[GRASS-SVN] r53418 - in grass-addons/grass7/raster: . r.mess
svn_grass at osgeo.org
Tue Oct 16 01:59:21 PDT 2012
Author: pvanbosgeo
Date: 2012-10-16 01:59:20 -0700 (Tue, 16 Oct 2012)
New Revision: 53418
Added:
grass-addons/grass7/raster/r.mess/
grass-addons/grass7/raster/r.mess/Makefile
grass-addons/grass7/raster/r.mess/r.mess
grass-addons/grass7/raster/r.mess/r.mess.html
Adding new script r.mess
Added: grass-addons/grass7/raster/r.mess/Makefile
--- grass-addons/grass7/raster/r.mess/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.mess/Makefile 2012-10-16 08:59:20 UTC (rev 53418)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.out.gmt
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.mess/r.mess
--- grass-addons/grass7/raster/r.mess/r.mess (rev 0)
+++ grass-addons/grass7/raster/r.mess/r.mess 2012-10-16 08:59:20 UTC (rev 53418)
@@ -0,0 +1,349 @@
+#!/bin/sh
+# MODULE: r.mess
+# AUTHOR(S): Paulo van Breugel <p.vanbreugel AT gmail.com>
+# PURPOSE: Calculate the multivariate environmental similarity
+# surface (MESS) as proposed by Elith et al., 2010,
+# Methods in Ecology & Evolution, 1(330–342).
+# NOTES: This GRASS script should give results very close (but
+# due to rounding differences probably not exactly the
+# same) to those calculated in Maxent. However, note that
+# Maxent uses, as far as I understand, the background
+# points. Therefore, if you want to compare the MESS layer
+# as calculated by Maxent with the results of this script
+# you need to make sure to use the same points as input
+# Disclaimer: I use it in my work, but I am aware that it needs
+# improvements. Suggestions for improvements are most
+# welcome. In the meantime, use it at your own risk
+# COPYRIGHT: (C) 2012 Paulo van Breugel
+# http://ecodiv.org
+# http://pvanb.wordpress.com/
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Computes multivariate environmental similarity surface
+#%End
+#%option
+#% key: vector_input
+#% type: string
+#% gisprompt: old,vector
+#% description: Reference points
+#% key_desc: name
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: raster_input
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Input raster map(s)
+#% key_desc: names
+#% required: yes
+#% multiple: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new
+#% description: Root name of the output MESS data layers
+#% key_desc: name
+#% required: yes
+#%end
+#%option
+#% key: columns
+#% type: string
+#% description: Columns with environmental variables
+#% key_desc: string
+#% answer: Same names as input layers
+#% required: no
+#%end
+##%flag
+##% key: n
+##% description: Keep individual environmental dissimilarity layers (IED)
+##%end
+#%flag
+#% key: m
+#% description: Most dissimilar variable (MoD)
+#%end
+#%flag
+#% key: k
+#% description: Calculate MESS_mean
+#%end
+#%flag
+#% key: l
+#% description: Calculate MESS_median
+#%end
+## GRASS team recommandations
+## Check if in GRASS
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." 1>&2
+ exit 1
+fi
+## check for awk
+if [ ! -x "$(which awk)" ] ; then
+ g.message -e "<awk> required, please install <awk> or <gawk> first"
+ exit 1
+fi
+## To parse the code into interactive menu
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+## set environment so that awk works properly in all languages ##
+unset LC_ALL
+export LC_NUMERIC=C
+## what to do in case of user break:
+exitprocedure()
+ echo "User break!"
