx']) / int(map_region['cols'])
+ pixel_y_length = (map_region['miny'] - map_region['maxy']) / int(map_region['rows'])
- pixel_x_length = (self.bbox['maxx'] - self.bbox['minx']) / int(cols)
- pixel_y_length = (self.bbox['miny'] - self.bbox['maxy']) / int(rows)
- geo_transform = [ self.bbox['minx'] , pixel_x_length , 0.0 , self.bbox['maxy'] , 0.0 , pixel_y_length ]
+ geo_transform = [map_region['minx'] , pixel_x_length , 0.0 , map_region['maxy'] , 0.0 , pixel_y_length]
temp_map_dataset.SetGeoTransform(geo_transform )
temp_map_dataset = None
@@ -220,3 +199,405 @@
tif_ds.GetRasterBand(iBand+1).WriteArray(dst_data,0,iY)
return tif_ds
+class BaseRequestMgr:
+ """!Base class for request managers.
+ def _isGeoProj(self, proj):
+ """!Is it geographic projection?
+ if (proj.find("+proj=latlong") != -1 or \
+ proj.find("+proj=longlat") != -1):
+ return True
+ return False
+ def find(self, etreeElement, tag, ns = None):
+ """!Wraper for etree element find method.
+ if not ns:
+ res = etreeElement.find(tag)
+ else:
+ res = etreeElement.find(ns(tag))
+ if res is None:
+ grass.fatal(_("Unable to parse capabilities file. \n Tag '%s' was not found.") % tag)
+ return res
+ def findall(self, etreeElement, tag, ns = None):
+ """!Wraper for etree element findall method.
+ if not ns:
+ res = etreeElement.findall(tag)
+ else:
+ res = etreeElement.findall(ns(tag))
+ if not res:
+ return res
+class WMSRequestMgr(BaseRequestMgr):
+ def __init__(self, params, bbox, region, tile_size, proj_srs, cap_file = None):
+ """!Initialize data needed for iteration through tiles.
+ self.version = params['wms_version']
+ proj = params['proj_name'] + "=EPSG:"+ str(params['srs'])
+ self.url = params['url'] + ("?SERVICE=WMS&REQUEST=GetMap&VERSION=%s&LAYERS=%s&WIDTH=%s&HEIGHT=%s&STYLES=%s&BGCOLOR=%s&TRANSPARENT=%s" % \
+ (params['wms_version'], params['layers'], tile_size['cols'], tile_size['rows'], params['styles'], \
+ params['bgcolor'], params['transparent']))
+ self.url += "&" +proj+ "&" + "FORMAT=" + params['format']
+ self.bbox = bbox
+ self.proj_srs = proj_srs
+ self.tile_rows = tile_size['rows']
+ self.tile_cols = tile_size['cols']
+ if params['urlparams'] != "":
+ self.url += "&" + params['urlparams']
+ cols = int(region['cols'])
+ rows = int(region['rows'])
+ # computes parameters of tiles
+ self.num_tiles_x = cols / self.tile_cols
+ self.last_tile_x_size = cols % self.tile_cols
+ self.tile_length_x = float(self.tile_cols) / float(cols) * (self.bbox['maxx'] - self.bbox['minx'])
+ self.last_tile_x = False
+ if self.last_tile_x_size != 0:
+ self.last_tile_x = True
+ self.num_tiles_x = self.num_tiles_x + 1
+ self.num_tiles_y = rows / self.tile_rows
+ self.last_tile_y_size = rows % self.tile_rows
+ self.tile_length_y = float(self.tile_rows) / float(rows) * (self.bbox['maxy'] - self.bbox['miny'])
+ self.last_tile_y = False
+ if self.last_tile_y_size != 0:
+ self.last_tile_y = True
+ self.num_tiles_y = self.num_tiles_y + 1
+ self.tile_bbox = dict(self.bbox)
+ self.tile_bbox['maxx'] = self.bbox['minx'] + self.tile_length_x
+ self.i_x = 0
+ self.i_y = 0
+ self.map_region = self.bbox
+ self.map_region['cols'] = cols
+ self.map_region['rows'] = rows
+ def GetMapRegion(self):
+ """!Get size in pixels and bounding box of raster where all tiles will be merged.
