[GRASS-SVN] r55827 - in grass/trunk/gui/wxpython: animation core
svn_grass at osgeo.org
Tue Apr 16 00:51:09 PDT 2013
Author: annakrat
Date: 2013-04-16 00:51:09 -0700 (Tue, 16 Apr 2013)
New Revision: 55827
grass/trunk/gui/wxpython/animation/controller.py
grass/trunk/gui/wxpython/animation/frame.py
grass/trunk/gui/wxpython/animation/mapwindow.py
grass/trunk/gui/wxpython/core/gconsole.py
wxGUI/animation: apply patch by Soeren Gebbert (#1926 parallel rendering)
Modified: grass/trunk/gui/wxpython/animation/controller.py
--- grass/trunk/gui/wxpython/animation/controller.py 2013-04-16 07:36:07 UTC (rev 55826)
+++ grass/trunk/gui/wxpython/animation/controller.py 2013-04-16 07:51:09 UTC (rev 55827)
@@ -138,7 +138,6 @@
win.DrawBitmap(bitmap, dataId)
# self.frame.SetStatusText(dataId)
self.slider.UpdateFrame(index)
- self.UpdateReloadStatus()
def SliderChanging(self, index):
if self.runAfterReleasingSlider is None:
@@ -302,7 +301,6 @@
self._updateSlider(timeLabels = timeLabels)
self._updateAnimations(activeIndices = indices, mapNamesDict = mapNamesDict)
- self._updateRegion()
self._updateBitmapData()
# if running:
# self.PauseAnimation(False)
@@ -310,8 +308,6 @@
# else:
self.EndAnimation()
def _updateSlider(self, timeLabels = None):
if self.temporalMode == TemporalMode.NONTEMPORAL:
self.frame.SetSlider('nontemporal')
@@ -433,35 +429,12 @@
def Reload(self):
self.EndAnimation()
activeIndices = [anim.windowIndex for anim in self.animationData]
for index in activeIndices:
self.bitmapProviders[index].Load(force = True)
self.EndAnimation()
- def UpdateReloadStatus(self):
- activeIndices = [anim.windowIndex for anim in self.animationData]
- for i, win in enumerate(self.mapwindows):
- if i in activeIndices and win.IsRescaled():
- self.frame.SetStatusText(_("Reload recommended"), 1)
- return
- self.frame.SetStatusText('', 1)
- def _updateRegion(self):
- grassRegion = grass.region()
- for anim in self.animationData:
- if anim.viewMode == '2d':
- self.mapwindows[anim.windowIndex].SetRegion(grassRegion)
- else:
- loadSize = self.bitmapProviders[anim.windowIndex].GetLoadSize() or \
- self.mapwindows[anim.windowIndex].GetClientSize()
- region = {}
- region['cols'], region['rows'] = loadSize
- self.mapwindows[anim.windowIndex].SetRegion(region)
def Export(self):
if not self.animationData:
GMessage(parent = self.frame, message = _("No animation to export."))
Modified: grass/trunk/gui/wxpython/animation/frame.py
--- grass/trunk/gui/wxpython/animation/frame.py 2013-04-16 07:36:07 UTC (rev 55826)
+++ grass/trunk/gui/wxpython/animation/frame.py 2013-04-16 07:51:09 UTC (rev 55827)
@@ -64,8 +64,9 @@
providers = self.providers,
bitmapPool = bitmapPool)
for win, provider in zip(self.windows, self.providers):
- win.Bind(wx.EVT_SIZE, lambda event, prov = provider,
- sizeMethod = win.GetClientSize: prov.WindowSizeChanged(event, sizeMethod))
+ win.Bind(wx.EVT_SIZE, lambda event, provider=provider,
+ sizeMethod=win.GetClientSize: self.FrameSizeChanged(event, provider, sizeMethod))
+ provider.mapsLoaded.connect(lambda: self.SetStatusText(''))
self.InitStatusbar()
self._mgr = wx.aui.AuiManager(self)
@@ -88,8 +89,7 @@
def InitStatusbar(self):
"""!Init statusbar."""
- statusbar = self.CreateStatusBar(number = 2, style = 0)
- statusbar.SetStatusWidths([-3, -2])
+ self.CreateStatusBar(number = 1, style = 0)
def _addPanes(self):
self._mgr.AddPane(self.animationPanel, wx.aui.AuiPaneInfo().CentrePane().
