[GRASS-SVN] r53268 - in grass/trunk/lib/raster3d: . test
svn_grass at osgeo.org
Sat Sep 22 17:40:56 PDT 2012
Author: huhabla
Date: 2012-09-22 17:40:56 -0700 (Sat, 22 Sep 2012)
New Revision: 53268
grass/trunk/lib/raster3d/defaults.c
grass/trunk/lib/raster3d/fpcompress.c
grass/trunk/lib/raster3d/open.c
grass/trunk/lib/raster3d/test/Makefile
grass/trunk/lib/raster3d/test/test_g3d_lib.h
grass/trunk/lib/raster3d/test/test_main.c
grass/trunk/lib/raster3d/test/test_put_get_value_large_file.c
Disbaled the use of XDR and RLE when opening a new 3D raster map.
New maps are using now the non-XDR related functions for reading and writing
and the LZW compression. RLE was disabled since it is buggy with large tiles and files.
Modified: grass/trunk/lib/raster3d/defaults.c
--- grass/trunk/lib/raster3d/defaults.c 2012-09-22 00:18:55 UTC (rev 53267)
+++ grass/trunk/lib/raster3d/defaults.c 2012-09-23 00:40:56 UTC (rev 53268)
@@ -8,8 +8,8 @@
#define RASTER3D_NO_DEFAULT -10
#define RASTER3D_COMPRESSION_DEFAULT RASTER3D_COMPRESSION
-#define RASTER3D_USE_LZW_DEFAULT RASTER3D_NO_LZW
-#define RASTER3D_USE_RLE_DEFAULT RASTER3D_USE_RLE
+#define RASTER3D_USE_LZW_DEFAULT RASTER3D_USE_LZW
+#define RASTER3D_USE_RLE_DEFAULT RASTER3D_NO_RLE
#define RASTER3D_PRECISION_DEFAULT RASTER3D_MAX_PRECISION
#define RASTER3D_CACHE_SIZE_DEFAULT 1000
#define RASTER3D_CACHE_SIZE_MAX_DEFAULT 16777216
Modified: grass/trunk/lib/raster3d/fpcompress.c
--- grass/trunk/lib/raster3d/fpcompress.c 2012-09-22 00:18:55 UTC (rev 53267)
+++ grass/trunk/lib/raster3d/fpcompress.c 2012-09-23 00:40:56 UTC (rev 53268)
@@ -692,7 +692,7 @@
-/* IMPORTANT!!! this function changes the "src". */
+/* IMPORTANT!!! this function modifies "src" in case of run length encoding RLE. */
int
Rast3d_fpcompress_write_xdr_nums(int fd, char *src, int nofNum, int precision,
Modified: grass/trunk/lib/raster3d/open.c
--- grass/trunk/lib/raster3d/open.c 2012-09-22 00:18:55 UTC (rev 53267)
+++ grass/trunk/lib/raster3d/open.c 2012-09-23 00:40:56 UTC (rev 53268)
@@ -243,7 +243,8 @@
Rast3d_make_mapset_map_directory(map->fileName);
- map->useXdr = RASTER3D_USE_XDR;
+ /* XDR support has been removed */
+ map->useXdr = RASTER3D_NO_XDR;
if (g3d_file_type == FCELL_TYPE) {
if (precision > 23)
@@ -266,8 +267,6 @@
if (compression == RASTER3D_NO_COMPRESSION)
precision = RASTER3D_MAX_PRECISION;
- if (compression == RASTER3D_COMPRESSION)
if (RASTER3D_HAS_INDEX) {
map->indexLongNbytes = sizeof(long);
Modified: grass/trunk/lib/raster3d/test/Makefile
--- grass/trunk/lib/raster3d/test/Makefile 2012-09-22 00:18:55 UTC (rev 53267)
+++ grass/trunk/lib/raster3d/test/Makefile 2012-09-23 00:40:56 UTC (rev 53268)
@@ -3,7 +3,10 @@
PGM=test.g3d.lib
LIBES = $(GISLIB) $(RASTER3DLIB) $(RASTERLIB)
-DEPENDENCIES = $(GISDEP) $(RASTER3DDEP) $(RASTERDEP)
+DEPENDENCIES = $(GISDEP) $(RASTER3DDEP) $(RASTERDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
include $(MODULE_TOPDIR)/include/Make/Module.make
default: cmd
Modified: grass/trunk/lib/raster3d/test/test_g3d_lib.h
--- grass/trunk/lib/raster3d/test/test_g3d_lib.h 2012-09-22 00:18:55 UTC (rev 53267)
+++ grass/trunk/lib/raster3d/test/test_g3d_lib.h 2012-09-23 00:40:56 UTC (rev 53268)
@@ -25,6 +25,6 @@
double compute_time_difference(struct timeval start, struct timeval end);
