[GRASS-SVN] r55812 - grass/trunk/locale/po
svn_grass at osgeo.org
Mon Apr 15 01:30:23 PDT 2013
Author: lucadelu
Date: 2013-04-15 01:30:21 -0700 (Mon, 15 Apr 2013)
New Revision: 55812
grass/trunk/locale/po/grassmods_it.po
Anna Zanchetta: cont'ed
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2013-04-15 08:27:29 UTC (rev 55811)
+++ grass/trunk/locale/po/grassmods_it.po 2013-04-15 08:30:21 UTC (rev 55812)
@@ -14,7 +14,7 @@
"Project-Id-Version: grassmods_it\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2013-02-26 14:45+0100\n"
-"PO-Revision-Date: 2013-03-13 12:57+0100\n"
+"PO-Revision-Date: 2013-04-09 16:21+0100\n"
"Last-Translator: anna\n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
"Language: it\n"
@@ -23,7 +23,7 @@
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: Lokalize 1.4\n"
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
-"X-Poedit-Bookmarks: 1765,2474,415,1273,-1,-1,-1,-1,-1,-1\n"
+"X-Poedit-Bookmarks: 1765,2381,2449,2554,2623,3551,3587,-1,-1,6460\n"
"X-Poedit-Language: Italian\n"
"X-Poedit-Country: ITALY\n"
"X-Poedit-SourceCharset: utf-8\n"
@@ -1797,15 +1797,15 @@
#: ../raster3d/r3.out.vtk/parameters.c:71
msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
-msgstr ""
+msgstr "Crea output 3d di elevazione con una superficie superiore e inferiore, entrambe le mappe raster sono richieste."
#: ../raster3d/r3.out.vtk/parameters.c:82
msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
+msgstr "Tre (R,G,B) mappe raster 3D per creare valori RGB [redmap, greenmap, bluemap]"
#: ../raster3d/r3.out.vtk/parameters.c:92
msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
+msgstr "Tre (x,y,z) mappe raster 3D per creare valori vettore [xmap, ymap, zmap]"
#: ../raster3d/r3.out.vtk/parameters.c:98 ../raster/r.out.vtk/parameters.c:88
#: ../vector/v.out.vtk/main.c:73
@@ -1825,7 +1825,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:121
msgid "Scale factor effects the origin"
-msgstr ""
+msgstr "Il fattore di scala condiziona l'origine"
#: ../raster3d/r3.out.vtk/parameters.c:127
#: ../raster/r.out.vtk/parameters.c:130 ../vector/v.out.vtk/main.c:86
@@ -1947,7 +1947,7 @@
#: ../raster3d/r3.in.ascii/main.c:289
#, c-format
msgid "Data exists in input file after fully importing expected data. [%.4f ...]"
-msgstr ""
+msgstr "Ci sono dati nel file di input dopo aver importato completamente i dati previsti. [%.4f...]"
#: ../raster3d/r3.in.ascii/main.c:325
#, fuzzy
@@ -3348,7 +3348,7 @@
#: ../raster/r.profile/main.c:93
msgid "Output RRR:GGG:BBB color values for each profile point"
-msgstr ""
+msgstr "Valori RRR:GGG:BBB di colore di output per ogni punto del profilo"
#: ../raster/r.profile/main.c:112
#, c-format
@@ -4017,6 +4017,8 @@
"\n"
"Input value here [0-100]: "
msgstr ""
+"\n"
+"Qui valore di input [0-100]: "
#: ../raster/r.watershed/shed/com_line.c:379
msgid ""
@@ -4193,7 +4195,7 @@
#: ../raster/r.watershed/shed/main.c:41
msgid "Slow version of water analysis program starting now"
-msgstr ""
+msgstr "Inizia ora la versione lenta del programma di analisi dell'acqua"
#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
#, c-format
@@ -12762,11 +12764,11 @@
#: ../raster/r.horizon/main.c:281
msgid "Coordinate for which you want to calculate the horizon"
-msgstr ""
+msgstr "Coordinata per la quale vuoi calcolare l'orizzonte"
#: ../raster/r.horizon/main.c:296
msgid "Write output in degrees (default is radians)"
-msgstr ""
+msgstr "Scrive l'output in gradi (il default è radianti)"
#: ../raster/r.horizon/main.c:344
msgid "Can't read the coordinates from the \"coord\" option."
