[GRASS-SVN] r53406 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Mon Oct 15 11:01:55 PDT 2012
Author: martinl
Date: 2012-10-15 11:01:55 -0700 (Mon, 15 Oct 2012)
New Revision: 53406
grass/trunk/gui/wxpython/core/workspace.py
wxGUI: variable clean up
Modified: grass/trunk/gui/wxpython/core/workspace.py
--- grass/trunk/gui/wxpython/core/workspace.py 2012-10-15 16:06:54 UTC (rev 53405)
+++ grass/trunk/gui/wxpython/core/workspace.py 2012-10-15 18:01:55 UTC (rev 53406)
@@ -585,9 +585,9 @@
region = mapTree.GetMap().GetCurrentRegion()
mapdisp = mapTree.GetMapDisplay()
- displayPos = mapTree.mapdisplay.GetPosition()
- displaySize = mapTree.mapdisplay.GetSize()
- if mapTree.mapdisplay.toolbars['map'].combo.GetSelection() == 1:
+ displayPos = mapdisp.GetPosition()
+ displaySize = mapdisp.GetSize()
+ if mapdisp.toolbars['map'].combo.GetSelection() == 1:
viewmode = '3d'
else:
viewmode = '2d'
@@ -601,11 +601,11 @@
'extent="%f,%f,%f,%f" '
'viewMode="%s" >\n' % (' ' * self.indent,
dispName.encode('utf8'),
- int(mapTree.mapdisplay.GetProperty('render')),
- mapTree.mapdisplay.statusbarManager.GetMode(),
- int(mapTree.mapdisplay.GetProperty('region')),
- int(mapTree.mapdisplay.GetProperty('alignExtent')),
- int(mapTree.mapdisplay.GetProperty('resolution')),
+ int(mapdisp.GetProperty('render')),
+ mapdisp.statusbarManager.GetMode(),
+ int(mapdisp.GetProperty('region')),
+ int(mapdisp.GetProperty('alignExtent')),
+ int(mapdisp.GetProperty('resolution')),
displayPos[0],
displayPos[1],
displaySize[0],
@@ -617,7 +617,7 @@
viewmode
# projection statusbar info
- if mapTree.mapdisplay.GetProperty('projection') and \
+ if mapdisp.GetProperty('projection') and \
UserSettings.Get(group='display', key='projection', subkey='proj4'):
self.indent += 4
file.write('%s<projection' % (' ' * self.indent))
@@ -636,8 +636,8 @@
item = mapTree.GetFirstChild(mapTree.root)[0]
self.__writeLayer(mapTree, item)
- if mapTree.mapdisplay.MapWindow3D is not None:
- nvizDisp = mapTree.mapdisplay.MapWindow3D
+ if mapdisp.MapWindow3D is not None:
+ nvizDisp = mapdisp.MapWindow3D
self.__writeNvizState(view = nvizDisp.view, iview = nvizDisp.iview,
light = nvizDisp.light, constants = nvizDisp.constants)
