[GRASS-SVN] r55642 - grass/trunk/vector/v.in.dxf
svn_grass at osgeo.org
Sat Apr 6 02:58:25 PDT 2013
Author: hcho
Date: 2013-04-06 02:58:25 -0700 (Sat, 06 Apr 2013)
New Revision: 55642
grass/trunk/vector/v.in.dxf/dxf_to_vect.c
Removed an empty line
Modified: grass/trunk/vector/v.in.dxf/dxf_to_vect.c
--- grass/trunk/vector/v.in.dxf/dxf_to_vect.c 2013-04-06 09:54:31 UTC (rev 55641)
+++ grass/trunk/vector/v.in.dxf/dxf_to_vect.c 2013-04-06 09:58:25 UTC (rev 55642)
@@ -16,7 +16,6 @@
int dxf_to_vect(struct dxf_file *dxf, struct Map_info *Map)
int code;
int bounds = 0;
if (dxf_find_header(dxf)) {
