[GRASS-SVN] r53199 - grass/trunk/locale/po
svn_grass at osgeo.org
Mon Sep 17 15:11:35 PDT 2012
Author: neteler
Date: 2012-09-17 15:11:35 -0700 (Mon, 17 Sep 2012)
New Revision: 53199
grass/trunk/locale/po/grasslibs_pl.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grasswxpy_pl.po
Milena Nowotarska: cont'ed
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po 2012-09-17 22:11:20 UTC (rev 53198)
+++ grass/trunk/locale/po/grasslibs_pl.po 2012-09-17 22:11:35 UTC (rev 53199)
@@ -9,7 +9,7 @@
"Project-Id-Version: grasslibs_pl\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-08-29 15:57+0200\n"
-"PO-Revision-Date: 2012-08-30 00:46+0100\n"
+"PO-Revision-Date: 2012-09-17 22:46+0100\n"
"Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
"Language-Team: GRASS Translation Team\n"
"Language: pl\n"
@@ -6695,17 +6695,17 @@
#: ../lib/gis/parser_help.c:194 ../lib/gis/parser_interface.c:329
#: ../lib/gis/parser_html.c:163 ../lib/gis/parser_rest.c:164
msgid "Allow output files to overwrite existing files"
-msgstr "Pozwól plikom wyjściowym nadpisywać istniejące pliki"
+msgstr "Nadpisz istniejące pliki"
#: ../lib/gis/parser_help.c:196 ../lib/gis/parser_interface.c:337
#: ../lib/gis/parser_html.c:167 ../lib/gis/parser_rest.c:168
msgid "Verbose module output"
-msgstr "Głośne wyjście modułu (maximum komunikatów)"
+msgstr "Głośne wyjście modułu (maksimum komunikatów)"
#: ../lib/gis/parser_help.c:197 ../lib/gis/parser_interface.c:344
#: ../lib/gis/parser_html.c:170 ../lib/gis/parser_rest.c:171
msgid "Quiet module output"
-msgstr "Ciche wyjście modułu (minimum komunikatów)"
+msgstr "Uruchom bez komunikatów"
#: ../lib/gis/parser_help.c:205
#, fuzzy
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2012-09-17 22:11:20 UTC (rev 53198)
+++ grass/trunk/locale/po/grassmods_pl.po 2012-09-17 22:11:35 UTC (rev 53199)
@@ -9,7 +9,7 @@
"Project-Id-Version: grassmods_pl\n"
-"PO-Revision-Date: 2012-08-30 16:49+0100\n"
+"PO-Revision-Date: 2012-09-17 22:47+0100\n"
"Language-Team: Polish <grass-translations at lists.osgeo.org>\n"
"Language: pl\n"
@@ -468,7 +468,7 @@
#: ../vector/v.vol.rst/main.c:650
#, c-format
msgid "Raster map <%s> not found"
-msgstr "Mapy rastrowa <%s> nie została znaleziona"
+msgstr "Mapa rastrowa <%s> nie została znaleziona"
#: ../doc/vector/v.example/main.c:53
msgid "My first vector module"
@@ -1874,7 +1874,7 @@
#: ../misc/m.nviz.image/args.c:129
msgid "Name of raster map(s) for elevation"
-msgstr "Nazwa map(y) rastrowych(ej) do wysokości"
+msgstr "Nazwa map(y) rastrowych(ej) do wysokości"
#: ../misc/m.nviz.image/args.c:138
msgid "Elevation value(s)"
@@ -11113,7 +11113,7 @@
#: ../raster/r.bitpattern/main.c:89
msgid "Quiet"
-msgstr "Cisza"
+msgstr "Ciche wyjście modułu"
#: ../raster/r.to.vect/lines_io.c:76
msgid "write_line: found half a loop!"
@@ -22665,7 +22665,7 @@
#: ../vector/v.overlay/main.c:58
msgid "Overlays two vector maps."
-msgstr "Nakłada na siebie dwie mapy rastrowe."
+msgstr "Nakłada na siebie dwie mapy wektorowe."
#: ../vector/v.overlay/main.c:61 ../vector/v.select/args.c:12
msgid "Name of input vector map (A)"
@@ -23513,9 +23513,8 @@
#: ../vector/v.proj/main.c:280 ../vector/v.proj/main.c:400
#: ../vector/v.rectify/main.c:243
-#, fuzzy
msgid "Reading input vector map"
-msgstr "Mapa wektorowa punktów początkowych"
+msgstr "Czytanie wejściowej mapy wektorowej"
#: ../vector/v.proj/main.c:303
#, fuzzy, c-format
@@ -23529,9 +23528,9 @@
msgstr "Błąd w pj_do_transform"
#: ../vector/v.proj/main.c:389
-#, fuzzy, c-format
+#, c-format
msgid "Reprojecting primitives: "
-msgstr "Nazwa istniejącego pliku wektorowego"
+msgstr "Reprojekcja prymitywów: "
#: ../vector/v.proj/main.c:423
msgid "Try to disable wrapping to -180,180 if topological errors occurred."