@@ -12774,19 +12776,19 @@
#: ../raster/r.horizon/main.c:362
msgid "You didn't specify a direction value or step size. Aborting."
-msgstr ""
+msgstr "Non hai specificato il valore di direzione o la dimensione del passo. L'operazione verrà interrotta."
#: ../raster/r.horizon/main.c:367
msgid "You didn't specify a horizon raster name. Aborting."
-msgstr ""
+msgstr "Non hai specificato il nome di un raster di orizzonte. L'operazione verrà interrotta."
#: ../raster/r.horizon/main.c:377
msgid "You didn't specify an angle step size. Aborting."
-msgstr ""
+msgstr "Non hai specificato la misura del passo dell'angolo. L'operazione verrà interrotta."
#: ../raster/r.horizon/main.c:390
msgid "Could not read bufferzone size. Aborting."
-msgstr ""
+msgstr "Impossibile leggere la dimensione della zona di buffer. L'operazione verrà interrotta."
#: ../raster/r.horizon/main.c:395 ../raster/r.horizon/main.c:401
#: ../raster/r.horizon/main.c:408 ../raster/r.horizon/main.c:415
@@ -12816,7 +12818,7 @@
#: ../raster/r.horizon/main.c:421
msgid "Could not read maximum distance. Aborting."
-msgstr ""
+msgstr "Impossibile leggere la distanza massima. L'operazione verrà interrotta."
#: ../raster/r.horizon/main.c:472
msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
@@ -13099,7 +13101,7 @@
#: ../raster/simwe/simlib/input.c:222
msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr ""
+msgstr "L'infiltrazione eccede l'intensità di precipitazione ovunque! Nessun flusso superficiale."
#: ../raster/simwe/simlib/input.c:246
#, c-format
@@ -13748,7 +13750,7 @@
#: ../raster/r.in.ascii/gethead.c:105
msgid "error getting file position"
-msgstr ""
+msgstr "errore nell'ottenere la posizione del file"
#: ../raster/r.in.ascii/gethead.c:164
msgid "illegal type field: using type int"
@@ -13789,7 +13791,7 @@
#: ../raster/r.what.color/main.c:106
msgid "Values to query colors for"
-msgstr ""
+msgstr "Valori per i quali interrogare i colori"
#: ../raster/r.what.color/main.c:113
msgid "Output format (printf-style)"
@@ -13838,7 +13840,7 @@
#: ../raster/r.out.vrml/main.c:136
#, c-format
msgid "Opening %s for writing... "
-msgstr ""
+msgstr "Aprendo %s per scrivere..."
#: ../raster/r.out.vrml/put_grid.c:38
msgid "Writing vertices..."
@@ -13872,11 +13874,11 @@
#: ../raster/r.surf.fractal/main.c:79
#, c-format
msgid "Fractal dimension of %.2lf must be between 2 and 3."
-msgstr ""
+msgstr "La dimensione frattale di %.2lf deve essere tra 2 e 3."
#: ../raster/r.surf.fractal/spec_syn.c:61
msgid "Preliminary surface calculations..."
-msgstr ""
+msgstr "Calcoli superficiali preliminari..."
#: ../raster/r.surf.fractal/spec_syn.c:120
#, c-format
@@ -19654,19 +19656,19 @@
#: ../display/d.linegraph/main.c:126
msgid "Name of data file for X axis of graph"
-msgstr ""
+msgstr "Nome del file di dati per l'asse X del grafico"
#: ../display/d.linegraph/main.c:132
msgid "Name of data file(s) for Y axis of graph"
-msgstr ""
+msgstr "Nome del(i) file di dati per l'asse Y del grafico"
#: ../display/d.linegraph/main.c:139
msgid "Path to file location"
-msgstr ""
+msgstr "Percorso per la location del file"
#: ../display/d.linegraph/main.c:147
msgid "Color for Y data"
-msgstr ""
+msgstr "Colore per i dati Y"
#: ../display/d.linegraph/main.c:156
msgid "Color for axis, tics, numbers, and title"
@@ -19686,17 +19688,17 @@
#: ../display/d.linegraph/main.c:226
msgid "Maximum of 10 Y data files exceeded"
-msgstr ""
+msgstr "Oltrepassato il massimo di 10 file di dati in Y"
#: ../display/d.linegraph/main.c:255
#, c-format
msgid "Only <%d> colors given for <%d> lines"
-msgstr ""
+msgstr "Solo <%d> colori dati per <%d> linee"
#: ../display/d.linegraph/main.c:309
#, c-format
msgid "Y input file <%s> contains %s data points than the X input file"
-msgstr ""
+msgstr "Il file Y di input <%s> contiene %s punti rispetto al file X di input"
#: ../display/d.linegraph/main.c:314
#, c-format
@@ -19706,12 +19708,12 @@
#: ../display/d.linegraph/main.c:375
#, c-format
msgid "Problem reading X data file at line %d"
-msgstr ""
+msgstr "Problema nella lettura del file dati X alla linea %d"
#: ../display/d.linegraph/main.c:385
#, c-format
msgid "Problem reading <%s> data file at line %d"
-msgstr ""
+msgstr "Problema nella lettura del file <%s> alla linea %d"
#: ../display/d.profile/main.c:68
#, fuzzy, c-format
@@ -19746,7 +19748,7 @@
#: ../display/d.what.rast/main.c:54
msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
-msgstr ""
+msgstr "Permette all'utente di interrogare interattivamente i contenuti dei layer di una mappa raster multipla in location specificate dall'utente all'interno della regione geografica corrente."
