[GRASS-SVN] r55641 - grass/trunk/vector/v.in.dxf
svn_grass at osgeo.org
Sat Apr 6 02:54:31 PDT 2013
Author: hcho
Date: 2013-04-06 02:54:31 -0700 (Sat, 06 Apr 2013)
New Revision: 55641
grass/trunk/vector/v.in.dxf/dxf_to_vect.c
Fixed a possible infinite loop
Modified: grass/trunk/vector/v.in.dxf/dxf_to_vect.c
--- grass/trunk/vector/v.in.dxf/dxf_to_vect.c 2013-04-05 19:50:34 UTC (rev 55640)
+++ grass/trunk/vector/v.in.dxf/dxf_to_vect.c 2013-04-06 09:54:31 UTC (rev 55641)
@@ -16,18 +16,21 @@
int dxf_to_vect(struct dxf_file *dxf, struct Map_info *Map)
int code;
int bounds = 0;
if (dxf_find_header(dxf)) {
/* code == 0: end of the header section */
code = dxf_get_code(dxf);
- while (code != 0) {
+ while (code != 0) { /* ENDSEC */
if (code == -2) /* EOF */
return 0;
/* only looking for header groups (code == 9) */
- if (code != 9)
+ if (code != 9) {
+ code = find_next_header_variable(dxf);
continue;
if (strcmp(dxf_buf, "$EXTMAX") == 0) {
/* read in lines and process information until a 9
@@ -78,12 +81,8 @@
- else {
- while ((code = dxf_get_code(dxf)) != 9 && code != 0) {
- if (code == -2) /* EOF */
- return 0;
+ else
if (bounds == 6)
break;
@@ -153,6 +152,19 @@
return 0;
+int find_next_header_variable(struct dxf_file *dxf)
+ int code;
+ /* code 9: header variable
+ * code 0: ENDSEC
+ * code -2: EOF
+ while ((code = dxf_get_code(dxf)) != 9 && code != 0 && code != -2) ;
+ return code;
int check_ext(double x, double y, double z)
if (x < ext.W)
