[GRASS-SVN] r53084 - grass/trunk/lib/vector
svn_grass at osgeo.org
Tue Sep 4 09:14:56 PDT 2012
Author: wenzeslaus
Date: 2012-09-04 09:14:56 -0700 (Tue, 04 Sep 2012)
New Revision: 53084
Added:
grass/trunk/lib/vector/vectorlib_indices.dox
Removed:
grass/trunk/lib/vector/vectorlib_spatialindex.dox
grass/trunk/lib/vector/vectorlib.dox
grass/trunk/lib/vector/vectorlib_files.dox
grass/trunk/lib/vector/vectorlib_libraries.dox
dox: fixing titles and references (including invisible problem with vlibs label)
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2012-09-04 13:48:24 UTC (rev 53083)
+++ grass/trunk/lib/vector/vectorlib.dox 2012-09-04 16:14:56 UTC (rev 53084)
@@ -2,6 +2,8 @@
by GRASS Development Team (http://grass.osgeo.org)
+\tableofcontents
\par Table of contents
- \ref vlibBackground
- \ref vlibIntro
@@ -18,10 +20,10 @@
- \ref vlibSeealso
\par Subpages
-- \subpage vlibs
+- \subpage vlibDescription
- \subpage vlibFormat
- \subpage vlibTopology
-- \subpage vlibSpatialIndex
+- \subpage vlibIndices
- \subpage vlibAscii
- \subpage vlibOgr
- \subpage vlibTin
Modified: grass/trunk/lib/vector/vectorlib_files.dox
--- grass/trunk/lib/vector/vectorlib_files.dox 2012-09-04 13:48:24 UTC (rev 53083)
+++ grass/trunk/lib/vector/vectorlib_files.dox 2012-09-04 16:14:56 UTC (rev 53084)
@@ -2,6 +2,8 @@
+\tableofcontents
- \ref vlibDirectoryStructure
@@ -159,7 +161,7 @@
Besides internal library functions there are two main libraries:
- Vlib (Vector library), see \ref vlibIntro
-- DGLib (Directed Graph Library), see \ref vlibDglib
+- DGLib (Directed Graph Library), see \ref dglib
For historical reasons, there are two internal libraries:
Copied: grass/trunk/lib/vector/vectorlib_indices.dox (from rev 53077, grass/trunk/lib/vector/vectorlib_spatialindex.dox)
--- grass/trunk/lib/vector/vectorlib_indices.dox (rev 0)
+++ grass/trunk/lib/vector/vectorlib_indices.dox 2012-09-04 16:14:56 UTC (rev 53084)
@@ -0,0 +1,236 @@
+/*! \page vlibIndices Spatial and category indices
+by GRASS Development Team (http://grass.osgeo.org)
+\tableofcontents
+\par Table of contents
+- \ref vlibSpidx
+ - \ref vlibSidxFileFormat
+- \ref vlibCidx
+ - \ref vlibCidxFileFormat
+ - \ref vlibCidxFileHead
+\section vlibSpidx Vector library spatial index management
+Spatial index (based on R*-tree) is created with topology, see \ref
+RTree data structure.
+Spatial index occupies a lot of memory but it is necessary for
+topology building. Also, it takes some time to release the memory
+occupied by spatial index (see dig_spidx_free()). The spatial index can
+also be built in file to save memory by setting the environment variable
+GRASS_VECTOR_LOWMEM.
+The function building topology - Vect_build() - is usually called at
+the end of modules (before Vect_close()) so it is faster to call
+<tt>exit()</tt> and operating system releases all the memory much
+faster. By default the memory is not released.
+It is possible to call Vect_set_release_support() before Vect_close()
+to enforce memory release, but it takes some time on large files.
+The spatial index is stored in file and not loaded for old vectors that
+are not updated, saving a lot of memory. Spatial queries are done in
+file.
+Currently most of the modules do not release the memory occupied for
+spatial index and work like this (pseudocode):
+\code
+int main
+ Vect_open_new();
+ /* writing new vector */
+ Vect_build();
+ Vect_close(); /* memory is not released */
+\endcode
+In general it is possible to free the memory with Vect_set_release_support()
+such as:
+\code
+int main
+ Vect_open_new();
+ Vect_build();
+ Vect_set_release_support();
+ Vect_close(); /* memory is released */
+\endcode
+but it takes a bit longer.
+It makes sense to release the spatial index if it is used only at the beginning
+of a module or in permanently running programs like QGIS. Note that this
+applies only when creating a new vector or updating an old vector.
