[GRASS-SVN] r53625 - grass/trunk/vector/v.kernel
svn_grass at osgeo.org
Wed Oct 31 12:36:29 PDT 2012
Author: mmetz
Date: 2012-10-31 12:36:28 -0700 (Wed, 31 Oct 2012)
New Revision: 53625
grass/trunk/vector/v.kernel/main.c
v.kernel: use topology to get line type
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2012-10-31 19:34:18 UTC (rev 53624)
+++ grass/trunk/vector/v.kernel/main.c 2012-10-31 19:36:28 UTC (rev 53625)
@@ -687,7 +687,7 @@
n = Vect_get_node_n_lines(Map, node);
for (i = 0; i < n; i++) {
line = Vect_get_node_line(Map, node, i);
- type = Vect_read_line(Map, NULL, NULL, abs(line));
+ type = Vect_get_line_type(Map, abs(line));
if (type & GV_LINES)
count++;