+ return self.map_region
+ def GetNextTile(self):
+ """!Get url for request the tile from server and information for merging the tile with other tiles
+ tileRef = {}
+ if self.i_x >= self.num_tiles_x:
+ return None
+ tileRef['sizeX'] = self.tile_cols
+ if self.i_x == self.num_tiles_x - 1 and self.last_tile_x:
+ tileRef['sizeX'] = self.last_tile_x_size
+ # set bbox for tile (N, S)
+ if self.i_y != 0:
+ self.tile_bbox['miny'] -= self.tile_length_y
+ self.tile_bbox['maxy'] -= self.tile_length_y
+ else:
+ self.tile_bbox['maxy'] = self.bbox['maxy']
+ self.tile_bbox['miny'] = self.bbox['maxy'] - self.tile_length_y
+ tileRef['sizeY'] = self.tile_rows
+ if self.i_y == self.num_tiles_y - 1 and self.last_tile_y:
+ tileRef['sizeY'] = self.last_tile_y_size
+ if self._isGeoProj(self.proj_srs) and self.version == "1.3.0":
+ query_bbox = self._flipBbox(self.tile_bbox, self.proj_srs)
+ else:
+ query_bbox = self.tile_bbox
+ query_url = self.url + "&" + "BBOX=%s,%s,%s,%s" % ( query_bbox['minx'], query_bbox['miny'], query_bbox['maxx'], query_bbox['maxy'])
+ tileRef['t_cols_offset'] = int(self.tile_cols * self.i_x)
+ tileRef['t_rows_offset'] = int(self.tile_rows * self.i_y)
+ if self.i_y >= self.num_tiles_y - 1:
+ self.i_y = 0
+ self.i_x += 1
+ # set bbox for next tile (E, W)
+ self.tile_bbox['maxx'] += self.tile_length_x
+ self.tile_bbox['minx'] += self.tile_length_x
+ else:
+ self.i_y += 1
+ return query_url, tileRef
+ def _flipBbox(self, bbox, proj, version):
+ Flips coordinates if WMS standard is 1.3.0 and
+ projection is geographic.
+ value flips between this keys:
+ maxy -> maxx
+ maxx -> maxy
+ miny -> minx
+ minx -> miny
+ @return copy of bbox with flipped coordinates
+ temp_bbox = dict(bbox)
+ new_bbox = {}
+ new_bbox['maxy'] = temp_bbox['maxx']
+ new_bbox['miny'] = temp_bbox['minx']
+ new_bbox['maxx'] = temp_bbox['maxy']
+ new_bbox['minx'] = temp_bbox['miny']
+ return new_bbox
+class WMTSRequestMgr(BaseRequestMgr):
+ def __init__(self, params, bbox, region, proj_srs, cap_file = None):
+ """!Initializes data needed for iteration through tiles.
+ self.meters_per_unit = None
+ # constant defined in WMTS standard (in meters)
+ self.pixel_size = 0.00028
+ # parse capabilities file
+ cap_tree = etree.parse(cap_file)
+ root = cap_tree.getroot()
+ # get layer tile matrix sets with same projection
+ mat_sets = self._getMatSets(root, params)
+ # TODO: what if more tile matrix sets are returned?
+ params['tile_matrix_set'] = mat_sets[0].find(self._ns_ows('Identifier')).text
+ # find tile matrix with resolution closest and smaller to wanted resolution
+ tile_mat = self._findTileMats(mat_sets[0].findall(self._ns_wmts('TileMatrix')), region, bbox)
+ # initialize data needed for iteration through tiles
+ self._computeRequestData(tile_mat, params, bbox)
+ def _getMatSets(self, root, params):
+ """!Get matrix sets which are available for chosen layer and have required EPSG.