+For example:
+\code
+int main
+ Vect_open_update();
+ /* select features using spatial index, e.g. Vect_select_lines_by_box() */
+ /* do some processing which needs memory */
+\endcode
+See also \ref spatial_index data structure.
+\subsection vlibSidxFileFormat Sidx file format specification
+Spatial index file ('sidx') is read by Vect_open_sidx().
+\subsubsection vlibSidxFileHead Header
+Note: <tt>plus</tt> is instance of \ref Plus_head structure.
+<table border="1" style="border-collapse: collapse" cellpadding="5">
+<tr><td><b>Name</b></td><td><b>Type</b></td><td><b>Number</b></td><td><b>Description</b></td></tr>
+<tr><td>plus->spidx_Version_Major </td><td>C</td><td>1</td><td>file version (major)</td></tr>
+<tr><td>plus->spidx_Version_Minor </td><td>C</td><td>1</td><td>file version (minor)</td></tr>
+<tr><td>plus->spidx_Back_Major</td><td>C</td><td>1</td><td>supported from GRASS version (major)</td></tr>
+<tr><td>plus->spidx_Back_Minor</td><td>C</td><td>1</td><td>supported from GRASS version (minor)</td></tr>
+<tr><td>plus->spidx_port->byte_order</td><td>C</td><td>1</td><td>little or big endian
+ flag; files are written in machine native order but
+ files in both little and big endian order may be
+ readl; zero for little endian</td></tr>
+<tr><td>plus->spidx_port.off_t_size</td><td>C</td><td>1</td><td>off_t size (LFS)</td></tr>
+<tr><td>plus->spidx_head_size</td><td>L</td><td>1</td><td>header size</td></tr>
+<tr><td>plus->spidx_with_z</td><td>C</td><td>1</td><td>2D/3D vector data</td></tr>
+<tr><td>ndims</td><td>C</td><td>1</td><td>Number of dimensions</td></tr>
+<tr><td>nsides</td><td>C</td><td>1</td><td>Number of sides</td></tr>
+<tr><td>nodesize</td><td>I</td><td>1</td><td>%Node size</td></tr>
+<tr><td>nodecard</td><td>I</td><td>1</td><td>%Node card (?)</td></tr>
+<tr><td>leafcard</td><td>I</td><td>1</td><td>Leaf card (?)</td></tr>
+<tr><td>min_node_fill</td><td>I</td><td>1</td><td>Minimum node fill (?)</td></tr>
+<tr><td>min_leaf_fill</td><td>I</td><td>1</td><td>Minimum leaf fill (?)</td></tr>
+<tr><td>plus->Node_spidx->n_nodes</td><td>I</td><td>1</td><td>Number of nodes</td></tr>
+<tr><td>plus->Node_spidx->n_leafs</td><td>I</td><td>1</td><td>Number of leafs</td></tr>
+<tr><td>plus->Node_spidx->n_levels</td><td>I</td><td>1</td><td>Number of levels</td></tr>
+<tr><td>plus->Node_spidx_offset</td><td>O</td><td>1</td><td>%Node offset</td></tr>
+<tr><td>plus->Line_spidx->n_nodes</td><td>I</td><td>1</td><td>Number of nodes</td></tr>
+<tr><td>plus->Line_spidx->n_leafs</td><td>I</td><td>1</td><td>Number of leafs</td></tr>
+<tr><td>plus->Line_spidx->n_levels</td><td>I</td><td>1</td><td>Number of levels</td></tr>
+<tr><td>plus->Line_spidx_offset</td><td>O</td><td>1</td><td>Line offset</td></tr>
+<tr><td>plus->Area_spidx->n_nodes</td><td>I</td><td>1</td><td>Number of nodes</td></tr>
+<tr><td>plus->Area_spidx->n_leafs</td><td>I</td><td>1</td><td>Number of leafs</td></tr>
+<tr><td>plus->Area_spidx->n_levels</td><td>I</td><td>1</td><td>Number of levels</td></tr>
+<tr><td>plus->Area_spidx_offset</td><td>O</td><td>1</td><td>Area offset</td></tr>
+<tr><td>plus->Isle_spidx->n_nodes</td><td>I</td><td>1</td><td>Number of nodes</td></tr>
+<tr><td>plus->Isle_spidx->n_leafs</td><td>I</td><td>1</td><td>Number of leafs</td></tr>
+<tr><td>plus->Isle_spidx->n_levels</td><td>I</td><td>1</td><td>Number of levels</td></tr>
+<tr><td>plus->Isle_spidx_offset</td><td>O</td><td>1</td><td>Isle offset</td></tr>
+<tr><td>plus->Face_spidx_offset</td><td>O</td><td>1</td><td>Face offset</td></tr>
+<tr><td>plus->Volume_spidx_offset</td><td>O</td><td>1</td><td>Volume offset</td></tr>
+<tr><td>plus->Hole_spidx_offset</td><td>O</td><td>1</td><td>Hole offset</td></tr>
+<tr><td>plus->coor_size</td><td>O</td><td>1</td><td>Coor file size</td></tr>
+</table>
+\section vlibCidx Vector library category index management
+The category index (stored in the cidx file) improves the performance
+of all selections by cats/attributes (SQL, e.g. <tt>d.vect
+cats=27591</tt>, <tt>v.extract list=20000-21000</tt>). This avoids
+that all selections have to be made by looping through all vector
+lines. Category index is also essential for simple feature
+representation of GRASS vectors.
