[GRASS-SVN] r53269 - in grass/trunk/raster3d: r3.cross.rast r3.retile r3.to.rast
svn_grass at osgeo.org
Sat Sep 22 17:42:26 PDT 2012
Author: huhabla
Date: 2012-09-22 17:42:25 -0700 (Sat, 22 Sep 2012)
New Revision: 53269
grass/trunk/raster3d/r3.cross.rast/test.r3.cross.rast.sh
grass/trunk/raster3d/r3.retile/test.r3.retile.sh
grass/trunk/raster3d/r3.retile/test_retile_map_10_info.ref
grass/trunk/raster3d/r3.retile/test_retile_map_1_info.ref
grass/trunk/raster3d/r3.retile/test_retile_map_2_info.ref
grass/trunk/raster3d/r3.retile/test_retile_map_3_info.ref
grass/trunk/raster3d/r3.retile/test_retile_map_4_info.ref
grass/trunk/raster3d/r3.retile/test_retile_map_5_info.ref
grass/trunk/raster3d/r3.retile/test_retile_map_6_info.ref
grass/trunk/raster3d/r3.retile/test_retile_map_7_info.ref
grass/trunk/raster3d/r3.retile/test_retile_map_8_info.ref
grass/trunk/raster3d/r3.retile/test_retile_map_9_info.ref
grass/trunk/raster3d/r3.to.rast/test.r3.to.rast.sh
Tests updated to generate text files for reference file comparison.
Modified: grass/trunk/raster3d/r3.cross.rast/test.r3.cross.rast.sh
--- grass/trunk/raster3d/r3.cross.rast/test.r3.cross.rast.sh 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.cross.rast/test.r3.cross.rast.sh 2012-09-23 00:42:25 UTC (rev 53269)
@@ -34,4 +34,4 @@
r3.cross.rast --o input=volume_null elevation=elev_cross output=test_cross_section_result
# Export of the references
-# for i in `g.mlist type=rast pattern=test_cross_section_*` ; do r.out.ascii input=$i output=${i}.ref; done
+for i in `g.mlist type=rast pattern=test_cross_section_*` ; do r.out.ascii input=$i output=${i}.txt; done
Modified: grass/trunk/raster3d/r3.retile/test.r3.retile.sh
--- grass/trunk/raster3d/r3.retile/test.r3.retile.sh 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test.r3.retile.sh 2012-09-23 00:42:25 UTC (rev 53269)
@@ -14,28 +14,28 @@
# We @test the retiling with different tile sizes, with and without tile caching.
# The validation is based on @raster3d maps and r3.info generated @files.
# We use @precision=0 for data export
-r3.retile input=volume_null output=test_retile_map_1 tiledim=1x1x1
-r3.info -i map=test_retile_map_1 > test_retile_map_1_info.txt
-r3.retile input=volume_null output=test_retile_map_2 tiledim=1x1x1 -c
-r3.info -i map=test_retile_map_2 > test_retile_map_2_info.txt
-r3.retile input=volume_null output=test_retile_map_3 tiledim=8x8x4
-r3.info -i map=test_retile_map_3 > test_retile_map_3_info.txt
-r3.retile input=volume_null output=test_retile_map_4 tiledim=8x8x4 -c
-r3.info -i map=test_retile_map_4 > test_retile_map_4_info.txt
-r3.retile input=volume_null output=test_retile_map_5 tiledim=16x16x16
-r3.info -i map=test_retile_map_5 > test_retile_map_5_info.txt
-r3.retile input=volume_null output=test_retile_map_6 tiledim=16x16x16 -c
-r3.info -i map=test_retile_map_6 > test_retile_map_6_info.txt
-r3.retile input=volume_null output=test_retile_map_7 tiledim=35x47x23
-r3.info -i map=test_retile_map_7 > test_retile_map_7_info.txt
-r3.retile input=volume_null output=test_retile_map_8 tiledim=35x47x23 -c
-r3.info -i map=test_retile_map_8 > test_retile_map_8_info.txt
-r3.retile input=volume_null output=test_retile_map_9 tiledim=34x46x22
-r3.info -i map=test_retile_map_9 > test_retile_map_9_info.txt
-r3.retile input=volume_null output=test_retile_map_10 tiledim=34x46x22 -c
-r3.info -i map=test_retile_map_10 > test_retile_map_10_info.txt
+r3.retile --o input=volume_null output=test_retile_map_1 tiledim=1x1x1
+r3.info -g map=test_retile_map_1 > test_retile_map_1_info.txt
+r3.retile --o input=volume_null output=test_retile_map_2 tiledim=1x1x1 -c
+r3.info -g map=test_retile_map_2 > test_retile_map_2_info.txt
+r3.retile --o input=volume_null output=test_retile_map_3 tiledim=8x8x4
+r3.info -g map=test_retile_map_3 > test_retile_map_3_info.txt
+r3.retile --o input=volume_null output=test_retile_map_4 tiledim=8x8x4 -c
+r3.info -g map=test_retile_map_4 > test_retile_map_4_info.txt
+r3.retile --o input=volume_null output=test_retile_map_5 tiledim=16x16x16
+r3.info -g map=test_retile_map_5 > test_retile_map_5_info.txt
+r3.retile --o input=volume_null output=test_retile_map_6 tiledim=16x16x16 -c
+r3.info -g map=test_retile_map_6 > test_retile_map_6_info.txt
+r3.retile --o input=volume_null output=test_retile_map_7 tiledim=35x47x23
+r3.info -g map=test_retile_map_7 > test_retile_map_7_info.txt
+r3.retile --o input=volume_null output=test_retile_map_8 tiledim=35x47x23 -c
+r3.info -g map=test_retile_map_8 > test_retile_map_8_info.txt
+r3.retile --o input=volume_null output=test_retile_map_9 tiledim=34x46x22
+r3.info -g map=test_retile_map_9 > test_retile_map_9_info.txt
