[GRASS-SVN] r53286 - in grass/trunk: lib/python/temporal raster temporal/t.rast.out.vtk
svn_grass at osgeo.org
Fri Sep 28 16:11:38 PDT 2012
Author: huhabla
Date: 2012-09-28 16:11:38 -0700 (Fri, 28 Sep 2012)
New Revision: 53286
grass/trunk/lib/python/temporal/base.py
grass/trunk/raster/rasterintro.html
grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
Handle empty maps ids
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py 2012-09-28 15:37:54 UTC (rev 53285)
+++ grass/trunk/lib/python/temporal/base.py 2012-09-28 23:11:38 UTC (rev 53286)
@@ -660,13 +660,17 @@
without layer information
@param return the name of the vector map as name at mapset
+ or None in case the id was not set
- if self.id.find(":") >= 0:
- # Remove the layer identifier from the id
- return self.id.split("@")[0].split(":")[0] + "@" + \
- self.id.split("@")[1]
+ if self.id:
+ if self.id.find(":") >= 0:
+ # Remove the layer identifier from the id
+ return self.id.split("@")[0].split(":")[0] + "@" + \
+ self.id.split("@")[1]
+ else:
+ return self.id
else:
- return self.id
+ return None
def get_layer(self):
"""!Convenient method to get the layer of the map (part of primary key)
Modified: grass/trunk/raster/rasterintro.html
--- grass/trunk/raster/rasterintro.html 2012-09-28 15:37:54 UTC (rev 53285)
+++ grass/trunk/raster/rasterintro.html 2012-09-28 23:11:38 UTC (rev 53286)
@@ -135,7 +135,7 @@
at each region cell's centre.</li>
<li><a href="r.resamp.bspline.html">r.resamp.bspline</a> Bicubic or bilinear
spline interpolation with Tykhonov regularization.</li>
-<li>For <a href="r.resamp.stats.html">r.resamp.stats</a> without <b>-w</b>, the value of
+<li>For <a href="r.resamp.stats.html">r.resamp.stats</a> without <b>-w</b>, the value of
each region cell is the chosen aggregate of the values from all of the raster
cells whose centres fall within the bounds of the region cell.
<br>
Modified: grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
--- grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2012-09-28 15:37:54 UTC (rev 53285)
+++ grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2012-09-28 23:11:38 UTC (rev 53286)
@@ -123,10 +123,8 @@
if maps is not None:
for map in maps:
if use_granularity:
- if len(map) > 0:
+ if map and len(map) > 0:
id = map[0].get_map_id()
- else:
- continue
else:
id = map.get_map_id()
# None ids will be replaced by NULL maps