+Category index is created for each field. In memory, it is stored in
+\ref Cat_index data structure.
+Category index is built with topology, but it is <b>not updated</b> if
+vector is edited on level 2. Category index is stored in 'cidx' file,
+'cat' array is written/read by one call of dig__fwrite_port_I() or
+dig__fread_port_I().
+Stored values can be retrieved either by index in 'cat' array (if all
+features of given field are required) or by category value (one or few
+features), always by <tt>Vect_cidx_*()</tt> functions.
+To create category index, it will be necessary to rebuild topology for
+all existing vectors. This is an opportunity to make (hopefully) last
+changes in 'topo', 'cidx' formats.
+\subsection vlibCidxFileFormat Cidx file format specification
+Category index file ('cidx') is read by Vect_cidx_open().
+\subsubsection vlibCidxFileHead Header
+<tr><td>plus->cpidx_Version_Major </td><td>C</td><td>1</td><td>file version (major)</td></tr>
+<tr><td>plus->cpidx_Version_Minor </td><td>C</td><td>1</td><td>file version (minor)</td></tr>
+<tr><td>plus->cpidx_Back_Major</td><td>C</td><td>1</td><td>supported from GRASS version (major)</td></tr>
+<tr><td>plus->cpidx_Back_Minor</td><td>C</td><td>1</td><td>supported from GRASS version (minor)</td></tr>
+<tr><td>plus->cidx_port->byte_order</td><td>C</td><td>1</td><td>little or big endian
+<tr><td>plus->cidx_head_size</td><td>L</td><td>1</td><td>cidx head size</td></tr>
+<tr><td>plus->n_cidx</td><td>I</td><td>1</td><td>number of fields</td></tr>
+<tr><td>field</td><td>I</td><td>n_cidx</td><td>field number</td></tr>
+<tr><td>n_cats</td><td>I</td><td>n_cidx</td><td>number of categories</td></tr>
+<tr><td>n_ucats</td><td>I</td><td>n_cidx</td><td>number of unique categories</td></tr>
+<tr><td>n_types</td><td>I</td><td>n_cidx</td><td>number of feature types</td></tr>
+<tr><td>rtype</td><td>I</td><td>n_cidx * n_types</td><td>Feature type</td></tr>
+<tr><td>type[t]</td><td>I</td><td>n_cidx * n_types</td><td>Number of items</td></tr>
+</table>
Modified: grass/trunk/lib/vector/vectorlib_libraries.dox
--- grass/trunk/lib/vector/vectorlib_libraries.dox 2012-09-04 13:48:24 UTC (rev 53083)
+++ grass/trunk/lib/vector/vectorlib_libraries.dox 2012-09-04 16:14:56 UTC (rev 53084)
@@ -1,4 +1,4 @@
-/*! \page vlibs Vector libraries
+/*! \page vlibDescription Vector libraries
Deleted: grass/trunk/lib/vector/vectorlib_spatialindex.dox
--- grass/trunk/lib/vector/vectorlib_spatialindex.dox 2012-09-04 13:48:24 UTC (rev 53083)
+++ grass/trunk/lib/vector/vectorlib_spatialindex.dox 2012-09-04 16:14:56 UTC (rev 53084)
@@ -1,234 +0,0 @@
-/*! \page vlibSpatialIndex Spatial index
-by GRASS Development Team (http://grass.osgeo.org)
-\par Table of contents
-- \ref vlibSpidx
- - \ref vlibSidxFileFormat
-- \ref vlibCidx
- - \ref vlibCidxFileFormat
- - \ref vlibCidxFileHead
-\section vlibSpidx Vector library spatial index management
-Spatial index (based on R*-tree) is created with topology, see \ref
-RTree data structure.
