[GRASS-SVN] r53095 - grass/branches/develbranch_6/include/iostream
Wed Sep 5 17:13:43 PDT 2012
Author: neteler
Date: 2012-09-05 17:13:42 -0700 (Wed, 05 Sep 2012)
New Revision: 53095
   grass/branches/develbranch_6/include/iostream/embuffer.h
   grass/branches/develbranch_6/include/iostream/minmaxheap.h
iostream: glynn: Fix iostream bugs (bug #1714) (backport from trunk, r53077)
Modified: grass/branches/develbranch_6/include/iostream/embuffer.h
--- grass/branches/develbranch_6/include/iostream/embuffer.h	2012-09-06 00:13:33 UTC (rev 53094)
+++ grass/branches/develbranch_6/include/iostream/embuffer.h	2012-09-06 00:13:42 UTC (rev 53095)
@@ -1,10 +1,25 @@
  *  MODULE:	iostream
  *  COPYRIGHT (C) 2007 Laura Toma
+ *  Iostream is a library that implements streams, external memory
+ *  sorting on streams, and an external memory priority queue on
+ *  streams. These are the fundamental components used in external
+ *  memory algorithms.
+ * Credits: The library was developed by Laura Toma.  The kernel of
+ * class STREAM is based on the similar class existent in the GPL TPIE
+ * project developed at Duke University. The sorting and priority
+ * queue have been developed by Laura Toma based on communications
+ * with Rajiv Wickremesinghe. The library was developed as part of
+ * porting Terraflow to GRASS in 2001.  PEARL upgrades in 2003 by
+ * Rajiv Wickremesinghe as part of the Terracost project.
  *  This program is free software; you can redistribute it and/or modify
  *  it under the terms of the GNU General Public License as published by
  *  the Free Software Foundation; either version 2 of the License, or
@@ -363,8 +378,7 @@
   // return the number of items actually inserted
   long insert(AMI_STREAM<T>* str,
-	      //long bos=0);
-	      long bos);
+	      long bos=0);
   //print range of elements in buffer
   void print_range();
@@ -1120,7 +1134,7 @@
    return the number of items actually inserted */
 template<class T, class Key>
-long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos=0) {
+long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos) {
   assert(str);
Modified: grass/branches/develbranch_6/include/iostream/minmaxheap.h
--- grass/branches/develbranch_6/include/iostream/minmaxheap.h	2012-09-06 00:13:33 UTC (rev 53094)
+++ grass/branches/develbranch_6/include/iostream/minmaxheap.h	2012-09-06 00:13:42 UTC (rev 53095)
@@ -4,6 +4,22 @@
@@ -491,7 +507,7 @@
   T a, b;
   min(a);
   max(b);
-  if (size) {
+  if (size()) {
     cout << a.getPriority() << ".."
 	 << b.getPriority();
