[GRASS-SVN] r53276 - grass-addons/grass7/imagery/i.segment.xl
svn_grass at osgeo.org
Thu Sep 27 08:44:17 PDT 2012
Author: mmetz
Date: 2012-09-27 08:44:17 -0700 (Thu, 27 Sep 2012)
New Revision: 53276
grass-addons/grass7/imagery/i.segment.xl/create_isegs.c
grass-addons/grass7/imagery/i.segment.xl/iseg.h
grass-addons/grass7/imagery/i.segment.xl/open_files.c
grass-addons/grass7/imagery/i.segment.xl/rclist.c
grass-addons/grass7/imagery/i.segment.xl/write_output.c
i.segment.xl: add control for memory consumption
Modified: grass-addons/grass7/imagery/i.segment.xl/create_isegs.c
--- grass-addons/grass7/imagery/i.segment.xl/create_isegs.c 2012-09-27 11:33:21 UTC (rev 53275)
+++ grass-addons/grass7/imagery/i.segment.xl/create_isegs.c 2012-09-27 15:44:17 UTC (rev 53276)
@@ -14,23 +14,27 @@
#include <grass/rbtree.h> /* Red Black Tree library functions */
#include "iseg.h"
-#define EPSILON 1.0e-16
+#define EPSILON 1.0e-12
/* internal functions */
-static int merge_regions(struct ngbr_stats *, /* Ri */
- struct reg_stats *,
- struct ngbr_stats *, /* Rk */
+static int merge_regions(struct ngbr_stats *, struct reg_stats *, /* Ri */
+ struct ngbr_stats *, struct reg_stats *, /* Rk */
+ int,
struct globals *);
static int search_neighbors(struct ngbr_stats *, /* Ri */
+ struct reg_stats *,
struct NB_TREE *, /* Ri's neighbors */
double *, /* highest similarity */
struct ngbr_stats *, /* Ri's best neighbor */
struct globals *);
static int set_candidate_flag(struct ngbr_stats *, int , struct globals *);
-static int find_best_neighbor(struct ngbr_stats *, struct NB_TREE *,
- struct reg_stats **, struct ngbr_stats *,
- double *, int, struct globals *);
+static int find_best_neighbor(struct ngbr_stats *, struct reg_stats *,
+ struct NB_TREE *, struct ngbr_stats *,
+ struct reg_stats *, double *, int,
+ struct globals *);
+static int calculate_reg_stats(int, int, struct reg_stats *,
/* function used by binary tree to compare items */
static int compare_rc(const void *first, const void *second)
@@ -60,6 +64,7 @@
static int compare_double(double first, double second)
/* standard comparison, gives good results */
if (first < second)
return -1;
@@ -69,11 +74,35 @@
* can give weird results if EPSILON is too large or
* if the formula is changed because this is operating at the
* limit of double fp precision */
- if (first < second)
- return ((second > (first + first * EPSILON)) ? -1 : 0);
- return (first > (second + second * EPSILON));
+ if (first < second && first + first * EPSILON < second)
+ return -1;
+ if (first > second && first > second + second * EPSILON)
+ return 1;
+ return 0;
+static int dump_Ri(struct ngbr_stats *Ri, struct reg_stats *Ri_rs, double *Ri_sim,
+ double *Rk_sim, int *Ri_nn, int *Rk_nn, struct globals *globals)
+ int i;
+ G_debug(0, "Ri, Ri_rs ID: %d, %d", Ri->id, Ri_rs->id);
+ G_debug(0, "Ri, Ri_rs count: %d, %d", Ri->count, Ri_rs->count);
+ for (i = 0; i < globals->nbands; i++) {
+ G_debug(0, "Ri, Ri_rs mean %d: %g, %g", i, Ri->mean[i], Ri_rs->mean[i]);
+ G_debug(0, "Ri_rs sum %d: %g", i, Ri_rs->sum[i]);
+ G_debug(0, "Ri nn: %d", *Ri_nn);
+ if (Rk_nn)
+ G_debug(0, "Rk nn: %d", *Rk_nn);
+ G_debug(0, "Ri similarity: %g", *Ri_sim);
+ if (Rk_sim)
+ G_debug(0, "Rk similarity: %g", *Rk_sim);
+ return 1;
int create_isegs(struct globals *globals)
int row, col;
@@ -152,40 +181,44 @@
int Ri_nn, Rk_nn; /* number of neighbors for Ri/Rk */
struct NB_TREE *Ri_ngbrs, *Rk_ngbrs;
struct NB_TRAV travngbr;
- struct reg_stats *Ri_rs, *Rk_rs, *Rk_bestn_rs;
- int verbose = (G_verbose() >= 3);
+ /* not all regions are in the tree, but we always need reg_stats for Ri and Rk */
+ struct reg_stats Ri_rs, Rk_rs, Rk_bestn_rs;
double *dp;
struct NB_TREE *tmpnbtree;
G_verbose_message("Running region growing algorithm");
+ /* init neighbor stats */
Ri.mean = G_malloc(globals->datasize);
Rk.mean = G_malloc(globals->datasize);
Rk_bestn.mean = G_malloc(globals->datasize);
Ri_ngbrs = nbtree_create(globals->nbands, globals->datasize);
Rk_ngbrs = nbtree_create(globals->nbands, globals->datasize);
+ /* init region stats */
+ Ri_rs.mean = G_malloc(globals->datasize);
+ Ri_rs.sum = G_malloc(globals->datasize);
+ Rk_rs.mean = G_malloc(globals->datasize);
+ Rk_rs.sum = G_malloc(globals->datasize);
+ Rk_bestn_rs.mean = G_malloc(globals->datasize);