-Spatial index occupies a lot of memory but it is necessary for
-topology building. Also, it takes some time to release the memory
-occupied by spatial index (see dig_spidx_free()). The spatial index can
-also be built in file to save memory by setting the environment variable
-GRASS_VECTOR_LOWMEM.
-The function building topology - Vect_build() - is usually called at
-the end of modules (before Vect_close()) so it is faster to call
-<tt>exit()</tt> and operating system releases all the memory much
-faster. By default the memory is not released.
-It is possible to call Vect_set_release_support() before Vect_close()
-to enforce memory release, but it takes some time on large files.
-The spatial index is stored in file and not loaded for old vectors that
-are not updated, saving a lot of memory. Spatial queries are done in
-file.
-Currently most of the modules do not release the memory occupied for
-spatial index and work like this (pseudocode):
-\code
-int main
- Vect_open_new();
- /* writing new vector */
- Vect_build();
- Vect_close(); /* memory is not released */
-\endcode
-In general it is possible to free the memory with Vect_set_release_support()
-such as:
-\code
-int main
- Vect_open_new();
- Vect_build();
- Vect_set_release_support();
- Vect_close(); /* memory is released */
-\endcode
-but it takes a bit longer.
-It makes sense to release the spatial index if it is used only at the beginning
-of a module or in permanently running programs like QGIS. Note that this
-applies only when creating a new vector or updating an old vector.
-For example:
-\code
-int main
- Vect_open_update();
- /* select features using spatial index, e.g. Vect_select_lines_by_box() */
- /* do some processing which needs memory */
-\endcode
-See also \ref spatial_index data structure.
-\subsection vlibSidxFileFormat Sidx file format specification
-Spatial index file ('sidx') is read by Vect_open_sidx().
-\subsubsection vlibSidxFileHead Header
-Note: <tt>plus</tt> is instance of \ref Plus_head structure.
-<table border="1" style="border-collapse: collapse" cellpadding="5">
-<tr><td><b>Name</b></td><td><b>Type</b></td><td><b>Number</b></td><td><b>Description</b></td></tr>
-<tr><td>plus->spidx_Version_Major </td><td>C</td><td>1</td><td>file version (major)</td></tr>
-<tr><td>plus->spidx_Version_Minor </td><td>C</td><td>1</td><td>file version (minor)</td></tr>
-<tr><td>plus->spidx_Back_Major</td><td>C</td><td>1</td><td>supported from GRASS version (major)</td></tr>
-<tr><td>plus->spidx_Back_Minor</td><td>C</td><td>1</td><td>supported from GRASS version (minor)</td></tr>
-<tr><td>plus->spidx_port->byte_order</td><td>C</td><td>1</td><td>little or big endian
- flag; files are written in machine native order but
- files in both little and big endian order may be
- readl; zero for little endian</td></tr>
-<tr><td>plus->spidx_port.off_t_size</td><td>C</td><td>1</td><td>off_t size (LFS)</td></tr>
-<tr><td>plus->spidx_head_size</td><td>L</td><td>1</td><td>header size</td></tr>
-<tr><td>plus->spidx_with_z</td><td>C</td><td>1</td><td>2D/3D vector data</td></tr>
-<tr><td>ndims</td><td>C</td><td>1</td><td>Number of dimensions</td></tr>
-<tr><td>nsides</td><td>C</td><td>1</td><td>Number of sides</td></tr>
-<tr><td>nodesize</td><td>I</td><td>1</td><td>%Node size</td></tr>
-<tr><td>nodecard</td><td>I</td><td>1</td><td>%Node card (?)</td></tr>
-<tr><td>leafcard</td><td>I</td><td>1</td><td>Leaf card (?)</td></tr>
-<tr><td>min_node_fill</td><td>I</td><td>1</td><td>Minimum node fill (?)</td></tr>
-<tr><td>min_leaf_fill</td><td>I</td><td>1</td><td>Minimum leaf fill (?)</td></tr>
-<tr><td>plus->Node_spidx->n_nodes</td><td>I</td><td>1</td><td>Number of nodes</td></tr>
-<tr><td>plus->Node_spidx->n_leafs</td><td>I</td><td>1</td><td>Number of leafs</td></tr>
-<tr><td>plus->Node_spidx->n_levels</td><td>I</td><td>1</td><td>Number of levels</td></tr>
