[GRASS-SVN] r53277 - grass/trunk/vector/v.univar
svn_grass at osgeo.org
Thu Sep 27 11:01:51 PDT 2012
Author: mmetz
Date: 2012-09-27 11:01:50 -0700 (Thu, 27 Sep 2012)
New Revision: 53277
grass/trunk/vector/v.univar/main.c
v.univar: forward port new -d flag, some fixes for -d flag (to be backported)
Modified: grass/trunk/vector/v.univar/main.c
--- grass/trunk/vector/v.univar/main.c 2012-09-27 15:44:17 UTC (rev 53276)
+++ grass/trunk/vector/v.univar/main.c 2012-09-27 18:01:50 UTC (rev 53277)
@@ -16,6 +16,28 @@
* comes with GRASS for details.
+/* TODO
+ * - add flag to weigh by line/boundary length and area size
+ * Roger Bivand on GRASS devel ml on July 2 2004
+ * http://lists.osgeo.org/pipermail/grass-dev/2004-July/014976.html
+ * "[...] calculating weighted means, weighting by line length
+ * or area surface size [does not make sense]. I think it would be
+ * better to treat each line or area as a discrete, unweighted, unit
+ * unless some reason to the contrary is given, just like points/sites.
+ * It is probably more important to handle missing data gracefully
+ * than weight the means or other statistics, I think. There may be
+ * reasons to weigh sometimes, but most often I see ratios or rates of
+ * two variables, rather than of a single variable and length or area."
+ * - use geodesic distances for the geometry option (distance to closest
+ * other feature)
+ * - use sample instead of population mean/stddev
#include <stdlib.h>
#include <string.h>
#include <math.h>
@@ -24,41 +46,46 @@
#include <grass/dbmi.h>
#include <grass/glocale.h>
+static void select_from_geometry(void);
+static void select_from_database(void);
+static void summary(void);
+struct Option *field_opt, *where_opt, *col_opt;
+struct Flag *shell_flag, *extended, *geometry;
+struct Map_info Map;
+struct line_cats *Cats;
+struct field_info *Fi;
+dbDriver *Driver;
+dbCatValArray Cvarr;
+int otype, ofield;
+int compatible = 1; /* types are compatible: point+centroid or line+boundary or area */
+int nmissing = 0; /* number of missing atttributes */
+int nnull = 0; /* number of null values */
+int nzero = 0; /* number of zero distances */
+int first = 1;
+/* Statistics */
+int count = 0; /* number of features with non-null attribute */
+double sum = 0.0;
+double sumsq = 0.0;
+double sumcb = 0.0;
+double sumqt = 0.0;
+double sum_abs = 0.0;
+double min = 0.0 / 0.0; /* init as nan */
+double max = 0.0 / 0.0;
+double mean, mean_abs, pop_variance, sample_variance, pop_stdev,
+ sample_stdev, pop_coeff_variation, kurtosis, skewness;
+double total_size = 0.0; /* total size: length/area */
+/* Extended statistics */
+int perc;
int main(int argc, char *argv[])
struct GModule *module;
- struct Option *map_opt, *type_opt, *field_opt, *col_opt, *where_opt,
+ struct Option *map_opt, *type_opt,
*percentile;
- struct Flag *shell_flag, *extended;
- struct Map_info Map;
- struct field_info *Fi;
- dbDriver *Driver;
- dbCatValArray Cvarr;
- struct line_pnts *Points;
- struct line_cats *Cats;
- int otype, ofield;
- int compatible = 1; /* types are compatible: point+centroid or line+boundary or area */
- int nrec, ctype, nlines, line, nareas, area;
- int nmissing = 0; /* number of missing atttributes */
