[GRASS-SVN] r53198 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Mon Sep 17 15:11:21 PDT 2012
Author: neteler
Date: 2012-09-17 15:11:20 -0700 (Mon, 17 Sep 2012)
New Revision: 53198
grass/branches/releasebranch_6_4/locale/po/grasslibs_pl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po
Milena Nowotarska: cont'ed
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_pl.po 2012-09-17 22:11:12 UTC (rev 53197)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_pl.po 2012-09-17 22:11:20 UTC (rev 53198)
@@ -9,7 +9,7 @@
"Project-Id-Version: grasslibs_pl\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-02-01 08:43+0100\n"
-"PO-Revision-Date: 2012-08-30 00:46+0100\n"
+"PO-Revision-Date: 2012-09-17 22:46+0100\n"
"Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
"Language-Team: GRASS Translation Team\n"
"Language: pl\n"
@@ -3507,15 +3507,15 @@
#: ../lib/gis/parser.c:1176 ../lib/gis/parser.c:1500 ../lib/gis/parser.c:1660
#: ../lib/gis/parser.c:1948
msgid "Allow output files to overwrite existing files"
-msgstr "Pozwól plikom wyjściowym nadpisywać istniejące pliki"
+msgstr "Nadpisz istniejące pliki"
#: ../lib/gis/parser.c:1178 ../lib/gis/parser.c:1508 ../lib/gis/parser.c:1664
msgid "Verbose module output"
-msgstr "Głośne wyjście modułu (maximum komunikatów)"
+msgstr "Głośne wyjście modułu (maksimum komunikatów)"
#: ../lib/gis/parser.c:1179 ../lib/gis/parser.c:1515 ../lib/gis/parser.c:1667
msgid "Quiet module output"
-msgstr "Ciche wyjście modułu (minimum komunikatów)"
+msgstr "Uruchom bez komunikatów"
#: ../lib/gis/parser.c:1184
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-09-17 22:11:12 UTC (rev 53197)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-09-17 22:11:20 UTC (rev 53198)
@@ -9,7 +9,7 @@
"Project-Id-Version: grassmods_pl\n"
-"PO-Revision-Date: 2012-08-30 16:49+0100\n"
+"PO-Revision-Date: 2012-09-17 22:47+0100\n"
"Language-Team: Polish <grass-translations at lists.osgeo.org>\n"
"Language: pl\n"
@@ -281,7 +281,7 @@
#: ../vector/v.drape/main.c:245
#, c-format
msgid "Raster map <%s> not found"
-msgstr "Mapy rastrowa <%s> nie została znaleziona"
+msgstr "Mapa rastrowa <%s> nie została znaleziona"
#: ../visualization/xganim/main.c:370 ../doc/raster/r.example/main.c:122
#: ../raster/r.bilinear/main.c:94 ../raster/r.profile/main.c:144
@@ -392,7 +392,7 @@
#: ../imagery/i.cluster/main.c:163 ../vector/v.kcv/main.c:106
#: ../vector/v.sample/main.c:129 ../vector/v.perturb/main.c:117
msgid "Quiet"
-msgstr "Cisza"
+msgstr "Ciche wyjście modułu"
#: ../doc/raster/r.example/main.c:114 ../raster/r.mode/main.c:94
#: ../raster/r.watershed/shed/com_line.c:231
@@ -1552,7 +1552,7 @@
#: ../misc/m.nviz.image/args.c:121
msgid "Name of raster map(s) for elevation"
-msgstr "Nazwa map(y) rastrowych(ej) do wysokości"
+msgstr "Nazwa map(y) rastrowych(ej) do wysokości"
#: ../misc/m.nviz.image/args.c:130
msgid "Elevation value(s)"
@@ -20575,7 +20575,7 @@
#: ../vector/v.overlay/main.c:56
msgid "Overlays two vector maps."
-msgstr "Nakłada na siebie dwie mapy rastrowe."
+msgstr "Nakłada na siebie dwie mapy wektorowe."