@@ -24311,26 +24310,23 @@
#: ../vector/v.parallel/main.c:51
msgid "Creates parallel line to input vector lines."
-msgstr "Tworzy linie równoległe do linii wejściowych."
+msgstr "Tworzy linie równoległe do podanych linii wektorowych."
#: ../vector/v.parallel/main.c:66
-#, fuzzy
msgid "Offset along major axis in map units"
-msgstr "Odległość położenia kamery (w jednostkach mapy)"
+msgstr "Odległość wzdłuż głównej osi, w jednostkach mapy"
#: ../vector/v.parallel/main.c:74
-#, fuzzy
msgid "Offset along minor axis in map units"
+msgstr "Odległość wzdłuż krótszej osi, w jednostkach mapy"
#: ../vector/v.parallel/main.c:82 ../vector/v.buffer/main.c:259
msgid "Angle of major axis in degrees"
-msgstr ""
+msgstr "Kąt głównej osi w stopniach"
#: ../vector/v.parallel/main.c:91
-#, fuzzy
msgid "Side"
-msgstr "&Strona:"
+msgstr "Strona"
#: ../vector/v.parallel/main.c:95
#, fuzzy
@@ -24347,18 +24343,16 @@
msgstr "Utwórz linie równoległe do podanych linii"
#: ../vector/v.parallel/main.c:106
-#, fuzzy
msgid "Tolerance of arc polylines in map units"
-msgstr "Współrzędne są podane w jednostkach mapy"
+msgstr "Tolerancja linii łuków w jednostkach mapy"
#: ../vector/v.parallel/main.c:110
msgid "Make outside corners round"
-msgstr ""
+msgstr "Zewnętrzne rogi zaokrąglone"
#: ../vector/v.parallel/main.c:114
-#, fuzzy
msgid "Create buffer-like parallel lines"
-msgstr "Utwórz linie równoległe do podanych linii"
+msgstr "Utwórz linie równoległe jak bufory"
#: ../vector/v.support/main.c:41
msgid "Updates vector map metadata."
@@ -27605,8 +27599,9 @@
msgstr "Znajduje najkrótszą trasę przy użyciu rozkładów jazdy."
#: ../vector/v.net.timetable/main.c:309
+#, fuzzy
msgid "Layer number or name with walking connections or -1"
-msgstr ""
+msgstr "Numer warstwy lub nazwa lub -1"
#: ../vector/v.net.timetable/main.c:315
#, fuzzy
@@ -27693,12 +27688,12 @@
#: ../vector/v.out.svg/main.c:201
msgid "No areas found, skipping type=poly"
-msgstr ""
+msgstr "Nie znaleziono obszarów, pomijanie type=poly"
#: ../vector/v.out.svg/main.c:211 ../vector/v.extrude/main.c:214
#, c-format
msgid "Skipping area %d without centroid"
-msgstr ""
+msgstr "Pomijanie obszaru %d bez centroidu"
#: ../vector/v.out.svg/main.c:238
#, c-format
@@ -30319,25 +30314,24 @@
#: ../vector/v.extrude/main.c:77
msgid "Trace elevation"
-msgstr ""
+msgstr "Podążaj za ukształtowaniem terenu"
#: ../vector/v.extrude/main.c:99
msgid "Elevation raster for height extraction"
-msgstr ""
+msgstr "Raster z wysokością"
#: ../vector/v.extrude/main.c:106
msgid "Fixed height for 3D vector objects"
-msgstr ""
+msgstr "Stała wartość wysokości dla obiektów 3D"
#: ../vector/v.extrude/main.c:111
-#, fuzzy
msgid "Name of attribute column with object heights"
-msgstr "Nazwa wyświetlanej kolumny"
+msgstr "Nazwa kolumny zawierającej wysokość obiektów"
#: ../vector/v.extrude/main.c:119
-#, fuzzy, c-format
+#, c-format
msgid "One of '%s' or '%s' parameters must be set"
-msgstr "Jeden z parametrów [%s] lub [%s] musi być ustawiony"
+msgstr "Jeden z parametrów '%s' lub '%s' musi być ustawiony"
#: ../vector/v.extrude/main.c:175
#, fuzzy, c-format
@@ -30347,17 +30341,16 @@
#: ../vector/v.extrude/main.c:184
#, c-format
msgid "Column <%s>: invalid data type"
-msgstr ""
+msgstr "Kolumna <%s>: niewłaściwy typ danych"
#: ../vector/v.extrude/main.c:204
-#, fuzzy
msgid "Extruding areas..."
