[GRASS-SVN] r53596 - in grass/trunk: general/g.rename vector/v.proj
svn_grass at osgeo.org
Sun Oct 28 10:49:44 PDT 2012
Author: martinl
Date: 2012-10-28 10:49:44 -0700 (Sun, 28 Oct 2012)
New Revision: 53596
grass/trunk/general/g.rename/main.c
grass/trunk/vector/v.proj/main.c
replace G__location_path() by G_location_path()
Modified: grass/trunk/general/g.rename/main.c
--- grass/trunk/general/g.rename/main.c 2012-10-28 17:48:16 UTC (rev 53595)
+++ grass/trunk/general/g.rename/main.c 2012-10-28 17:49:44 UTC (rev 53596)
@@ -56,7 +56,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- location_path = G__location_path();
+ location_path = G_location_path();
mapset = G_mapset();
for (n = 0; n < nlist; n++) {
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c 2012-10-28 17:48:16 UTC (rev 53595)
+++ grass/trunk/vector/v.proj/main.c 2012-10-28 17:49:44 UTC (rev 53596)
@@ -38,7 +38,7 @@
int out_zone = 0;
int overwrite; /* overwrite output map */
const char *mapset;
- const char *omap_name, *map_name, *iset_name, *oset_name, *iloc_name;
+ const char *omap_name, *map_name, *iset_name, *iloc_name;
struct pj_info info_in;
struct pj_info info_out;
const char *gbase;
@@ -148,8 +148,6 @@
else
iset_name = G_store(G_mapset());
- oset_name = G_store(G_mapset());
iloc_name = ilocopt->answer;
if (ibaseopt->answer)
@@ -222,7 +220,7 @@
exit(EXIT_FAILURE);
Vect_set_open_level(1);
- G_debug(1, "Open old: location: %s mapset : %s", G__location_path(),
+ G_debug(1, "Open old: location: %s mapset : %s", G_location_path(),
G_mapset());
Vect_open_old(&Map, map_name, mapset);
@@ -362,7 +360,7 @@
tgt_box.S = y;
- G_debug(1, "Open new: location: %s mapset : %s", G__location_path(),
+ G_debug(1, "Open new: location: %s mapset : %s", G_location_path(),
G_mapset());
Vect_open_new(&Out_Map, omap_name, Vect_is_3d(&Map));