#: ../vector/v.overlay/main.c:59 ../vector/v.select/args.c:10
msgid "Name of input vector map (A)"
@@ -21349,14 +21349,13 @@
msgstr "Plik rastrowy <%s> nie został znaleziony"
#: ../vector/v.proj/main.c:270
-#, fuzzy, c-format
+#, c-format
msgid "Reprojecting primitives: "
-msgstr "Nazwa istniejącego pliku wektorowego"
+msgstr "Reprojekcja prymitywów: "
#: ../vector/v.proj/main.c:281
-#, fuzzy
msgid "Reading input vector map"
-msgstr "Mapa wektorowa punktów początkowych"
+msgstr "Czytanie wejściowej mapy wektorowej"
#: ../vector/v.proj/main.c:287
msgid "Error in pj_do_transform"
@@ -21499,7 +21498,7 @@
#: ../vector/v.buffer2/main.c:185 ../vector/v.parallel2/main.c:73
msgid "Angle of major axis in degrees"
-msgstr ""
+msgstr "Kąt głównej osi w stopniach"
#: ../vector/v.buffer2/main.c:191
#, fuzzy
@@ -23943,11 +23942,11 @@
#: ../vector/v.distance/main.c:144
msgid "Layer number (from)"
-msgstr "Liczba warstw (z)"
+msgstr "Numer warstwy (z)"
#: ../vector/v.distance/main.c:149
msgid "Layer number (to)"
-msgstr "Liczba warstw (na)"
+msgstr "Numer warstwy (na)"
#: ../vector/v.distance/main.c:155
msgid "Name for output vector map containing lines connecting nearest elements"
@@ -24167,7 +24166,7 @@
#: ../vector/v.to.db/parse.c:46
#, fuzzy
msgid "Query layer number (read from)"
-msgstr "Liczba warstw"
+msgstr "Odpytaj numer warstwy"
#: ../vector/v.to.db/parse.c:47 ../vector/v.to.db/parse.c:99
#: ../db/base/execute.c:118
@@ -24273,40 +24272,35 @@
#: ../vector/v.parallel2/main.c:45
msgid "Creates parallel line to input vector lines."
-msgstr "Tworzy linie równoległe do linii wejściowych."
+msgstr "Tworzy linie równoległe do podanych linii wektorowych."
#: ../vector/v.parallel2/main.c:57
-#, fuzzy
msgid "Offset along major axis in map units"
-msgstr "Odległość położenia kamery (w jednostkach mapy)"
+msgstr "Odległość wzdłuż głównej osi, w jednostkach mapy"
#: ../vector/v.parallel2/main.c:65
-#, fuzzy
msgid "Offset along minor axis in map units"
+msgstr "Odległość wzdłuż krótszej osi, w jednostkach mapy"
#: ../vector/v.parallel2/main.c:82
-#, fuzzy
msgid "Side"
-msgstr "&Strona:"
+msgstr "Strona"
#: ../vector/v.parallel2/main.c:84
msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
-msgstr ""
+msgstr "lewa;Linia równoległa jest po lewej;prawa;Linia równoległa jest po prawej;obie;Linie równoległe są po obu stronach"
#: ../vector/v.parallel2/main.c:94
-#, fuzzy
msgid "Tolerance of arc polylines in map units"
-msgstr "Współrzędne są podane w jednostkach mapy"
+msgstr "Tolerancja linii łuków w jednostkach mapy"
#: ../vector/v.parallel2/main.c:98
msgid "Make outside corners round"
-msgstr ""
+msgstr "Zewnętrzne rogi zaokrąglone"
#: ../vector/v.parallel2/main.c:102
-#, fuzzy
msgid "Create buffer-like parallel lines"
-msgstr "Utwórz linie równoległe do podanych linii"
+msgstr "Utwórz linie równoległe jak bufory"
#: ../vector/v.mkgrid/write_grid.c:42
#, fuzzy
@@ -24610,9 +24604,8 @@
msgstr ""
#: ../vector/v.net.flow/main.c:86
-#, fuzzy
msgid "Source layer number or name"
+msgstr "Numer lub nazwa warstwy źródłowej"
#: ../vector/v.net.flow/main.c:91
#, fuzzy
@@ -25818,8 +25811,9 @@
msgstr "Znajduje najkrótszą trasę przy użyciu rozkładów jazdy."
#: ../vector/v.net.timetable/main.c:267
+#, fuzzy
msgid "Layer number or name with walking connections or -1"
-msgstr ""
+msgstr "Numer warstwy lub nazwa lub -1"
#: ../vector/v.net.timetable/main.c:272
#, fuzzy
@@ -25910,12 +25904,12 @@
#: ../vector/v.out.svg/main.c:205
msgid "No areas found, skipping type=poly"
-msgstr ""
+msgstr "Nie znaleziono obszarów, pomijanie type=poly"
#: ../vector/v.out.svg/main.c:215 ../vector/v.extrude/main.c:204
#, c-format
msgid "Skipping area %d without centroid"
-msgstr ""
+msgstr "Pomijanie obszaru %d bez centroidu"
#: ../vector/v.out.svg/main.c:242
#, c-format
@@ -27575,62 +27569,59 @@
#: ../vector/v.extrude/main.c:71
msgid "Extrudes flat vector object to 3D with defined height."
