[GRASS-SVN] r53249 - in grass/branches/develbranch_6: locale/po vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label
svn_grass at osgeo.org
Thu Sep 20 12:26:20 PDT 2012
Author: neteler
Date: 2012-09-20 12:26:19 -0700 (Thu, 20 Sep 2012)
New Revision: 53249
grass/branches/develbranch_6/locale/po/grassmods_ar.po
grass/branches/develbranch_6/locale/po/grassmods_cs.po
grass/branches/develbranch_6/locale/po/grassmods_de.po
grass/branches/develbranch_6/locale/po/grassmods_el.po
grass/branches/develbranch_6/locale/po/grassmods_es.po
grass/branches/develbranch_6/locale/po/grassmods_fr.po
grass/branches/develbranch_6/locale/po/grassmods_hi.po
grass/branches/develbranch_6/locale/po/grassmods_it.po
grass/branches/develbranch_6/locale/po/grassmods_ja.po
grass/branches/develbranch_6/locale/po/grassmods_ko.po
grass/branches/develbranch_6/locale/po/grassmods_lv.po
grass/branches/develbranch_6/locale/po/grassmods_mr.po
grass/branches/develbranch_6/locale/po/grassmods_pl.po
grass/branches/develbranch_6/locale/po/grassmods_pt.po
grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
grass/branches/develbranch_6/locale/po/grassmods_ru.po
grass/branches/develbranch_6/locale/po/grassmods_sl.po
grass/branches/develbranch_6/locale/po/grassmods_th.po
grass/branches/develbranch_6/locale/po/grassmods_tr.po
grass/branches/develbranch_6/locale/po/grassmods_vi.po
grass/branches/develbranch_6/locale/po/grassmods_zh.po
grass/branches/develbranch_6/vector/v.lrs/v.lrs.create/main.c
grass/branches/develbranch_6/vector/v.lrs/v.lrs.label/main.c
msg style fix
Modified: grass/branches/develbranch_6/locale/po/grassmods_ar.po
--- grass/branches/develbranch_6/locale/po/grassmods_ar.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_ar.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24449,7 +24449,7 @@
msgstr "%d ÙÙØ§Ø· تÙ
تØÙ
ÙÙÙØ§\n"
#: ../vector/v.lrs/v.lrs.create/main.c:121
-msgid "Create Linear Reference System"
+msgid "Creates Linear Reference System"
msgstr ""
#: ../vector/v.lrs/v.lrs.create/main.c:130
@@ -24623,7 +24623,7 @@
msgstr "dig ÙØ±Ø§Ø¡Ø© Ù
ÙÙ...\n"
#: ../vector/v.lrs/v.lrs.label/main.c:103
-msgid "Create stationing from input lines, and linear reference system"
+msgid "Creates stationing from input lines, and linear reference system"
msgstr ""
#: ../vector/v.lrs/v.lrs.label/main.c:111
Modified: grass/branches/develbranch_6/locale/po/grassmods_cs.po
--- grass/branches/develbranch_6/locale/po/grassmods_cs.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_cs.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24616,7 +24616,7 @@
msgstr "[%d] bodů - nalezeno pÅÃliÅ¡ mnoh záznamů"
msgstr "vytvoÅit lineárnà referenÄnà systém"
@@ -24780,7 +24780,7 @@
msgstr "Buduji topologii pro vektorovou mapu s chybami ..."
msgstr "VytváÅà staniÄenà ze vstupnÃch liniÃ, a lineárnà referenÄnà systém "
Modified: grass/branches/develbranch_6/locale/po/grassmods_de.po
--- grass/branches/develbranch_6/locale/po/grassmods_de.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_de.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24597,8 +24597,8 @@
msgstr "[%d] Punkte - zu viele Einträge gefunden."
