[GRASS-SVN] r55604 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Wed Apr 3 03:53:55 PDT 2013
Author: zarch
Date: 2013-04-03 03:53:55 -0700 (Wed, 03 Apr 2013)
New Revision: 55604
grass/trunk/lib/python/script/setup.py.sed
Add a new function, rename dit to etcpy
Modified: grass/trunk/lib/python/script/setup.py.sed
--- grass/trunk/lib/python/script/setup.py.sed 2013-04-03 10:45:53 UTC (rev 55603)
+++ grass/trunk/lib/python/script/setup.py.sed 2013-04-03 10:53:55 UTC (rev 55604)
@@ -25,7 +25,18 @@
import sys
import tempfile as tmpfile
-def init(gisbase, dbase = '', location = 'demolocation', mapset = 'PERMANENT'):
+def write_gisrc(dbase, location, mapset):
+ """Write the gisrc file and return the gisrc path."""
+ fd, gisrc = tmpfile.mkstemp()
+ os.write(fd, "GISDBASE: %s\n" % dbase)
+ os.write(fd, "LOCATION_NAME: %s\n" % location)
+ os.write(fd, "MAPSET: %s\n" % mapset)
+ os.close(fd)
+ return gisrc
+def init(gisbase, dbase='', location='demolocation', mapset='PERMANENT'):
"""!Initialize system variables to run scripts without starting
GRASS explicitly.
@@ -40,32 +51,27 @@
# define PATH
os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'bin')
os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'scripts')
- if sys.platform.startswith('win'): # added for winGRASS
- os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'extralib')
+ if sys.platform.startswith('win'): # added for winGRASS
+ os.environ['PATH'] += os.pathsep + os.path.join(gisbase, 'extralib')
# define LD_LIBRARY_PATH
if '@LD_LIBRARY_PATH_VAR@' not in os.environ:
os.environ['@LD_LIBRARY_PATH_VAR@'] = ''
os.environ['@LD_LIBRARY_PATH_VAR@'] += os.pathsep + os.path.join(gisbase, 'lib')
os.environ['GIS_LOCK'] = str(os.getpid())
# Set PYTHONPATH to find GRASS Python modules
path = os.getenv('PYTHONPATH')
- dir = os.path.join(gisbase, 'etc', 'python')
+ etcpy = os.path.join(gisbase, 'etc', 'python')
if path:
- path = dir + os.pathsep + path
+ path = etcpy + os.pathsep + path
else:
- path = dir
+ path = etcpy
os.environ['PYTHONPATH'] = path
if not dbase:
dbase = gisbase
- fd, gisrc = tmpfile.mkstemp()
- os.environ['GISRC'] = gisrc
- os.write(fd, "GISDBASE: %s\n" % dbase)
- os.write(fd, "LOCATION_NAME: %s\n" % location)
- os.write(fd, "MAPSET: %s\n" % mapset)
- os.close(fd)
- return gisrc
+ os.environ['GISRC'] = write_gisrc(dbase, location, mapset)
+ return os.environ['GISRC']