-msgstr ""
+msgstr "Wytłacza płaskie obiekty wektorowe do 3D ze zdefiniowaną wysokością."
#: ../vector/v.extrude/main.c:75
msgid "Trace elevation"
-msgstr ""
+msgstr "Podążaj za ukształtowaniem terenu"
#: ../vector/v.extrude/main.c:78
msgid "Name of input 2D vector map"
-msgstr "Nazwa mapy wektorowej 2D"
+msgstr "Nazwa źródłowej mapy wektorowej 2D"
#: ../vector/v.extrude/main.c:81
msgid "Name of resulting 3D vector map"
-msgstr "Nazwa wynikowego pliku wektorowego 3D"
+msgstr "Nazwa wyjściowej mapy wektorowej 3D"
#: ../vector/v.extrude/main.c:93
msgid "Elevation raster for height extraction"
-msgstr ""
+msgstr "Raster z wysokością"
#: ../vector/v.extrude/main.c:100
msgid "Fixed height for 3D vector objects"
-msgstr ""
+msgstr "Stała wartość wysokości dla obiektów 3D"
#: ../vector/v.extrude/main.c:105
-#, fuzzy
msgid "Name of attribute column with object heights"
-msgstr "Nazwa wyświetlanej kolumny"
+msgstr "Nazwa kolumny zawierającej wysokość obiektów"
#: ../vector/v.extrude/main.c:119
-#, fuzzy, c-format
+#, c-format
msgid "One of '%s' or '%s' parameters must be set"
-msgstr "Jeden z parametrów [%s] lub [%s] musi być ustawiony"
+msgstr "Jeden z parametrów '%s' lub '%s' musi być ustawiony"
#: ../vector/v.extrude/main.c:194
-#, fuzzy
msgid "Extruding areas..."
-msgstr "Zapiywanie %s ..."
+msgstr "Wytłaczanie obszarów..."
#: ../vector/v.extrude/main.c:219
-#, fuzzy, c-format
+#, c-format
msgid "Cannot select attributes for area %d"
-msgstr "Nir można wybrać atrybutów dla pola #%d"
+msgstr "Nie można wybrać atrybutów dla pola %d"
#: ../vector/v.extrude/main.c:258
-#, fuzzy
msgid "Extruding vector primitives..."
+msgstr "Wytłaczanie prymitywów wektorowych ..."
#: ../vector/v.extrude/main.c:291
-#, fuzzy, c-format
+#, c-format
msgid "Cannot select attributes for area #%d"
+msgstr "Nie można wybrać atrybutów dla pola #%d"
#: ../vector/v.extrude/main.c:309
#, c-format
msgid "Column <%s>: invalid data type"
-msgstr ""
+msgstr "Kolumna <%s>: niewłaściwy typ danych"
#: ../vector/v.segment/main.c:54
msgid "Creates points/segments from input vector lines and positions."
@@ -27690,9 +27681,9 @@
msgstr "Wczytano [%d] linii"
#: ../vector/v.segment/main.c:231
-#, fuzzy, c-format
+#, c-format
msgid "%d lines written to output map (%d lost)"
-msgstr "[%d] linii zapisanych do mapy wejściowej(%d utraconych)"
+msgstr "%d linii zapisanych do mapy wyjściowej(%d utraconych)"
#: ../vector/v.what/what.c:157
#, c-format
@@ -27898,9 +27889,8 @@
msgstr "Odwracanie matrycy..."
#: ../vector/v.generalize/displacement.c:198
-#, fuzzy
msgid "Unable to calculate the inverse matrix"
-msgstr "nie można zamknąć mapy wejściowej"
+msgstr "Nie można obliczyć matrycy odwróconej"
#: ../vector/v.generalize/displacement.c:201
msgid "Resolving conflicts..."