- int nnull = 0; /* number of null values */
- int first = 1;
- /* Statistics */
- int count = 0; /* number of features with non-null attribute */
- double sum = 0.0;
- double sumsq = 0.0;
- double sumcb = 0.0;
- double sumqt = 0.0;
- double sum_abs = 0.0;
- double min = 0.0 / 0.0; /* init as nan */
- double max = 0.0 / 0.0;
- double mean, mean_abs, pop_variance, sample_variance, pop_stdev,
- sample_stdev, pop_coeff_variation, kurtosis, skewness;
- double total_size = 0.0; /* total size: length/area */
- /* Extended statistics */
- int perc;
module = G_define_module();
G_add_keyword(_("vector"));
G_add_keyword(_("statistics"));
@@ -76,7 +103,7 @@
type_opt->answer = "point,line,area";
col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
- col_opt->required = YES;
+ col_opt->required = NO;
where_opt = G_define_standard_option(G_OPT_DB_WHERE);
@@ -97,15 +124,23 @@
extended->key = 'e';
extended->description = _("Calculate extended statistics");
+ geometry = G_define_flag();
+ geometry->key = 'd';
+ geometry->description = _("Calculate geometry distances instead of table data.");
G_gisinit(argv[0]);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ /* Only require col_opt answer if -g flag is not set */
+ if (!col_opt->answer && !geometry->answer) {
+ G_fatal_error(_("Required parameter <%s> not set:\n\t(%s)"), col_opt->key, col_opt->description);
otype = Vect_option_to_types(type_opt);
perc = atoi(percentile->answer);
- Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
/* open input vector */
@@ -118,18 +153,138 @@
compatible = 0;
if ((otype & GV_LINES) && (otype & GV_AREA))
compatible = 0;
+ if (!compatible && geometry->answer)
+ compatible = 1; /* distances is compatible with all kinds of geometries */
if (!compatible) {
G_warning(_("Incompatible vector type(s) specified, only number of features, minimum, maximum and range "
"can be calculated"));
- if (extended->answer && !(otype & GV_POINTS)) {
+ if (extended->answer && (!(otype & GV_POINTS) || geometry->answer)) {
G_warning(_("Extended statistics is currently supported only for points/centroids"));
- /* Read attributes */
- db_CatValArray_init(&Cvarr);
+ if (geometry->answer)
+ select_from_geometry();
+ else
+ select_from_database();
+ summary();
+ Vect_close(&Map);
+ exit(EXIT_SUCCESS);
+ int i, j, k, ncats, *cats;
+ int type;
+ struct line_pnts *iPoints, *jPoints;
+ int nlines;
+ iPoints = Vect_new_line_struct();
+ jPoints = Vect_new_line_struct();
+ if (where_opt->answer != NULL) {
+ if (ofield < 1) {
+ G_fatal_error(_("'layer' must be > 0 for 'where'."));
+ Fi = Vect_get_field(&Map, ofield);
+ if (!Fi) {
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ ofield);
+ Driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (Driver == NULL)
+ G_fatal_error("Unable to open database <%s> by driver <%s>",
+ Fi->database, Fi->driver);
+ ncats = db_select_int(Driver, Fi->table, Fi->key, where_opt->answer,
+ &cats);
+ if (ncats == -1)
+ G_fatal_error(_("Unable select categories from table <%s>"), Fi->table);
+ db_close_database_shutdown_driver(Driver);
+ else
+ ncats = 0;
+ count = 0;
+ nlines = Vect_get_num_lines(&Map);
+ /* Start calculating the statistics based on distance to all other primitives.
