[GRASS-SVN] r53405 - grass/trunk/vector/v.net
Mon Oct 15 09:06:55 PDT 2012
Author: neteler
Date: 2012-10-15 09:06:54 -0700 (Mon, 15 Oct 2012)
New Revision: 53405
   grass/trunk/vector/v.net/v.net.html
HTML cosmetics
Modified: grass/trunk/vector/v.net/v.net.html
--- grass/trunk/vector/v.net/v.net.html	2012-10-15 16:06:01 UTC (rev 53404)
+++ grass/trunk/vector/v.net/v.net.html	2012-10-15 16:06:54 UTC (rev 53405)
@@ -54,20 +54,22 @@
 For nodes created using the <em>connect</em> and <em>arcs</em> operations (methods 1
 and 3 above), the nodes can be reconnected to the attribute table of the
 input vector points file using the attribute table manager ("manage layers"
-tab) or by running (<em><a href="v.db.connect.html">v.db.connect</a></em>).
+tab) or by running <em><a href="v.db.connect.html">v.db.connect</a></em>.
 <p>
 For nodes created using the <em>nodes</em> operation
 (method 2 above), it is possible to create an attribute table for the
 new nodes in layer 2 using the attribute table manager and connect it to
-layer 2 ("manage layers" tab) or to create a table with v.db.addtable,
-connect it to layer 2 with (<em><a href="v.db.connect.html">v.db.connect</a></em>),
-and update the new table with cat values with (<em><a href="v.to.db.html">v.to.db</a></em>).
+layer 2 ("manage layers" tab) or to create a table with
+<em><a href="v.db.addtable.html">v.db.addtable</a>,
+connect it to layer 2 with <em><a href="v.db.connect.html">v.db.connect</a></em>,
+and update the new table with cat values with <em><a href="v.to.db.html">v.to.db</a></em>.
 <p>
 Once a vector network has been created, it can be analyzed in a number
 of powerful ways using the suite of <em>v.net</em>.* modules. The shortest route
-between two nodes, following arcs, can be computed (<em><a href="v.net.path.html">v.net.path</a></em>), as can the
+between two nodes, following arcs, can be computed
+(<em><a href="v.net.path.html">v.net.path</a></em>), as can the
 shortest route that will pass through a set of nodes and return to the
 starting node (<em><a href="v.net.salesman.html">v.net.salesman</a></em>).
 Least cost routes through the network can be calculated on the basis of