@@ -28545,7 +28535,7 @@
#: ../vector/v.net.connectivity/main.c:70
msgid "Set1 layer number or name"
-msgstr "Zestaw1 liczba warstw lub nazwa"
+msgstr "Zestaw1 numer warstwy lub nazwa"
#: ../vector/v.net.connectivity/main.c:71
#: ../vector/v.net.connectivity/main.c:76
@@ -28563,7 +28553,7 @@
#: ../vector/v.net.connectivity/main.c:86
msgid "Set2 layer number or name"
-msgstr "Zestaw2 liczba warstw lub nazwa"
+msgstr "Zestaw2 numer warstwy lub nazwa"
#: ../vector/v.net.connectivity/main.c:87
#: ../vector/v.net.connectivity/main.c:92
@@ -28819,7 +28809,7 @@
#: ../locale/scriptstrings/v.centroids_to_translate.c:6
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:10
msgid "Layer number"
+msgstr "Numer warstwy"
#: ../vector/v.out.vtk/main.c:93
msgid "Export numeric attribute table fields as VTK scalar variables"
@@ -31014,9 +31004,8 @@
msgstr ""
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:5
-#, fuzzy
msgid "Percentile to calculate (requires -e flag)"
+msgstr ""
#: ../locale/scriptstrings/r.tileset_to_translate.c:1
msgid "Produces tilings of the source projection for use in the destination region and projection."
@@ -31370,9 +31359,8 @@
msgstr "wektor, obszar, rozłączanie"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-#, fuzzy
msgid "Layer number. If -1, all layers are extracted."
-msgstr "Numer warstwy. Jesli -l, wszystkie warstwy są wyświetlane."
+msgstr "Numer warstwy. Dla -l, wszystkie warstwy będą wyciągnięte."
#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
#, fuzzy
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po 2012-09-17 22:11:12 UTC (rev 53197)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po 2012-09-17 22:11:20 UTC (rev 53198)
@@ -8,8 +8,8 @@
"Project-Id-Version: grasswxpy_pl\n"
-"PO-Revision-Date: 2012-09-08 01:03+0100\n"
-"Last-Translator: Robert Szczepanek <robert at szczepanek.pl>\n"
+"PO-Revision-Date: 2012-09-17 23:03+0100\n"
+"Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
"Language: pl\n"
"MIME-Version: 1.0\n"
@@ -22,9 +22,8 @@
"X-Poedit-Bookmarks: 977,-1,-1,-1,-1,-1,-1,-1,-1,-1\n"
#: ../gui/wxpython/gui_modules/psmap.py:55
-#, fuzzy
msgid "GRASS GIS Cartographic Composer (experimental prototype)"
-msgstr "Graficzny modeler GRASS GIS"
+msgstr "Kompozytor wydruków GRASS GIS (prototyp)"
#: ../gui/wxpython/gui_modules/psmap.py:176
msgid ""
@@ -94,9 +93,8 @@
msgstr ""
#: ../gui/wxpython/gui_modules/psmap.py:912
-#, fuzzy
msgid "wxGUI Cartographic Composer"
-msgstr "Graficzny modeler wxGUI"
+msgstr "Kompozytor wydruków wxGUI"
#: ../gui/wxpython/gui_modules/psmap.py:914
msgid ""
@@ -5298,16 +5296,16 @@
#: ../gui/wxpython/gui_modules/menuform.py:749
#: ../gui/wxpython/gui_modules/menuform.py:762
msgid "Required"
-msgstr "Wymagane"
+msgstr "Podstawa"
#: ../gui/wxpython/gui_modules/menuform.py:752
msgid "Optional"
-msgstr "Opcjonalne"
+msgstr "Opcje"
#: ../gui/wxpython/gui_modules/menuform.py:795
msgid "Manual"
-msgstr "Przewodnik użytkownika"
+msgstr "Przewodnik"
#: ../gui/wxpython/gui_modules/menuform.py:835
#: ../gui/wxpython/gui_modules/menuform.py:1303
@@ -8676,9 +8674,8 @@
# przykryj nie brzmi ...; może złącz, scal?
#: ../gui/wxpython/menustrings.py:312
-#, fuzzy
msgid "Overlay rasters"
-msgstr "Przykryj mapy rastrowe"
+msgstr "Nakładanie rastrów"
# poprzecznego?
#: ../gui/wxpython/menustrings.py:313
@@ -9500,7 +9497,7 @@
#: ../gui/wxpython/menustrings.py:520
-msgstr "Utworzy linie równoległe do podanych linii wektorowych."
#: ../gui/wxpython/menustrings.py:521
msgid "Dissolve boundaries"
@@ -9564,7 +9561,7 @@
#: ../gui/wxpython/menustrings.py:537
msgid "Topology maintenance"
-msgstr ""
+msgstr "Topologia"
#: ../gui/wxpython/menustrings.py:538
msgid "Create or rebuild topology"
