[GRASS-SVN] r53605 - grass/trunk/db/drivers/sqlite
Mon Oct 29 07:56:17 PDT 2012
Author: martinl
Date: 2012-10-29 07:56:17 -0700 (Mon, 29 Oct 2012)
New Revision: 53605
   grass/trunk/db/drivers/sqlite/db.c
SQLite DB driver: implement delete_database()
Modified: grass/trunk/db/drivers/sqlite/db.c
--- grass/trunk/db/drivers/sqlite/db.c	2012-10-29 09:43:06 UTC (rev 53604)
+++ grass/trunk/db/drivers/sqlite/db.c	2012-10-29 14:56:17 UTC (rev 53605)
@@ -102,7 +102,6 @@
  * \return always returns DB_OK
 int db__driver_close_database(void)
     G_debug(3, "db_close_database()");
@@ -117,11 +116,10 @@
  * \brief Create new empty SQLite database.
  * \param handle dbHandle
  * \return DB_OK on success
  * \return DB_FAILED on failure
 int db__driver_create_database(dbHandle *handle)
     const char *name;
@@ -144,5 +142,27 @@
 	return DB_FAILED;
-    return DB_FAILED;
+    return DB_OK;
+ * \brief Delete existing SQLite database.
+ * \param handle dbHandle
+ * \return DB_OK on success
+ * \return DB_FAILED on failure
+int db__driver_delete_database(dbHandle *handle)
+    const char *name;
+    name = db_get_handle_dbname(handle);
+    if (access(name, F_OK) != 0) {
+        db_d_append_error(_("Database <%s> not found"), name);
+        db_d_report_error();
+        return DB_FAILED;
+    return remove(name) == 0 ? DB_OK : DB_FAILED;