+ contents = self.find(root, 'Contents', self._ns_wmts)
+ layers = self.findall(contents, 'Layer', self._ns_wmts)
+ ch_layer = None
+ for layer in layers:
+ layer_id = layer.find(self._ns_ows('Identifier')).text
+ if layer_id and layer_id == params['layers']:
+ ch_layer = layer
+ break
+ if ch_layer is None:
+ grass.fatal(_("Layer '%s' was not found in capabilities file") % params['layers'])
+ mat_set_links = self.findall(ch_layer, 'TileMatrixSetLink', self._ns_wmts)
+ suitable_mat_sets = []
+ tileMatrixSets = self.findall(contents, 'TileMatrixSet', self._ns_wmts)
+ for link in mat_set_links:
+ mat_set_link_id = link.find(self._ns_wmts('TileMatrixSet')).text
+ if not mat_set_link_id:
+ continue
+ for mat_set in tileMatrixSets:
+ mat_set_id = mat_set.find(self._ns_ows('Identifier')).text
+ if mat_set_id and mat_set_id != mat_set_link_id:
+ continue
+ mat_set_srs = mat_set.find(self._ns_ows('SupportedCRS')).text
+ if mat_set_srs and mat_set_srs.lower() == ("EPSG:"+ str(params['srs'])).lower():
+ suitable_mat_sets.append(mat_set)
+ if not suitable_mat_sets:
+ grass.fatal(_("Layer '%s' is not available with %s code.") % (params['layers'], "EPSG:" + str(params['srs'])))
+ return suitable_mat_sets
+ def _findTileMats(self, tile_mats, region, bbox):
+ """!Find tile matrix set with closest and smaller resolution to requested resolution
+ scale_dens = []
+ scale_dens.append((bbox['maxy'] - bbox['miny']) / region['rows'] * self._getMetersPerUnit() / self.pixel_size)
+ scale_dens.append((bbox['maxx'] - bbox['minx']) / region['cols'] * self._getMetersPerUnit() / self.pixel_size)
+ scale_den = min(scale_dens)
+ first = True
+ for t_mat in tile_mats:
+ mat_scale_den = float(t_mat.find(self._ns_wmts('ScaleDenominator')).text)
+ if first:
+ best_scale_den = mat_scale_den
+ best_t_mat = t_mat
+ first = False
+ continue
+ best_diff = best_scale_den - scale_den
+ mat_diff = mat_scale_den - scale_den
+ if (best_diff < mat_diff and mat_diff < 0) or \
+ (best_diff > mat_diff and best_diff > 0):
+ return best_t_mat
+ def _getMetersPerUnit(self):
+ """!Get coefficient which allows to convert units of request projection into meters
+ if self.meters_per_unit:
+ return self.meters_per_unit
+ # for geographic projection
+ if self._isGeoProj(self.proj_srs):
+ proj_params = proj_srs.split(' ')
+ for param in proj_parmas:
+ if '+a' in param:
+ a = float(param.split('=')[1])
+ break
+ equator_perim = 2 * pi * a
+ # meters per degree on equator
+ self.meters_per_unit = equator_perim / 360
+ # other units
+ elif '+to_meter' in self.proj_srs:
+ proj_params = self.proj_srs.split(' ')
+ for param in proj_params:
+ if '+to_meter' in param:
+ self.meters_per_unit = 1/float(param.split('=')[1])
+ break
+ # coordinate system in meters
+ else:
+ def _computeRequestData(self, tile_mat, params, bbox):
+ scale_den = float(tile_mat.find(self._ns_wmts('ScaleDenominator')).text)
+ pixel_span = scale_den * self.pixel_size / self._getMetersPerUnit()