#: ../display/d.what.rast/main.c:75
msgid "Field separator (terse mode only)"
@@ -19754,7 +19756,7 @@
#: ../display/d.what.rast/main.c:89
msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr ""
+msgstr "Stampa colonne/righe per l'intera mappa nella risoluzione di griglia della regione"
#: ../display/d.info/main.c:33 ../display/d.erase/main.c:31
#: ../display/d.mon/main.c:39
@@ -19774,23 +19776,23 @@
#: ../display/d.info/main.c:42
msgid "Display screen rectangle (left, right, top, bottom)"
-msgstr ""
+msgstr "Mostra il rettangolo dello schermo (sinistra, destra, alto, basso)"
#: ../display/d.info/main.c:46
msgid "Display screen dimensions (width, height)"
-msgstr ""
+msgstr "Mostra le dimensioni dello schermo (larghezza, altezza)"
#: ../display/d.info/main.c:50
msgid "Display active frame rectangle"
-msgstr ""
+msgstr "Mostra il rettangolo di cornice attivo"
#: ../display/d.info/main.c:54
msgid "Display screen rectangle of current region"
-msgstr ""
+msgstr "Mostra il rettangolo dello schermo della regione corrente"
#: ../display/d.info/main.c:59
msgid "Display geographic coordinates and resolution of entire screen"
-msgstr ""
+msgstr "Mostra le coordinate geografiche e la risoluzione dell'intero schermo"
#: ../display/d.info/main.c:66
#, fuzzy
@@ -19799,7 +19801,7 @@
#: ../display/d.vect.chart/main.c:66
msgid "Displays charts of vector data in the active frame on the graphics monitor."
-msgstr ""
+msgstr "Mostra grafici dei dati vettore nella cornice attiva sul monitor dei grafici."
#: ../display/d.vect.chart/main.c:83
msgid "Chart type"
@@ -19810,7 +19812,7 @@
#: ../display/d.vect.chart/main.c:121 ../display/d.vect.chart/main.c:130
#: ../display/d.vect.chart/main.c:136
msgid "Chart properties"
-msgstr ""
+msgstr "Proprietà del grafico"
#: ../display/d.vect.chart/main.c:91
msgid "Attribute columns containing data"
@@ -19818,7 +19820,7 @@
#: ../display/d.vect.chart/main.c:97
msgid "Column used for pie chart size"
-msgstr ""
+msgstr "Colonna usata per la dimensione del grafico a torta"
#: ../display/d.vect.chart/main.c:105
msgid "Size of chart (diameter for pie, total width for bar)"
@@ -19826,7 +19828,7 @@
#: ../display/d.vect.chart/main.c:112
msgid "Scale for size (to get size in pixels)"
-msgstr ""
+msgstr "Scala per la dimensione (ottenere la dimensione in pixel)"
#: ../display/d.vect.chart/main.c:119
msgid "Outline color"
@@ -19834,23 +19836,23 @@
#: ../display/d.vect.chart/main.c:128
msgid "Colors used to fill charts"
-msgstr ""
+msgstr "Colori usati per riempire il grafico"
#: ../display/d.vect.chart/main.c:135
msgid "Center the bar chart around a data point"
-msgstr ""
+msgstr "Centra la barra del grafico vicino a un punto dei dati"
#: ../display/d.vect.chart/main.c:144
msgid "Maximum value used for bar plot reference"
-msgstr ""
+msgstr "Valore massimo usato per riferimento nel plot della barra"
#: ../display/d.vect.chart/main.c:149 ../display/d.thematic.area/main.c:163
msgid "Create legend information and send to stdout"
-msgstr ""
+msgstr "Crea informazioni sulla leggenda e le manda a stdout"
#: ../display/d.barscale/main.c:55
msgid "Displays a barscale on the graphics monitor."