int unit_test_coordinate_transform(void);
int unit_test_put_get_value(void);
-int unit_test_put_get_value_large_file(int depths, int rows, int cols);
+int unit_test_put_get_value_large_file(int depths, int rows, int cols, int tile_size);
#endif
Modified: grass/trunk/lib/raster3d/test/test_main.c
--- grass/trunk/lib/raster3d/test/test_main.c 2012-09-22 00:18:55 UTC (rev 53267)
+++ grass/trunk/lib/raster3d/test/test_main.c 2012-09-23 00:40:56 UTC (rev 53268)
@@ -21,8 +21,8 @@
/*- Parameters and global variables -----------------------------------------*/
typedef struct {
- struct Option *unit, *integration, *depths, *rows, *cols;
- struct Flag *full, *testunit, *testint;
+ struct Option *unit, *integration, *depths, *rows, *cols, *tile_size;
+ struct Flag *full, *testunit, *testint, *rle, *compression;
} paramType;
paramType param; /*Parameters */
@@ -54,22 +54,29 @@
param.depths->type = TYPE_INTEGER;
param.depths->required = NO;
param.depths->answer = "20";
- param.depths->description = _("The number of depths to be used for the large file put value test");
+ param.depths->description = _("The number of depths to be used for the large file put/get value test");
param.rows = G_define_option();
param.rows->key = "rows";
param.rows->type = TYPE_INTEGER;
param.rows->required = NO;
param.rows->answer = "5400";
- param.rows->description = _("The number of rows to be used for the large file put value test");
+ param.rows->description = _("The number of rows to be used for the large file put/get value test");
param.cols = G_define_option();
param.cols->key = "cols";
param.cols->type = TYPE_INTEGER;
param.cols->required = NO;
param.cols->answer = "10800";
- param.cols->description = _("The number of columns to be used for the large file put value test");
+ param.cols->description = _("The number of columns to be used for the large file put/get value test");
+ param.tile_size = G_define_option();
+ param.tile_size->key = "tile_size";
+ param.tile_size->type = TYPE_INTEGER;
+ param.tile_size->required = NO;
+ param.tile_size->answer = "32";
+ param.tile_size->description = _("The tile size in kilo bytes to be used for the large file put/get value test. Set the tile size to 2048 and the number of row*cols*depths > 130000 to reproduce the tile rle error.");
param.testunit = G_define_flag();
param.testunit->key = 'u';
param.testunit->description = _("Run all unit tests");
@@ -82,6 +89,13 @@
param.full->key = 'a';
param.full->description = _("Run all unit and integration tests");
+ param.compression = G_define_flag();
+ param.compression->key = 'l';
+ param.compression->description = _("Switch lzw compression on");
+ param.rle = G_define_flag();
+ param.rle->key = 'r';
+ param.rle->description = _("Use run length encoding RLE to encode/decode single tiles. Attention RLE is buggy in case of large tiles or files.");
@@ -91,7 +105,10 @@
int main(int argc, char *argv[]) {
struct GModule *module;
int returnstat = 0, i;
- int depths, rows, cols;
+ int depths, rows, cols, tile_size;
+ int doCompress = RASTER3D_COMPRESSION;
+ int doLzw = RASTER3D_USE_LZW;
+ int doRle = RASTER3D_NO_RLE;
/* Initialize GRASS */
G_gisinit(argv[0]);
@@ -109,6 +126,23 @@
depths = atoi(param.depths->answer);
rows = atoi(param.rows->answer);
