[GRASS-SVN] r53284 - grass/branches/develbranch_6/vector/v.univar
Fri Sep 28 08:35:50 PDT 2012
Author: mmetz
Date: 2012-09-28 08:35:50 -0700 (Fri, 28 Sep 2012)
New Revision: 53284
   grass/branches/develbranch_6/vector/v.univar/main.c
v.univar: fix r53281, disable r39304 (bugs in -d)
Modified: grass/branches/develbranch_6/vector/v.univar/main.c
--- grass/branches/develbranch_6/vector/v.univar/main.c	2012-09-28 12:49:16 UTC (rev 53283)
+++ grass/branches/develbranch_6/vector/v.univar/main.c	2012-09-28 15:35:50 UTC (rev 53284)
@@ -83,10 +83,6 @@
 /* Extended statistics */
 int perc;
-static void select_from_geometry(void);
-static void select_from_database(void);
-static void summary(void);
 int main(int argc, char *argv[])
     struct GModule *module;
@@ -144,7 +140,11 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    /* Only require col_opt answer if -g flag is not set */
+    if (geometry->answer)
+	G_fatal_error(_("The '-%c' flag is currently broken, please use v.distance instead."),
+	              geometry->key);
+    /* Only require col_opt answer if -d flag is not set */
     if (!col_opt->answer && !geometry->answer) {
 	G_fatal_error(_("Required parameter <%s> not set:\n\t(%s)"), col_opt->key, col_opt->description);
@@ -228,7 +228,8 @@
     count = 0;
     nlines = Vect_get_num_primitives(&Map, otype);
-    /* Start calculating the statistics based on distance to all other primitives.
+    /* this does not make sense:
+     * Start calculating the statistics based on distance to all other primitives.
        Use the centroid of areas and the first point of lines */
     for (i = 1; i <= nlines; i++) {
@@ -249,6 +250,9 @@
 	    if (!ok)
 	        continue;
+	/* starting from i + 1 is wrong because with
+	 * 1--2----3
+	 * the nearest feature of 2 would be 3 */
 	for (j = i + 1; j < nlines; j++) {
 	    /* get distance to this object */
 	    double val = 0.0;
@@ -257,6 +261,8 @@
 	    if (!(type & otype))
 		continue;
+	    /* where opt is missing here */
 	    /* now calculate the min distance between each point in line i with line j */
 	    for (k = 0; k < iPoints->n_points; k++) {
@@ -291,6 +297,7 @@
 	    count++;
 	    G_debug(3, "i=%d j=%d sum = %f val=%f", i, j, sum, val);
+	/* areas are missing in case of otype & GV_AREAS */