+ Rk_bestn_rs.sum = G_malloc(globals->datasize);
t = 0;
n_merges = 1;
/* threshold calculation */
alpha2 = globals->alpha * globals->alpha;
+ threshold = alpha2 * globals->threshold;
+ G_debug(1, "Squared threshold: %g", threshold);
/* make the divisor a constant ? */
divisor = globals->nrows + globals->ncols;
- while (t < globals->end_t && n_merges > 0) {
+ while (t++ < globals->end_t && n_merges > 0) {
- /* optional threshold as a function of t. does not make sense */
- threshold = alpha2 * globals->threshold;
+ G_message(_("Pass %d:"), t);
- t++;
- G_debug(3, "####### Starting outer do loop! t = %d #######", t);
- if (verbose)
- G_verbose_message(_("Pass %d:"), t);
- else
- G_percent(t, globals->end_t, 1);
n_merges = 0;
globals->candidate_count = 0;
flag_clear_all(globals->candidate_flag);
@@ -206,8 +239,7 @@
/*process candidate cells */
for (row = globals->row_min; row < globals->row_max; row++) {
- if (verbose)
- G_percent(row, globals->row_max, 4);
+ G_percent(row, globals->row_max, 4);
for (col = globals->col_min; col < globals->col_max; col++) {
if (!(FLAG_GET(globals->candidate_flag, row, col)))
continue;
@@ -235,23 +267,20 @@
/* find Ri's best neighbor, clear candidate flag */
Ri_similarity = globals->threshold + 1;
- globals->rs.id = Ri.id;
- if ((Ri_rs = rgtree_find(globals->reg_tree, &(globals->rs))) != NULL) {
- memcpy(Ri.mean, Ri_rs->mean, globals->datasize);
- Ri.count = Ri_rs->count;
- else {
- segment_get(&globals->bands_seg, (void *)Ri.mean,
- Ri.row, Ri.col);
- Ri.count = 1;
+ Ri_rs.id = Ri.id;
+ fetch_reg_stats(Ri.row, Ri.col, &Ri_rs, globals);
+ memcpy(Ri.mean, Ri_rs.mean, globals->datasize);
+ Ri.count = Ri_rs.count;
/* Ri is now complete */
+ G_debug(4, "Ri is now complete");
- Rk_rs = NULL;
- Ri_nn = find_best_neighbor(&Ri, Ri_ngbrs, &Rk_rs,
- &Rk, &Ri_similarity, 1,
- globals);
+ /* find best neighbor, get region stats for Rk */
+ Ri_nn = find_best_neighbor(&Ri, &Ri_rs, Ri_ngbrs,
+ &Rk, &Rk_rs, &Ri_similarity,
+ 1, globals);
/* Rk is now complete */
+ G_debug(4, "Rk is now complete");
if (Ri_nn == 0) {
/* this can only happen if only one segment is left */
@@ -259,7 +288,8 @@
pathflag = FALSE;
Ri.count = 0;
- if (!(t & 1) && Ri_nn == 1 &&
+ if (/* !(t & 1) && */ Ri_nn == 1 &&
!(FLAG_GET(globals->candidate_flag, Rk.row, Rk.col)) &&
compare_double(Ri_similarity, threshold) == -1) {
/* this is slow ??? */
@@ -276,21 +306,21 @@
if (Rk.count < 2)
G_fatal_error("Rk count too low");
if (Rk.count < Ri.count)
- G_debug(1, "Rk count lower than Ri count");
+ G_debug(4, "Rk count lower than Ri count");
- merge_regions(&Ri, Ri_rs, &Rk, Rk_rs, globals);
+ merge_regions(&Ri, &Ri_rs, &Rk, &Rk_rs, 1, globals);
n_merges++;
pathflag = FALSE;
- if (t & 1) {
+ if (/* t & */ 1) {
if ((globals->nn < 8 && Rk.count <= 8) ||
(globals->nn >= 8 && Rk.count <= globals->nn))
candidates_only = FALSE;
while (pathflag) {
pathflag = FALSE;
@@ -311,17 +341,23 @@
G_debug(4, "Working with Rk");
/* find Rk's best neighbor, do not clear candidate flag */
- Rk_similarity = globals->threshold + 1;
- Rk_bestn_rs = NULL;
- Rk_nn = find_best_neighbor(&Rk, Rk_ngbrs,
+ /* Rk_similarity = globals->threshold + 1; */
+ Rk_similarity = Ri_similarity;
+ Rk_bestn_rs.count = 0;
+ /* Rk_rs is already complete */
+ Rk_nn = find_best_neighbor(&Rk, &Rk_rs, Rk_ngbrs,
+ &Rk_bestn,
&Rk_bestn_rs,
- &Rk_bestn,
&Rk_similarity, 0,
globals);
/* not mutually best neighbors */
if (Rk_similarity != Ri_similarity) {
- do_merge = 0;
+ /* important for fp precision limit
+ * because region stats may be calculated
+ * in two slightly different ways */
+ if (fabs(Ri_similarity / Rk_similarity - 1) > EPSILON)
+ do_merge = 0;
/* Ri has only one neighbor, merge */
if (Ri_nn == 1 && Rk_nn > 1)
@@ -337,8 +373,10 @@
adjthresh = pow(alpha2, 1. + (double) smaller / divisor) *
globals->threshold;
- if (compare_double(Ri_similarity, adjthresh) == 1)
- do_merge = 0;
+ do_merge = 0;
+ if (compare_double(Ri_similarity, adjthresh) == -1) {
+ do_merge = 1;
if (do_merge) {
@@ -358,7 +396,7 @@
nbtree_clear(Rk_ngbrs);
Ri_nn += Ri_ngbrs->count;
/* Ri is now updated, Rk no longer usable */
/* made a merge, need another iteration */
@@ -372,16 +410,11 @@
/* use neighbor tree to find Ri's new best neighbor */
- search_neighbors(&Ri, Ri_ngbrs, &Ri_similarity,
