[GRASS-SVN] r53626 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Wed Oct 31 12:50:11 PDT 2012
Author: mmetz
Date: 2012-10-31 12:50:11 -0700 (Wed, 31 Oct 2012)
New Revision: 53626
grass/trunk/display/d.vect/area.c
d.vect: skip isles asap
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c 2012-10-31 19:36:28 UTC (rev 53625)
+++ grass/trunk/display/d.vect/area.c 2012-10-31 19:50:11 UTC (rev 53626)
@@ -61,6 +61,11 @@
if (!Vect_area_alive(Map, area))
continue;
+ centroid = Vect_get_area_centroid(Map, area);
+ if (!centroid) {
+ continue;
/* Check box */
Vect_get_area_box(Map, area, &box);
if (box.N < window->south || box.S > window->north ||
@@ -84,7 +89,6 @@
continue;
else {
- centroid = Vect_get_area_centroid(Map, area);
G_debug(3, "centroid = %d", centroid);
if (centroid < 1)
continue;
@@ -107,7 +111,6 @@
else if (Clist->field > 0) {
found = FALSE;
G_debug(3, "\tcentroid = %d", centroid);
if (centroid < 1)
continue;
@@ -159,7 +162,7 @@
(Clist->field > 0 ? Clist->field :
(Cats->n_cats > 0 ? Cats->field[0] : 1)));
- if (!Vect_get_area_centroid(Map, area) && cat == -1) {
+ if (cat == -1) {
continue;
