[GRASS-SVN] r53164 - grass-addons/grass7/imagery/i.segment.xl
svn_grass at osgeo.org
Tue Sep 11 02:00:59 PDT 2012
Author: mmetz
Date: 2012-09-11 02:00:59 -0700 (Tue, 11 Sep 2012)
New Revision: 53164
grass-addons/grass7/imagery/i.segment.xl/create_isegs.c
grass-addons/grass7/imagery/i.segment.xl/parse_args.c
i.segment.xl code cleanup
Modified: grass-addons/grass7/imagery/i.segment.xl/create_isegs.c
--- grass-addons/grass7/imagery/i.segment.xl/create_isegs.c 2012-09-11 08:36:22 UTC (rev 53163)
+++ grass-addons/grass7/imagery/i.segment.xl/create_isegs.c 2012-09-11 09:00:59 UTC (rev 53164)
@@ -16,8 +16,6 @@
#define EPSILON 1.0e-16
-int debug_level;
/* internal functions */
static int merge_regions(struct ngbr_stats *, /* Ri */
struct reg_stats *,
@@ -175,12 +173,10 @@
alpha2 = globals->alpha * globals->alpha;
/* make the divisor a constant ? */
divisor = globals->nrows + globals->ncols;
- debug_level = 5;
while (t < globals->end_t && n_merges > 0) {
- /* optional threshold as a function of t. */
+ /* optional threshold as a function of t. does not make sense */
threshold = alpha2 * globals->threshold;
t++;
@@ -190,9 +186,6 @@
else
G_percent(t, globals->end_t, 1);
- if (t >= 50)
- debug_level = 5;
n_merges = 0;
globals->candidate_count = 0;
flag_clear_all(globals->candidate_flag);
@@ -292,8 +285,11 @@
pathflag = FALSE;
/* this is slow ??? */
- if (0 && (t & 1) && Rk.count <= globals->nn)
+ if (t & 1) {
+ if ((globals->nn < 8 && Rk.count <= 8) ||
+ (globals->nn >= 8 && Rk.count <= globals->nn))
candidates_only = FALSE;
while (pathflag) {
pathflag = FALSE;
@@ -547,6 +543,7 @@
+ G_percent(1, 1, 1);
G_free(Ri.mean);
Modified: grass-addons/grass7/imagery/i.segment.xl/parse_args.c
--- grass-addons/grass7/imagery/i.segment.xl/parse_args.c 2012-09-11 08:36:22 UTC (rev 53163)
+++ grass-addons/grass7/imagery/i.segment.xl/parse_args.c 2012-09-11 09:00:59 UTC (rev 53164)
@@ -87,7 +87,7 @@
endt->key = "iterations";
endt->type = TYPE_INTEGER;
endt->required = NO;
- endt->answer = "1000";
+ endt->answer = "100";
endt->description = _("Maximum number of iterations.");
outband = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -185,8 +185,8 @@
if (atoi(endt->answer) > 0)
globals->end_t = atoi(endt->answer);
else {
- globals->end_t = 1000;
- G_warning(_("Invalid number of iterations, 1000 will be used."));
+ globals->end_t = 100;
+ G_warning(_("Invalid number of iterations, 100 will be used."));
else
