[GRASS-SVN] r53417 - grass/trunk/vector/v.distance
svn_grass at osgeo.org
Tue Oct 16 00:48:36 PDT 2012
Author: mmetz
Date: 2012-10-16 00:48:35 -0700 (Tue, 16 Oct 2012)
New Revision: 53417
grass/trunk/vector/v.distance/distance.c
grass/trunk/vector/v.distance/main.c
grass/trunk/vector/v.distance/v.distance.html
v.distance update for areas to areas
Modified: grass/trunk/vector/v.distance/distance.c
--- grass/trunk/vector/v.distance/distance.c 2012-10-16 07:20:22 UTC (rev 53416)
+++ grass/trunk/vector/v.distance/distance.c 2012-10-16 07:48:35 UTC (rev 53417)
@@ -197,6 +197,7 @@
int i, j;
double tmp_dist;
int isle, nisles;
+ int all_inside_outer, all_outside_outer, all_outside_inner;
static struct line_pnts *aPoints = NULL;
static struct line_pnts **iPoints = NULL;
static struct bound_box *ibox = NULL;
@@ -237,6 +238,8 @@
/* inside area ? */
+ all_inside_outer = all_outside_outer = 1;
+ all_outside_inner = 1;
for (i = 0; i < Points->n_points; i++) {
if (Vect_point_in_box(Points->x[i], Points->y[i],
@@ -246,6 +249,15 @@
poly = Vect_point_in_poly(Points->x[i], Points->y[i], aPoints);
+ if (poly > 0) {
+ /* inside outer ring */
+ all_outside_outer = 0;
+ else {
+ /* outside outer ring */
+ all_inside_outer = 0;
/* exactly on boundary */
if (poly == 2) {
line2line(Points, type, aPoints, GV_BOUNDARY,
@@ -255,9 +267,9 @@
return 1;
- /* inside */
else if (poly == 1) {
- int inside = 0;
+ int inside_isle = 0;
for (j = 0; j < nisles; j++) {
if (Vect_point_in_box(Points->x[i], Points->y[i], Points->z[i],
@@ -270,6 +282,8 @@
double tmp_fx, tmp_fy, tmp_fz, tmp_fangle, tmp_falong;
double tmp_tx, tmp_ty, tmp_tz, tmp_tangle, tmp_talong;
+ /* pass all points of the line,
+ * this will catch an intersection */
line2line(Points, type, iPoints[j], GV_BOUNDARY,
&tmp_fx, &tmp_fy, &tmp_fz, &tmp_falong, &tmp_fangle,
&tmp_tx, &tmp_ty, &tmp_tz, &tmp_talong, &tmp_tangle,
@@ -291,16 +305,17 @@
*tangle = tmp_tangle;
- if (poly == 1)
- inside = 1;
+ if (poly == 1) /* excludes isle boundary */
+ inside_isle = 1;
if (*dist == 0)
break;
- /* inside area (inside outer ring, outside inner rings) */
- if (!inside) {
+ /* inside area (inside outer ring, outside inner rings
+ * or exactly on one of the inner rings) */
+ if (!inside_isle) {
*fx = Points->x[i];
*fy = Points->y[i];
*fz = Points->z[i];
@@ -313,18 +328,49 @@
return 1;
- /* inside one of the islands */
- else
- return 2;
+ else {
+ /* inside one of the islands */
+ all_outside_inner = 0;
+ if (*dist == 0) {
+ /* the line intersected with the isle boundary
+ * -> line is partially inside the area */
+ return 1;
+ /* else continue with next point */
} /* end inside outer ring */
- /* not possible */
+ else {
+ /* point not in box of outer ring */
+ /* exactly on boundary */
if (*dist == 0)
return 1;
+ /* if all points are inside the outer ring and inside inner rings,
+ * there could still be an intersection with one of the inner rings */
+ if (all_inside_outer) {
+ if (all_outside_inner) {
+ /* at least one point is really inside the area!
