[GRASS-SVN] r53094 - grass/branches/releasebranch_6_4/include/iostream
svn_grass at osgeo.org
Wed Sep 5 17:13:33 PDT 2012
Author: neteler
Date: 2012-09-05 17:13:33 -0700 (Wed, 05 Sep 2012)
New Revision: 53094
grass/branches/releasebranch_6_4/include/iostream/embuffer.h
grass/branches/releasebranch_6_4/include/iostream/minmaxheap.h
iostream: glynn: Fix iostream bugs (bug #1714) (backport from trunk, r53077)
Modified: grass/branches/releasebranch_6_4/include/iostream/embuffer.h
--- grass/branches/releasebranch_6_4/include/iostream/embuffer.h 2012-09-05 09:43:07 UTC (rev 53093)
+++ grass/branches/releasebranch_6_4/include/iostream/embuffer.h 2012-09-06 00:13:33 UTC (rev 53094)
@@ -1,10 +1,25 @@
* MODULE: iostream
* COPYRIGHT (C) 2007 Laura Toma
+ * Iostream is a library that implements streams, external memory
+ * sorting on streams, and an external memory priority queue on
+ * streams. These are the fundamental components used in external
+ * memory algorithms.
+ * Credits: The library was developed by Laura Toma. The kernel of
+ * class STREAM is based on the similar class existent in the GPL TPIE
+ * project developed at Duke University. The sorting and priority
+ * queue have been developed by Laura Toma based on communications
+ * with Rajiv Wickremesinghe. The library was developed as part of
+ * porting Terraflow to GRASS in 2001. PEARL upgrades in 2003 by
+ * Rajiv Wickremesinghe as part of the Terracost project.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
@@ -363,8 +378,7 @@
// return the number of items actually inserted
long insert(AMI_STREAM<T>* str,
- //long bos=0);
- long bos);
+ long bos=0);
//print range of elements in buffer
void print_range();
@@ -1120,7 +1134,7 @@
return the number of items actually inserted */
template<class T, class Key>
-long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos=0) {
+long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos) {
assert(str);
Modified: grass/branches/releasebranch_6_4/include/iostream/minmaxheap.h
--- grass/branches/releasebranch_6_4/include/iostream/minmaxheap.h 2012-09-05 09:43:07 UTC (rev 53093)
+++ grass/branches/releasebranch_6_4/include/iostream/minmaxheap.h 2012-09-06 00:13:33 UTC (rev 53094)
@@ -4,6 +4,22 @@
@@ -491,7 +507,7 @@
T a, b;
min(a);
max(b);
- if (size) {
+ if (size()) {
cout << a.getPriority() << ".."
<< b.getPriority();
