[GRASS-SVN] r53086 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Tue Sep 4 15:53:44 PDT 2012
Author: huhabla
Date: 2012-09-04 15:53:44 -0700 (Tue, 04 Sep 2012)
New Revision: 53086
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
Fixed overwrite flag check
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-09-04 17:04:04 UTC (rev 53085)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-09-04 22:53:44 UTC (rev 53086)
@@ -197,6 +197,7 @@
# Put the map into the database
if not map.is_in_db(dbif):
+ print "Map not in db"
is_in_db = False
# Break in case no valid time is provided
if start == "" or start is None:
@@ -217,8 +218,23 @@
else:
is_in_db = True
- if not core.overwrite:
+ # Check the overwrite flag
+ if not core.overwrite():
+ if map.get_layer():
+ core.warning(_("Map is already registered in temporal database. "
+ "Unable to update %s map <%s> with layer %i. "
+ "Overwrite flag is not set.") %
+ (map.get_type(), map.get_map_id(), map.get_layer()))
+ else:
+ "Unable to update %s map <%s>. "
+ (map.get_type(), map.get_map_id()))
+ # Jump to next map
continue
+ # Select information from temporal database
map.select(dbif)
# Safe the datasets that must be updated
@@ -230,11 +246,11 @@
if name and map.get_temporal_type() != sp.get_temporal_type():
dbif.close()
if map.get_layer():
- core.fatal(_("Unable to register %s map <%s> with layer. "
+ core.fatal(_("Unable to update %s map <%s> with layer. "
"The temporal types are different.") %
else:
- core.fatal(_("Unable to register %s map <%s>. "
+ core.fatal(_("Unable to update %s map <%s>. "