-msgstr "Erzeuge Linearesreferenzsystem"
+msgstr "Erzeugt Lineares Referenzsystem"
msgid "Output vector map where oriented lines are written"
@@ -24773,7 +24773,7 @@
msgstr "Erstelle Topologie für Fehlerkarte (err)..."
msgstr ""
"Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -23237,7 +23237,7 @@
msgstr ""
msgstr ""
@@ -23399,7 +23399,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24737,10 +24737,10 @@
#: ../vector/v.lrs/v.lrs.where/main.c:227
#, c-format
msgid "[%d] points - too many records found"
-msgstr "[%d]puntos - demasiados registros encontrados"
+msgstr "[%d] puntos - demasiados registros encontrados"
msgstr "Crear Sistema de Referencia Lineal (LRS)"
@@ -24917,7 +24917,7 @@
#, fuzzy
msgstr "líneas"
Modified: grass/branches/develbranch_6/locale/po/grassmods_fr.po
--- grass/branches/develbranch_6/locale/po/grassmods_fr.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_fr.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -26221,7 +26221,7 @@
msgstr "%d points en dehors de la région courante"
msgstr ""
@@ -26401,7 +26401,7 @@
msgstr "Lecteur du fichier raster..."
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_hi.po
--- grass/branches/develbranch_6/locale/po/grassmods_hi.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_hi.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -25001,7 +25001,7 @@
msgstr "नहà¥à¤"
msgstr ""
@@ -25174,7 +25174,7 @@
msgstr "n"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -23721,7 +23721,7 @@
msgstr "[%d] punti - trovati troppi record"
msgstr "Crea sistema di riferimento lineare"
@@ -23886,7 +23886,7 @@
"Costruzione della topologia per la mappa degli errori (err) in corso..."
msgstr " Crea dislocazioni da linee, e il sistema di riferimento lineare"
Modified: grass/branches/develbranch_6/locale/po/grassmods_ja.po
--- grass/branches/develbranch_6/locale/po/grassmods_ja.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_ja.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -23930,7 +23930,7 @@
msgstr "[%d] ã®ãã¤ã³ã - è¨é²ãå¤éãã¾ã"
msgstr "ç·ååç
§ç³»ã使"
@@ -24093,7 +24093,7 @@
msgstr "誤差 (err) ãããã®å°å½¢ãæ§ç¯ä¸ããã"
msgstr "æå®ã©ã¤ã³ããã®åºç¹ã¨ç·ååç
§ç³»ã使"
Modified: grass/branches/develbranch_6/locale/po/grassmods_ko.po
--- grass/branches/develbranch_6/locale/po/grassmods_ko.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_ko.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -23518,7 +23518,7 @@
msgstr ""
msgstr ""
@@ -23685,7 +23685,7 @@
msgstr "ì¶ë ¥í ëì¤í°ë§µ"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_lv.po
--- grass/branches/develbranch_6/locale/po/grassmods_lv.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_lv.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24235,7 +24235,7 @@
msgstr "DrukÄt tekoÅ¡o reÄ£ionu pÄc platuma/garuma"
msgstr ""
@@ -24408,7 +24408,7 @@
msgstr "Lasam dig_att failu...\n"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_mr.po
--- grass/branches/develbranch_6/locale/po/grassmods_mr.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_mr.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -23661,7 +23661,7 @@
msgstr "'%s'. डà¥à¤°à¤¾à¤à¤µà¤° à¤à¤¾à¤²à¥ हà¥à¤¤ नाहà¥"
msgstr ""
@@ -23830,7 +23830,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pl.po
--- grass/branches/develbranch_6/locale/po/grassmods_pl.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_pl.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -22929,7 +22929,7 @@
msgstr ""
msgstr "Utwórz Linear Reference System"
@@ -23090,7 +23090,7 @@
msgstr ""
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -25322,7 +25322,7 @@
msgstr "%d pontos fora da região atual."
msgstr ""
@@ -25496,7 +25496,7 @@
msgstr "Lendo arquivo dig_att...\n"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -25151,7 +25151,7 @@
msgstr ""
@@ -25325,7 +25325,7 @@
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24580,7 +24580,7 @@
msgstr "[%d] ÑоÑек - ÑлиÑком много запиÑей"
msgstr "СоздаÑÑ Ð»Ð¸Ð½ÐµÐ¹Ð½ÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
@@ -24746,7 +24746,7 @@
msgstr "ÐоÑÑÑоение Ñопологии Ð´Ð»Ñ ÑÐ»Ð¾Ñ Ð¾Ñибок (err) ..."