@@ -229,6 +229,13 @@
def OnExportAnimation(self, event):
self.controller.Export()
+ def FrameSizeChanged(self, event, provider, sizeMethod):
+ provider.WindowSizeChanged(*sizeMethod())
+ if self.animationPanel.shown:
+ self.SetStatusText(_("Window size has changed, rerender maps if needed"))
+ event.Skip()
def OnHelp(self, event):
RunCommand('g.manual',
quiet = True,
Modified: grass/trunk/gui/wxpython/animation/mapwindow.py
--- grass/trunk/gui/wxpython/animation/mapwindow.py 2013-04-16 07:36:07 UTC (rev 55826)
+++ grass/trunk/gui/wxpython/animation/mapwindow.py 2013-04-16 07:51:09 UTC (rev 55827)
@@ -18,12 +18,14 @@
import os
import wx
+from multiprocessing import Process, Queue
+import tempfile
import grass.script as grass
from core.gcmd import RunCommand
from core.debug import Debug
-from utils import ComputeScaledRect
+from grass.pydispatch.signal import Signal
class BufferedWindow(wx.Window):
A Buffered window class (http://wiki.wxpython.org/DoubleBufferedDrawing).
@@ -106,11 +108,7 @@
Debug.msg(2, "AnimationWindow.__init__()")
self.bitmap = wx.EmptyBitmap(1, 1)
- self.x = self.y = 0
self.text = ''
- self.size = wx.Size()
- self.rescaleNeeded = False
- self.region = None
self.parent = parent
BufferedWindow.__init__(self, parent = parent, id = id, style = style)
@@ -124,88 +122,46 @@
Debug.msg(5, "AnimationWindow.Draw()")
dc.Clear() # make sure you clear the bitmap!
- dc.DrawBitmap(self.bitmap, x = self.x, y = self.y)
+ dc.DrawBitmap(self.bitmap, x=0, y=0)
dc.DrawText(self.text, 0, 0)
def OnSize(self, event):
Debug.msg(5, "AnimationWindow.OnSize()")
- self._computeBitmapCoordinates()
self.DrawBitmap(self.bitmap, self.text)
BufferedWindow.OnSize(self, event)
if event:
event.Skip()
- def IsRescaled(self):
- return self.rescaleNeeded
- def _rescaleIfNeeded(self, bitmap):
- """!If the bitmap has different size than the window, rescale it."""
- bW, bH = bitmap.GetSize()
- wW, wH = self.size
- if abs(bW - wW) > 5 and abs(bH - wH) > 5:
- self.rescaleNeeded = True
- im = wx.ImageFromBitmap(bitmap)
- im.Rescale(*self.size)
- bitmap = wx.BitmapFromImage(im)
- else:
- return bitmap
def DrawBitmap(self, bitmap, text):
"""!Draws bitmap.
Does not draw the bitmap if it is the same one as last time.
- bmp = self._rescaleIfNeeded(bitmap)
- if self.bitmap == bmp:
+ if self.bitmap == bitmap:
return
- self.bitmap = bmp
+ self.bitmap = bitmap
self.text = text
self.UpdateDrawing()
- def _computeBitmapCoordinates(self):
- """!Computes where to place the bitmap
- to be in the center of the window."""
- if not self.region:
- return
- cols = self.region['cols']
- rows = self.region['rows']
- params = ComputeScaledRect((cols, rows), self.GetClientSize())
- self.x = params['x']
- self.y = params['y']
- self.size = (params['width'], params['height'])
- def SetRegion(self, region):
- """!Sets region for size computations.
- Region is set from outside to avoid calling g.region multiple times.
- self.region = region
- def GetAdjustedSize(self):
- return self.size
- def GetAdjustedPosition(self):
- return self.x, self.y
class BitmapProvider(object):
"""!Class responsible for loading data and providing bitmaps"""
- def __init__(self, frame, bitmapPool):
+ def __init__(self, frame, bitmapPool, imageWidth=640, imageHeight=480, nprocs=4):
self.datasource = None
self.dataNames = None
self.dataType = None
self.bitmapPool = bitmapPool
self.frame = frame
- self.loadSize = wx.Size()
+ self.imageWidth = imageWidth # width of the image to render with d.rast or d.vect
+ self.imageHeight = imageHeight # height of the image to render with d.rast or d.vect
+ self.nprocs = nprocs # Number of procs to be used for rendering
self.suffix = ''
self.nvizRegion = None
+ self.mapsLoaded = Signal('mapsLoaded')
def GetDataNames(self):
return self.dataNames
@@ -245,22 +201,17 @@
bitmap = self.bitmapPool[None]
return bitmap
- def GetLoadSize(self):
- return self.loadSize
- def WindowSizeChanged(self, event, sizeMethod):
+ def WindowSizeChanged(self, width, height):
"""!Sets size when size of related window changes."""
