[GRASS-SVN] r53597 - in grass/trunk/db/drivers: . postgres sqlite
Sun Oct 28 11:05:19 PDT 2012
Author: martinl
Date: 2012-10-28 11:05:18 -0700 (Sun, 28 Oct 2012)
New Revision: 53597
Added:
   grass/trunk/db/drivers/sqlite/listdb.c
   grass/trunk/db/drivers/README
   grass/trunk/db/drivers/postgres/listdb.c
   grass/trunk/db/drivers/sqlite/db.c
DB drivers: SQLite - create_database() and list_databases() implemented
            PostgreSQL - list_databases() enabled
Modified: grass/trunk/db/drivers/README
--- grass/trunk/db/drivers/README	2012-10-28 17:49:44 UTC (rev 53596)
+++ grass/trunk/db/drivers/README	2012-10-28 18:05:18 UTC (rev 53597)
@@ -2,13 +2,13 @@
 The driver functions are for internal usage.
 The DBMI API to be used for module programming is available in:
-grass6/lib/db/
+lib/db/
 NOTE:
 db__driver_* functions are implemented in a driver.  If some of them
 are not used or defined, the driver will use stub functions in
-grass6/lib/db/stubs/
+lib/db/stubs/
 For some platforms like Cygwin, multiply defined symbols are not
 resolved in a way that UNIX does.  Even worse is that it is impossible
@@ -23,6 +23,6 @@
 Function pointers are defined in grass6/lib/db/dbmi_driver/dbstubs.h
 This header file can be generated with
-grass6/lib/db/dbmi_driver/mk_dbstubs_h.sh
+lib/db/dbmi_driver/mk_dbstubs_h.sh
-Please read grass6/lib/db/README
+Please read lib/db/README
Modified: grass/trunk/db/drivers/postgres/listdb.c
--- grass/trunk/db/drivers/postgres/listdb.c	2012-10-28 17:49:44 UTC (rev 53596)
+++ grass/trunk/db/drivers/postgres/listdb.c	2012-10-28 18:05:18 UTC (rev 53597)
@@ -7,7 +7,9 @@
   (>=v2). Read the file COPYING that comes with GRASS for details.
   \author Radim Blazek
+  \author Updated for GRASS 7 by Martin Landa <landa.martin gmail.com>
 #include <grass/dbmi.h>
 #include <grass/glocale.h>
 #include "globals.h"
@@ -26,18 +28,22 @@
     *dbcount = 0;
     /* TODO: the solution below is not good as user usually does not have permissions for "template1" */
-    db_d_append_error(_("db_driver_list_databases() is not implemented"));
-    db_d_report_error();
-    return DB_FAILED;
+    /*    db_d_append_error(_("db_driver_list_databases() is not implemented"));
+          db_d_report_error();
+          return DB_FAILED;
-    if (npaths > 0) {
-	G_debug(3, "location: %s", db_get_string(dbpath));
-	if (parse_conn(db_get_string(dbpath), &pgconn) == DB_FAILED) {
-	    return DB_FAILED;
+    if (npaths < 1) {
+        db_d_append_error(_("No path given"));
+        return DB_FAILED;
+    if (parse_conn(db_get_string(dbpath), &pgconn) == DB_FAILED) {
+        return DB_FAILED;
     G_debug(3, "host = %s, port = %s, options = %s, tty = %s",
 	    pgconn.host, pgconn.port, pgconn.options, pgconn.tty);
Modified: grass/trunk/db/drivers/sqlite/db.c
--- grass/trunk/db/drivers/sqlite/db.c	2012-10-28 17:49:44 UTC (rev 53596)
+++ grass/trunk/db/drivers/sqlite/db.c	2012-10-28 18:05:18 UTC (rev 53597)
@@ -14,6 +14,7 @@
 #include <stdlib.h>
 #include <string.h>
+#include <unistd.h>
 #include <grass/gis.h>
@@ -31,7 +32,7 @@
 int db__driver_open_database(dbHandle * handle)
-    char name2[2000];
+    char name2[GPATH_MAX];
     const char *name;
     G_debug(3, "\ndb_driver_open_database()");
@@ -81,8 +82,9 @@
     G_debug(2, "name2 = '%s'", name2);
     if (sqlite3_open(name2, &sqlite) != SQLITE_OK) {
-	db_d_append_error("%s %s",
-			  _("Unable to open database: "),
+	db_d_append_error("%s %s\n%s",
+			  _("Unable to open database:"),
+                          name2,
 			  (char *)sqlite3_errmsg(sqlite));
 	return DB_FAILED;
@@ -110,3 +112,37 @@
     return DB_OK;
+ * \brief Create new empty SQLite database.