-msgstr ""
+msgstr "Mostra una barra di scala nel monitor dei grafici"
#: ../display/d.barscale/main.c:59
msgid "Use feet/miles instead of meters"
@@ -19858,11 +19860,11 @@
#: ../display/d.barscale/main.c:63
msgid "Draw a line scale instead of a bar scale"
-msgstr ""
+msgstr "Disegna "
#: ../display/d.barscale/main.c:67
msgid "Write text on top of the scale, not to the right"
-msgstr ""
+msgstr "Scrive un testo sulla sommità della scala, non sulla destra"
#: ../display/d.barscale/main.c:71
msgid "Draw a north arrow only"
@@ -19884,11 +19886,11 @@
#: ../display/d.barscale/main.c:108
#, c-format
msgid "%s does not work with a latitude-longitude location"
-msgstr ""
+msgstr "%s non funziona con una location latitudine-longitudine"
#: ../display/d.barscale/main.c:116
msgid "Choose either -n or -s flag"
-msgstr ""
+msgstr "Scegli il flag -n o -s"
#: ../display/d.erase/main.c:32
#: ../locale/scriptstrings/d.redraw_to_translate.c:5
@@ -20588,7 +20590,7 @@
#: ../display/d.thematic.area/main.c:224
#, c-format
msgid "Data (%s) not numeric. Column must be numeric."
-msgstr "I dati (%s) non sono numerici. La colonna dev'essere di tipo numerico"
+msgstr "I dati (%s) non sono numerici. La colonna dev'essere di tipo numerico."
#: ../display/d.thematic.area/main.c:228
#: ../display/d.thematic.area/plot1.c:134
@@ -32052,11 +32054,11 @@
#: ../vector/v.label.sa/labels.c:90
#, c-format
msgid "Font '%s' is not a FreeType font\n"
-msgstr ""
+msgstr "Il tipo di carattere '%s' non è un tipo FreeType\n"
#: ../vector/v.label.sa/labels.c:94
msgid "Font file format is not supported by FreeType"
-msgstr ""
+msgstr "Il formato del file di carattere non è supportato da FreeType"
#: ../vector/v.label.sa/labels.c:96
msgid "Font file can not be loaded"
@@ -32077,7 +32079,7 @@
#: ../vector/v.label.sa/main.c:41
msgid "Create optimally placed labels for vector map(s)"
-msgstr ""
+msgstr "Crea etichette posizionate in maniera ottimale per il vettore(i)"
#: ../vector/v.label.sa/main.c:71
msgid "Name of TrueType font (as listed in the fontcap)"
@@ -32137,15 +32139,15 @@
#: ../vector/v.in.db/main.c:141
#, c-format
msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
-msgstr ""
+msgstr "Il vettoriale di output, tabella <%s> (driver: <%s>, database: <%s>) esiste già"
#: ../vector/v.in.db/main.c:191
msgid "Key column must be integer"
-msgstr ""
+msgstr "La colonna chieva deve essere di tipo intero"
#: ../vector/v.in.db/main.c:199
msgid "x/y/z column must be integer or double"
-msgstr ""
+msgstr "la colonna x/y/z deve essere di tipo intero o double"
#: ../vector/v.in.db/main.c:237
msgid "Unable to copy table"
@@ -32167,15 +32169,15 @@
#: ../vector/v.surf.idw/main.c:100 ../vector/v.surf.idw/main.c:124
msgid "Values"
-msgstr ""
+msgstr "Valori"
#: ../vector/v.surf.idw/main.c:115
msgid "Don't index points by raster cell"
-msgstr ""
+msgstr "Non indicizza punti per cella di raster"
#: ../vector/v.surf.idw/main.c:116
msgid "Slower but uses less memory and includes points from outside region in the interpolation"
