[GRASS-SVN] r53450 - grass/branches/develbranch_6/gui/wxpython/gui_core
svn_grass at osgeo.org
Wed Oct 17 12:28:09 PDT 2012
Author: martinl
Date: 2012-10-17 12:28:09 -0700 (Wed, 17 Oct 2012)
New Revision: 53450
grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py
wxGUI: Select - mapset is not selectable (don't dismiss)
(merge r53449 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py 2012-10-17 19:26:44 UTC (rev 53449)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/gselect.py 2012-10-17 19:28:09 UTC (rev 53450)
@@ -506,19 +506,21 @@
if self.seltree.GetRootItem() == self.seltree.GetItemParent(item):
self.value = [] # cannot select mapset item
+ evt.Skip()
+ return
+ mapsetItem = self.seltree.GetItemParent(item)
+ fullName = self.seltree.GetItemText(item)
+ if self.fullyQualified:
+ fullName += '@' + self.seltree.GetItemText(mapsetItem).split(':', -1)[1].strip()
+ if self.multiple is True:
+ # text item should be unique
+ self.value.append(fullName)
else:
- mapsetItem = self.seltree.GetItemParent(item)
- fullName = self.seltree.GetItemText(item)
- if self.fullyQualified:
- fullName += '@' + self.seltree.GetItemText(mapsetItem).split(':', -1)[1].strip()
- if self.multiple is True:
- # text item should be unique
- self.value.append(fullName)
- else:
- self.value = [fullName]
+ self.value = [fullName]
- self.Dismiss()
+ self.Dismiss()
evt.Skip()
