[GRASS-SVN] r55828 - in grass/trunk: lib/python/temporal temporal/t.rast.neighbors temporal/t.support temporal/t.unregister
svn_grass at osgeo.org
Tue Apr 16 01:31:10 PDT 2013
Author: huhabla
Date: 2013-04-16 01:31:10 -0700 (Tue, 16 Apr 2013)
New Revision: 55828
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
grass/trunk/temporal/t.support/t.support.py
grass/trunk/temporal/t.unregister/t.unregister.py
Massive speed gain by removing verbose and percent messages.
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-04-16 07:51:09 UTC (rev 55827)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-04-16 08:31:10 UTC (rev 55828)
@@ -506,8 +506,9 @@
if self.get_stds_register() is not None:
statement += "DROP TABLE " + self.get_stds_register() + ";\n"
- core.verbose(_("Delete %s dataset <%s> from temporal database")
- % (self.get_type(), self.get_id()))
+ # Commented because of performance issue calling g.message thousend times
+ #core.verbose(_("Delete %s dataset <%s> from temporal database")
+ # % (self.get_type(), self.get_id()))
# Delete yourself from the database, trigger functions will
# take care of dependencies
@@ -545,15 +546,16 @@
@return The SQL statements if execute == False, else an empty string
- if self.get_layer() is not None:
- core.verbose(_("Unregister %(type)s map <%(map)s> with "
- "layer %(layer)s from space time datasets" % \
- {'type':self.get_type(), 'map':self.get_map_id(),
- 'layer':self.get_layer()}))
- else:
- core.verbose(_("Unregister %(type)s map <%(map)s> "
- "from space time datasets"
- % {'type':self.get_type(), 'map':self.get_map_id()}))
+ #if self.get_layer() is not None:
+ # core.verbose(_("Unregister %(type)s map <%(map)s> with "
+ # "layer %(layer)s from space time datasets" % \
+ # {'type':self.get_type(), 'map':self.get_map_id(),
+ # 'layer':self.get_layer()}))
+ #else:
+ # core.verbose(_("Unregister %(type)s map <%(map)s> "
+ # "from space time datasets"
+ # % {'type':self.get_type(), 'map':self.get_map_id()}))
statement = ""
dbif, connect = init_dbif(dbif)
@@ -563,11 +565,7 @@
# For each stds in which the map is registered
if rows is not None:
- count = 0
- num_sps = len(rows)
for row in rows:
- core.percent(count, num_sps, 1)
- count += 1
# Create a space time dataset object to remove the map
# from its register
stds = self.get_new_stds_instance(row["id"])
@@ -578,8 +576,6 @@
if update == True and execute == True:
stds.update_from_registered_maps(dbif)
- core.percent(1, 1, 1)
if execute:
dbif.execute_transaction(statement)
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-16 07:51:09 UTC (rev 55827)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-16 08:31:10 UTC (rev 55828)
@@ -1115,16 +1115,11 @@
rows = self.get_registered_maps("id", None, None, dbif)
# Unregister each registered map in the table
- num_maps = len(rows)
- count = 0
for row in rows:
- core.percent(count, num_maps, 1)
# Unregister map
map = self.get_new_map_instance(row["id"])
statement += self.unregister_map(
map=map, dbif=dbif, execute=False)
- count += 1
# Safe the DROP table statement
statement += "DROP TABLE " + self.get_map_register() + ";\n"
@@ -1163,17 +1158,18 @@
dbif.close()
core.fatal(_("Only maps with absolute or relative valid time can "
"be registered"))
- if map.get_layer():
- core.verbose(_("Register %s map <%s> with layer %s in space "
- "time %s dataset <%s>") % (map.get_type(),
- map.get_map_id(),
- map.get_layer(),
- map.get_type(),
- self.get_id()))
- else:
- core.verbose(_("Register %s map <%s> in space time %s "
- "dataset <%s>") % (map.get_type(), map.get_map_id(),
- map.get_type(), self.get_id()))
+ #if map.get_layer():
+ # core.verbose(_("Register %s map <%s> with layer %s in space "
+ # "time %s dataset <%s>") % (map.get_type(),
+ # map.get_map_id(),
+ # map.get_layer(),
+ # map.get_type(),
+ # self.get_id()))
+ #else:
+ # core.verbose(_("Register %s map <%s> in space time %s "
+ # "dataset <%s>") % (map.get_type(), map.get_map_id(),
+ # map.get_type(), self.get_id()))
# First select all data from the database
map.select(dbif)
@@ -1223,9 +1219,10 @@
self.set_relative_time_unit(map_rel_time_unit)
statement += self.relative_time.get_update_all_statement_mogrified(
