[GRASS-SVN] r53416 - grass/branches/releasebranch_6_4/vector/v.net
svn_grass at osgeo.org
Tue Oct 16 00:20:22 PDT 2012
Author: mlennert
Date: 2012-10-16 00:20:22 -0700 (Tue, 16 Oct 2012)
New Revision: 53416
grass/branches/releasebranch_6_4/vector/v.net/description.html
Correcting man page: there is no arc operation in grass6.*.
Modified: grass/branches/releasebranch_6_4/vector/v.net/description.html
--- grass/branches/releasebranch_6_4/vector/v.net/description.html 2012-10-16 07:20:12 UTC (rev 53415)
+++ grass/branches/releasebranch_6_4/vector/v.net/description.html 2012-10-16 07:20:22 UTC (rev 53416)
@@ -19,8 +19,7 @@
nodes are stored in a different data layer (normally layer 2).
<p>
-<em>v.net</em> offers two ways to add nodes to a network of arcs and one
-method to add arcs to a set of nodes:
+<em>v.net</em> offers two ways to add nodes to a network of arcs:
<ol>
<li>Use the <em>connect</em> operation to create nodes from a vector points
@@ -37,11 +36,6 @@
For an <em>arc</em> that consists of several segments connected by
vertices (the typical case), only the starting and ending vertices are
treated as network nodes.</li>
-<li>Create straight-line arcs between pairs of nodes with the <em>arcs</em> option.
-This produces networks like those of airline flights between airports. It is
-also similar to the kind of network created with social networking
-software, making it possible to create georeferenced social networks.</li>
</ol>
<p>
@@ -51,8 +45,8 @@
information.
<p>
-For nodes created using the <em>connect</em> and <em>arcs</em> operations (methods 1
-and 3 above), the nodes can be reconnected to the attribute table of the
+For nodes created using the <em>connect</em> operation (method 1
+above), the nodes can be reconnected to the attribute table of the
input vector points file using the attribute table manager ("manage layers"
tab) or by running <em><a href="v.db.connect.html">v.db.connect</a></em>.
