[GRASS-SVN] r53606 - grass/trunk/db/drivers/postgres
svn_grass at osgeo.org
Mon Oct 29 07:57:47 PDT 2012
Author: martinl
Date: 2012-10-29 07:57:47 -0700 (Mon, 29 Oct 2012)
New Revision: 53606
grass/trunk/db/drivers/postgres/db.c
PostgreSQL DB driver: create/delete_database() implemented
Modified: grass/trunk/db/drivers/postgres/db.c
--- grass/trunk/db/drivers/postgres/db.c 2012-10-29 14:56:17 UTC (rev 53605)
+++ grass/trunk/db/drivers/postgres/db.c 2012-10-29 14:57:47 UTC (rev 53606)
@@ -7,6 +7,7 @@
(>=v2). Read the file COPYING that comes with GRASS for details.
\author Radim Blazek
+ \author Create/drop database by Martin Landa <landa.martin gmail.com>
#include <stdlib.h>
@@ -26,6 +27,8 @@
+static int create_delete_db();
int db__driver_open_database(dbHandle * handle)
char buf[500];
@@ -187,3 +190,95 @@
PQfinish(pg_conn);
return DB_OK;
+ \brief Create new empty PostgreSQL database.
+ \param handle dbHandle
+ \return DB_OK on success
+ \return DB_FAILED on failure
+int db__driver_create_database(dbHandle *handle)
+ return create_delete_db(handle, TRUE);
+ \brief Drop existing PostgreSQL database.
+int db__driver_delete_database(dbHandle *handle)
+ return create_delete_db(handle, FALSE);
+/* create or drop database */
+int create_delete_db(dbHandle *handle, int create)
+ dbString stmt;
+ const char *template_db, *name, *user, *password;
+ PGCONN pgconn;
+ PGresult *res;
+ db_init_string(&stmt);
+ template_db = "template1";
+ name = db_get_handle_dbname(handle); /* database to create */
+ if (parse_conn(template_db, &pgconn) == DB_FAILED) {
+ db_d_report_error();
+ return DB_FAILED;
+ G_debug(3,
+ "db_driver_create_database(): host = %s, port = %s, options = %s, tty = %s, "
+ "dbname = %s, user = %s, password = %s, "
+ "schema = %s", pgconn.host, pgconn.port, pgconn.options,
+ pgconn.tty, pgconn.dbname, pgconn.user, pgconn.password,
+ pgconn.schema);
+ db_get_login("pg", template_db, &user, &password);
+ pg_conn = PQsetdbLogin(pgconn.host, pgconn.port, pgconn.options, pgconn.tty,
+ pgconn.dbname, user, password);
+ if (PQstatus(pg_conn) == CONNECTION_BAD) {
+ db_d_append_error(_("Connection failed."));
+ db_d_append_error("\n");
+ db_d_append_error(PQerrorMessage(pg_conn));
+ PQfinish(pg_conn);
+ return DB_FAILED;
+ /* create new database */
+ if (create)
+ db_set_string(&stmt, "CREATE DATABASE ");
+ else
+ db_set_string(&stmt, "DROP DATABASE ");
+ db_append_string(&stmt, name);
+ res = PQexec(pg_conn,
+ db_get_string(&stmt));
+ if (!res || PQresultStatus(res) != PGRES_COMMAND_OK) {
+ if (create)
+ db_d_append_error(_("Unable to create database <%s>"), name);
+ else
+ db_d_append_error(_("Unable to drop database <%s>"), name);
+ PQclear(res);
+ return DB_FAILED;
+ PQclear(res);
+ return DB_OK;