-msgstr ""
+msgstr "Più lento ma usa meno memoria e include punti dalla regione esterna nell'interpolazione"
#: ../vector/v.surf.idw/main.c:123 ../vector/v.surf.bspline/main.c:110
msgid "Use z coordinates for approximation (3D vector maps only)"
@@ -32188,7 +32190,7 @@
#: ../vector/v.surf.idw/main.c:135
msgid "No attribute column specified"
-msgstr ""
+msgstr "Non è stata specificata nessuna colonna degli attributi"
#: ../vector/v.surf.idw/main.c:251
#, c-format
@@ -32284,7 +32286,7 @@
#: ../vector/v.drape/main.c:158
msgid "Elevation raster map for height extraction"
-msgstr ""
+msgstr "Raster di elevazione da cui estrarre la quota"
#: ../vector/v.drape/main.c:172
#, fuzzy
@@ -32303,23 +32305,23 @@
#: ../vector/v.drape/main.c:176
msgid "Sampling method"
-msgstr ""
+msgstr "Metodo di campionamento"
#: ../vector/v.drape/main.c:181
msgid "Scale sampled raster values"
-msgstr ""
+msgstr "Valori raster campionati su una scala"
#: ../vector/v.drape/main.c:189
msgid "Vector Z value for unknown height"
-msgstr ""
+msgstr "Valori Z del vettore per altezza non nota"
#: ../vector/v.drape/main.c:191
msgid "Will set Z to this value, if value from raster map can not be read"
-msgstr ""
+msgstr "Imposterà Z su questo valore, se il valore non può essere letto dal raster"
#: ../vector/v.drape/main.c:267
msgid "No features match Your query"
-msgstr ""
+msgstr "Nessuna caratteristica soddisfa la tua richiesta"
#: ../vector/v.drape/main.c:368 ../vector/v.drape/main.c:378
msgid "Due to error attribute data to new map are not transferred"
@@ -32776,16 +32778,16 @@
#: ../vector/v.to.rast/support.c:176
#, c-format
msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
+msgstr "Errore nella colonna di definizione del colore (%s) con cat %d: colorstring [%s]"
#: ../vector/v.to.rast/support.c:179
msgid "Color set to [200:200:200]"
-msgstr ""
+msgstr "Colore impostato su [200:200:200]"
#: ../vector/v.to.rast/support.c:184
#, c-format
msgid "Error in color definition column (%s), with cat %d"
-msgstr ""
+msgstr "Errore nella colonna di definizione del colore (%s), con cat %d"
#: ../vector/v.to.rast/support.c:273
msgid "Label column was not specified, no labels will be written"
@@ -32813,7 +32815,7 @@
#: ../vector/v.to.rast/vect2rast.c:71
#, c-format
msgid "Column type (%s) not supported (did you mean 'labelcolumn'?)"
-msgstr ""
+msgstr "Il tipo (%s) della colonna non è supportato (volevi dire 'labelcolumn')"
#: ../vector/v.to.rast/vect2rast.c:101
#, c-format
@@ -32837,12 +32839,12 @@
#: ../vector/v.to.rast/vect2rast.c:162
#, c-format
msgid "Problem processing areas from vector map <%s>, continuing..."
-msgstr ""
+msgstr "Problema nel processare aree dal vettoriale <%s>, proseguo..."
#: ../vector/v.to.rast/vect2rast.c:174
#, c-format
msgid "Problem processing lines from vector map <%s>, continuing..."
-msgstr ""
+msgstr "Problema nel processare linee dal vettoriale <%s>, proseguo..."
#: ../vector/v.to.rast/vect2rast.c:199
msgid "Creating support files for raster map..."
@@ -32873,7 +32875,7 @@
#: ../vector/v.to.rast/main.c:72
msgid "Source of raster values"
-msgstr ""
+msgstr "Sorgente per i calori raster"
#: ../vector/v.to.rast/main.c:76
#, fuzzy
@@ -32906,7 +32908,7 @@
#: ../vector/v.to.rast/main.c:92
msgid "Name of color definition column (with RRR:GGG:BBB entries)"
-msgstr ""
+msgstr "Nome per la colonna di definizione del colore (con valori di tipo RRR:GGG:BBB)"
#: ../vector/v.to.rast/main.c:98
msgid "Name of column used as raster category labels"
@@ -32944,7 +32946,7 @@
#: ../vector/v.to.rast/do_lines.c:133
#, c-format
msgid "%d lines with varying height were not written to raster"
-msgstr ""
+msgstr "le linee %d con altezza variabile non erano scritte sul raster"
#: ../vector/v.to.rast/do_areas.c:50 ../vector/v.to.rast/do_areas.c:58
#, c-format
@@ -34417,11 +34419,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
msgid "Theme"
-msgstr ""
+msgstr "Tema"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
msgid "Thematic divisions of data for display"
-msgstr ""
+msgstr "Divisioni tematiche dei dati per la visualizzazione"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
msgid "Break points for custom breaks option"
@@ -34441,27 +34443,27 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
+msgstr "Larghezza minima per la dimensione dell'icona/linea per punti/linee graduati"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
+msgstr "Larghezza massima per la dimensione dell'icona/linea per punti/linee graduati"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
msgid "Number of classes for interval theme (integer)"
-msgstr ""
+msgstr "Numero di classi per tema intervallo (intero)"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
msgid "Color scheme for graduated color mapping"
-msgstr ""
+msgstr "Schema di colori per mappatura a colori graduati"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:25
msgid "Select 'single_color' for graduated point/line display"
-msgstr ""
+msgstr "Seleziona 'single_color' per la visualizzazione graduata di punti/linee"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
msgid "Color for graduated points map"
-msgstr ""
+msgstr "Colore per mappa di punti graduata"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
@@ -34473,11 +34475,11 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr ""
+msgstr "Nome colore GRASS o tripletta R:G:B. Imposta lo schema colori su un colore singolo."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
msgid "Beginning color for custom color gradient"
-msgstr ""
+msgstr "Colore iniziale per il gradiente di colore personalizzato"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
@@ -34486,7 +34488,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:36
msgid "Ending color for custom color gradient"
-msgstr ""
+msgstr "Colore finale per il gradiente di colore personalizzato"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:39
msgid "Select WXGUI display monitor for legend"
@@ -34502,7 +34504,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:46
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:48
msgid "Files"
-msgstr ""
+msgstr "File"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
msgid "Save thematic map commands to group file for GIS Manager"
@@ -34538,7 +34540,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
msgid "Use math notation brackets in legend"
-msgstr ""
+msgstr "Usa le parentesi con notazione matematica nella legenda"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
#: ../locale/scriptstrings/r.plane_to_translate.c:3
@@ -34555,7 +34557,7 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
+msgstr "Fattore di scale per converire le unità orizzontale in unità verticali"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:11
@@ -34565,7 +34567,7 @@
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:10
msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
+msgstr "Imposta il fattore di scala (si applica solo a location lat./long., se nessuno: scala=1)"
#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
#, fuzzy
@@ -34583,11 +34585,11 @@
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
msgid "Color using standard deviation bands"
-msgstr ""
+msgstr "Colora usando le bande di deviazione standard"
#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
msgid "Force center at zero"
-msgstr ""
+msgstr "Forza il centro su zero"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
#, fuzzy
@@ -34801,11 +34803,11 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
msgid "Allows to join a table to a vector map table."
-msgstr ""
+msgstr "Permette di unire una tabella ad una tabella di una mappa vettoriale."
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
msgid "Vector map to which to join other table"
-msgstr ""
+msgstr "Mappa vettoriale alla quale unire un'altra tabella"
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
msgid "layer,column"
@@ -34813,7 +34815,7 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:7
msgid "Layer where to join"
-msgstr ""
+msgstr "Layer sul quale unire"
#: ../locale/scriptstrings/v.db.join_to_translate.c:8
#, fuzzy
@@ -34991,7 +34993,7 @@
#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
msgid "Create a 3D line from 3 column data"
-msgstr ""
+msgstr "Crea una linea 3D da 3 colonne di dati"
#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
msgid "Name of input file (or \"-\" to read from stdin)"
@@ -35027,7 +35029,7 @@
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
msgid "Drops a column from the attribute table connected to a given vector map."
-msgstr ""
+msgstr "Elimina una colonna dalla tabella attributi connessa a una data mappa vettoriale."
#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
#, fuzzy
@@ -36099,11 +36101,11 @@
#: ../locale/scriptstrings/r.tileset_to_translate.c:6
msgid "Name of region to use instead of current region for bounds and resolution"
-msgstr ""
+msgstr "Nome della regione da usare invece di quella corrente per bordi e risoluzione"
#: ../locale/scriptstrings/r.tileset_to_translate.c:7
msgid "Source projection"
-msgstr ""
+msgstr "Proiezione della sorgente"
#: ../locale/scriptstrings/r.tileset_to_translate.c:8
#: ../locale/scriptstrings/r.tileset_to_translate.c:10
@@ -36169,7 +36171,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
+msgstr "Nome della regione da cui richiedere i dati. Se omesso, viene usata la regione corrente"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
msgid "WMS standard"
@@ -36181,7 +36183,7 @@
#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
msgid "Reprojection method to use"
-msgstr ""
+msgstr "Metodo di riproiezione da usare"
#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
msgid "Maximum columns to request at a time"
@@ -39989,7 +39991,7 @@
#~ msgstr "La password è stata archiviata nel file"
#~ msgid "Resizes active display monitor"
-#~ msgstr "Ridimensiona il monitor attivo visualizzato"
+#~ msgstr "Ridimensiona il monitor di visualizzazione attivo"
#~ msgid "Display the HTML man pages of GRASS"
#~ msgstr "Visualizza la pagina di supporto HTML di GRASS "
@@ -40007,7 +40009,7 @@
#~ msgstr "Nuovo schema"
#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "Salva il monitor attivo visualizzato in un file PNG nella directory home"
+#~ msgstr "Salva il monitor di visualizzazione attivo in un file PNG nella directory home"
#~ msgid "Name of PNG file"
#~ msgstr "Nome del file PNG"
@@ -41390,3 +41392,168 @@
#~ msgid "Error while reading input raster map."
#~ msgstr "Errore durante la lettura del raster di input."
+#~ msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
+#~ msgstr "Non sono stati forniti dati raster 3D, mappe vettoriali RGB o xyz. Verrà scritta solo la geometria"
+#~ msgid ""
+#~ "Sorry, if any of the following options are set:\n"
+#~ " basin, stream, half.basin, length.slope, or slope.steepness\n"
+#~ " you MUST provide a value for the basin threshold parameter."
+#~ msgstr ""
+#~ "Spiacente, se non è impostata nessuna delle opzioni seguenti:\n"
+#~ " allora DEVI fornire un valore per il parametro di soglia del bacino."
+#~ msgid "Could not read east bufferzone size. Aborting."
+#~ msgstr "Impossibile leggere la dimensione est della zona di buffer. L'operazione verrà interrotta."
+#~ msgid "Could not read west bufferzone size. Aborting."
+#~ msgstr "Impossibile leggere la dimensione ovest della zona di buffer. L'operazione verrà interrotta."
+#~ msgid "Could not read south bufferzone size. Aborting."
+#~ msgstr "Impossibile leggere la dimensione sud della zona di buffer. L'operazione verrà interrotta."
+#~ msgid "Could not read north bufferzone size. Aborting."
+#~ msgstr "Impossibile leggere la dimensione nord della zona di buffer. L'operazione verrà interrotta."
+#~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+#~ msgstr "Calcolando la mappa %01d di %01d (angolo %lf, raster <%s>)"
+#~ msgid "Setting window header"
+#~ msgstr "Impostando l'intestazione della finestra"
+#~ msgid ""
+#~ "\n"
+#~ "\n"
+#~ "Use mouse to choose action"
+#~ msgstr ""
+#~ "\n"
+#~ "\n"
+#~ "Usa il mouse per selezionare l'azione"
+#~ msgid "** no %s files found **\n"
+#~ msgstr "** file %s non trovati **\n"
+#~ msgid "Click here to CONTINUE\n"
+#~ msgstr "Clicca qui per CONTINUARE\n"
+#~ msgid "Display information about the active display monitor"
+#~ msgstr "Mostra informazioni riguardo il monitor di visualizzazione attivo"
+#~ msgid "Use mouse to interactively place scale"
+#~ msgstr "Usa il mouse per posizionare la scala in maniera interattiva"
+#~ msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
+#~ msgstr "Le coordinate di schermo per l'angolo in alto a sinistra dell'etichetta ([0,0] è il punto in alto a sinistra della cornice)"
+#~ msgid "Erase the contents of the active display frame with user defined color"
+#~ msgstr "Sostitisce i contenuti della cornice di display attiva con il colore definito dall'utente"
+#~ msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+#~ msgstr "Colore col il quale sostituire, o un colore standard GRASS o una tripletta R:G:B (separate da colonne)"
+#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+#~ msgstr "Converte un layer vettoriale GRASS binario (solo punti) in un GRASS layer raster 3D."