+ cleanup
+ exit 1
+## shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+## testing if output maps already exist
+## Set easier variable names
+OUTMAPS="${GIS_OPT_OUTPUT}"
+INMAPS="${GIS_OPT_RASTER_INPUT}"
+# test for output raster map
+g.findfile element=cell file=${OUTMAPS}_combined > /dev/null
+ if [ $? -eq 0 ] ; then
+ g.message -e 'There is already a raster <${OUTMAPS}>'
+ exit 1
+fi
+# test for output raster maps
+oIFS=$IFS
+IFS=,
+for nvar in $INMAPS ; do
+ arrIN=${OUTMAPS}_`echo $nvar | awk 'BEGIN{FS="@"}{print $1}'`
+ g.findfile element=cell file=${arrIN} > /dev/null
+ exit 1
+ fi
+done
+IFS=$oIFS
+unset arrIN
+## Config and general procedures
+##fix this path
+if [ -z "$PROCESSDIR" ] ; then
+ PROCESSDIR="$HOME"
+fi
+#fix this path
+if [ -z "$LOGDIR" ] ; then
+ LOGDIR="$HOME"
+fi
+LOGFILE="$LOGDIR/r.mess.log"
+echo "r.mess :" >> "$LOGFILE"
+## Preparing input variables for use in R script
+# Create vectors with names output maps [arrOUT]
+# Create vector with names temporary layers [tmpLY]
+# Create vector with names input layers without mapset name [arrIN]
+# The 'removeThis' elements are to initiate the vector. How can I avoid this?
+arrOUT="${OUTMAPS}_MESS"
+tmpLY="removeThis"
+arrIN="removeThis2"
+counter=0
+IFS=,
+for nvar in ${INMAPS} ; do
+ arrOUT="$arrOUT;${OUTMAPS}_`echo $nvar | awk 'BEGIN{FS="@"}{print $1}'`"
+ counter=`expr $counter + 1`
+ tmpLY="${tmpLY};tmp.mess_$$_$counter"
+ arrIN="${arrIN};`echo $nvar | awk 'BEGIN{FS="@"}{print $1}'`"
+done
+## Creating the R script
+writeScript(){
+cat > $1 << "EOF"
+options(echo = FALSE)
+require(spgrass6)
+## Get vector with variables
+args <- commandArgs(trailingOnly=TRUE)
+ipn <- unlist(strsplit(args[1],";"))[-1] # variable names
+ipl <- unlist(strsplit(args[2],",")) # environmental layers
+opl <- unlist(strsplit(args[3],";")) # output layers
+opi <- opl[-1] # base name individual layers
+opc <- opl[1] # name of MESS layer
+tml <- unlist(strsplit(args[4], ";"))[-1] # temporary layers
+vtl <- args[5] # vector layer
+cln <- args[6]
+# Import the vector point layer
+spl <- readVECT6(vtl)
+# Extract columns and create table
+# Use column names if given, otherwise,
+# use names input layers (ipl)
+if(cln == "Same names as input layers"){
+ spld <- spl at data[,ipn]
+}else{
+ cln <- unlist(strsplit(cln,","))
+ spld <- spld[,cln]
+# Create the r.mapcalc expressions to calculate the mess for the
+# individual layers. The main step is to define the graph function to
+# be used (check out: possible alternative would be to use reclass)
+if(is.null(dim(spld))){
+ minp <- min(spld)
+ maxp <- max(spld)
+}else{
+ minp <- apply(spld, 2, min)
+ maxp <- apply(spld, 2, max)
+for(i in 1:length(ipl)){
+ envir <- system(paste("r.univar -t map=", ipl[i], " separator=,", sep=""), intern=TRUE) # check: use separator in grass7 / fs in grass64
+ envir <- as.numeric(unlist(strsplit(envir[2], split=",")))
+ envmax <- ifelse(envir[4]==maxp[i],maxp[i]+(maxp[i]-minp[i])*0.001,envir[4])
+ envmin <- ifelse(envir[3]==minp[i],minp[i]-(maxp[i]-minp[i])*0.001,envir[3])
+ if(is.null(dim(spld))){
+ a <- table(spld)
+ }else{a <- table(spld[,i])
+ x1 <- as.numeric(rownames(a))
+ x2 <- c(x1[-1],envmax)
+ x3 <- x1 + (x2-x1)/1000
+ a1 <- paste(envmin, paste(x1,x3,sep=",", collapse=","), envmax, sep=",")
+ b <- round(cumsum(as.numeric(a))/sum(a)*100,3)
+ a2 <- paste(0, 0, paste(b, b, sep=",", collapse=","), sep=",")
+ a3 <- paste(strsplit(a1,",")[[1]],strsplit(a2,",")[[1]],sep=",", collapse=",")
