[GRASS-SVN] r53285 - grass/branches/releasebranch_6_4/vector/v.univar
svn_grass at osgeo.org
Fri Sep 28 08:37:55 PDT 2012
Author: mmetz
Date: 2012-09-28 08:37:54 -0700 (Fri, 28 Sep 2012)
New Revision: 53285
grass/branches/releasebranch_6_4/vector/v.univar/main.c
v.univar: fix r53282, disable r43625 (bugs in -d)
Modified: grass/branches/releasebranch_6_4/vector/v.univar/main.c
--- grass/branches/releasebranch_6_4/vector/v.univar/main.c 2012-09-28 15:35:50 UTC (rev 53284)
+++ grass/branches/releasebranch_6_4/vector/v.univar/main.c 2012-09-28 15:37:54 UTC (rev 53285)
@@ -83,10 +83,6 @@
/* Extended statistics */
int perc;
-static void select_from_geometry(void);
-static void select_from_database(void);
-static void summary(void);
int main(int argc, char *argv[])
struct GModule *module;
@@ -144,7 +140,11 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- /* Only require col_opt answer if -g flag is not set */
+ if (geometry->answer)
+ G_fatal_error(_("The '-%c' flag is currently broken, please use v.distance instead."),
+ geometry->key);
+ /* Only require col_opt answer if -d flag is not set */
if (!col_opt->answer && !geometry->answer) {
G_fatal_error(_("Required parameter <%s> not set:\n\t(%s)"), col_opt->key, col_opt->description);
@@ -228,7 +228,8 @@
count = 0;
nlines = Vect_get_num_primitives(&Map, otype);
- /* Start calculating the statistics based on distance to all other primitives.
+ /* this does not make sense:
+ * Start calculating the statistics based on distance to all other primitives.
Use the centroid of areas and the first point of lines */
for (i = 1; i <= nlines; i++) {
@@ -249,6 +250,9 @@
if (!ok)
continue;
+ /* starting from i + 1 is wrong because with
+ * 1--2----3
+ * the nearest feature of 2 would be 3 */
for (j = i + 1; j < nlines; j++) {
/* get distance to this object */
double val = 0.0;
@@ -257,6 +261,8 @@
if (!(type & otype))
continue;
+ /* where opt is missing here */
/* now calculate the min distance between each point in line i with line j */
for (k = 0; k < iPoints->n_points; k++) {
@@ -291,6 +297,7 @@
count++;
G_debug(3, "i=%d j=%d sum = %f val=%f", i, j, sum, val);
+ /* areas are missing in case of otype & GV_AREAS */