- &Rk, globals);
+ search_neighbors(&Ri, &Ri_rs, Ri_ngbrs, &Ri_similarity,
+ &Rk, &Rk_rs, globals);
if (Ri_nn > 0 && compare_double(Ri_similarity, threshold) == -1) {
- Ri_rs = rgtree_find(globals->reg_tree, &(globals->rs));
- globals->rs.id = Rk.id;
- Rk_rs = rgtree_find(globals->reg_tree, &(globals->rs));
pathflag = TRUE;
/* candidates_only:
* FALSE: less passes, takes a bit longer, but less memory
@@ -395,7 +428,7 @@
if (compare_double(Rk_similarity, threshold) == -1) {
pathflag = TRUE;
- /* test this */
+ /* test this: can it cause an infinite loop ? */
if (!(FLAG_GET(globals->candidate_flag, Rk.row, Rk.col)))
pathflag = FALSE;
@@ -422,11 +455,22 @@
Ri = Rk;
Rk = Rk_bestn;
Rk_bestn.mean = dp;
- Ri_rs = Rk_rs;
- Rk_rs = Rk_bestn_rs;
+ Ri_rs.id = Rk_rs.id;
+ Rk_rs.id = Rk_bestn_rs.id;
+ Rk_bestn_rs.id = 0;
+ Ri_rs.count = Rk_rs.count;
+ Rk_rs.count = Rk_bestn_rs.count;
+ dp = Ri_rs.mean;
+ Ri_rs.mean = Rk_rs.mean;
+ Rk_rs.mean = Rk_bestn_rs.mean;
+ Rk_bestn_rs.mean = dp;
+ dp = Ri_rs.sum;
+ Ri_rs.sum = Rk_rs.sum;
+ Rk_rs.sum = Rk_bestn_rs.sum;
+ Rk_bestn_rs.sum = dp;
tmpnbtree = Ri_ngbrs;
Ri_ngbrs = Rk_ngbrs;
Rk_ngbrs = tmpnbtree;
@@ -458,10 +502,11 @@
if (globals->min_segment_size > 1) {
G_message(_("Merging segments smaller than %d cells"), globals->min_segment_size);
- /* optional threshold as a function of t. */
threshold = globals->alpha * globals->alpha * globals->threshold;
+ n_merges = 0;
/* Set candidate flag to true/1 for all non-NULL cells */
@@ -498,18 +543,17 @@
if (Ri.id < 0)
continue;
+ Ri_rs.id = Ri.id;
+ /* get segment size */
while (do_merge) {
- /* get segment size */
- Ri.count = 1;
do_merge = 0;
- if (Ri_rs != NULL) {
/* merge all smaller than min size */
if (Ri.count < globals->min_segment_size)
@@ -524,8 +568,8 @@
Ri.row, Ri.col);
- &Rk_rs, &Rk,
+ &Rk, &Rk_rs,
&Ri_similarity, 1,
globals);
@@ -535,7 +579,9 @@
nbtree_clear(Ri_ngbrs);
/* merge Ri with Rk */
+ /* do not clear candidate flag for Rk */
+ merge_regions(&Ri, &Ri_rs, &Rk, &Rk_rs, 0, globals);
+ n_merges++;
if (Ri_nn <= 0 || Ri.count >= globals->min_segment_size)
do_merge = 0;
@@ -544,8 +590,12 @@
G_percent(1, 1, 1);
+ /* finished one pass for processing candidate pixels */
+ G_verbose_message("%d merges", n_merges);
+ /* free neighbor stats */
G_free(Ri.mean);
G_free(Rk.mean);
G_free(Rk_bestn.mean);
@@ -555,20 +605,29 @@
free(Ri_ngbrs);
free(Rk_ngbrs);
+ /* free region stats */
+ G_free(Ri_rs.mean);
+ G_free(Ri_rs.sum);
+ G_free(Rk_rs.mean);
+ G_free(Rk_rs.sum);
+ G_free(Rk_bestn_rs.mean);
+ G_free(Rk_bestn_rs.sum);
return TRUE;
static int find_best_neighbor(struct ngbr_stats *Ri,
- struct NB_TREE *Ri_ngbrs,
- struct reg_stats **Rk_rs,
- struct ngbr_stats *Rk,
- double *sim, int clear_cand,
- struct globals *globals)
+ struct reg_stats *Ri_rs,
+ struct NB_TREE *Ri_ngbrs,
+ struct ngbr_stats *Rk,
+ struct reg_stats *Rk_rs,
+ double *sim, int clear_cand,
+ struct globals *globals)
- int n, n_ngbrs, no_check;
+ int n, n_ngbrs, no_check, cmp;
struct rc ngbr_rc, next;
struct rclist rilist;
- double tempsim, *dp;
+ double tempsim;
int neighbors[8][2];
struct RB_TREE *no_check_tree; /* cells already checked */
struct reg_stats *rs_found;
@@ -586,18 +645,17 @@
ngbr_rc.col = Ri->col;
rbtree_insert(no_check_tree, &ngbr_rc);
- Ri->count = 1;
n_ngbrs = 0;
/* TODO: add size of largest region to reg_tree, use this as min */
Rk->count = globals->ncells;
/* go through segment, spreading outwards from head */
rclist_init(&rilist);
- rclist_add(&rilist, Ri->row, Ri->col);
- while (rclist_drop(&rilist, &next)) {
+ /* check neighbors of start cell */
+ next.row = Ri->row;
+ next.col = Ri->col;
+ do {
/* remove from candidates */
if (clear_cand)
FLAG_UNSET(globals->candidate_flag, next.row, next.col);
@@ -633,7 +691,7 @@
/* not yet checked, don't check it again */
- /* get Rk ID */
+ /* get neighbor ID */
segment_get(&globals->rid_seg,
(void *) &(globals->ns.id),
ngbr_rc.row, ngbr_rc.col);
@@ -642,7 +700,6 @@
/* want to check this neighbor's neighbors */
rclist_add(&rilist, ngbr_rc.row, ngbr_rc.col);
- Ri->count++;
else {
@@ -653,44 +710,56 @@
globals->rs.id = globals->ns.id;
rs_found = rgtree_find(globals->reg_tree,
&(globals->rs));
- if (rs_found != NULL) {
- globals->ns.mean = rs_found->mean;
- globals->ns.count = rs_found->count;