+ system(paste("r.mapcalc '", tml[i], " = graph(", ipl[i], ",", a3, ")'", sep=""))
+ system(paste("r.mapcalc '", opi[i], " = if(", tml[i], "==0, (float(", ipl[i], ")-", minp[i], ")/(", maxp[i], "-", minp[i], ") *100.0, if(", tml[i], "<=50, 2 * ", tml[i], ", if(", tml[i], "<100.0, 2 * (100.0- ", tml[i], "), (", maxp[i], "- float(", ipl[i], "))/(", maxp[i], "-", minp[i], ") * 100.0)))'", sep=""))
+ system(paste("g.remove rast=", tml[i], sep=""))
+ # plotting the accumulative frequency plots for each bioclim variable
+ #d1 <- paste(envir[3], paste(x1,x3,sep=",", collapse=","), envir[4], sep=",")
+ #d2 <- paste(0, 0, paste(b, b, sep=",", collapse=","), sep=",")
+ #png(paste(ipn, ".png", sep=""))
+ #plot(strsplit(d1,",")[[1]],strsplit(d2,",")[[1]],type="l", xlab=ipn[i], ylab="% plots")
+ #dev.off()
+system(paste("r.series output=", opc, " input=", paste(opi, collapse=","), " method=minimum", sep=""))
+# Optionally, calculating extra layers (min_raster, mean and median)
+# Defines categories for min_raster
+if(args[7]==1){
+ system(paste("r.series output=", opc, "_MoD input=", paste(opi, collapse=","), " method=min_raster", sep=""))
+ nuv <- cbind(seq(from=0, to=length(ipn)-1, by = 1), ipn)
+ reclvar <- apply(nuv,1,function(x){paste(x[1],x[2], sep=":")})
+ tmpclas <- tempfile(pattern = "classification.rules.")
+ sink(tmpclas)
+ for(i in 1:length(reclvar)){
+ cat(reclvar[i]); cat("\n")
+ sink()
+ system(paste("r.category map=", opc, "_MoD rules=", tmpclas, sep=""))
+ unlink(tmpclas)
+if(args[8]==1){
+ system(paste("r.series output=", opc, "_mean input=", paste(opi, collapse=","), " method=minimum", sep=""))
+if(args[9]==1){
+ system(paste("r.series output=", opc, "_median input=", paste(opi, collapse=","), " method=median", sep=""))
+EOF
+# RGrass script generation
+RGRASSSCRIPT="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$RGRASSSCRIPT" ] ; then
+ g.message -e 'ERROR: unable to create temporary file for RGrass script' 1>&2
+ exit 1
+fi
+writeScript "$RGRASSSCRIPT"
+## RGrass call
+# Message
+g.message message='Calculating MESS layers.. this may take some time'
+##using R to create MESS layers
+#--slave
+R --vanilla --args "$arrIN" "${INMAPS}" "$arrOUT" "$tmpLY" "${GIS_OPT_VECTOR_INPUT}" "${GIS_OPT_COLUMNS}" "$GIS_FLAG_M" "$GIS_FLAG_K" "$GIS_FLAG_L" < "$RGRASSSCRIPT" >> "$LOGFILE" 2>&1
+if [ $? -ne 0 ] ; then
+ echo "ERROR: an error occurred during R script execution" 1>&2
+ exit 1
+fi
+g.message "Finished"
Property changes on: grass-addons/grass7/raster/r.mess/r.mess
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass7/raster/r.mess/r.mess.html
--- grass-addons/grass7/raster/r.mess/r.mess.html (rev 0)
+++ grass-addons/grass7/raster/r.mess/r.mess.html 2012-10-16 08:59:20 UTC (rev 53418)
@@ -0,0 +1,126 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<title>GRASS GIS manual: r.mess</title>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+<link rel="stylesheet" href="grassdocs.css" type="text/css">
+</head>
+<body bgcolor="white">
+<img src="grass_logo.png" alt="GRASS logo">
+<hr align="center" noshade="noshade" size="6">
+<h2>NAME</h2>
+<em><b>r.mess</b></em> - Computes the individual and multivariate
+environmental similarity surfaces (IESS and MESS)<br>
+<h2>KEYWORDS</h2>
+<h2>SYNOPSIS</h2>
+<div id="name"><b>r.mess</b><br>
+</div>
+<b>r.mess help</b><br>
+<div id="synopsis"><b>r.mess</b> [-<b>mkl</b>] <b>vector_input</b>=<em>name</em>
+<b>raster_input</b>=<em>names</em>[,<i>names</i>,...] <b>output</b>=<em>name</em>
