[GRASS-SVN] r55605 - in grass/trunk/lib/python/pygrass/modules: . grid
svn_grass at osgeo.org
Wed Apr 3 03:57:50 PDT 2013
Author: zarch
Date: 2013-04-03 03:57:50 -0700 (Wed, 03 Apr 2013)
New Revision: 55605
Added:
grass/trunk/lib/python/pygrass/modules/grid/
grass/trunk/lib/python/pygrass/modules/grid/Makefile
grass/trunk/lib/python/pygrass/modules/grid/__init__.py
grass/trunk/lib/python/pygrass/modules/grid/grid.py
grass/trunk/lib/python/pygrass/modules/grid/patch.py
grass/trunk/lib/python/pygrass/modules/grid/split.py
grass/trunk/lib/python/pygrass/modules/Makefile
grass/trunk/lib/python/pygrass/modules/__init__.py
Add the new GridModule class
Modified: grass/trunk/lib/python/pygrass/modules/Makefile
--- grass/trunk/lib/python/pygrass/modules/Makefile 2013-04-03 10:53:55 UTC (rev 55604)
+++ grass/trunk/lib/python/pygrass/modules/Makefile 2013-04-03 10:57:50 UTC (rev 55605)
@@ -11,7 +11,7 @@
MODULES = shortcuts
-CLEAN_SUBDIRS = interface
+CLEAN_SUBDIRS = interface grid
PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/pygrass/modules/__init__.py
--- grass/trunk/lib/python/pygrass/modules/__init__.py 2013-04-03 10:53:55 UTC (rev 55604)
+++ grass/trunk/lib/python/pygrass/modules/__init__.py 2013-04-03 10:57:50 UTC (rev 55605)
@@ -8,7 +8,7 @@
import interface
from interface import Module
-#import grid
-#from grid.grid import GridModule
+import grid
+from grid.grid import GridModule
import shortcuts
Added: grass/trunk/lib/python/pygrass/modules/grid/Makefile
--- grass/trunk/lib/python/pygrass/modules/grid/Makefile (rev 0)
+++ grass/trunk/lib/python/pygrass/modules/grid/Makefile 2013-04-03 10:57:50 UTC (rev 55605)
@@ -0,0 +1,32 @@
+MODULE_TOPDIR = ../../../../..
+include $(MODULE_TOPDIR)/include/Make/Other.make
+include $(MODULE_TOPDIR)/include/Make/Python.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+PYDIR = $(ETC)/python
+GDIR = $(PYDIR)/grass
+PGDIR = $(GDIR)/pygrass
+DSTDIR= $(PGDIR)/modules/grid
+MODULES = split patch grid
+PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
+PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
+default: $(PYFILES) $(PYCFILES) $(GDIR)/__init__.py $(GDIR)/__init__.pyc
+$(PYDIR):
+ $(MKDIR) $@
+$(GDIR): | $(PYDIR)
+ $(MKDIR) $@
+$(DSTDIR): | $(GDIR)
+ $(MKDIR) $@
+$(DSTDIR)/%: % | $(DSTDIR)
+ $(INSTALL_DATA) $< $@
+#doxygen:
+DOXNAME = pythonpygrass
\ No newline at end of file
Added: grass/trunk/lib/python/pygrass/modules/grid/__init__.py
--- grass/trunk/lib/python/pygrass/modules/grid/__init__.py (rev 0)
+++ grass/trunk/lib/python/pygrass/modules/grid/__init__.py 2013-04-03 10:57:50 UTC (rev 55605)
@@ -0,0 +1,10 @@
+# -*- coding: utf-8 -*-
+Created on Wed Apr 3 10:41:30 2013
+ at author: pietro
+import split
+import patch
+import grid
+from grid import GridModule
Added: grass/trunk/lib/python/pygrass/modules/grid/grid.py
--- grass/trunk/lib/python/pygrass/modules/grid/grid.py (rev 0)
+++ grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-04-03 10:57:50 UTC (rev 55605)
@@ -0,0 +1,182 @@
+Created on Thu Mar 28 11:06:00 2013
+ at author: pietro
+import os
+import multiprocessing as mltp
+import subprocess as sub
+from grass.script.setup import write_gisrc
+from grass.pygrass.gis import Mapset, Location, make_mapset
+from grass.pygrass.modules import Module
+from split import split_region_tiles
+from patch import patch_map
+_GREG = Module('g.region')
+def get_cmd(cmdd):
+ """Transforma a cmd dictionary to a list of parameters"""
+ cmd = [cmdd['name'], ]
+ cmd.extend(("%s=%s" % (k, v) for k, v in cmdd['inputs']))
+ cmd.extend(("%s=%s" % (k, v) for k, v in cmdd['outputs']))
+ cmd.extend(("%s" % (flg) for flg in cmdd['flags'] if len(flg) == 1))
+ cmd.extend(("--%s" % (flg[0]) for flg in cmdd['flags'] if len(flg) > 1))
+ return cmd
+def cmd_exe((bbox, mapnames, msetname, cmd)):
+ """Create a mapset, and execute a cmd inside."""
