[GRASS-SVN] r53451 - in grass/branches/develbranch_6/gui/wxpython: dbmgr gui_core
svn_grass at osgeo.org
Wed Oct 17 12:59:51 PDT 2012
Author: martinl
Date: 2012-10-17 12:59:51 -0700 (Wed, 17 Oct 2012)
New Revision: 53451
grass/branches/develbranch_6/gui/wxpython/dbmgr/manager.py
grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
wxGUI: fix usage of internal variables
Modified: grass/branches/develbranch_6/gui/wxpython/dbmgr/manager.py
--- grass/branches/develbranch_6/gui/wxpython/dbmgr/manager.py 2012-10-17 19:28:09 UTC (rev 53450)
+++ grass/branches/develbranch_6/gui/wxpython/dbmgr/manager.py 2012-10-17 19:59:51 UTC (rev 53451)
@@ -579,8 +579,8 @@
self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
try:
- self.map = self.parent.curr_page.maptree.Map
- self.mapdisplay = self.parent.curr_page.maptree.mapdisplay
+ self.map = self.parent.GetLayerTree().GetMap()
+ self.mapdisplay = self.parent.GetLayerTree().GetMapDisplay()
except:
self.map = self.mapdisplay = None
@@ -1274,7 +1274,7 @@
# set opacity based on queried layer
if self.parent and self.parent.GetName() == "LayerManager" and \
self.treeItem:
- maptree = self.parent.curr_page.maptree
+ maptree = self.parent.GetLayerTree()
opacity = maptree.GetPyData(self.treeItem)[0]['maplayer'].GetOpacity(float = True)
self.qlayer.SetOpacity(opacity)
if zoom:
@@ -2102,9 +2102,9 @@
name = dlg.GetName(full = True)
if name and dlg.IsChecked('add'):
# add layer to map layer tree
- self.parent.curr_page.maptree.AddLayer(ltype = 'vector',
- lname = name,
- lcmd = ['d.vect', 'map=%s' % name])
+ self.parent.GetLayerTree().AddLayer(ltype = 'vector',
+ lname = name,
+ lcmd = ['d.vect', 'map=%s' % name])
dlg.Destroy()
def OnDeleteSelected(self, event):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py 2012-10-17 19:28:09 UTC (rev 53450)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py 2012-10-17 19:59:51 UTC (rev 53451)
@@ -527,20 +527,21 @@
"Try adding it as a command layer instead.") % command[0])
return
+ mapdisp = self.parent.GetMapDisplay()
if layertype == 'barscale':
- self.parent.curr_page.maptree.GetMapDisplay().OnAddBarscale(None)
+ mapdisp.OnAddBarscale(None)
elif layertype == 'rastleg':
- self.parent.curr_page.maptree.GetMapDisplay().OnAddLegend(None)
+ mapdisp.OnAddLegend(None)
elif layertype == 'redraw':
- self.parent.curr_page.maptree.GetMapDisplay().OnRender(None)
+ mapdisp.OnRender(None)
else:
# add layer into layer tree
lname, found = utils.GetLayerNameFromCmd(command, fullyQualified = True,
layerType = layertype)
if self.parent.GetName() == "LayerManager":
- self.parent.curr_page.maptree.AddLayer(ltype = layertype,
- lname = lname,
- lcmd = command)
+ self.parent.GetLayerTree().AddLayer(ltype = layertype,
+ lname = lname,
+ lcmd = command)
else:
# other GRASS commands (r|v|g|...)