dbif)
- core.verbose(_("Set temporal unit for space time %s dataset "
- "<%s> to %s") % (map.get_type(), self.get_id(),
- map_rel_time_unit))
+ #core.verbose(_("Set temporal unit for space time %s dataset "
+ # "<%s> to %s") % (map.get_type(), self.get_id(),
+ # map_rel_time_unit))
stds_rel_time_unit = self.get_relative_time_unit()
@@ -1303,15 +1300,16 @@
map.set_stds_register(map_register_table)
statement += map.metadata.get_update_statement_mogrified(dbif)
- core.verbose(_("Created register table <%s> for "
- "%s map <%s> with layer %s") %
- (map_register_table, map.get_type(),
- map.get_map_id(), map.get_layer()))
- else:
- core.verbose(_("Created register table <%s> for %s map <%s>") %
- map.get_map_id()))
+ # core.verbose(_("Created register table <%s> for "
+ # "%s map <%s> with layer %s") %
+ # (map_register_table, map.get_type(),
+ # map.get_map_id(), map.get_layer()))
+ #else:
+ # core.verbose(_("Created register table <%s> for %s map <%s>") %
+ # map.get_map_id()))
# We need to create the table and register it
if stds_register_table is None:
@@ -1332,9 +1330,10 @@
self.set_map_register(stds_register_table)
statement += self.metadata.get_update_statement_mogrified(dbif)
- core.verbose(_("Created register table <%s> for space "
- (stds_register_table, map.get_type(), self.get_id()))
+ #core.verbose(_("Created register table <%s> for space "
+ # (stds_register_table, map.get_type(), self.get_id()))
# We need to execute the statement at this time
if statement != "":
@@ -1413,12 +1412,13 @@
map_register_table = map.get_stds_register()
stds_register_table = self.get_map_register()
- if map.get_layer() is not None:
- core.verbose(_("Unregister %s map <%s> with layer %s") % \
- (map.get_type(), map.get_map_id(), map.get_layer()))
- else:
- core.verbose(_("Unregister %s map <%s>") % (
- map.get_type(), map.get_map_id()))
+ #if map.get_layer() is not None:
+ # core.verbose(_("Unregister %s map <%s> with layer %s") % \
+ # (map.get_type(), map.get_map_id(), map.get_layer()))
+ #else:
+ # core.verbose(_("Unregister %s map <%s>") % (
+ # map.get_type(), map.get_map_id()))
# Check if the map is registered in the space time raster dataset
if map_register_table is not None:
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2013-04-16 07:51:09 UTC (rev 55827)
+++ grass/trunk/lib/python/temporal/extract.py 2013-04-16 08:31:10 UTC (rev 55828)
@@ -109,7 +109,8 @@
for row in rows:
count += 1
- core.percent(count, num_rows, 1)
+ if count%10 == 0:
+ core.percent(count, num_rows, 1)
map_name = "%s_%i" % (base, count)
@@ -141,18 +142,18 @@
# Add process to the process list
if type == "raster":
- core.verbose(_("Apply r.mapcalc expression: \"%s\"")
- % expr)
+ #core.verbose(_("Apply r.mapcalc expression: \"%s\"")
+ # % expr)
proc_list.append(Process(target=run_mapcalc2d,
args=(expr,)))
elif type == "raster3d":
- core.verbose(_("Apply r3.mapcalc expression: \"%s\"")
- % expr)
+ #core.verbose(_("Apply r3.mapcalc expression: \"%s\"")
+ # % expr)
proc_list.append(Process(target=run_mapcalc3d,
args=(expr,)))
elif type == "vector":
- core.verbose(_("Apply v.extract where statement: \"%s\"")
- % expression)
+ #core.verbose(_("Apply v.extract where statement: \"%s\"")
+ # % expression)
if row["layer"]:
proc_list.append(Process(target=run_vector_extraction,
args=(row["name"] + "@" + \
@@ -208,9 +209,10 @@
count = 0
for row in rows:
count += 1
+ if count%10 == 0:
old_map = sp.get_new_map_instance(row["id"])
old_map.select(dbif)
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2013-04-16 07:51:09 UTC (rev 55827)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2013-04-16 08:31:10 UTC (rev 55828)
@@ -235,7 +235,8 @@
for i in range(num):
count += 1
- core.percent(count, num, 1)
+ if count%10 == 0:
+ core.percent(count, num, 1)
# Create the r.mapcalc statement for the current time step
@@ -289,9 +290,9 @@
map_list.append(new_map)
+ #core.verbose(_("Apply mapcalc expression: \"%s\"") % expr)
# Start the parallel r.mapcalc computation
- core.verbose(_("Apply mapcalc expression: \"%s\"") % expr)
proc_list.append(Process(target=_run_mapcalc2d, args=(expr,)))
else:
@@ -338,7 +339,8 @@
for new_map in map_list:
count += 1
+ if count%10 == 0:
# Read the map data
new_map.load()
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2013-04-16 07:51:09 UTC (rev 55827)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2013-04-16 08:31:10 UTC (rev 55828)
@@ -182,7 +182,8 @@
core.message(_("Gathering map informations"))
for count in range(len(maplist)):
+ if count%50 == 0:
+ core.percent(count, num_maps, 1)
# Get a new instance of the map type
map = dataset_factory(type, maplist[count]["id"])
@@ -303,7 +304,8 @@
num_maps = len(map_object_list)
core.message(_("Register maps in the space time raster dataset"))
for map in map_object_list:
+ if count%50 == 0:
sp.register_map(map=map, dbif=dbif)
count += 1
@@ -379,14 +381,15 @@
start_time, increment, 1)
if end_time is None:
core.fatal(_("Error in increment computation"))
- core.verbose(_("Set absolute valid time for map <%(id)s> with "
- "layer %(layer)s to %(start)s - %(end)s") %
- {'id': map.get_map_id(), 'layer': map.get_layer(),
- 'start': str(start_time), 'end': str(end_time)})
- else:
- core.verbose(_("Set absolute valid time for map <%s> to %s - %s") %
- (map.get_map_id(), str(start_time), str(end_time)))
+ # core.verbose(_("Set absolute valid time for map <%(id)s> with "
+ # "layer %(layer)s to %(start)s - %(end)s") %
+ # {'id': map.get_map_id(), 'layer': map.get_layer(),
+ # 'start': str(start_time), 'end': str(end_time)})
+ #else:
+ # core.verbose(_("Set absolute valid time for map <%s> to %s - %s") %
+ # (map.get_map_id(), str(start_time), str(end_time)))
map.set_absolute_time(start_time, end_time, None)
else:
@@ -401,15 +404,16 @@
if interval:
end_time = start_time + int(increment)
- core.verbose(_("Set relative valid time for map <%s> with layer %s "
- "to %i - %s with unit %s") %
- (map.get_map_id(), map.get_layer(), start_time,
- str(end_time), unit))
- else:
- core.verbose(_("Set relative valid time for map <%s> to %i - %s "
- "with unit %s") % (map.get_map_id(), start_time,
+ # core.verbose(_("Set relative valid time for map <%s> with layer %s "
+ # "to %i - %s with unit %s") %
+ # (map.get_map_id(), map.get_layer(), start_time,
+ # str(end_time), unit))
+ #else:
+ # core.verbose(_("Set relative valid time for map <%s> to %i - %s "
+ # "with unit %s") % (map.get_map_id(), start_time,
map.set_relative_time(start_time, end_time, unit)
@@ -893,13 +897,13 @@
return None
if sp.is_in_db(dbif) and overwrite == True:
- core.info(_("Overwrite space time %s dataset <%s> "
+ core.warning(_("Overwrite space time %s dataset <%s> "
"and unregister all maps.") %
(sp.get_new_map_instance(None).get_type(), name))
sp.delete(dbif)
sp = sp.get_new_instance(id)
- core.verbose(_("Create space time %s dataset.") %
+ core.verbose(_("Create new space time %s dataset.") %
sp.get_new_map_instance(None).get_type())
sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py 2013-04-16 07:51:09 UTC (rev 55827)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py 2013-04-16 08:31:10 UTC (rev 55828)
@@ -142,7 +142,8 @@
for row in rows:
count += 1
- grass.percent(count, num_rows, 1)
+ if count%10 == 0:
+ grass.percent(count, num_rows, 1)
map_id = dummy.build_id(map_name, mapset)
@@ -206,8 +207,8 @@
count = 0
for row in rows:
count += 1
+ if count%10 == 0:
# Register the new maps
if row["id"] in new_maps:
new_map = new_maps[row["id"]]
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py 2013-04-16 07:51:09 UTC (rev 55827)
+++ grass/trunk/temporal/t.support/t.support.py 2013-04-16 08:31:10 UTC (rev 55828)
@@ -69,7 +69,6 @@
def main():
# Get the options
@@ -131,8 +130,9 @@
# We collect the delete and update statements
for map in maps:
- grass.percent(count, len(maps), 1)
count += 1
+ if count%10 == 0:
+ grass.percent(count, len(maps), 1)
map.select(dbif=dbif)
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py 2013-04-16 07:51:09 UTC (rev 55827)
+++ grass/trunk/temporal/t.unregister/t.unregister.py 2013-04-16 08:31:10 UTC (rev 55828)
@@ -130,7 +130,8 @@
# Unregister already registered maps
grass.message(_("Unregistered maps"))
for mapid in maplist:
- grass.percent(count, num_maps, 1)
+ if count%10 == 0:
+ grass.percent(count, num_maps, 1)
map = tgis.dataset_factory(type, mapid)