- # sizeMethod is GetClientSize, must be used instead of GetSize
- self.size = sizeMethod()
- event.Skip()
+ self.imageWidth, self.imageHeight = width, height
- def _createNoDataBitmap(self, ncols, nrows):
+ def _createNoDataBitmap(self, width, height):
"""!Creates 'no data' bitmap.
Used when requested bitmap is not available (loading data was not successful) or
we want to show 'no data' bitmap.
- bitmap = wx.EmptyBitmap(ncols, nrows)
+ bitmap = wx.EmptyBitmap(width, height)
dc = wx.MemoryDC()
dc.SelectObject(bitmap)
dc.Clear()
@@ -268,7 +219,7 @@
dc.SetFont(wx.Font(pointSize = 40, family = wx.FONTFAMILY_SCRIPT,
style = wx.FONTSTYLE_NORMAL, weight = wx.FONTWEIGHT_BOLD))
tw, th = dc.GetTextExtent(text)
- dc.DrawText(text, (ncols-tw)/2, (nrows-th)/2)
+ dc.DrawText(text, (width-tw)/2, (height-th)/2)
dc.SelectObject(wx.NullBitmap)
return bitmap
@@ -294,30 +245,22 @@
else:
updateFunction = None
- if self.dataType == 'rast':
- size, scale = self._computeScale()
- # loading ...
- self._loadRasters(rasters = self.datasource, names = self.dataNames,
- size = size, scale = scale, force = force, updateFunction = updateFunction)
+ if self.dataType == 'rast' or self.dataType == 'vect':
+ self._loadMaps(mapType=self.dataType, maps = self.datasource, names = self.dataNames,
+ force = force, updateFunction = updateFunction)
elif self.dataType == 'nviz':
self._load3D(commands = self.datasource, region = self.nvizRegion, names = self.dataNames,
if progress:
progress.Destroy()
+ self.mapsLoaded.emit()
def Unload(self):
- def _computeScale(self):
- """!Computes parameters for creating bitmaps."""
- region = grass.region()
- ncols, nrows = region['cols'], region['rows']
- params = ComputeScaledRect((ncols, nrows), self.size)
- return ((params['width'], params['height']), params['scale'])
def _dryLoad(self, rasters, names, force):
"""!Tries how many bitmaps will be loaded.
Used for progress dialog.
@@ -336,54 +279,75 @@
return count, maxLength
- def _loadRasters(self, rasters, names, size, scale, force, updateFunction):
- """!Loads rasters (also rasters from temporal dataset).
+ def _loadMaps(self, mapType, maps, names, force, updateFunction):
+ """!Loads rasters/vectors (also from temporal dataset).
- Uses r.out.ppm.
+ Uses d.rast/d.vect and multiprocessing for parallel rendering
- @param rasters raster maps to be loaded
+ @param mapType Must be "rast" or "vect"
+ @param maps raster or vector maps to be loaded
@param names names used as keys for bitmaps
- @param size size of new bitmaps
- @param scale used for adjustment of region resolution for r.out.ppm
@param force load everything even though it is already there
@param updateFunction function called for updating progress dialog
- for key in ('rows', 'cols', 'cells'):
- region.pop(key)
- # sometimes it renderes nonsense - depends on resolution
- # should we set the resolution of the raster?