-msgstr "Zapiywanie %s ..."
+msgstr "Wytłaczanie obszarów..."
#: ../vector/v.extrude/main.c:229
-#, fuzzy, c-format
+#, c-format
msgid "Cannot select attributes for area %d"
-msgstr "Nir można wybrać atrybutów dla pola #%d"
+msgstr "Nie można wybrać atrybutów dla pola %d"
#: ../vector/v.extrude/main.c:268
#, fuzzy
@@ -30365,9 +30358,9 @@
#: ../vector/v.extrude/main.c:301
-#, fuzzy, c-format
+#, c-format
msgid "Cannot select attributes for area #%d"
+msgstr "Nie można wybrać atrybutów dla pola #%d"
#: ../vector/v.segment/main.c:57
msgid "Creates points/segments from input vector lines and positions."
@@ -30427,9 +30420,9 @@
msgstr "Wczytano [%d] linii"
#: ../vector/v.segment/main.c:228
-#, fuzzy, c-format
+#, c-format
msgid "%d lines written to output map (%d lost)"
-msgstr "[%d] linii zapisanych do mapy wejściowej(%d utraconych)"
+msgstr "%d linii zapisanych do mapy wyjściowej(%d utraconych)"
#: ../vector/v.what/what.c:261
#, c-format
@@ -30647,9 +30640,8 @@
msgstr "Odwracanie matrycy..."
#: ../vector/v.generalize/displacement.c:199
-#, fuzzy
msgid "Unable to calculate the inverse matrix"
-msgstr "nie można zamknąć mapy wejściowej"
+msgstr "Nie można obliczyć matrycy odwróconej"
#: ../vector/v.generalize/displacement.c:202
msgid "Resolving conflicts..."
@@ -31929,7 +31921,7 @@
#: ../vector/v.out.vtk/main.c:85
msgid "Layer number"
-msgstr "Liczba warstw"
+msgstr "Numer warstwy"
#: ../vector/v.out.vtk/main.c:95
msgid "Export numeric attribute table fields as VTK scalar variables"
@@ -39006,10 +38998,10 @@
#~ msgstr "Sprawdzanie punktów wektorowych..."
#~ msgid "Layer number (from)"
-#~ msgstr "Liczba warstw (z)"
+#~ msgstr "Numer warstwy (z)"
#~ msgid "Layer number (to)"
-#~ msgstr "Liczba warstw (na)"
+#~ msgstr "Numer warstwy (na)"
#, fuzzy
#~ msgid "Name of table created for output when the distance to all flag is used"
@@ -39025,7 +39017,7 @@
#, fuzzy
#~ msgid "Query layer number (read from)"
-#~ msgstr "Liczba warstw"
+#~ msgstr "Odpytaj numer warstwy"
#, fuzzy
#~ msgid "Creates a GRASS vector map of a user-defined grid."
@@ -39054,9 +39046,8 @@
#~ msgid "vector, network, flow"
#~ msgstr "wctor, eksport"
-#, fuzzy
#~ msgid "Source layer number or name"
+#~ msgstr "Numer lub nazwa warstwy źródłowej"
#, fuzzy
#~ msgid "Sink layer number or name"
@@ -39346,14 +39337,13 @@
#~ msgstr "wektor, geometria, 3D"
#~ msgid "Name of input 2D vector map"
-#~ msgstr "Nazwa mapy wektorowej 2D"
+#~ msgstr "Nazwa źródłowej mapy wektorowej 2D"
#~ msgid "Name of resulting 3D vector map"
-#~ msgstr "Nazwa wynikowego pliku wektorowego 3D"
+#~ msgstr "Nazwa wyjściowej mapy wektorowej 3D"
-#, fuzzy
#~ msgid "Extruding vector primitives..."
-#~ msgstr "Zapiywanie %s ..."
+#~ msgstr "Wytłaczanie prymitywów wektorowych ..."
#, fuzzy
#~ msgid "Name of input vector map containing lines"
@@ -39429,10 +39419,10 @@
#~ msgstr "Liczba kolumn"
#~ msgid "Set1 layer number or name"
-#~ msgstr "Zestaw1 liczba warstw lub nazwa"
+#~ msgstr "Zestaw1 numer warstwy lub nazwa"
#~ msgid "Set2 layer number or name"
-#~ msgstr "Zestaw2 liczba warstw lub nazwa"
+#~ msgstr "Zestaw2 numer warstwy lub nazwa"
#, fuzzy
#~ msgid "Cannot allocate memory for row buffer"
@@ -40030,10 +40020,6 @@
#~ msgid "calculates univariate statistics from a GRASS raster map"
#~ msgstr "oblicza statystyki z mapy rastrowej GRASS"
-#, fuzzy
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "nie można zamknąć mapy wejściowej"
#~ msgid "raster, tiling"
#~ msgstr "raster, kafelkowanie"
@@ -40106,9 +40092,8 @@
#~ msgid "vector, area, dissolve"
#~ msgstr "wektor, obszar, rozłączanie"
-#, fuzzy
#~ msgid "Layer number. If -1, all layers are extracted."