+ mset = Mapset()
+ try:
+ make_mapset(msetname)
+ except:
+ pass
+ env = os.environ.copy()
+ env['GISRC'] = write_gisrc(mset.gisdbase, mset.location, msetname)
+ if mapnames:
+ inputs = dict(cmd['inputs'])
+ # reset the inputs to
+ for key in mapnames:
+ inputs[key] = mapnames[key]
+ cmd['inputs'] = inputs.items()
+ # set the region to the tile
+ _GREG(env_=env, rast=key)
+ else:
+ # set the computational region
+ _GREG(env_=env, **bbox)
+ # run the grass command
+ sub.Popen(get_cmd(cmd), env=env).wait()
+class GridModule(object):
+ """Run GRASS raster commands in a multiproccessing mode.
+ Parameters
+ cmd: raster GRASS command
+ Only command staring with r.* are valid.
+ width: integer
+ Width of the tile, in pixel.
+ height: integer
+ Height of the tile, in pixel.
+ overlap: integer
+ Overlap between tiles, in pixel.
+ nthreads: number of threads
+ Default value is equal to the number of processor available.
+ split: boolean
+ If True use r.tile to split all the inputs.
+ run_: boolean
+ If False only instantiate the object.
+ args and kargs: cmd parameters
+ Give all the parameters to the command.
+ Examples
+ >>> grd = GridModule('r.slope.aspect',
+ ... width=500, height=500, overlap=2,
+ ... processes=None, split=True,
+ ... elevation='elevation',
+ ... slope='slope', aspect='aspect', overwrite=True)
+ >>> grd.run()
+ def __init__(self, cmd, width=None, height=None, overlap=0, processes=None,
+ split=False, *args, **kargs):
+ kargs['run_'] = False
+ self.mset = Mapset()
+ self.module = Module(cmd, *args, **kargs)
+ self.width = width
+ self.height = height
+ self.overlap = overlap
+ self.processes = processes
+ self.bboxes = split_region_tiles(width=width, height=height,
+ overlap=overlap)
+ self.msetstr = cmd.replace('.', '') + "_%03d_%03d"
+ self.inlist = None
+ if split:
+ self.split()
+ def clean_location(self):
+ """Remove all created mapsets."""
+ mapsets = Location().mapsets(self.msetstr.split('_')[0] + '_*')
+ for mset in mapsets:
+ Mapset(mset).delete()
+ def split(self):
+ """Split all the raster inputs using r.tile"""
+ rtile = Module('r.tile')
+ inlist = {}
+ #import pdb; pdb.set_trace()
+ for inmap in self.module.inputs:
+ inm = self.module.inputs[inmap]
+ if inm.type == 'raster' and inm.value:
+ rtile(input=inm.value, output=inm.value,
+ width=self.width, height=self.height,
+ overlap=self.overlap)
+ patt = '%s-*' % inm.value
+ inlist[inm.value] = sorted(self.mset.glist(type='rast',
+ pattern=patt))
+ self.inlist = inlist
+ def get_works(self):
+ """Return a list of tuble with the parameters for cmd_exe function"""
+ works = []
+ cmd = self.module.get_dict()
+ for row, box_row in enumerate(self.bboxes):
+ for col, box in enumerate(box_row):
+ inms = None
+ if self.inlist:
+ inms = {}
+ cols = len(box_row)
+ for key in self.inlist:
+ indx = row * cols + col
+ inms[key] = "%s@%s" % (self.inlist[key][indx],
+ self.mset.name)
+ # set the computational region, prepare the region parameters
+ bbox = dict([(k[0], str(v)) for k, v in box.items()[:-2]])
+ works.append((bbox, inms, self.msetstr % (row, col), cmd))
+ return works
+ def run(self, patch=True, clean=True):
+ """Run the GRASS command."""
+ self.module.flags.overwrite = True
+ pool = mltp.Pool(processes=self.processes)
+ result = pool.map_async(cmd_exe, self.get_works())
+ result.wait()
+ if not result.successful():
+ raise RuntimeError
+ if patch:
+ self.patch()
+ if clean:
+ self.clean_location()
+ self.rm_tiles()
+ def patch(self):
+ """Patch the final results."""
+ # patch all the outputs
+ for otmap in self.module.outputs:
+ otm = self.module.outputs[otmap]
+ if otm.type == 'raster' and otm.value:
+ patch_map(otm.value, self.mset.name, self.msetstr,
+ split_region_tiles(width=self.width,
+ height=self.height),
+ self.module.flags.overwrite)
+ def rm_tiles(self):
+ """Remove all the tiles."""