+ Use the centroid of areas and the first point of lines */
+ for (i = 1; i <= nlines; i++) {
+ type = Vect_read_line(&Map, iPoints, Cats, i);
+ if (!(type & otype))
+ continue;
+ if (where_opt->answer) {
+ int ok = FALSE;
+ for (j = 0; j < Cats->n_cats; j++) {
+ if (Vect_cat_in_array(Cats->cat[j], cats, ncats)) {
+ ok = TRUE;
+ break;
+ if (!ok)
+ continue;
+ for (j = i + 1; j < nlines; j++) {
+ /* get distance to this object */
+ double val = 0.0;
+ type = Vect_read_line(&Map, jPoints, Cats, j);
+ continue;
+ /* now calculate the min distance between each point in line i with line j */
+ for (k = 0; k < iPoints->n_points; k++) {
+ double dmin = 0.0;
+ Vect_line_distance(jPoints, iPoints->x[k], iPoints->y[k], iPoints->z[k], 1,
+ NULL, NULL, NULL, &dmin, NULL, NULL);
+ if((k == 0) || (dmin < val)) {
+ val = dmin;
+ if (val == 0) {
+ nzero++;
+ continue;
+ if (first) {
+ max = val;
+ min = val;
+ first = 0;
+ else {
+ if (val > max)
+ max = val;
+ if (val < min)
+ min = val;
+ sum += val;
+ sumsq += val * val;
+ sumcb += val * val * val;
+ sumqt += val * val * val * val;
+ sum_abs += fabs(val);
+ count++;
+ G_debug(3, "i=%d j=%d sum = %f val=%f", i, j, sum, val);
+ int nrec, ctype, nlines, line, nareas, area;
+ struct line_pnts *Points;
if (Fi == NULL) {
G_fatal_error(_(" Database connection not defined for layer <%s>"), field_opt->answer);
@@ -141,7 +296,7 @@
/* Note do not check if the column exists in the table because it may be an expression */
+ db_CatValArray_init(&Cvarr);
nrec =
db_select_CatValArray(Driver, Fi->table, Fi->key, col_opt->answer,
where_opt->answer, &Cvarr);
@@ -156,6 +311,8 @@
+ Points = Vect_new_line_struct();
/* Lines */
@@ -307,9 +464,12 @@
G_debug(2, "sum = %f total_size = %f", sum, total_size);
if (compatible) {
- if ((otype & GV_LINES) || (otype & GV_AREA)) {
+ if (((otype & GV_LINES) || (otype & GV_AREA)) && !geometry->answer) {
mean = sum / total_size;
mean_abs = sum_abs / total_size;
/* Roger Bivand says it is wrong see GRASS devel list 7/2004 */
@@ -345,8 +505,13 @@
if (shell_flag->answer) {
fprintf(stdout, "n=%d\n", count);
- fprintf(stdout, "nmissing=%d\n", nmissing);
- fprintf(stdout, "nnull=%d\n", nnull);
+ if (geometry->answer) {
+ fprintf(stdout, "nzero=%d\n", nzero);
+ else {
+ fprintf(stdout, "nmissing=%d\n", nmissing);
+ fprintf(stdout, "nnull=%d\n", nnull);
if (count > 0) {
fprintf(stdout, "min=%g\n", min);
fprintf(stdout, "max=%g\n", max);
@@ -368,10 +533,16 @@
else {
- fprintf(stdout, "number of features with non NULL attribute: %d\n",
- count);
- fprintf(stdout, "number of missing attributes: %d\n", nmissing);
- fprintf(stdout, "number of NULL attributes: %d\n", nnull);
+ if(geometry->answer) {
+ fprintf(stdout, "number of non zero distances: %d\n", count);
+ fprintf(stdout, "number of zero distances: %d\n", nzero);
+ else {
+ fprintf(stdout, "number of features with non NULL attribute: %d\n",
+ count);
+ fprintf(stdout, "number of missing attributes: %d\n", nmissing);
+ fprintf(stdout, "number of NULL attributes: %d\n", nnull);
if (count > 0) {
fprintf(stdout, "minimum: %g\n", min);
fprintf(stdout, "maximum: %g\n", max);
@@ -396,7 +567,8 @@
/* TODO: mode, skewness, kurtosis */
- if (extended->answer && compatible && (otype & GV_POINTS) && count > 0) {
+ /* Not possible to calculate for point distance, since we don't collect the population */
+ if (extended->answer && compatible && (otype & GV_POINTS) && !geometry->answer && count > 0) {
double quartile_25 = 0.0, quartile_75 = 0.0, quartile_perc = 0.0;
double median = 0.0;
int qpos_25, qpos_75, qpos_perc;
@@ -456,8 +628,4 @@
fprintf(stdout, "%dth percentile: %g\n", perc, quartile_perc);
- Vect_close(&Map);
- exit(EXIT_SUCCESS);