+r3.retile --o input=volume_null output=test_retile_map_10 tiledim=34x46x22 -c
+r3.info -g map=test_retile_map_10 > test_retile_map_10_info.txt
# Create the validation files
-# for map in `g.mlist type=rast3d pattern=test_retile_map_*` ; do
-# r3.out.ascii input=${map} output=${map}.ref dp=0
-# done
\ No newline at end of file
+for map in `g.mlist type=rast3d pattern=test_retile_map_*` ; do
+ r3.out.ascii input=${map} output=${map}.txt dp=0
+done
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_10_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_10_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_10_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
+vertical_units="units"
tilenumx=2
tilenumy=2
tilenumz=2
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_1_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_1_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_1_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
tilenumx=35
tilenumy=47
tilenumz=23
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_2_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_2_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_2_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
tilenumx=35
tilenumy=47
tilenumz=23
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_3_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_3_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_3_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
tilenumx=5
tilenumy=6
tilenumz=6
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_4_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_4_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_4_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
tilenumx=5
tilenumy=6
tilenumz=6
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_5_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_5_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_5_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
tilenumx=3
tilenumy=3
tilenumz=2
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_6_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_6_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_6_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
tilenumx=3
tilenumy=3
tilenumz=2
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_7_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_7_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_7_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
tilenumx=1
tilenumy=1
tilenumz=1
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_8_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_8_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_8_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
tilenumx=1
tilenumy=1
tilenumz=1
Modified: grass/trunk/raster3d/r3.retile/test_retile_map_9_info.ref
--- grass/trunk/raster3d/r3.retile/test_retile_map_9_info.ref 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.retile/test_retile_map_9_info.ref 2012-09-23 00:42:25 UTC (rev 53269)
@@ -1,3 +1,16 @@
+north=47
+south=0
+east=35
+west=0
+bottom=0
+top=23
+nsres=1
+ewres=1
+tbres=1
+datatype="DCELL"
+timestamp="none"
+units="none"
tilenumx=2
tilenumy=2
tilenumz=2
Modified: grass/trunk/raster3d/r3.to.rast/test.r3.to.rast.sh
--- grass/trunk/raster3d/r3.to.rast/test.r3.to.rast.sh 2012-09-23 00:40:56 UTC (rev 53268)
+++ grass/trunk/raster3d/r3.to.rast/test.r3.to.rast.sh 2012-09-23 00:42:25 UTC (rev 53269)
@@ -22,7 +22,7 @@
# for i in `g.mlist type=rast pattern=test_raster_slice_1*` ; do r.out.ascii input=$i output=${i}.ref; done
-for i in `g.mlist type=rast pattern=test_raster_slice_float*` ; do r.out.ascii input=$i output=${i}.ref; done
+for i in `g.mlist type=rast pattern=test_raster_slice_float*` ; do r.out.ascii input=$i output=${i}.txt; done
# The next @preprocess step adjusts the raster region to increase the resolution by 2
g.region res=7.5 -p3
@@ -32,7 +32,7 @@
r3.to.rast --o input=volume_null output=test_raster_slice_2
-# for i in `g.mlist type=rast pattern=test_raster_slice_2*` ; do r.out.ascii input=$i output=${i}.ref; done
+for i in `g.mlist type=rast pattern=test_raster_slice_2*` ; do r.out.ascii input=$i output=${i}.txt; done
# The next @preprocess step adjusts the raster region to increase the resolution by 2 again
g.region res=5 -p3
@@ -42,4 +42,4 @@
r3.to.rast --o input=volume_null output=test_raster_slice_3
-# for i in `g.mlist type=rast pattern=test_raster_slice_3*` ; do r.out.ascii input=$i output=${i}.ref; done
+for i in `g.mlist type=rast pattern=test_raster_slice_3*` ; do r.out.ascii input=$i output=${i}.txt; done
