[GRASS-SVN] r53085 - in grass/trunk: lib/python/temporal temporal/t.unregister
Tue Sep 4 10:04:05 PDT 2012
Author: huhabla
Date: 2012-09-04 10:04:04 -0700 (Tue, 04 Sep 2012)
New Revision: 53085
   grass/trunk/lib/python/temporal/space_time_datasets_tools.py
   grass/trunk/temporal/t.unregister/t.unregister.py
Bugfix in t.sample and t.unregister.
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-09-04 16:14:56 UTC (rev 53084)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-09-04 17:04:04 UTC (rev 53085)
@@ -223,19 +223,20 @@
             # Safe the datasets that must be updated
             datasets = map.get_registered_datasets(dbif)
-            for dataset in datasets:
-                datatsets_to_modify[dataset["id"]] = dataset["id"]
-            if name and map.get_temporal_type() != sp.get_temporal_type():
-                dbif.close()
-                if map.get_layer():
-                    core.fatal(_("Unable to register %s map <%s> with layer. "
-                                 "The temporal types are different.") %
-                               (map.get_type(), map.get_map_id(), map.get_layer()))
-                else:
-                    core.fatal(_("Unable to register %s map <%s>. "
-                               (map.get_type(), map.get_map_id()))
+            if datasets:
+                for dataset in datasets:
+                    datatsets_to_modify[dataset["id"]] = dataset["id"]
+                if name and map.get_temporal_type() != sp.get_temporal_type():
+                    dbif.close()
+                    if map.get_layer():
+                        core.fatal(_("Unable to register %s map <%s> with layer. "
+                                     "The temporal types are different.") %
+                                   (map.get_type(), map.get_map_id(), map.get_layer()))
+                    else:
+                        core.fatal(_("Unable to register %s map <%s>. "
+                                   (map.get_type(), map.get_map_id()))
         # Load the data from the grass file database
         map.load()
@@ -664,6 +665,7 @@
             string += "%s%s" % ("end_time", separator)
             string += "%s%s" % ("interval_length", separator)
             string += "%s" % ("distance_from_begin")
+            print string
         first_time, dummy = mapmatrizes[0][0]["granule"].get_valid_time()
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py	2012-09-04 16:14:56 UTC (rev 53084)
+++ grass/trunk/temporal/t.unregister/t.unregister.py	2012-09-04 17:04:04 UTC (rev 53085)
@@ -94,7 +94,7 @@
     dummy = tgis.RasterDataset(None)
     # Map names as comma separated string
-    if maps is not None:
+    if maps is not None and maps != "":
         if maps.find(",") == -1:
             maplist = [maps, ]
         else:
