[GRASS-SVN] r55643 - grass/trunk/lib/vector/Vlib
Sat Apr 6 04:40:17 PDT 2013
Author: mmetz
Date: 2013-04-06 04:40:17 -0700 (Sat, 06 Apr 2013)
New Revision: 55643
   grass/trunk/lib/vector/Vlib/copy.c
Vlib: fix isle/area check
Modified: grass/trunk/lib/vector/Vlib/copy.c
--- grass/trunk/lib/vector/Vlib/copy.c	2013-04-06 09:58:25 UTC (rev 55642)
+++ grass/trunk/lib/vector/Vlib/copy.c	2013-04-06 11:40:17 UTC (rev 55643)
@@ -349,16 +349,18 @@
     Vect_get_area_boundaries(Map, area, List);
     is_isle = FALSE;
-    /* do we need to check all boundaries ? */
+    /* do we need to check all boundaries ? no */
     for (i = 0; i < List->n_values && !is_isle; i++) {
-        line = abs(List->value[i]);
-        if (1 != Vect_get_line_areas(Map, line, &left, &right))
+        line = List->value[i];
+        if (1 != Vect_get_line_areas(Map, abs(line), &left, &right))
             continue;
-        isle = abs(left == area ? right : left);
+        isle = line > 0 ? right : left;
-        if (Vect_get_isle_area(Map, isle) > 0)
+        if (isle < 0 && Vect_get_isle_area(Map, abs(isle)) > 0) {
             is_isle = TRUE;
+	    break;
     G_debug(3, "is_isle(): area %d skip? -> %s", area, is_isle ? "yes" : "no");