+ if (!rs_found) {
+ /* region stats are not in search tree */
+ rs_found = &(globals->rs);
+ calculate_reg_stats(ngbr_rc.row, ngbr_rc.col,
+ rs_found, globals);
- else {
- (void *)globals->bands_val,
- ngbr_rc.row, ngbr_rc.col);
+ globals->ns.mean = rs_found->mean;
+ globals->ns.count = rs_found->count;
+ /* globals->ns is now complete */
- globals->ns.mean = globals->bands_val;
- globals->ns.count = 1;
- /* next Rk = globals->ns is now complete */
tempsim = (globals->calculate_similarity)(Ri, &globals->ns, globals);
- if (compare_double(tempsim, *sim) == -1) {
+ cmp = compare_double(tempsim, *sim);
+ if (cmp == -1) {
*sim = tempsim;
/* copy temp Rk to Rk */
- dp = Rk->mean;
- *Rk = globals->ns;
- Rk->mean = dp;
- memcpy(Rk->mean, globals->ns.mean,
+ Rk->row = ngbr_rc.row;
+ Rk->col = ngbr_rc.col;
+ Rk->id = rs_found->id;
+ Rk->count = rs_found->count;
+ memcpy(Rk->mean, rs_found->mean,
globals->datasize);
- *Rk_rs = rs_found;
+ Rk_rs->id = Rk->id;
+ Rk_rs->count = Rk->count;
+ memcpy(Rk_rs->mean, rs_found->mean,
+ globals->datasize);
+ memcpy(Rk_rs->sum, rs_found->sum,
- else if (compare_double(tempsim, *sim) == 0) {
+ else if (cmp == 0) {
/* resolve ties: prefer smaller regions */
if (Rk->count > globals->ns.count) {
- dp = Rk->mean;
- Rk->mean = dp;
- memcpy(Rk->mean,
- globals->ns.mean,
globals->datasize);
@@ -702,7 +771,7 @@
} while (n--); /* end do loop - next neighbor */
- } /* while there are cells to check */
+ } while (rclist_drop(&rilist, &next)); /* while there are cells to check */
/* clean up */
rbtree_destroy(no_check_tree);
@@ -780,31 +849,36 @@
static int search_neighbors(struct ngbr_stats *Ri,
double *sim,
struct ngbr_stats *next;
+ int cmp, i;
G_debug(4, "search_neighbors");
nbtree_init_trav(&travngbr, Ri_ngbrs);
- Rk->count = globals->ncells;
+ Rk->count = globals->ncells + 1;
while ((next = nbtree_traverse(&travngbr))) {
tempsim = (globals->calculate_similarity)(Ri, next, globals);
+ if (cmp == -1) {
*sim = tempsim;
dp = Rk->mean;
*Rk = *next;
Rk->mean = dp;
memcpy(Rk->mean, next->mean, globals->datasize);
/* resolve ties, prefer smaller regions */
G_debug(4, "resolve ties");
@@ -816,150 +890,115 @@
+ /* faster, but with fp error:
+ * calculate sum from mean and count */
+ memcpy(Rk_rs->mean, Rk->mean, globals->datasize);
+ i = globals->nbands - 1;
+ do {
+ Rk_rs->sum[i] = Rk_rs->mean[i] * Rk_rs->count;
+ } while (i--);
+ /* a bit slower but correct: */
+ fetch_reg_stats(Rk->row, Rk->col, Rk_rs, globals);
return 1;
static int merge_regions(struct ngbr_stats *Ri, struct reg_stats *Ri_rs,
struct ngbr_stats *Rk, struct reg_stats *Rk_rs,
+ int do_cand, struct globals *globals)
- int n, do_cand;
- int Ri_id, Rk_id, larger_id, R_id;
+ int n;
+ int R_id;
struct rc next, ngbr_rc;
struct rclist rlist;
- struct reg_stats *new_rs, old_rs;
+ struct reg_stats *new_rs;
G_debug(4, "merge_regions");
- Ri_id = Ri->id;
- Rk_id = Rk->id;
+ /* Ri ID must always be positive */
+ if (Ri_rs->id < 1)
+ G_fatal_error("Ri id is negative: %d", Ri_rs->id);
+ /* if Rk ID is negative (no seed), Rk count must be 1 */
+ if (Rk_rs->id < 1 && Rk_rs->count > 1)
+ G_fatal_error("Rk id is negative: %d, but count is > 1: %d",
+ Rk_rs->id, Rk_rs->count);
- /* update segment number and clear candidate flag */
+ /* update segment id and clear candidate flag */
/* cases
- * Ri, Rk are single cells, not in tree
+ * Ri, Rk are not in the tree
* Ri, Rk are both in the tree
* Ri is in the tree, Rk is not
* Rk is in the tree, Ri is not
- /* for each member of Ri and Rk, write new average bands values and segment values */
+ /* Ri_rs, Rk_rs must always be set */
+ /* add Rk */
+ Ri_rs->count += Rk_rs->count;
+ n = globals->nbands - 1;
+ do {
+ Ri_rs->sum[n] += Rk_rs->sum[n];
+ Ri_rs->mean[n] = Ri_rs->sum[n] / Ri_rs->count;
+ } while (n--);
if (Ri->count >= Rk->count) {
- larger_id = Ri_id;
- if (Ri_rs) {
- new_rs = Ri_rs;
- else {
- new_rs = &(globals->rs);
- new_rs->id = Ri_id;
- new_rs->count = 1;
- memcpy(new_rs->sum, Ri->mean, globals->datasize);
- memcpy(new_rs->mean, Ri->mean, globals->datasize);
- /* add Rk */
- if (Rk_rs) {
- new_rs->count += Rk_rs->count;
- n = globals->nbands - 1;
- do {
- new_rs->sum[n] += Rk_rs->sum[n];
- } while (n--);
- else {
- new_rs->count++;
- do {
- new_rs->sum[n] += Rk->mean[n];