-<tr><td>plus->Node_spidx_offset</td><td>O</td><td>1</td><td>%Node offset</td></tr>
-<tr><td>plus->Line_spidx->n_nodes</td><td>I</td><td>1</td><td>Number of nodes</td></tr>
-<tr><td>plus->Line_spidx->n_leafs</td><td>I</td><td>1</td><td>Number of leafs</td></tr>
-<tr><td>plus->Line_spidx->n_levels</td><td>I</td><td>1</td><td>Number of levels</td></tr>
-<tr><td>plus->Line_spidx_offset</td><td>O</td><td>1</td><td>Line offset</td></tr>
-<tr><td>plus->Area_spidx->n_nodes</td><td>I</td><td>1</td><td>Number of nodes</td></tr>
-<tr><td>plus->Area_spidx->n_leafs</td><td>I</td><td>1</td><td>Number of leafs</td></tr>
-<tr><td>plus->Area_spidx->n_levels</td><td>I</td><td>1</td><td>Number of levels</td></tr>
-<tr><td>plus->Area_spidx_offset</td><td>O</td><td>1</td><td>Area offset</td></tr>
-<tr><td>plus->Isle_spidx->n_nodes</td><td>I</td><td>1</td><td>Number of nodes</td></tr>
-<tr><td>plus->Isle_spidx->n_leafs</td><td>I</td><td>1</td><td>Number of leafs</td></tr>
-<tr><td>plus->Isle_spidx->n_levels</td><td>I</td><td>1</td><td>Number of levels</td></tr>
-<tr><td>plus->Isle_spidx_offset</td><td>O</td><td>1</td><td>Isle offset</td></tr>
-<tr><td>plus->Face_spidx_offset</td><td>O</td><td>1</td><td>Face offset</td></tr>
-<tr><td>plus->Volume_spidx_offset</td><td>O</td><td>1</td><td>Volume offset</td></tr>
-<tr><td>plus->Hole_spidx_offset</td><td>O</td><td>1</td><td>Hole offset</td></tr>
-<tr><td>plus->coor_size</td><td>O</td><td>1</td><td>Coor file size</td></tr>
-</table>
-\section vlibCidx Vector library category index management
-The category index (stored in the cidx file) improves the performance
-of all selections by cats/attributes (SQL, e.g. <tt>d.vect
-cats=27591</tt>, <tt>v.extract list=20000-21000</tt>). This avoids
-that all selections have to be made by looping through all vector
-lines. Category index is also essential for simple feature
-representation of GRASS vectors.
-Category index is created for each field. In memory, it is stored in
-\ref Cat_index data structure.
-Category index is built with topology, but it is <b>not updated</b> if
-vector is edited on level 2. Category index is stored in 'cidx' file,
-'cat' array is written/read by one call of dig__fwrite_port_I() or
-dig__fread_port_I().
-Stored values can be retrieved either by index in 'cat' array (if all
-features of given field are required) or by category value (one or few
-features), always by <tt>Vect_cidx_*()</tt> functions.
-To create category index, it will be necessary to rebuild topology for
-all existing vectors. This is an opportunity to make (hopefully) last
-changes in 'topo', 'cidx' formats.
-\subsection vlibCidxFileFormat Cidx file format specification
-Category index file ('cidx') is read by Vect_cidx_open().
-\subsubsection vlibCidxFileHead Header
-<tr><td>plus->cpidx_Version_Major </td><td>C</td><td>1</td><td>file version (major)</td></tr>
-<tr><td>plus->cpidx_Version_Minor </td><td>C</td><td>1</td><td>file version (minor)</td></tr>
-<tr><td>plus->cpidx_Back_Major</td><td>C</td><td>1</td><td>supported from GRASS version (major)</td></tr>
-<tr><td>plus->cpidx_Back_Minor</td><td>C</td><td>1</td><td>supported from GRASS version (minor)</td></tr>
-<tr><td>plus->cidx_port->byte_order</td><td>C</td><td>1</td><td>little or big endian
-<tr><td>plus->cidx_head_size</td><td>L</td><td>1</td><td>cidx head size</td></tr>
-<tr><td>plus->n_cidx</td><td>I</td><td>1</td><td>number of fields</td></tr>
-<tr><td>field</td><td>I</td><td>n_cidx</td><td>field number</td></tr>
-<tr><td>n_cats</td><td>I</td><td>n_cidx</td><td>number of categories</td></tr>
-<tr><td>n_ucats</td><td>I</td><td>n_cidx</td><td>number of unique categories</td></tr>
-<tr><td>n_types</td><td>I</td><td>n_cidx</td><td>number of feature types</td></tr>
-<tr><td>rtype</td><td>I</td><td>n_cidx * n_types</td><td>Feature type</td></tr>
-<tr><td>type[t]</td><td>I</td><td>n_cidx * n_types</td><td>Number of items</td></tr>
-</table>
