[GRASS-SVN] r53165 - grass-addons/grass6/raster/r.cog
svn_grass at osgeo.org
Tue Sep 11 04:57:41 PDT 2012
Author: hamish
Date: 2012-09-11 04:57:41 -0700 (Tue, 11 Sep 2012)
New Revision: 53165
grass-addons/grass6/raster/r.cog/r.cog
still not right, but a lot less wrong
Modified: grass-addons/grass6/raster/r.cog/r.cog
--- grass-addons/grass6/raster/r.cog/r.cog 2012-09-11 09:00:59 UTC (rev 53164)
+++ grass-addons/grass6/raster/r.cog/r.cog 2012-09-11 11:57:41 UTC (rev 53165)
@@ -183,32 +183,29 @@
## v.surf.rst with very high smoothing and low tension ...?
# maybe the r.univar mean or median of the magnitude of the axes' 1st derivatives:
-# r.mapcalc "tmp.magnitude = sqrt(tmp.rcog.$$.dx*tmp.rcog.$$.dx \
-# + tmp.rcog.$$.dy*tmp.rcog.$$.dy)"
-# r.univar -g tmp.magnitude
+#DIP_try1=`r.univar -eg map="$TMP_MAP.slope" | grep '^median=' | cut -f2 -d'='`
+#GRASS_VERBOSE=0 \
+# r.mapcalc "$TMP_MAP.magnitude = sqrt(tmp.rcog.$$.dx^2 \
+# + tmp.rcog.$$.dy^2)"
+#DIP=`r.univar -eg map="$TMP_MAP.magnitude" | grep '^median=' | cut -f2 -d'='`
-DIP_try1=`r.univar -eg map="$TMP_MAP.slope" | grep '^median=' | cut -f2 -d'='`
-# this is completely incorrect:
-FUDGE="$DIP_try1"
-GRASS_VERBOSE=0 \
- r.mapcalc "$TMP_MAP.magnitude = sqrt(tmp.rcog.$$.dx*tmp.rcog.$$.dx \
- + tmp.rcog.$$.dy*tmp.rcog.$$.dy) * $FUDGE"
-DIP=`r.univar -eg map="$TMP_MAP.magnitude" | grep '^median=' | cut -f2 -d'='`
DX=`r.univar -g map="$TMP_MAP.dx" | grep '^mean=' | cut -f2 -d'='`
DY=`r.univar -g map="$TMP_MAP.dy" | grep '^mean=' | cut -f2 -d'='`
+# maybe use length along az not simply avg cell res() dist?
+GRASS_VERBOSE=0 \
+ r.mapcalc "$TMP_MAP.dz = nsres() * tan($TMP_MAP.slope)"
+DZ=`r.univar -g map="$TMP_MAP.dz" | grep '^mean=' | cut -f2 -d'='`
-#r.univar map="$TMP_MAP.slope" -e
-#d.rast "$TMP_MAP"
+eval `g.region -g | grep res`
+RES="$nsres"
PI=3.14159265358979323846
+DIP=`echo "$DZ $RES" | awk -v PI="$PI" '{print atan2($1, $2) * (180/PI)}'`
AZ=`echo "$DX $DY" | awk -v PI="$PI" '{print atan2($2, $1) * (180/PI)}'`
if [ "$GIS_FLAG_G" -eq 0 ] ; then