+#~ msgid "Column name (type must be numeric)"
+#~ msgstr "Nome della colonna (il tipo deve essere numerico)"
+#~ msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+#~ msgstr "Impossibile caricare i pesi per la sovrapposizione. La colonna %s nella tabella <%s> non è di tipo numerico"
+#~ msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
+#~ msgstr "Colonna numerica cui dare la precedenza in caso di etichette sovrapposte. L'etichetta con peso minore viene nascosta."
+#~ msgid "%s: Unable to read font definition file; use the default"
+#~ msgstr "%s: Impossibile leggere il file di definizione del tipo di carattere; usa il default"
+#~ msgid "%s: No font definition file"
+#~ msgstr "%s: Nessun file di definizione"
+#~ msgid "If set to 0, z coordinates are used (3D vector only)"
+#~ msgstr "Se impostato su 0, vengono usate le coordinate z (solo vettori 3D)"
+#~ msgid "Required if layer > 0"
+#~ msgstr "RIchiesto se layer > 0"
+#~ msgid "Power parameter; greater values assign greater influence to closer points"
+#~ msgstr "Parametro di potenza; valori maggiori assegnano maggiore influenza a punti più vicini"
+#~ msgid "No data points found"
+#~ msgstr "Non sono stati trovati punti di dati"
+#~ msgid "vector, raster, conversion"
+#~ msgstr "vettore, raster, conversione"
+#~ msgid "Select x11 display monitor for legend"
+#~ msgstr "Seleziona il monitor display x11 per la legenda"
+#~ msgid "Drops a column from selected attribute table"
+#~ msgstr "Elimina una colonna da una tabella attributi selezionata"
+#~ msgid "Table from which to drop attribute column"
+#~ msgstr "Tabella dalla quale eliminare la colonna atributi"
+#~ msgid "Redraws the current display frame in the GRASS monitor"
+#~ msgstr "Ridisegna la cornice di visualazzione corrente nel monitor GRASS"
+#~ msgid "Redraw all frames"
+#~ msgstr "Ridisegna tutte le cornici"
+#~ msgid "Join column in map table"
+#~ msgstr "Colonna di unione nella tabella della mappa"
+#~ msgid "Number of seconds to pause between slides"
+#~ msgstr "Numero di secondi di pausa tra slide"
+#~ msgid "Import ASCII x,y[,z] coordinates as a series of lines."
+#~ msgstr "Importa coordinate ASCII x,y[,z] come una serie di linee."
+#~ msgid "LANDSAT red channel"
+#~ msgstr "Canale LANDSAT rosso"
+#~ msgid "LANDSAT green channel"
+#~ msgstr "Canale LANDSAT verde"
+#~ msgid "LANDSAT blue channel"
+#~ msgstr "Canale LANDSAT blu"
+#~ msgid "Width in pixels of new display monitor"
+#~ msgstr "Larghezza in pixel del nuovo monitor di visualizzazione"
+#~ msgid "Height in pixels of new display monitor"
+#~ msgstr "Altezza in pixel del nuovo monitor di visualizzazione"
+#~ msgid "Table to drop"
+#~ msgstr "Tabella da eliminare"
+#~ msgid "Vector map for which to drop attribute column"
+#~ msgstr "Mappa vettoriale per la quale eliminare una colonna attributi"
+#~ msgid "Layer where to drop column"
+#~ msgstr "Layer in cui eliminare la colonna"
+#~ msgid "Layer from which to drop linked attribute table"
+#~ msgstr "Layer dal quale eliminare la tabella attributi collegata"
+#~ msgid "Split the display into subframes."
+#~ msgstr "Separa il display in sottocornici."
+#~ msgid "Number of subframes"
+#~ msgstr "Numero di sottocornici"
+#~ msgid "Split horizontally not vertically"
+#~ msgstr "Separa orizzontalmente non verticalmente"
+#~ msgid "Prints a graph of the correlation between data layers (in pairs)."
+#~ msgstr "Stampa un grafico della correlazione tra layer di dati (in coppie)"
+#~ msgid "calculates univariate statistics from a GRASS raster map"
+#~ msgstr "calcola statistica univariata da una mappa raster GRASS"
+#~ msgid "extended statistics (quartiles and percentile)"
+#~ msgstr "statistica estesa (quartili e percentile)"
+#~ msgid "Verbosity level"
+#~ msgstr "Livello di verbosità"