+ tl_corner = tile_mat.find(self._ns_wmts('TopLeftCorner')).text.split(' ')
+ self.t_cols = int(tile_mat.find(self._ns_wmts('TileWidth')).text)
+ t_length_x = pixel_span * self.t_cols
+ self.t_rows = int(tile_mat.find(self._ns_wmts('TileHeight')).text)
+ t_length_y = pixel_span * self.t_rows
+ t_mat_min_x = float(tl_corner[0])
+ t_mat_max_y = float(tl_corner[1])
+ epsilon = 2e-15
+ self.t_num_bbox = {}
+ self.t_num_bbox['min_col'] = int(floor((bbox['minx'] - t_mat_min_x) / t_length_x + epsilon))
+ self.t_num_bbox['max_col'] = int(floor((bbox['maxx'] - t_mat_min_x) / t_length_x - epsilon))
+ self.t_num_bbox['min_row'] = int(floor((t_mat_max_y - bbox['maxy']) / t_length_y + epsilon))
+ self.t_num_bbox['max_row'] = int(floor((t_mat_max_y - bbox['miny']) / t_length_y - epsilon))
+ matWidth = int(tile_mat.find(self._ns_wmts('MatrixWidth')).text)
+ matHeight = int(tile_mat.find(self._ns_wmts('MatrixHeight')).text)
+ self.intersects = False
+ for col in ['min_col', 'max_col']:
+ for row in ['min_row', 'max_row']:
+ if (0 <= self.t_num_bbox[row] and self.t_num_bbox[row] <= matHeight) and \
+ (0 <= self.t_num_bbox[col] and self.t_num_bbox[col] <= matWidth):
+ self.intersects = True
+ if not self.intersects:
+ grass.warning(_('Region is out of server data extend.'))
+ self.map_region = None
+ return
+ if self.t_num_bbox['min_col'] < 0:
+ self.t_num_bbox['min_col'] = 0
+ if self.t_num_bbox['max_col'] > (matWidth - 1):
+ self.t_num_bbox['max_col'] = matWidth - 1
+ if self.t_num_bbox['min_row'] < 0:
+ self.t_num_bbox['min_row'] = 0
+ if self.t_num_bbox['max_row'] > (matHeight - 1):
+ self.t_num_bbox['max_row'] = matHeight - 1
+ num_tiles = (self.t_num_bbox['max_col'] - self.t_num_bbox['min_col'] + 1) * (self.t_num_bbox['max_row'] - self.t_num_bbox['min_row'] + 1)
+ grass.message(_('Fetching %d tiles with %d x %d pixel size per tile...') % (num_tiles, self.t_cols, self.t_rows))
+ self.url = params['url'] + ("?SERVICE=WMTS&REQUEST=GetTile&VERSION=1.0.0&" \
+ "LAYER=%s&STYLE=%s&FORMAT=%s&TILEMATRIXSET=%s&TILEMATRIX=%s" % \
+ (params['layers'], params['styles'], params['format'],
+ params['tile_matrix_set'], tile_mat.find(self._ns_ows('Identifier')).text ))
+ self.map_region = {}
+ self.map_region['minx'] = self.t_num_bbox['min_col'] * t_length_x + t_mat_min_x
+ self.map_region['maxy'] = t_mat_max_y - (self.t_num_bbox['min_row']) * t_length_y
+ self.map_region['maxx'] = (self.t_num_bbox['max_col'] + 1) * t_length_x + t_mat_min_x
+ self.map_region['miny'] = t_mat_max_y - (self.t_num_bbox['max_row'] + 1) * t_length_y
+ self.map_region['cols'] = self.t_cols * (self.t_num_bbox['max_col'] - self.t_num_bbox['min_col'] + 1)
+ self.map_region['rows'] = self.t_rows * (self.t_num_bbox['max_row'] - self.t_num_bbox['min_row'] + 1)
+ self.i_col = self.t_num_bbox['min_col']
+ self.i_row = self.t_num_bbox['min_row']
+ self.tileRef = {
+ 'sizeX' : self.t_cols,
+ 'sizeY' : self.t_rows
+ if not self.intersects or self.i_col > self.t_num_bbox['max_col']:
