[GRASS-SVN] r53248 - in grass/branches/releasebranch_6_4: locale/po vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label
svn_grass at osgeo.org
Thu Sep 20 12:23:03 PDT 2012
Author: neteler
Date: 2012-09-20 12:23:02 -0700 (Thu, 20 Sep 2012)
New Revision: 53248
grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
grass/branches/releasebranch_6_4/vector/v.lrs/v.lrs.create/main.c
grass/branches/releasebranch_6_4/vector/v.lrs/v.lrs.label/main.c
msg style fix
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ar.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24085,7 +24085,7 @@
msgstr "%d ÙÙØ§Ø· تÙ
تØÙ
ÙÙÙØ§\n"
#: ../vector/v.lrs/v.lrs.create/main.c:121
-msgid "Create Linear Reference System"
+msgid "Creates Linear Reference System"
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:130
@@ -24259,7 +24259,7 @@
msgstr "dig ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
#: ../vector/v.lrs/v.lrs.label/main.c:103
-msgid "Create stationing from input lines, and linear reference system"
+msgid "Creates stationing from input lines, and linear reference system"
msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:111
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_cs.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24193,7 +24193,7 @@
msgstr "[%d] bodů - nalezeno pÅÃliÅ¡ mnoh záznamů"
msgstr "vytvoÅit lineárnà referenÄnà systém"
@@ -24357,7 +24357,7 @@
msgstr "Buduji topologii pro vektorovou mapu s chybami ..."
msgstr "VytváÅà staniÄenà ze vstupnÃch liniÃ, a lineárnà referenÄnà systém "
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24163,8 +24163,8 @@
msgstr "[%d] Punkte - zu viele Einträge gefunden."
-msgstr "Erzeuge Linearesreferenzsystem"
+msgstr "Erzeugt Lineares Referenzsystem"
msgid "Output vector map where oriented lines are written"
@@ -24339,7 +24339,7 @@
msgstr "Erstelle Topologie für Fehlerkarte (err)..."
msgstr ""
"Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -22874,7 +22874,7 @@
msgstr ""
msgstr ""
@@ -23036,7 +23036,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_es.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_es.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24316,10 +24316,10 @@
#: ../vector/v.lrs/v.lrs.where/main.c:227
#, c-format
msgid "[%d] points - too many records found"
-msgstr "[%d]puntos - demasiados registros encontrados"
+msgstr "[%d] puntos - demasiados registros encontrados"
msgstr "Crear Sistema de Referencia Lineal (LRS)"
@@ -24496,7 +24496,7 @@
#, fuzzy
msgstr "líneas"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_fr.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -25809,7 +25809,7 @@
msgstr "%d points en dehors de la région courante"
msgstr ""
@@ -25989,7 +25989,7 @@
msgstr "Lecteur du fichier raster..."
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_hi.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24661,7 +24661,7 @@
msgstr "नहà¥à¤"
msgstr ""
@@ -24834,7 +24834,7 @@
msgstr "n"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_it.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_it.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -23348,7 +23348,7 @@
msgstr "[%d] punti - trovati troppi record"
msgstr "Crea sistema di riferimento lineare"
@@ -23513,7 +23513,7 @@
"Costruzione della topologia per la mappa degli errori (err) in corso..."
msgstr " Crea dislocazioni da linee, e il sistema di riferimento lineare"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ja.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -23511,7 +23511,7 @@
msgstr "[%d] ã®ãã¤ã³ã - è¨é²ãå¤éãã¾ã"
msgstr "ç·ååç
§ç³»ã使"
@@ -23674,7 +23674,7 @@
msgstr "誤差 (err) ãããã®å°å½¢ãæ§ç¯ä¸ããã"
msgstr "æå®ã©ã¤ã³ããã®åºç¹ã¨ç·ååç
§ç³»ã使"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ko.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -23151,7 +23151,7 @@
msgstr ""
msgstr ""
@@ -23318,7 +23318,7 @@
msgstr "ì¶ë ¥í ëì¤í°ë§µ"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_lv.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -23872,7 +23872,7 @@
msgstr "DrukÄt tekoÅ¡o reÄ£ionu pÄc platuma/garuma"
msgstr ""
@@ -24045,7 +24045,7 @@
msgstr "Lasam dig_att failu...\n"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_mr.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -23296,7 +23296,7 @@
msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
msgstr ""
@@ -23465,7 +23465,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_nl.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -22561,7 +22561,7 @@
msgstr ""
msgstr ""
@@ -22723,7 +22723,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pl.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -23681,7 +23681,7 @@
msgstr ""
msgstr "Utwórz Linear Reference System"
@@ -23843,7 +23843,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24948,7 +24948,7 @@
msgstr "%d pontos fora da região atual."