- } while (n--);
- do {
- new_rs->mean[n] = new_rs->sum[n] / new_rs->count;
- } while (n--);
- memcpy(Ri->mean, new_rs->mean, globals->datasize);
- Ri->count = new_rs->count;
- if (!Ri_rs) {
- /* add to tree */
- rgtree_insert(globals->reg_tree, new_rs);
- if (Rk_rs) {
+ if (Rk->count >= globals->min_reg_size) {
+ if (rgtree_find(globals->reg_tree, Rk_rs) == NULL)
+ G_fatal_error("merge regions: Rk should be in tree");
/* remove from tree */
- old_rs.id = Rk_id;
- rgtree_remove(globals->reg_tree, &old_rs);
+ rgtree_remove(globals->reg_tree, Rk_rs);
else {
- larger_id = Rk_id;
- Ri->id = Rk_id;
- if (Rk_rs) {
- new_rs = Rk_rs;
+ if (Ri->count >= globals->min_reg_size) {
+ if (rgtree_find(globals->reg_tree, Ri_rs) == NULL)
+ G_fatal_error("merge regions: Ri should be in tree");
+ /* remove from tree */
+ rgtree_remove(globals->reg_tree, Ri_rs);
- else {
- new_rs->id = Rk_id;
- memcpy(new_rs->sum, Rk->mean, globals->datasize);
- memcpy(new_rs->mean, Rk->mean, globals->datasize);
+ /* magic switch */
+ Ri_rs->id = Rk->id;
- /* add Ri */
- if (Ri_rs) {
- new_rs->count += Ri_rs->count;
- do {
- new_rs->sum[n] += Ri_rs->sum[n];
- } while (n--);
- else {
- new_rs->count++;
- do {
- new_rs->sum[n] += Ri->mean[n];
- } while (n--);
+ if ((new_rs = rgtree_find(globals->reg_tree, Ri_rs)) != NULL) {
+ /* update stats for tree item */
+ new_rs->count = Ri_rs->count;
+ memcpy(new_rs->mean, Ri_rs->mean, globals->datasize);
+ memcpy(new_rs->sum, Ri_rs->sum, globals->datasize);
+ else if (Ri_rs->count >= globals->min_reg_size) {
+ /* add to tree */
+ rgtree_insert(globals->reg_tree, Ri_rs);
- do {
- } while (n--);
+ Ri->count = Ri_rs->count;
+ memcpy(Ri->mean, Ri_rs->mean, globals->datasize);
- if (!Rk_rs) {
- /* add to tree */
- if (Ri_rs) {
- /* remove from tree */
- old_rs.id = Ri_id;
- if (larger_id == Ri_id) {
+ if (Ri->id == Ri_rs->id) {
/* Ri is already updated, including candidate flags
* need to clear candidate flag for Rk and set new id */
/* the actual merge: change region id */
- segment_put(&globals->rid_seg, (void *) &Ri_id, Rk->row, Rk->col);
+ segment_put(&globals->rid_seg, (void *) &Ri->id, Rk->row, Rk->col);
- do_cand = 0;
- if (FLAG_GET(globals->candidate_flag, Rk->row, Rk->col)) {
- /* clear candidate flag */
- FLAG_UNSET(globals->candidate_flag, Rk->row, Rk->col);
- globals->candidate_count--;
- do_cand = 1;
+ if (do_cand) {
+ do_cand = 0;
+ if (FLAG_GET(globals->candidate_flag, Rk->row, Rk->col)) {
+ /* clear candidate flag */
+ FLAG_UNSET(globals->candidate_flag, Rk->row, Rk->col);
+ globals->candidate_count--;
+ do_cand = 1;
rclist_init(&rlist);
@@ -988,11 +1027,12 @@
if (!(FLAG_GET(globals->null_flag, ngbr_rc.row, ngbr_rc.col))) {
- segment_get(&globals->rid_seg, (void *) &R_id, ngbr_rc.row, ngbr_rc.col);
+ segment_get(&globals->rid_seg, (void *) &R_id,
+ ngbr_rc.row, ngbr_rc.col);
- if (R_id == Rk_id) {
+ if (R_id == Rk->id) {
- segment_put(&globals->rid_seg, (void *) &Ri_id, ngbr_rc.row, ngbr_rc.col);
+ segment_put(&globals->rid_seg, (void *) &Ri->id, ngbr_rc.row, ngbr_rc.col);
rclist_add(&rlist, ngbr_rc.row, ngbr_rc.col);
@@ -1003,17 +1043,17 @@
else {
- /* larger_id == Rk_id */
+ /* Rk was larger than Ri */
/* clear candidate flag for Rk */
+ if (do_cand && FLAG_GET(globals->candidate_flag, Rk->row, Rk->col)) {
set_candidate_flag(Rk, FALSE, globals);
/* update region id for Ri */
- segment_put(&globals->rid_seg, (void *) &Rk_id, Ri->row, Ri->col);
+ segment_put(&globals->rid_seg, (void *) &Rk->id, Ri->row, Ri->col);
rclist_add(&rlist, Ri->row, Ri->col);
@@ -1038,9 +1078,9 @@
- if (R_id == Ri_id) {
+ if (R_id == Ri->id) {
- segment_put(&globals->rid_seg, (void *) &Rk_id, ngbr_rc.row, ngbr_rc.col);
+ segment_put(&globals->rid_seg, (void *) &Rk->id, ngbr_rc.row, ngbr_rc.col);
@@ -1049,11 +1089,18 @@
} while (n--);
+ Ri->id = Ri_rs->id; /* == Rk->id */
+ if (Ri->id != Rk->id)
+ G_fatal_error("Ri ID should be set to Rk ID");
- if (Rk_id > 0)
+ if (Rk->id > 0)
globals->n_regions--;
+ /* disable Rk */
+ Rk->id = Rk_rs->id = 0;
+ Rk->count = Rk_rs->count = 0;
return TRUE;
@@ -1127,3 +1174,168 @@
return TRUE;
+int fetch_reg_stats(int row, int col, struct reg_stats *rs,
+ struct reg_stats *rs_found;
+ if ((rs_found = rgtree_find(globals->reg_tree, rs)) != NULL) {
+ memcpy(rs->mean, rs_found->mean, globals->datasize);