- region['nsres'] /= scale
- region['ewres'] /= scale
- os.environ['GRASS_REGION'] = grass.region_env(**region)
- ncols, nrows = size
- self.loadSize = size
count = 0
+ # Variables for parallel rendering
+ proc_count = 0
+ proc_list = []
+ queue_list = []
+ name_list = []
+ mapNum = len(maps)
# create no data bitmap
if None not in self.bitmapPool or force:
- self.bitmapPool[None] = self._createNoDataBitmap(ncols, nrows)
- for raster, name in zip(rasters, names):
+ self.bitmapPool[None] = self._createNoDataBitmap(self.imageWidth, self.imageHeight)
+ for mapname, name in zip(maps, names):
+ count += 1
if name in self.bitmapPool and force is False:
continue
- count += 1
- # RunCommand has problem with DecodeString
- returncode, stdout, messages = read2_command('r.out.ppm', input = raster,
- flags = 'h', output = '-', quiet = True)
- if returncode != 0:
- self.bitmapPool[name] = wx.EmptyBitmap(ncols, nrows)
- continue
- bitmap = wx.BitmapFromBuffer(ncols, nrows, stdout)
- self.bitmapPool[name] = bitmap
+ # Queue object for interprocess communication
+ q = Queue()
+ # The separate render process
+ p = Process(target=mapRenderProcess, args=(mapType, mapname, self.imageWidth, self.imageHeight, q))
+ p.start()
+ queue_list.append(q)
+ proc_list.append(p)
+ name_list.append(name)
+ proc_count += 1
+ # Wait for all running processes and read/store the created images
+ if proc_count == self.nprocs or count == mapNum:
+ for i in range(len(name_list)):
+ proc_list[i].join()
+ filename = queue_list[i].get()
+ # Unfortunately the png files must be read here,
+ # since the swig wx objects can not be serialized by the Queue object :(
+ if filename == None:
+ self.bitmapPool[name_list[i]] = wx.EmptyBitmap(self.imageWidth, self.imageHeight)
+ else:
+ self.bitmapPool[name_list[i]] = wx.BitmapFromImage(wx.Image(filename))
+ os.remove(filename)
+ proc_count = 0
+ proc_list = []
+ queue_list = []
+ name_list = []
if updateFunction:
- keepGoing, skip = updateFunction(count, raster)
+ keepGoing, skip = updateFunction(count, mapname)
if not keepGoing:
break
- os.environ.pop('GRASS_REGION')
def _load3D(self, commands, region, names, force, updateFunction):
"""!Load 3D view images using m.nviz.image.
@@ -393,8 +357,7 @@
- ncols, nrows = self.size
- self.loadSize = ncols, nrows
+ ncols, nrows = self.imageWidth, self.imageHeight
count = 0
format = 'ppm'
tempFile = grass.tempfile(False)
@@ -419,7 +382,6 @@
if returncode != 0:
continue
self.bitmapPool[name] = wx.Bitmap(tempFileFormat)
@@ -430,6 +392,43 @@
grass.try_remove(tempFileFormat)
+def mapRenderProcess(mapType, mapname, width, height, fileQueue):
+ """!Render raster or vector files as png image and write the
+ resulting png filename in the provided file queue
+ @param mapname raster or vector map name to be rendered
+ @param width Width of the resulting image
+ @param height Height of the resulting image
+ @param fileQueue The inter process communication queue storing the file name of the image
+ # temporary file, we use python here to avoid calling g.tempfile for each render process
+ fileHandler, filename = tempfile.mkstemp(suffix=".png")
+ os.close(fileHandler)
+ # Set the environment variables for this process
+ os.environ['GRASS_WIDTH'] = str(width)
+ os.environ['GRASS_HEIGHT'] = str(height)
+ os.environ['GRASS_RENDER_IMMEDIATE'] = "png"
+ os.environ['GRASS_TRUECOLOR'] = "1"
+ os.environ['GRASS_TRANSPARENT'] = "1"
+ os.environ['GRASS_PNGFILE'] = str(filename)
+ if mapType == "rast":
+ Debug.msg(1, "Render raster image " + str(filename))
+ returncode, stdout, messages = read2_command('d.rast', map = mapname)
+ else:
+ Debug.msg(1, "Render vector image " + str(filename))
+ returncode, stdout, messages = read2_command('d.vect', map = mapname)
+ if returncode != 0:
+ fileQueue.put(None)
+ return
+ fileQueue.put(filename)
class BitmapPool():
"""!Class storing bitmaps (emulates dictionary)"""
def __init__(self):
@@ -459,4 +458,4 @@
kwargs['stderr'] = grass.PIPE
ps = grass.start_command(*args, **kwargs)
stdout, stderr = ps.communicate()
- return ps.returncode, stdout, stderr
\ No newline at end of file
+ return ps.returncode, stdout, stderr
Modified: grass/trunk/gui/wxpython/core/gconsole.py
--- grass/trunk/gui/wxpython/core/gconsole.py 2013-04-16 07:36:07 UTC (rev 55826)
+++ grass/trunk/gui/wxpython/core/gconsole.py 2013-04-16 07:51:09 UTC (rev 55827)
@@ -229,6 +229,9 @@
self.receiver = receiver
+ def flush(self):
+ pass
def write(self, s):
if len(s) == 0 or s == '\n':
return