+ * that should have been detected above */
+ G_fatal_error(_("At least one point is really inside the area!"));
+ /* else all points are inside one of the area isles
+ * and we already have the minimum distance */
+ return 2;
- /* line is outside area */
+ /* if at least one point was found to be inside the outer ring,
+ * but no point really inside the area,
+ * and at least one point outside,
+ * then there must be an intersection of the line with both
+ * the outer ring and one of the isle boundaries */
+ /* if all line points are outside of the area,
+ * intersection is still possible */
fx, fy, fz, falong, fangle,
tx, ty, tz, talong, tangle,
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2012-10-16 07:20:22 UTC (rev 53416)
+++ grass/trunk/vector/v.distance/main.c 2012-10-16 07:48:35 UTC (rev 53417)
@@ -968,19 +968,21 @@
int tmp_tcat, poly;
tarea = aList->id[i];
- G_debug(4, "%d: area %d", i, tarea);
+ G_debug(4, "%d: 'to' area id %d", i, tarea);
Vect_get_area_points(&To, tarea, TPoints);
ttype = GV_BOUNDARY;
- /* Find the distance to this area */
+ /* Find the distance of the outer ring of 'to' area
+ * to 'from' area */
poly = line2area(&From, TPoints, ttype, area, &fbox,
&tmp_dist, with_z, 0);
if (poly == 3) {
- /* 'to' area is outside 'from' area,
+ /* 'to' outer ring is outside 'from' area,
* check if 'from' area is inside 'to' area */
poly = 0;
/* boxes must overlap */
@@ -996,6 +998,8 @@
if (poly) {
/* 'from' area is (partially) inside 'to' area,
* get distance to 'to' area */
+ if (FPoints->n_points == 0)
+ Vect_get_area_points(&From, area, FPoints);
poly = line2area(&To, FPoints, ttype, tarea, &aList->box[i],
@@ -1004,7 +1008,7 @@
/* inside isle ? */
poly = poly == 2;
- if (poly) {
+ if (poly == 1) {
double tmp2_tx, tmp2_ty, tmp2_tz, tmp2_talong, tmp2_tangle;
double tmp2_fx, tmp2_fy, tmp2_fz, tmp2_falong, tmp2_fangle;
double tmp2_dist;
@@ -1040,7 +1044,7 @@
if (tmp_dist > max || tmp_dist < min)
continue; /* not in threshold */
- Vect_get_area_cats(&To, area, TCats);
+ Vect_get_area_cats(&To, tarea, TCats);
tmp_tcat = -1;
/* TODO: all cats of given field ? */
for (j = 0; j < TCats->n_cats; j++) {
Modified: grass/trunk/vector/v.distance/v.distance.html
--- grass/trunk/vector/v.distance/v.distance.html 2012-10-16 07:20:22 UTC (rev 53416)
+++ grass/trunk/vector/v.distance/v.distance.html 2012-10-16 07:48:35 UTC (rev 53417)
@@ -8,6 +8,38 @@
nearest points on features are written. <em>dmin</em> and/or
<em>dmax</em> can be used to limit the search radius.
+<p>
+For lines to lines, say line A to line B, <em>v.distance</em> calculates
+the shortest distance of each vertex in A with each segment (not vertex)
+in B. The module then calculates the shortest distance of each vertex in
+B to each segment in A. The overall shortest distance of A points to B
+segments and B points to A segments is used. Additionally,
+<em>v.distance</em> checks for intersections. In case of intersections,
+the first intersection found is used and the distance set to zero.
+<p>
+For lines to areas, the distance is set to zero if a line is (partially)
+inside an area. The first point of the line that is inside the area is
+used as common point. The distance is also set to zero if the line
+intersects with the outer ring or any of the inner rings (isles), in
+which case the fist intersection is used as common point.
+<p>
+For areas to areas, the module checks first for overlap or if one area
+is (partially) inside the other area. This is computationally quite
+intensive. If the outer rings of the two areas do not overlap, the
+distance is calculated as above for lines to lines, treating the outer
+rings as two lines. Again, the first point encountered falling into an
+area is used as common point, or the first intersection point.
+<p>
+For anything else than points to lines, there can be several common
+locations with zero distance, and the common location would then be the
+result of an overlay consisting of several points, lines, or areas.
+<em>v.distance</em> selects in these cases a single point, and does not
+create an overlay like <em>v.overlay</em>.
<h2>NOTES</h2>
If a nearest feature does not have a category, the attribute column is