msgstr ""
@@ -25122,7 +25122,7 @@
msgstr "Lendo arquivo dig_att...\n"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_pt_br.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24776,7 +24776,7 @@
msgstr ""
@@ -24950,7 +24950,7 @@
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_ru.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24156,7 +24156,7 @@
msgstr "[%d] ÑоÑек - ÑлиÑком много запиÑей"
msgstr "СоздаÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
@@ -24322,7 +24322,7 @@
msgstr "ÐоÑÑÑоение Ñопологии Ð´Ð»Ñ ÑÐ»Ð¾Ñ Ð¾Ñибок (err) ..."
msgstr "СоздаÑÑ ÑÑанÑии из иÑÑ
однÑÑ
линий и линейнÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_sl.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24314,7 +24314,7 @@
msgstr "Uporabi trenutno regijo"
msgstr ""
@@ -24488,7 +24488,7 @@
msgstr "Berem dig_att datoteko...\n"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_th.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_th.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -23960,7 +23960,7 @@
msgstr "[%d] à¸à¸¸à¸ - à¸à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸¡à¸²à¸à¹à¸à¸´à¸à¹à¸"
msgstr "สรà¹à¸²à¸ ระà¸à¸à¸à¸²à¸£à¸à¹à¸²à¸à¸à¸´à¸à¸à¸³à¹à¸«à¸à¹à¸à¹à¸à¸´à¸à¹à¸ªà¹à¸"
@@ -24122,7 +24122,7 @@
msgstr "สรà¹à¸²à¸ topology สำหรัภà¹à¸à¸à¸à¸µà¹à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸ ..."
msgstr "สรà¹à¸²à¸ stationing à¸à¸²à¸ à¹à¸ªà¹à¸à¸à¸µà¹à¸à¸³à¹à¸à¹à¸², à¹à¸¥à¸° ระà¸à¸à¸à¹à¸²à¸à¸à¸´à¸à¹à¸à¸´à¸à¹à¸ªà¹à¸"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_tr.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -23306,7 +23306,7 @@
msgstr "[%d] nokta - çok fazla kayıt bulundu"
msgstr ""
@@ -23468,7 +23468,7 @@
msgstr "Hata (err) haritası için topoloji kuruluyor..."
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_vi.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24119,7 +24119,7 @@
msgstr "[%d] Äiá»m - tìm thấy quá nhiá»u bản ghi"
msgstr "Tạo Há» tham chiếu Tuyến tÃnh"
@@ -24286,7 +24286,7 @@
msgstr "Äang xây dá»±ng lại tôpô cho bản Äá» chứa lá»i (err)..."
msgstr "Tạo há» thá»ng cá»c Äo từ các ÄÆ°á»ng Äầu và o, và há» tham chiếu tuyến tÃnh"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_zh.po 2012-09-20 19:23:02 UTC (rev 53248)
@@ -24112,7 +24112,7 @@
msgstr "%d 个ç¹å¨å½åèå´ä¹å¤ï¼å°è¢«å¿½ç¥"
msgstr ""
msgstr "ç¢éæä»¶è¯»åé误"
msgstr ""
Modified: grass/branches/releasebranch_6_4/vector/v.lrs/v.lrs.create/main.c
--- grass/branches/releasebranch_6_4/vector/v.lrs/v.lrs.create/main.c 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/vector/v.lrs/v.lrs.create/main.c 2012-09-20 19:23:02 UTC (rev 53248)
@@ -118,7 +118,7 @@
module = G_define_module();
module->keywords = _("vector, LRS, networking");
- module->description = _("Create Linear Reference System");
+ module->description = _("Creates Linear Reference System");
in_lines_opt = G_define_standard_option(G_OPT_V_INPUT);
in_lines_opt->key = "in_lines";
Modified: grass/branches/releasebranch_6_4/vector/v.lrs/v.lrs.label/main.c
--- grass/branches/releasebranch_6_4/vector/v.lrs/v.lrs.label/main.c 2012-09-20 18:38:11 UTC (rev 53247)
+++ grass/branches/releasebranch_6_4/vector/v.lrs/v.lrs.label/main.c 2012-09-20 19:23:02 UTC (rev 53248)
@@ -100,7 +100,7 @@
- module->description = _("Create stationing from input lines, "
+ module->description = _("Creates stationing from input lines, "
"and linear reference system");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