+ return None
+ query_url = self.url + "&TILECOL=%i&TILEROW=%i" % (int(self.i_col), int(self.i_row))
+ self.tileRef['t_cols_offset'] = int(self.t_cols * (self.i_col - self.t_num_bbox['min_col']))
+ self.tileRef['t_rows_offset'] = int(self.t_rows * (self.i_row - self.t_num_bbox['min_row']))
+ if self.i_row >= self.t_num_bbox['max_row']:
+ self.i_col += 1
+ else:
+ self.i_row += 1
+ return query_url, self.tileRef
+ def _ns_wmts(self, tag):
+ """!Helper method - XML namespace
+ return "{http://www.opengis.net/wmts/1.0}" + tag
+ def _ns_ows(self, tag):
+ return "{http://www.opengis.net/ows/1.1}" + tag
Modified: grass-addons/grass7/raster/r.in.wms2/wms_gdal_drv.py
--- grass-addons/grass7/raster/r.in.wms2/wms_gdal_drv.py 2012-10-09 21:50:21 UTC (rev 53347)
+++ grass-addons/grass7/raster/r.in.wms2/wms_gdal_drv.py 2012-10-09 22:02:55 UTC (rev 53348)
@@ -1,4 +1,5 @@
import os
try:
@@ -8,8 +9,6 @@
class NullDevice():
@@ -30,25 +29,25 @@
service.set("name","WMS")
version = etree.SubElement(service, "Version")
- version.text =self.o_wms_version
+ version.text =self.params['wms_version']
server_url = etree.SubElement(service, "ServerUrl")
- server_url.text =self.o_mapserver_url
+ server_url.text =self.params['url']
- srs = etree.SubElement(service, self.projection_name)
- srs.text = 'EPSG:' + str(self.o_srs)
+ srs = etree.SubElement(service, self.params['proj_name'])
+ srs.text = 'EPSG:' + str(self.params['srs'])
image_format = etree.SubElement(service, "ImageFormat")
- image_format.text = self.mime_format
+ image_format.text = self.params['format']
image_format = etree.SubElement(service, "Transparent")
- image_format.text = self.transparent
+ image_format.text = self.params['transparent']
layers = etree.SubElement(service, "Layers")
- layers.text = self.o_layers
+ layers.text = self.params['layers']
styles = etree.SubElement(service, "Styles")
- styles.text = self.o_styles
+ styles.text = self.params['styles']
data_window = etree.SubElement(gdal_wms, "DataWindow")
@@ -76,10 +75,10 @@
block_size_x.text = str(self.temp_map_bands_num)
block_size_x = etree.SubElement(gdal_wms, "BlockSizeX")
- block_size_x.text = str(self.tile_cols)
+ block_size_x.text = str(self.tile_size['cols'])
block_size_y = etree.SubElement(gdal_wms, "BlockSizeY")
- block_size_y.text = str(self.tile_rows)
+ block_size_y.text = str(self.tile_size['rows'])
xml_file = self._tempfile()
@@ -98,9 +97,11 @@
# GDAL WMS driver does not flip geographic coordinates
# according to WMS standard 1.3.0.
- if self.flip_coords and self.o_wms_version == "1.3.0":
+ if ("+proj=latlong" in self.proj_srs or \
+ "+proj=longlat" in self.proj_srs) and \
+ self.params['wms_version'] == "1.3.0":
grass.warning(_("If module will not be able to fetch the data in this\
- geographic projection, \n try flag -d or use WMS version 1.1.1."))
+ geographic projection, \n try 'WMS_GRASS' driver or use WMS version 1.1.1."))
self._debug("_download", "started")