msgstr "СоздаÑÑ ÑÑанÑии из иÑÑ
однÑÑ
линий и линейнÑÑ ÑиÑÑÐµÐ¼Ñ ÐºÐ¾Ð¾ÑдинаÑ"
Modified: grass/branches/develbranch_6/locale/po/grassmods_sl.po
--- grass/branches/develbranch_6/locale/po/grassmods_sl.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_sl.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24676,7 +24676,7 @@
msgstr "Uporabi trenutno regijo"
msgstr ""
@@ -24850,7 +24850,7 @@
msgstr "Berem dig_att datoteko...\n"
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_th.po
--- grass/branches/develbranch_6/locale/po/grassmods_th.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_th.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24357,7 +24357,7 @@
msgstr "[%d] à¸à¸¸à¸ - à¸à¸à¸à¹à¸à¸¡à¸¹à¸¥à¸¡à¸²à¸à¹à¸à¸´à¸à¹à¸"
msgstr "สรà¹à¸²à¸ ระà¸à¸à¸à¸²à¸£à¸à¹à¸²à¸à¸à¸´à¸à¸à¸³à¹à¸«à¸à¹à¸à¹à¸à¸´à¸à¹à¸ªà¹à¸"
@@ -24519,7 +24519,7 @@
msgstr "สรà¹à¸²à¸ topology สำหรัภà¹à¸à¸à¸à¸µà¹à¸à¹à¸à¸à¸´à¸à¸à¸¥à¸²à¸ ..."
msgstr "สรà¹à¸²à¸ stationing à¸à¸²à¸ à¹à¸ªà¹à¸à¸à¸µà¹à¸à¸³à¹à¸à¹à¸², à¹à¸¥à¸° ระà¸à¸à¸à¹à¸²à¸à¸à¸´à¸à¹à¸à¸´à¸à¹à¸ªà¹à¸"
Modified: grass/branches/develbranch_6/locale/po/grassmods_tr.po
--- grass/branches/develbranch_6/locale/po/grassmods_tr.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_tr.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -23707,7 +23707,7 @@
msgstr "[%d] nokta - çok fazla kayıt bulundu"
msgstr ""
@@ -23869,7 +23869,7 @@
msgstr "Hata (err) haritası için topoloji kuruluyor..."
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_vi.po
--- grass/branches/develbranch_6/locale/po/grassmods_vi.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_vi.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24544,7 +24544,7 @@
msgstr "[%d] Äiá»m - tìm thấy quá nhiá»u bản ghi"
msgstr "Tạo Há» tham chiếu Tuyến tÃnh"
@@ -24711,7 +24711,7 @@
msgstr "Äang xây dá»±ng lại tôpô cho bản Äá» chứa lá»i (err)..."
msgstr "Tạo há» thá»ng cá»c Äo từ các ÄÆ°á»ng Äầu và o, và há» tham chiếu tuyến tÃnh"
Modified: grass/branches/develbranch_6/locale/po/grassmods_zh.po
--- grass/branches/develbranch_6/locale/po/grassmods_zh.po 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/locale/po/grassmods_zh.po 2012-09-20 19:26:19 UTC (rev 53249)
@@ -24505,7 +24505,7 @@
msgstr "%d 个ç¹å¨å½åèå´ä¹å¤ï¼å°è¢«å¿½ç¥"
msgstr ""
@@ -24679,7 +24679,7 @@
msgstr "ç¢éæä»¶è¯»åé误"
msgstr ""
Modified: grass/branches/develbranch_6/vector/v.lrs/v.lrs.create/main.c
--- grass/branches/develbranch_6/vector/v.lrs/v.lrs.create/main.c 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/vector/v.lrs/v.lrs.create/main.c 2012-09-20 19:26:19 UTC (rev 53249)
@@ -118,7 +118,7 @@
module = G_define_module();
module->keywords = _("vector, LRS, networking");
- module->description = _("Create Linear Reference System");
+ module->description = _("Creates Linear Reference System");
in_lines_opt = G_define_standard_option(G_OPT_V_INPUT);
in_lines_opt->key = "in_lines";
Modified: grass/branches/develbranch_6/vector/v.lrs/v.lrs.label/main.c
--- grass/branches/develbranch_6/vector/v.lrs/v.lrs.label/main.c 2012-09-20 19:23:02 UTC (rev 53248)
+++ grass/branches/develbranch_6/vector/v.lrs/v.lrs.label/main.c 2012-09-20 19:26:19 UTC (rev 53249)
@@ -100,7 +100,7 @@
- module->description = _("Create stationing from input lines, "
+ module->description = _("Creates stationing from input lines, "
"and linear reference system");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