+ memcpy(rs->sum, rs_found->sum, globals->datasize);
+ rs->count = rs_found->count;
+ return 1;
+ calculate_reg_stats(row, col, rs, globals);
+ return 2;
+static int calculate_reg_stats(int row, int col, struct reg_stats *rs,
+ G_debug(4, "calculate_reg_stats()");
+ segment_get(&globals->bands_seg, (void *)globals->bands_val,
+ row, col);
+ rs->count = 1;
+ memcpy(rs->mean, globals->bands_val, globals->datasize);
+ memcpy(rs->sum, globals->bands_val, globals->datasize);
+ if (globals->min_reg_size < 3)
+ return 1;
+ if (globals->min_reg_size == 3) {
+ int n, i, rid;
+ struct rc ngbr_rc;
+ int neighbors[8][2];
+ globals->find_neighbors(row, col, neighbors);
+ for (n = 0; n < globals->nn; n++) {
+ ngbr_rc.row = neighbors[n][0];
+ ngbr_rc.col = neighbors[n][1];
+ if (ngbr_rc.row < 0 || ngbr_rc.row >= globals->nrows ||
+ ngbr_rc.col < 0 || ngbr_rc.col >= globals->ncols) {
+ continue;
+ if ((FLAG_GET(globals->null_flag, ngbr_rc.row, ngbr_rc.col)) == 0) {
+ segment_get(&globals->rid_seg, (void *) &rid,
+ if (rid == rs->id) {
+ /* update region stats */
+ do {
+ rs->sum[i] += globals->bands_val[i];
+ } while (i--);
+ rs->count++;
+ /* only one other neighbor can have the same ID */
+ break;
+ /* band mean */
+ do {
+ rs->mean[i] = rs->sum[i] / rs->count;
+ } while (i--);
+ return 2;
+ if (globals->min_reg_size > 3) {
+ /* rs->id must be set */
+ struct RB_TREE *rc_check_tree; /* cells already checked */
+ int n, i, rid;
+ struct rc ngbr_rc, next;
+ struct rclist rilist;
+ int no_check;
+ /* go through region, spreading outwards from head */
+ rclist_init(&rilist);
+ rc_check_tree = rbtree_create(compare_rc, sizeof(struct rc));
+ ngbr_rc.row = row;
+ ngbr_rc.col = col;
+ rbtree_insert(rc_check_tree, &ngbr_rc);
+ next.row = row;
+ next.col = col;
+ do {
+ G_debug(5, "find_pixel_neighbors for row: %d , col %d",
+ next.row, next.col);
+ globals->find_neighbors(next.row, next.col, neighbors);
+ n = globals->nn - 1;
+ n = 0;
+ do {
+ no_check = (ngbr_rc.row < 0 || ngbr_rc.row >= globals->nrows ||
+ ngbr_rc.col < 0 || ngbr_rc.col >= globals->ncols);
+ if (!no_check) {
+ /* already checked ? */
+ if (!rbtree_find(rc_check_tree, &ngbr_rc)) {
+ /* not yet checked, don't check it again */
+ /* want to check this neighbor's neighbors */
+ rclist_add(&rilist, ngbr_rc.row, ngbr_rc.col);
+ (void *)globals->bands_val,
+ do {
+ } while (i--);
+ rs->count++;
+ } while (n++ < globals->nn - 1); /* (n--); */
+ /* band mean */
+ do {
+ } while (i--);
+ /* clean up */
+ rbtree_destroy(rc_check_tree);
+ return 3;
+ return 0;
Modified: grass-addons/grass7/imagery/i.segment.xl/iseg.h
--- grass-addons/grass7/imagery/i.segment.xl/iseg.h 2012-09-27 11:33:21 UTC (rev 53275)
+++ grass-addons/grass7/imagery/i.segment.xl/iseg.h 2012-09-27 15:44:17 UTC (rev 53276)
@@ -67,7 +67,8 @@
/* results */
struct RG_TREE *reg_tree; /* search tree with region stats */
- struct reg_stats rs;
+ int min_reg_size; /* minimum region size */
+ struct reg_stats rs, rs_i, rs_k;
struct ngbr_stats ns;
size_t datasize; /* nbands * sizeof(double) */
int n_regions;
@@ -100,9 +101,15 @@
void find_four_neighbors(int, int, int[][2]);
void find_eight_neighbors(int, int, int[8][2]);
double calculate_euclidean_similarity(struct ngbr_stats *,
- struct ngbr_stats *, struct globals *);
+int fetch_reg_stats(int , int , struct reg_stats *,
+/* void calculate_reg_stats(int, int, struct reg_stats *,
+ struct globals *); */
/* rclist.c */
void rclist_init(struct rclist *);
void rclist_add(struct rclist *, int, int);
Modified: grass-addons/grass7/imagery/i.segment.xl/open_files.c
--- grass-addons/grass7/imagery/i.segment.xl/open_files.c 2012-09-27 11:33:21 UTC (rev 53275)
+++ grass-addons/grass7/imagery/i.segment.xl/open_files.c 2012-09-27 15:44:17 UTC (rev 53276)
@@ -9,6 +9,7 @@
static int load_seeds(struct globals *, int, int, int);
static int read_seed(struct globals *, SEGMENT *, struct rc *, int);
+static int manage_memory(int, int, struct globals *);
int open_files(struct globals *globals)
@@ -87,23 +88,16 @@
inlen = sizeof(DCELL) * Ref.nfiles;
outlen = sizeof(CELL);
+ G_debug(1, "data element size, in: %d , out: %d ", inlen, outlen);
+ globals->datasize = sizeof(double) * globals->nbands;
/* segment lib segment size */
srows = 64;
scols = 64;