+ # if split, remove tiles
+ if self.inlist:
+ grm = Module('g.remove')
+ grm(rast=self.inlist[key])
Added: grass/trunk/lib/python/pygrass/modules/grid/patch.py
--- grass/trunk/lib/python/pygrass/modules/grid/patch.py (rev 0)
+++ grass/trunk/lib/python/pygrass/modules/grid/patch.py 2013-04-03 10:57:50 UTC (rev 55605)
@@ -0,0 +1,60 @@
+Created on Tue Apr 2 18:57:42 2013
+ at author: pietro
+from grass.pygrass.gis.region import Region
+from grass.pygrass.raster import RasterRow
+from grass.pygrass.functions import coor2pixel
+def get_start_end_index(bbox_list):
+ """Convert a Bounding Box to a list of the index of
+ column start, end, row start and end
+ ss_list = []
+ reg = Region()
+ for bbox in bbox_list:
+ r_start, c_start = coor2pixel((bbox.west, bbox.north), reg)
+ r_end, c_end = coor2pixel((bbox.east, bbox.south), reg)
+ ss_list.append((int(r_start), int(r_end), int(c_start), int(c_end)))
+ return ss_list
+def patch_row(rast, rasts, bboxes):
+ """Patch a row of bound boxes."""
+ sei = get_start_end_index(bboxes)
+ # instantiate two buffer
+ buff = rasts[0][0]
+ rbuff = rasts[0][0]
+ r_start, r_end, c_start, c_end = sei[0]
+ for row in xrange(r_start, r_end):
+ for col, ras in enumerate(rasts):
+ r_start, r_end, c_start, c_end = sei[col]
+ buff = ras.get_row(row, buff)
+ rbuff[c_start:c_end] = buff[c_start:c_end]
+ rast.put_row(rbuff)
+def patch_map(raster, mapset, mset_str, bbox_list, overwrite=False):
+ """Patch raster using a bounding box list to trim the raster."""
+ # Instantiate the RasterRow input objects
+ rast = RasterRow(raster, mapset)
+ rtype = RasterRow(name=raster, mapset=mset_str % (0, 0))
+ rtype.open('r')
+ rast.open('w', mtype=rtype.mtype, overwrite=overwrite)
+ rtype.close()
+ rasts = []
+ for row, rbbox in enumerate(bbox_list):
+ rrasts = []
+ for col in range(len(rbbox)):
+ rrasts.append(RasterRow(name=raster, mapset=mset_str % (row, col)))
+ rrasts[-1].open('r')
+ rasts.append(rrasts)
+ patch_row(rast, rrasts, rbbox)
+ for rrast in rasts:
+ for rast_ in rrast:
+ rast_.close()
+ rast.close()
Added: grass/trunk/lib/python/pygrass/modules/grid/split.py
--- grass/trunk/lib/python/pygrass/modules/grid/split.py (rev 0)
+++ grass/trunk/lib/python/pygrass/modules/grid/split.py 2013-04-03 10:57:50 UTC (rev 55605)
@@ -0,0 +1,55 @@
+Created on Tue Apr 2 19:00:15 2013
+ at author: pietro
+from grass.pygrass.vector.basic import Bbox
+def get_bbox(reg, row, col, width, height, overlap):
+ """Return a Bbox"""
+ north = reg.north - (row * height - overlap) * reg.nsres
+ south = reg.north - ((row + 1) * height + overlap) * reg.nsres
+ east = reg.west + ((col + 1) * width + overlap) * reg.ewres
+ west = reg.west + (col * width - overlap) * reg.ewres
+ return Bbox(north=north if north <= reg.north else reg.north,
+ south=south if south >= reg.south else reg.south,
+ east=east if east <= reg.east else reg.east,
+ west=west if west >= reg.west else reg.west,)
+def split_region_tiles(region=None, width=100, height=100, overlap=0):
+ """Spit a region into a list of Bbox. ::
+ >>> reg = Region()
+ >>> reg.north = 1350
+ >>> reg.south = 0
+ >>> reg.nsres = 1
+ >>> reg.east = 1500
+ >>> reg.west = 0
+ >>> reg.ewres = 1
+ >>> reg.cols
+ 1500
+ >>> reg.rows
+ 1350
+ >>> split_region_tiles(region=reg, width=1000, height=700, overlap=0)
+ [[Bbox(1350.0, 650.0, 1000.0, 0.0), Bbox(1350.0, 650.0, 1500.0, 1000.0)],
+ [Bbox(650.0, 0.0, 1000.0, 0.0), Bbox(650.0, 0.0, 1500.0, 1000.0)]]
+ >>> split_region_tiles(region=reg, width=1000, height=700, overlap=10)
+ [[Bbox(1350.0, 640.0, 1010.0, 0.0), Bbox(1350.0, 640.0, 1500.0, 990.0)],
+ [Bbox(660.0, 0.0, 1010.0, 0.0), Bbox(660.0, 0.0, 1500.0, 990.0)]]
+ reg = region if region else Region()
+ ncols = (reg.cols + width - 1) // width
+ nrows = (reg.rows + height - 1) // height
+ box_list = []
+ #print reg
+ for row in xrange(nrows):
+ row_list = []
+ for col in xrange(ncols):
+ #print 'c', c, 'r', r
+ row_list.append(get_bbox(reg, row, col, width, height, overlap))
+ box_list.append(row_list)
+ return box_list