-#~ msgstr "Numer warstwy. Jesli -l, wszystkie warstwy są wyświetlane."
+#~ msgstr "Numer warstwy. Dla -l, wszystkie warstwy będą wyciągnięte."
#, fuzzy
#~ msgid "Name of column used to dissolve common boundaries"
@@ -40427,3 +40412,9 @@
#~ msgid "SPOT sensor"
#~ msgstr "Sensor SPOT"
+#~ msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
+#~ msgstr "lewa;Linia równoległa jest po lewej;prawa;Linia równoległa jest po prawej;obie;Linie równoległe są po obu stronach"
+#~ msgid "Extrudes flat vector object to 3D with defined height."
+#~ msgstr "Wytłacza płaskie obiekty wektorowe do 3D ze zdefiniowaną wysokością."
Modified: grass/trunk/locale/po/grasswxpy_pl.po
--- grass/trunk/locale/po/grasswxpy_pl.po 2012-09-17 22:11:20 UTC (rev 53198)
+++ grass/trunk/locale/po/grasswxpy_pl.po 2012-09-17 22:11:35 UTC (rev 53199)
@@ -8,8 +8,8 @@
"Project-Id-Version: grasswxpy_pl\n"
-"PO-Revision-Date: 2012-09-08 01:03+0100\n"
-"Last-Translator: Robert Szczepanek <robert at szczepanek.pl>\n"
+"PO-Revision-Date: 2012-09-17 23:03+0100\n"
+"Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
"Language: pl\n"
"MIME-Version: 1.0\n"
@@ -3911,12 +3911,12 @@
#: ../gui/wxpython/gui_core/forms.py:762 ../gui/wxpython/gui_core/forms.py:775
msgid "Required"
-msgstr "Wymagane"
+msgstr "Podstawa"
#: ../gui/wxpython/gui_core/forms.py:765 ../gui/wxpython/gui_core/forms.py:775
#: ../gui/wxpython/gui_core/forms.py:1990
msgid "Optional"
-msgstr "Opcjonalne"
+msgstr "Opcje"
#: ../gui/wxpython/gui_core/forms.py:842
#: ../gui/wxpython/gui_core/forms.py:1438
@@ -3958,7 +3958,7 @@
#: ../gui/wxpython/gui_core/forms.py:1607
msgid "Manual"
-msgstr "Przewodnik użytkownika"
+msgstr "Przewodnik"
#: ../gui/wxpython/gui_core/forms.py:1648
msgid "Nothing to load."
@@ -5825,9 +5825,8 @@
# przykryj nie brzmi ...; może złącz, scal?
#: ../gui/wxpython/menustrings.py:330
-#, fuzzy
msgid "Overlay rasters"
-msgstr "Przykryj mapy rastrowe"
+msgstr "Nakładanie rastrów"
# poprzecznego?
#: ../gui/wxpython/menustrings.py:331
@@ -6656,7 +6655,7 @@
#: ../gui/wxpython/menustrings.py:539
-msgstr "Utworzy linie równoległe do podanych linii wektorowych."
#: ../gui/wxpython/menustrings.py:540
msgid "Dissolve boundaries"
@@ -6729,7 +6728,7 @@
#: ../gui/wxpython/menustrings.py:558
msgid "Topology maintenance"
-msgstr ""
+msgstr "Topologia"
#: ../gui/wxpython/menustrings.py:559
msgid "Create or rebuild topology"
@@ -8295,9 +8294,8 @@
msgstr ""
#: ../gui/wxpython/psmap/frame.py:1018
-#, fuzzy
msgid "wxGUI Cartographic Composer"
-msgstr "Graficzny modeler wxGUI"
+msgstr "Kompozytor wydruków wxGUI"
#: ../gui/wxpython/psmap/frame.py:1020
msgid ""
@@ -14738,9 +14736,8 @@
#~ msgid "Settings named '%s' not found"
#~ msgstr "Ustawienia o nazwie '%s' nie odnalezione"
-#, fuzzy
#~ msgid "GRASS GIS Cartographic Composer (experimental prototype)"
-#~ msgstr "Graficzny modeler GRASS GIS"
+#~ msgstr "Kompozytor wydruków GRASS GIS (prototyp)"
#, fuzzy
#~ msgid "GRASS GIS Graphical Modeler (experimental prototype)"