- /* calculate number of segments in memory */
- nseg = (1024. * 1024. * globals->mb) /
- (sizeof(DCELL) * Ref.nfiles * srows * scols +
- + sizeof(CELL) * 2 * srows * scols);
+ nseg = manage_memory(srows, scols, globals);
/* create segment structures */
- G_debug(1, "image size: %d rows, %d cols", globals->nrows, globals->ncols);
- G_debug(1, "degmented to tiles with size: %d rows, %d cols", srows,
- scols);
- G_debug(1, "data element size, in: %d , out: %d ", inlen, outlen);
- G_debug(1, "number of segments in memory: %d", nseg);
if (segment_open
(&globals->bands_seg, G_tempfile(), globals->nrows, globals->ncols, srows,
scols, inlen, nseg) != 1)
@@ -259,7 +253,6 @@
Rast_close(in_fd[n]);
- globals->datasize = sizeof(double) * globals->nbands;
globals->rs.sum = G_malloc(globals->datasize);
globals->rs.mean = G_malloc(globals->datasize);
@@ -291,6 +284,8 @@
struct rc Ri;
G_debug(1, "load_seeds()");
+ G_message(_("Loading seeds from '%s'"), globals->seeds);
if (segment_open
(&seeds_seg, G_tempfile(), globals->nrows, globals->ncols,
@@ -353,7 +348,6 @@
G_free(seeds_buf);
Rast_close(seeds_fd);
segment_close(&seeds_seg);
@@ -457,7 +451,7 @@
/* insert into region tree */
- if (globals->rs.count > 1) {
+ if (globals->rs.count >= globals->min_reg_size) {
globals->rs.mean[i] = globals->rs.sum[i] / globals->rs.count;
@@ -466,3 +460,64 @@
return 1;
+static int manage_memory(int srows, int scols, struct globals *globals)
+ double reg_size_mb, segs_mb;
+ int reg_size_count, nseg, nseg_total;
+ /* minimum region size to store in search tree */
+ reg_size_mb = 2 * globals->datasize + /* mean, sum */
+ 2 * sizeof(int) + /* id, count */
+ sizeof(unsigned char) +
+ 2 * sizeof(struct REG_NODE *);
+ reg_size_mb /= (1024. * 1024.);
+ /* put aside some memory for segment structures */
+ segs_mb = globals->mb * 0.1;
+ if (segs_mb > 10)
+ segs_mb = 10;
+ /* calculate number of region stats that can be kept in memory */
+ reg_size_count = (globals->mb - segs_mb) / reg_size_mb;
+ globals->min_reg_size = 4;
+ if (reg_size_count < (double) globals->nrows * globals->ncols / globals->min_reg_size) {
+ globals->min_reg_size = (double) globals->nrows * globals->ncols / reg_size_count;
+ else {
+ reg_size_count = (double) globals->nrows * globals->ncols / globals->min_reg_size;
+ /* recalculate segs_mb */
+ segs_mb = globals->mb - reg_size_count * reg_size_mb;
+ G_verbose_message(_("Stats for regions with at least %d cells are stored in memory"),
+ globals->min_reg_size);
+ /* calculate number of segments in memory */
+ if (globals->bounds_map != NULL) {
+ /* input bands, segment ids, bounds map */
+ nseg = (1024. * 1024. * segs_mb) /
+ (sizeof(DCELL) * globals->nbands * srows * scols +
+ sizeof(CELL) * 4 * srows * scols);
+ else {
+ nseg_total = (globals->nrows / srows + (globals->nrows % srows > 0)) *
+ (globals->ncols / scols + (globals->ncols % scols > 0));
+ if (nseg > nseg_total)
+ nseg = nseg_total;
+ G_debug(1, "current region: %d rows, %d cols", globals->nrows, globals->ncols);
+ G_debug(1, "segmented to tiles with size: %d rows, %d cols", srows,
+ scols);
+ G_verbose_message(_("Number of segments in memory: %d of %d total"),
+ nseg, nseg_total);
+ return nseg;
Modified: grass-addons/grass7/imagery/i.segment.xl/rclist.c
--- grass-addons/grass7/imagery/i.segment.xl/rclist.c 2012-09-27 11:33:21 UTC (rev 53275)
+++ grass-addons/grass7/imagery/i.segment.xl/rclist.c 2012-09-27 15:44:17 UTC (rev 53276)
@@ -48,8 +48,8 @@
return 1;
- else
- return 0;
+ return 0;
void rclist_destroy(struct rclist *list)
Modified: grass-addons/grass7/imagery/i.segment.xl/write_output.c
--- grass-addons/grass7/imagery/i.segment.xl/write_output.c 2012-09-27 11:33:21 UTC (rev 53275)
+++ grass-addons/grass7/imagery/i.segment.xl/write_output.c 2012-09-27 15:44:17 UTC (rev 53276)
@@ -14,51 +14,25 @@
int write_output(struct globals *globals)
- int out_fd, mean_fd, row, col;
+ int out_fd, row, col;
CELL *outbuf, rid;
- FCELL *meanbuf;
struct Colors colors;
- double thresh, maxdev, sim, mingood;
- struct reg_stats *rs_found;
- struct ngbr_stats Ri, Rk;
+ struct History hist;
outbuf = Rast_allocate_c_buf();
G_debug(1, "preparing output raster");
/* open output raster map */
out_fd = Rast_open_new(globals->out_name, CELL_TYPE);
- if (globals->out_band) {