cols = atoi(param.cols->answer);
+ tile_size = atoi(param.tile_size->answer);
+ if(param.compression->answer) {
+ doCompress = RASTER3D_COMPRESSION;
+ doLzw = RASTER3D_USE_LZW;
+ } else {
+ doCompress = RASTER3D_NO_COMPRESSION;
+ doLzw = RASTER3D_NO_LZW;
+ if(param.rle->answer) {
+ doRle = RASTER3D_USE_RLE;
+ } else
+ doRle = RASTER3D_NO_RLE;
+ /* Set the compression mode that should be used */
+ Rast3d_set_compression_mode(doCompress, doLzw, doRle, RASTER3D_MAX_PRECISION);
/* Initiate the defaults for testing */
Rast3d_init_defaults();
@@ -117,7 +151,7 @@
if (param.testunit->answer || param.full->answer) {
returnstat += unit_test_coordinate_transform();
returnstat += unit_test_put_get_value();
- returnstat += unit_test_put_get_value_large_file(depths, rows, cols);
+ returnstat += unit_test_put_get_value_large_file(depths, rows, cols, tile_size);
/*Run the integration tests */
@@ -137,7 +171,7 @@
if (strcmp(param.unit->answers[i], "putget") == 0)
if (strcmp(param.unit->answers[i], "large") == 0)
i++;
Modified: grass/trunk/lib/raster3d/test/test_put_get_value_large_file.c
--- grass/trunk/lib/raster3d/test/test_put_get_value_large_file.c 2012-09-22 00:18:55 UTC (rev 53267)
+++ grass/trunk/lib/raster3d/test/test_put_get_value_large_file.c 2012-09-23 00:40:56 UTC (rev 53268)
@@ -19,18 +19,20 @@
#include "test_g3d_lib.h"
#include "grass/interpf.h"
-static int test_large_file(int depths, int rows, int cols);
+#define EPSILON 0.000000001
+static int test_large_file(int depths, int rows, int cols, int tile_size);
/* Perfrome the coordinate transformation tests ****************** */
int sum = 0;
G_message(_("\n++ Running g3d put/get value large file unit tests ++"));
- sum += test_large_file(depths, rows, cols);
+ sum += test_large_file(depths, rows, cols, tile_size);
if (sum > 0)
@@ -43,7 +45,7 @@
-int test_large_file(int depths, int rows, int cols)
+int test_large_file(int depths, int rows, int cols, int tile_size)
int sum = 0;
int x, y, z;
@@ -72,7 +74,7 @@
G_message("Creating 3D raster map");
- map = Rast3d_open_new_opt_tile_size("test_put_get_value_dcell_large", RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, 2048);
+ map = Rast3d_open_new_opt_tile_size("test_put_get_value_dcell_large", RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, tile_size);
/* The window is the same as the map region ... of course */
Rast3d_set_window_map(map, ®ion);
@@ -83,8 +85,9 @@
for(y = 0; y < region.rows; y++) {
for(x = 0; x < region.cols; x++) {
/* Add cols, rows and depths and put this in the map */
- value = x + y + z + x * y * z / count++;
+ value = count;
Rast3d_put_value(map, x, y, z, &value, DCELL_TYPE);
+ count++;
@@ -96,7 +99,7 @@
G_message("Verifying 3D raster map");
- map = Rast3d_open_cell_old("test_put_get_value_dcell_large", G_mapset(), ®ion, DCELL_TYPE, 2048);
+ map = Rast3d_open_cell_old("test_put_get_value_dcell_large", G_mapset(), ®ion, DCELL_TYPE, RASTER3D_USE_CACHE_XYZ);
count = 1;
for(z = 0; z < region.depths; z++) {
@@ -105,8 +108,11 @@
Rast3d_get_value(map, x, y, z, &value, DCELL_TYPE);
- if(value != (double)(x + y + z + x * y * z/count++))
+ if(fabs(value - (double)(count) > EPSILON)) {
+ /* printf("At: z %i y %i x %i -- value %.14lf != %.14lf\n", z, y, x, value, (double)(count)); */
sum++;
+ count++;