+[<b>columns</b>=<em>string</em>] [--<b>overwrite</b>] [--<b>verbose</b>]
+[--<b>quiet</b>] </div>
+<div id="flags">
+<h3>Flags:</h3>
+<dl>
+ <dt><b>-m</b></dt>
+ <dd>Most dissimilar variable (MoD)</dd>
+ <dt><b>-k</b></dt>
+ <dd>Calculate MESS_mean - the mean value of the individual <br>
+ </dd>
+ <dt><b>-l</b></dt>
+ <dd>Calculate MESS_median</dd>
+ <dt><b>--overwrite</b></dt>
+ <dd>Allow output files to overwrite existing files</dd>
+ <dt><b>--verbose</b></dt>
+ <dd>Verbose module output</dd>
+ <dt><b>--quiet</b></dt>
+ <dd>Quiet module output</dd>
+</dl>
+</div>
+<div id="parameters">
+<h3>Parameters:</h3>
+<dl>
+ <dt><b>vector_input</b>=<em>name</em> <b>[required]</b></dt>
+ <dd>Reference points</dd>
+ <dt><b>raster_input</b>=<em>names[,<i>names</i>,...]</em> <b>[required]</b></dt>
+ <dd>Input raster map(s)</dd>
+ <dt><b>output</b>=<em>name</em> <b>[required]</b></dt>
+ <dd>Root name of the output MESS data layers</dd>
+ <dt><b>columns</b>=<em>string</em></dt>
+ <dd>Columns with environmental variables</dd>
+ <dd>Default: <em>Same names as input layers</em></dd>
+</dl>
+</div>
+<div id="description">
+<h2>DESCRIPTION</h2>
+<dl>
+ <p><em>r.mess</em> computes the "Multivariate Environmental
+Similarity
+Surfaces" (MESS) in GRASS using R as backend. The
+MESS index was proposed by Elith et al (2010) and is also
+implemented in the Maxent software. The MESS approach
+can be described as follows (from Elith et al 2010):
+"The multivariate environmental similarity surface (MESS) calculation
+represents how similar a point is to a reference set of points, with
+respect to a set of predictor variables (V1, V2, ...). The values in
+the MESS are
+influenced by the full distribution of the reference points, so that
+sites within the environmental range of the reference points but in
+relatively unusual environments will have a smaller value than those in
+very common environments."</p>
+ <p>This module will also compute the individual environmental
+similarity surfaces (IESS), which represents how similar a point is to
+a set of reference set of points for each of the input variable. MESS
+is then simply calculated as the minimum of its similarity with respect
+to each variable.<br>
+ <br>
+The IESS can have negative values – these are sites where the variable
+has a
+value that is outside the range in the reference set. A negative MESS
+thus represents sites where at least one variable has a value that is
+outside the range of environments over the reference set, so these are
+novel environments.<br>
+ </p>
+ <p>In addition to the MESS, which is the minimum(IESS), the r.mess
+function also allows to compute mean and medium of the IESS layers.<br>
+ </p>
+</dl>
+</div>
+<div id="see also">
+<h2>SEE ALSO</h2>
+There is also a similar function implemented for R using the R package <span style="font-style: italic;">raster</span>. See <a href="http://rossijeanpierre.wordpress.com/2012/08/13/computing-the-multivariate-environmental-similarity-surfaces-mess-index-in-r/">here</a>. Since October 3 2012, this function is part of the dismo package in R.
+for more information and the script.<br>
+</div>
+<div id="authors">
+<h2>AUTHORS</h2>
+Contact: <a href="http://ecodiv.org/contact.html">Paulo van Breugel</a>
+</div>
+<div id="references">
+<h2>REFERENCES</h2>
+<ol>
+ <li>Elith, J., Kearney, M., & Phillips, S. 2010. The art of
+modelling range-shifting species. Methods in Ecology and Evolution 1:
+330–342.</li>
+</ol>
+</div>
+<br>
+<br>
+</body></html>