+ * \param handle dbHandle
+ * \return DB_OK on success
+ * \return DB_FAILED on failure
+int db__driver_create_database(dbHandle *handle)
+    const char *name;
+    name = db_get_handle_dbname(handle);
+    G_debug(1, "db_create_database(): %s", name);
+    if (access(name, F_OK) == 0) {
+        db_d_append_error(_("Database <%s> already exists"), name);
+        return DB_FAILED;
+    if (sqlite3_open(name, &sqlite) != SQLITE_OK) {
+			  _("Unable to create database:"),
+                          name,
+			  (char *) sqlite3_errmsg(sqlite));
+	return DB_FAILED;
+    return DB_FAILED;
Added: grass/trunk/db/drivers/sqlite/listdb.c
--- grass/trunk/db/drivers/sqlite/listdb.c	                        (rev 0)
+++ grass/trunk/db/drivers/sqlite/listdb.c	2012-10-28 18:05:18 UTC (rev 53597)
@@ -0,0 +1,171 @@
+  \file db/drivers/sqlite/listdb.c
+  \brief DBMI - Low Level SQLite database driver (list databases)
+  This program is free software under the GNU General Public License
+  (>=v2). Read the file COPYING that comes with GRASS for details.
+  \author  Martin Landa <landa.martin gmail.com>
+#include <dirent.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+#include "globals.h"
+#include "proto.h"
+static int listdb(dbString*, int, dbHandle**, int *);
+static void freedb(char **, int);
+  \brief List SQLite databases for given paths.
+  List all files with extension <b>.db</b> and it's possible to open
+  them as SQLite database.
+  \todo Do it better?
+  \param path list of paths
+  \param npaths number of given paths (?)
+  \param[out] handles output dbHandles
+  \param[out] count number of output handles
+  \return DB_OK on success
+  \return DB_FAILED on failure
+int db__driver_list_databases(dbString* path, int npaths,
+                              dbHandle** handles, int *count)
+    if (npaths < 1) {
+        return DB_FAILED;
+    if (strcmp(db_get_string(path), "") == 0) {
+        /* current location */
+        char *cpath;
+        dbString spath;
+        *handles = NULL;
+        *count = 0;
+        cpath = G_mapset_path();
+        db_init_string(&spath);
+        db_set_string(&spath, cpath);
+        G_free(cpath);
+        if (listdb(&spath, 1, handles, count) != DB_OK)
+            return DB_FAILED;
+    else {
+        if (listdb(path, npaths, handles, count) != DB_OK)
+            return DB_FAILED;
+    return DB_OK;
+/* list .db file in the given path
+   TODO: do it better?
+int listdb(dbString* path, int npaths,
+    int i, hcount, len;
+    dbHandle *hlist;
+    char **dlist;
+    DIR *dirp;
+    struct dirent *dp;
+    if (npaths < 0)
+        return DB_FAILED;
+    hcount = 0;
+    G_debug(3, "path = %s", db_get_string(path));
+    /* count number of dbs */
+    dirp = opendir(db_get_string(path));
+    if (dirp == NULL) {
+        db_d_append_error(_("Unable to open directory '%s'"),
+                          db_get_string(path));
+        return DB_FAILED;
+    dlist = NULL;
+    while ((dp = readdir(dirp)) != NULL) {
+        if (dp->d_name[0] == '.')
+            continue;
+        len = strlen(dp->d_name) - 3;
+        /* try to open file as SQLite database */
+        if (len > 0 &&
+            G_strcasecmp(dp->d_name + len, ".db") == 0 &&
+            sqlite3_open(dp->d_name, &sqlite) == SQLITE_OK) {
+            if (sqlite3_close(sqlite) == SQLITE_BUSY) {
+                db_d_append_error(_("SQLite database connection '%s' is still busy"),
+                                  dp->d_name);
+                continue;
+            hcount++;
+            dlist = (char **) G_realloc(dlist, hcount * sizeof(char *));
+            G_debug(3, "%s", dp->d_name);
+            dlist[hcount-1] = G_store(dp->d_name);
+    G_debug(1, "db count = %d", hcount);
+    /* allocate handles */
+    hlist = db_alloc_handle_array(hcount);
+    if (hlist == NULL) {
+        db_d_append_error(_("Out of memory"));
+        freedb(dlist, hcount);
+        closedir(dirp);
+        return DB_FAILED;
+    /* get db names */
+    for (i = 0; i < hcount; i++) {
+        db_init_handle(&hlist[i]);
+        if (db_set_handle(&hlist[i], dlist[i], NULL) != DB_OK) {
+            db_d_append_error(_("Unable to set handle"));
+            db_free_handle_array(hlist, hcount);
+            closedir(dirp);
+            return DB_FAILED;
+    closedir(dirp);
+    *handles = hlist;
+    *count = hcount;
+    return DB_OK;
+/* free allocated memory */
+static void freedb(char **dblist, int count)
+    int i;
+    for(i = 0; i < count; i++)
+        G_free(dblist[i]);
+    G_free(dblist);
Property changes on: grass/trunk/db/drivers/sqlite/listdb.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