- mean_fd = Rast_open_new(globals->out_band, FCELL_TYPE);
- meanbuf = Rast_allocate_f_buf();
- else {
- mean_fd = -1;
- meanbuf = NULL;
- /* goodness of fit for each cell: 1 = good fit, 0 = bad fit */
- /* similarity of each cell to region mean
- * max possible difference: globals->threshold
- * if similarity < globals->alpha * globals->alpha * globals->threshold
- * 1
- * else
- * (similarity - globals->alpha * globals->alpha * globals->threshold) /
- * (globals->threshold * (1 - globals->alpha * globals->alpha) */
- thresh = globals->alpha * globals->alpha * globals->threshold;
- maxdev = globals->threshold * (1 - globals->alpha * globals->alpha);
- mingood = 1;
G_debug(1, "start data transfer from segmentation file to raster");
- G_message(_("Writing output"));
+ G_message(_("Writing out segment IDs"));
for (row = 0; row < globals->nrows; row++) {
G_percent(row, globals->nrows, 9);
Rast_set_c_null_value(outbuf, globals->ncols);
- Rast_set_f_null_value(meanbuf, globals->ncols);
for (col = 0; col < globals->ncols; col++) {
if (!(FLAG_GET(globals->null_flag, row, col))) {
@@ -66,15 +40,70 @@
if (rid > 0) {
outbuf[col] = rid;
+ Rast_put_row(out_fd, outbuf, CELL_TYPE);
+ /* close and save segment id file */
+ Rast_close(out_fd);
- /* get values for Ri = larger region */
+ /* set colors */
+ Rast_init_colors(&colors);
+ Rast_make_random_colors(&colors, 1, globals->nrows * globals->ncols);
+ Rast_write_colors(globals->out_name, G_mapset(), &colors);
+ Rast_short_history(globals->out_name, "raster", &hist);
+ Rast_command_history(&hist);
+ Rast_write_history(globals->out_name, &hist);
+ /* write goodness of fit */
+ if (globals->out_band) {
+ int mean_fd;
+ FCELL *meanbuf;
+ double thresh, maxdev, sim, mingood;
+ struct ngbr_stats Ri, Rk;
+ mean_fd = Rast_open_new(globals->out_band, FCELL_TYPE);
+ meanbuf = Rast_allocate_f_buf();
+ /* goodness of fit for each cell: 1 = good fit, 0 = bad fit */
+ /* similarity of each cell to region mean
+ * max possible difference: globals->threshold
+ * if similarity < globals->alpha * globals->alpha * globals->threshold
+ * 1
+ * else
+ * (similarity - globals->alpha * globals->alpha * globals->threshold) /
+ * (globals->threshold * (1 - globals->alpha * globals->alpha) */
+ thresh = globals->alpha * globals->alpha * globals->threshold;
+ maxdev = globals->threshold * (1 - globals->alpha * globals->alpha);
+ mingood = 1;
+ G_message(_("Writing out goodness of fit"));
+ for (row = 0; row < globals->nrows; row++) {
+ G_percent(row, globals->nrows, 9);
+ Rast_set_f_null_value(meanbuf, globals->ncols);
+ for (col = 0; col < globals->ncols; col++) {
+ if (!(FLAG_GET(globals->null_flag, row, col))) {
+ segment_get(&globals->rid_seg, (void *) &rid, row, col);
+ if (rid > 0) {
+ /* get values for Ri = this region */
globals->rs.id = rid;
- rs_found = rgtree_find(globals->reg_tree, &(globals->rs));
+ fetch_reg_stats(Ri.row, Ri.col, &globals->rs, globals);
+ Ri.mean = globals->rs.mean;
+ Ri.count = globals->rs.count;
- Ri.mean = rs_found->mean;
+ sim = 0.;
+ /* region consists of more than one cell */
+ if (Ri.count > 1) {
/* get values for Rk = this cell */
@@ -85,9 +114,6 @@
/* calculate similarity */
sim = (*globals->calculate_similarity) (&Ri, &Rk, globals);
- else
- /* region consists of only one cell */
- sim = 0.;
if (0) {
if (sim < thresh)
@@ -108,31 +134,24 @@
+ Rast_put_row(mean_fd, meanbuf, FCELL_TYPE);
- Rast_put_row(out_fd, outbuf, CELL_TYPE);
- Rast_put_row(mean_fd, meanbuf, FCELL_TYPE);
- /* close and save file */
- Rast_close(out_fd);
Rast_close(mean_fd);
- /* set colors */
- Rast_init_colors(&colors);
- Rast_make_random_colors(&colors, 1, globals->nrows * globals->ncols);
- Rast_write_colors(globals->out_name, G_mapset(), &colors);
Rast_make_grey_scale_fp_colors(&colors, mingood, 1);
Rast_write_colors(globals->out_band, G_mapset(), &colors);
+ Rast_short_history(globals->out_band, "raster", &hist);
+ Rast_write_history(globals->out_band, &hist);
+ G_free(meanbuf);
/* free memory */
G_free(outbuf);
- G_free(meanbuf);
Rast_free_colors(&colors);
return TRUE;
@@ -151,12 +170,6 @@
segment_close(&globals->rid_seg);
- for (i = 0; i < globals->nrows; i++)
- G_free(globals->rid[i]);
- G_free(globals->rid);
flag_destroy(globals->null_flag);
flag_destroy(globals->candidate_flag);
